Off-peak Electricity Times UK: Your Guide to Cheaper Home Energy
What are off-peak electricity times in the UK?
Off-peak electricity times in the UK are periods when energy demand is lower, usually overnight or during specific low-usage hours set by your supplier. These times are part of time-of-use tariffs, such as Economy 7 or Economy 10, where electricity costs less outside peak hours. Fixed-time-of-use tariffs work by charging different unit rates at set times of day, encouraging households to shift usage to cheaper periods. The exact off-peak hours vary by region, meter type, and energy provider, but rates remain fixed within the tariff structure. By combining smart use of off-peak electricity with solar batteries, households can maximize savings while storing clean energy for when it's needed most.
Typical off-peak schedules and tariffs in the UK
Understanding how electricity off-peak times in the UK work in practice helps households plan their usage and reduce costs more effectively. While timings vary, most UK tariffs follow a few common patterns shaped by demand, season, and metering technology.
  1. Examples of off-peak hours from major UK suppliers
Most UK energy suppliers offer off-peak electricity late at night, when national demand is lowest. Typical off-peak windows often fall between 11:00 p.m. and 6:00 a.m. or midnight to 7:00 a.m., particularly on Economy 7 tariffs. These overnight hours are designed to encourage households to shift high-energy activities—such as running appliances or charging devices—to cheaper periods.
To give a clearer picture, the table below shows typical off-peak schedules by tariff type:
Tariff type
Typical off-peak electricity times
Economy 7
Around midnight to 7:00 a.m.
Economy 10
Overnight: ~7 hours (e.g., 10:00 p.m.–5:00 a.m.)
Midday: ~2 hours (e.g. 1:00 p.m.–3:00 p.m.)
Evening: ~1 hour (e.g. 8:00 p.m.–9:00 p.m.)
EV tariffs
Commonly midnight to 5:00 a.m., ideal for vehicle charging
Dynamic smart tariffs
Cheapest late at night and early morning; most expensive 4:00 p.m.–7:00 p.m. on weekdays
Note: Off-peak hours are not fixed nationwide. Timings depend on your energy supplier, tariff type, meter setup, and location, so it's always best to confirm details via your bill or supplier account.
  1. How tariffs vary by season and provider
Not all electricity plans include off-peak pricing. Many standard tariffs charge a single flat rate throughout the day and night, meaning households only benefit from cheaper electricity if they are on time-of-use tariffs such as Economy 7, Economy 10, EV tariffs, or dynamic smart tariffs.
While off-peak rates are usually consistent year-round, peak electricity prices often rise in winter due to higher demand for heating and lighting. This makes shifting usage to off-peak periods especially valuable during colder months. Even under the same tariff type, provider-specific pricing can influence how much households ultimately save.
  1. Smart meters and time-of-use tariff integration
Smart meters automatically record electricity use by time of day, removing guesswork around off-peak hours. They also unlock more advanced time-of-use and dynamic tariffs, where prices change across multiple periods rather than just day and night.
With these tariffs, electricity is typically cheapest overnight and in the early morning, while prices peak during high-demand periods—often 4:00 p.m. to 7:00 p.m. on weekdays. This gives households greater flexibility to plan usage and take advantage of low-cost electricity windows, especially when combined with flexible appliances or energy storage.
How energy usage timing affects your bill
When you use electricity, it can matter just as much as how much you use. By aligning energy-intensive activities with lower-cost time windows or self-generated power, households can significantly reduce their monthly bills.
  • Advantages of shifting consumption to off-peak times
Running appliances during off-peak times electricity UK means you pay a lower unit rate for the same electricity. Tasks such as laundry, dishwashing, and charging devices overnight can significantly reduce daily energy costs over time. For homes on time-of-use tariffs, these small habit changes often add up to meaningful annual savings.
  • Using solar energy and home storage systems
Solar panels generate electricity during the day, while home solar batteries store excess power for later use. This allows households to rely less on expensive peak-time grid electricity, especially in the evening. By combining solar generation with storage, energy use becomes more predictable, cost-efficient, and less exposed to rising tariffs.
Optimal home energy efficiency solutions for UK households
Making your home more energy-efficient isn't just about reducing waste; it's about cutting electricity costs, using power more intelligently, and future-proofing your household against rising bills. Combining high-performance storage with solar integration lets you shift usage away from expensive grid power and rely more on self-generated energy.
  1. For high-energy homes without solar panels: 450W rigid solar panel + STREAM AC Pro + STREAM Ultra
The 450W rigid solar panel + STREAM AC Pro + STREAM Ultra setup is perfect for homes with high electricity demand that are starting with solar. The STREAM Ultra provides 3.84 kWh of solar battery storage and, together with the STREAM AC Pro, delivers up to 2,300 W of total AC output, reliably powering household appliances such as washing machines, dishwashers, ovens, refrigerators, microwaves, and space heaters. Paired with the 450W solar panel array, it captures energy throughout the day. It stores it for evening or peak-hour use, helping reduce reliance on the grid and cut monthly electricity bills.
This complete solar and storage solution doesn't require stacked installation. Instead, the units can be placed separately and flexibly—on