What Does an Integrated Dishwasher Cost to Run in the UK?
- How Much Electricity Does a Dishwasher Use?
- How Much Does It Cost to Run a Dishwasher in the UK?
- What Changes a Dishwasher’s Electricity Use?
- How to Cut Your Dishwasher’s Running Costs
- How Solar and Time-of-Use Tariffs Cut Dishwasher Costs
- How to Stop Paying Peak Rates for Evening Cycles
- Conclusion
- Frequently Asked Questions
Running an integrated dishwasher five times a week on the Eco programme costs roughly £44 a year at the current average electricity rate. Use a more energy-intensive programme and that figure climbs. The age of the appliance and the tariff you are on also make a difference. From 1 October to 31 December 2026, Ofgem's average electricity rate is 26.32p per kWh, which gives us a useful basis for working out the cost of each wash.
A dishwasher does not have to be an expensive appliance to run. Most of the difference comes down to everyday choices: how full the machine is, which programme you select and whether you use heated drying. There is also the option of running it on cheaper electricity or using solar power. With home energy storage, surplus electricity generated during the day can be kept for an evening wash, rather than relying entirely on the grid.
Dishwasher power consumption for a modern UK model typically falls between 0.5kWh and 1.5kWh per cycle. Efficient models can use less on Eco, while intensive programmes and heated drying push consumption higher. Most of that electricity goes towards heating water. The pump, electronic controls and drying system account for the remainder.
Where a Dishwasher’s Electricity Goes
Heating water is the biggest part of a dishwasher's electricity use. The heating element brings the water up to the temperature needed for washing and rinsing, while the pump sends it through the spray arms. The controls use some power too, but their contribution is relatively small.
Drying is another part of the cycle to consider. Some machines use heated drying, which needs additional electricity. Others rely on condensation: the warm moisture inside the machine collects on cooler surfaces, allowing the dishes to dry without as much extra heat. On certain models, the door opens automatically at the end of the programme to let steam escape.
Water consumption affects the overall cost of using the appliance, but it is usually the electricity needed to heat that water that makes the bigger difference. An efficient dishwasher might use around 9–12 litres for a full load, although this varies between models. For comparison, one ASKO integrated model lists 0.54kWh of electricity and 9.4 litres of water for its Eco cycle.
Eco, Normal, Intensive and Quick Programmes Compared
The programme you use can change the cost of a wash quite considerably. Eco takes longer, but it uses lower temperatures and gives the detergent more time to work. Quick programmes shorten the wash, but that does not automatically make them cheaper. Some use higher temperatures or more energy over a shorter period to get the dishes clean.
Programme | Typical temperature | Duration | Energy per cycle | Cost at 26.32p/kWh | Water | Best suited to |
Eco | 45–50°C | 3–4 hours | 0.6–0.9kWh | 16–24p | 9–12L | Everyday full loads |
Normal/Auto | 50–60°C | 2–3 hours | 1.0–1.3kWh | 26–34p | 10–14L | Mixed loads |
Intensive | 65–70°C | 2–3 hours | 1.3–2.0kWh | 34–53p | 12–16L | Baked-on food and pans |
Quick | 55–65°C | 30–60 minutes | 1.0–1.4kWh | 26–37p | 9–13L | Small, lightly soiled loads |
Treat these as working estimates, not guaranteed figures. Two machines can use different amounts of electricity even when they are running programmes with similar names. Bosch's published programme information, for example, includes an Eco cycle using 0.543kWh and an Intensive programme using up to 1.25kWh. Check the product fiche or manual for the figures that apply to your own appliance.
Dishwasher Power Draw vs Energy Use
There is a difference between power draw and energy use. Dishwasher power draw is the amount of electricity the appliance needs at any given moment, measured in watts (W). Energy use, on the other hand, measures all the electricity used from the start to the end of a wash cycle, in kilowatt-hours (kWh).
A dishwasher with a connected load of around 1,800W might draw close to 2,400W while its heating element is operating. The demand then drops during stages when the machine is mainly circulating water or waiting between parts of the programme. The exact figures depend on the model.
This distinction matters if you plan to run the appliance from a battery system. A battery's stored energy determines how long it can supply power, but its inverter also needs to cope with the dishwasher's higher demand while the water is heating. Looking at the cycle's total kWh alone does not tell you whether the system can handle that peak load.
At 26.32p per kWh, a 0.65kWh Eco cycle costs about 17p. A Normal cycle using 1.10kWh comes to roughly 29p, while an Intensive cycle using 1.50kWh costs around 39p. These examples use Ofgem's average Direct Debit electricity rate for Great Britain between October and December 2026. Your actual unit rate will depend on your region, payment method and tariff.
You can work out the cost for your own machine with a simple calculation:
Energy used per cycle (kWh) × electricity rate (p/kWh) = cost per cycle
For example, a 0.65kWh wash at 26.32p per kWh costs 17.1p. The calculation does not include the standing charge, as that applies whether you use the dishwasher or not.
Household | Cycles per week | Eco: weekly / annual | Normal: weekly / annual | Eco at 7p off-peak: annual |
1–2 people | 3 | 51p / £26.69 | 87p / £45.17 | £7.10 |
3–4 people | 5 | 86p / £44.48 | £1.45 / £75.28 | £11.83 |
5+ people | 7 | £1.20 / £62.27 | £2.03 / £105.39 | £16.56 |
Large or shared household | 10 | £1.71 / £88.96 | £2.90 / £150.55 | £23.66 |
The estimates assume that an Eco cycle uses 0.65kWh and a Normal cycle uses 1.10kWh. The off-peak column uses an illustrative rate of 7p per kWh, not a rate available on every tariff. Annual costs assume the same number of washes each week for 52 weeks.
So, do dishwashers use a lot of electricity? Not usually when compared with major heating appliances. At five Eco washes a week, the example machine uses about 169kWh a year. Running the same number of Normal cycles takes roughly 286kWh. If both programmes could achieve the same cleaning results, then the average cost of Eco would be approximately £31 less per year.
Note: 26.32p/kWh is Ofgem’s price cap rate for October to December 2026 and changes each quarter. The costs in this article are estimates for illustration. Compare your tariff rate and check Ofgem for the current cap. |
The programme is only part of the picture. The temperature you select, how much you put in the machine, the way it dries the dishes and even the condition of its heating system can affect consumption. A few small changes to how you use and maintain the appliance can make a difference over time.
Temperature, Load Size and Drying
Higher temperatures generally mean higher electricity use because the machine has to heat the water further. An Intensive programme running at 65–70°C can use around twice as much electricity as Eco, although the difference depends on the appliance.
Load size matters as well. The dishwasher still needs to heat water and run its pump when it is only half full, so each plate effectively costs more to wash. Preferably, wait until you have sufficient for full load, but do not block the spray arms.
Drying is another place to look for savings. If your machine has an option to turn off heated drying, try using it and letting the dishes air-dry instead. The door can be partially open after the cycle, if it is allowed by the manufacturer.
Water Inlet Temperature and Limescale
Most dishwashers are designed to take cold mains water and heat it inside the appliance. That means the temperature of the incoming water can affect how much electricity the heating element needs, particularly during colder months. Some can be connected to hot water, and some are designed to be used for cold fill only. Before connecting to a hot supply please read the installation instructions.
Hard water creates a different problem. Limescale can build up around internal components, including the heating element, and affect how efficiently the machine operates. This is worth watching in hard-water areas such as parts of London, the South East and East Anglia. Keep the dishwasher salt topped up if your model requires it, and follow the manufacturer's guidance on descaling.
How to Read the UK Energy Label
Dishwasher energy labels have used the A-to-G scale since March 2021. The older A+, A++ and A+++ ratings belong to a previous system, so they are not directly comparable with today's labels.
The letter rating is useful, but it is not the only figure worth checking. The label also gives electricity consumption in kWh per 100 Eco cycles, water use per cycle, Eco programme duration, place settings and noise emissions. Divide the electricity figure by 100 to see the approximate consumption of one Eco wash. A label showing 54kWh per 100 cycles, for example, works out at 0.54kWh per cycle.
When comparing dishwashers, look at the actual kWh figure as well as the efficiency rating. The best dishwasher for your household is not necessarily the one with the highest letter grade. Capacity is also a factor – a larger model may be more practical than a smaller model, which may need to be run more frequently.
Is Replacing an Older Integrated Dishwasher Worth It?
An older integrated dishwasher using 1.40kWh per cycle costs about 37p to run at 26.32p per kWh. A newer model using 0.65kWh would cost around 17p for the same cycle. That is a saving of 0.75kWh, or roughly 20p per wash. Run the machine five times a week and the difference comes to about £51 a year; at seven washes a week, it is around £72.
Those savings are useful, but they do not automatically justify replacing a machine that still works well. Compare the likely reduction in running costs with the purchase price and installation bill. Integrated models can cost more to fit if the cabinet, furniture door, pipework or electrical connection needs attention.
People searching is dishwasher installation difficult electric are often trying to establish whether replacing an existing machine requires an electrician. If there is already a suitable, accessible 13A socket and the water and waste connections are in the right places, a like-for-like electrical connection is usually straightforward. A new socket, changes to the circuit or a hard-wired connection should be handled by a qualified electrician. The installer also needs to check the cabinet dimensions, door panel and hose positions before fitting the appliance.
You do not need to buy extra gadgets to reduce the cost of using a dishwasher. Start with the settings and maintenance tasks that affect every wash.
UK Dishwasher Energy-Saving Checklist
Wait for a full load, but leave enough space for water to reach every dish.
Choose Eco for everyday washing. Keep Intensive for pans and stubborn food.
Scrape food off plates instead of rinsing them under a hot tap.
Switch off heated drying if your model allows it, and let the dishes air-dry.
Refill dishwasher salt and rinse aid when needed.
Clean the filter regularly, ideally once a month.
Use the delay-start setting to run the machine during a cheaper tariff period.
These steps are simple, but they work best when they become part of your usual routine. There is little point choosing Eco if the spray arms are blocked or the filter is clogged with food.
How to Clean a Dishwasher
Knowing how to clean a dishwasher helps prevent trapped food and mineral deposits from affecting its performance. Start with the filter. Remove it according to the manual, rinse it under warm water and clear away any food debris. Check the spray-arm holes too, as small pieces of food or limescale can restrict the water flow. Wipe around the door seal with a damp cloth.
Every few months, use a dishwasher cleaner or descaler approved by the manufacturer. Follow the instructions on the product, particularly if you live in a hard-water area. Don't use homemade chemicals to clean the seals: some ingredients are harmful for seals and mixing cleaning chemicals may be dangerous.
A time-of-use tariff changes the price of electricity depending on when you use it. Some smart tariffs offer off-peak rates around 7p per kWh, while others charge closer to 13p. These are examples rather than standard UK rates; prices, eligibility and off-peak hours vary between suppliers and plans. Intelligent Octopus Go, for instance, is designed around eligible electric vehicle charging, so it will not suit every household. Check the current terms and your own unit rates before switching.
The difference can be worthwhile. At 7p per kWh, a 0.65kWh Eco wash costs about 4.6p. At the Ofgem average of 26.32p, the same cycle costs around 17p. Five washes a week would come to approximately £11.83 a year on the illustrative off-peak rate, compared with £44.48 at the average rate.
A delay-start function makes it easier to take advantage of cheaper hours. Load the dishwasher after dinner, set the start time and let it run when the lower rate begins. Just make sure the programme finishes at a suitable time and that the appliance is safe to leave running unattended in line with its instructions.
Solar panels can reduce the amount of electricity you need to buy from the grid. They usually generate most during daylight hours, which is not always when the dishwasher gets used. A large number of homes fill it up after dinner time when the sun has either stopped producing energy or produced less. A battery can fill in the gap and store excess electricity generated during the day for use later.
Note: The 7p and 13p off-peak rates are illustrative. Tariff availability, eligibility and pricing vary by supplier and change over time. Before switching, review the terms and guidance of your supplier and Ofgem. |
Home energy storage gives households a way to keep surplus solar electricity instead of using it all as it is generated or exporting it to the grid. That stored energy can then be used in the evening, when the dishwasher and other appliances are more likely to be running. The right setup depends on whether you are starting from scratch with solar or already have panels on the roof.
For Homes Without Solar Panels Yet
If you are planning a new solar installation, think about how you will use the electricity in the evening. The EcoFlow STREAM 5000 combines solar input with battery storage, so you can keep surplus daytime electricity for later use. It stores 5kWh (5,024Wh) and supports expansion up to 90kWh. It also accepts up to 5,000W of solar input through four 1,250W MPPT channels, with a 3,000W AC output. This stored energy can help power an integrated dishwasher after dinner.
For Homes With Solar Already Installed
Having solar panels does not always mean you use much of the electricity they generate. If the household is out during the day, surplus power may be exported before everyone returns home and starts using appliances. The EcoFlow STREAM AC 5000 is intended for households with existing solar installations that want to add battery storage. It offers 5kWh / 5024Wh of capacity, expandable up to 90kWh, alongside 3000W AC output. Intelligent Mode+ manages household energy use, while Local Mode supports operation without an internet connection. For an integrated dishwasher usually switched on after dinner, storing some of the day's surplus generation can help reduce reliance on grid electricity in the evening.
Note: Compliant generation-only plug-in solar kits have been legal to buy and use in Great Britain since 27 August 2026, but these rules do not cover plug-in batteries or solar-plus-storage systems. Home batteries, including the EcoFlow STREAM 5000 and STREAM AC 5000, are not plug-in solar products. They need to be professionally installed and must meet the requirements of the IET Wiring Regulations (BS 7671) and DNO connection requirements. Please adhere to the guidance provided on GOV.UK and call a qualified installer to check what is required for your home. |
An integrated dishwasher costs around 17p per Eco wash or 29p on the Normal programme at the current average electricity rate of 26.32p per kWh. This equals about £44 or £75 a year at 5 washings per week. Full loads, selecting Eco when appropriate, using a clean filter and cheaper tariff hours will all help. When purchasing a replacement, refer to the actual kWh given in the energy label instead of just the efficiency grade.
Solar panels and battery storage offer another way to manage the electricity used for evening washes. EcoFlow UK offers home energy storage options for households planning a new solar installation or adding a battery to an existing system. Explore the EcoFlow STREAM range to see which setup may suit your household's energy needs.
Do integrated dishwashers use less electricity than freestanding ones?
Not simply because they are built into the kitchen. An integrated model can be just as efficient as a freestanding one with a similar capacity and energy rating. Compare the kWh per 100 Eco cycles on the energy labels to get a clearer picture of their running costs.
Is a dishwasher cheaper than washing up by hand?
It often is, particularly when you wash a full load. An efficient dishwasher can clean a large load using around 9 litres of water. Washing the same dishes by hand under a running tap can use considerably more, although using a washing-up bowl rather than leaving the tap running changes the comparison.
What size integrated dishwasher suits my household?
A standard 60cm dishwasher generally holds around 12–14 place settings and suits many family households. A 45cm slimline model usually holds about nine place settings, making it a practical option for a smaller kitchen or household. Check the cabinet opening, appliance depth and furniture-door measurements before ordering.
Can I run a dishwasher from a home battery?
Yes, as long as the battery system can supply the dishwasher's power demand and the electrical connection is suitable. Check the appliance's rated power and peak demand, as well as the inverter's supported output. Ask a qualified installer to confirm that the proposed system and connection are compatible before relying on it.
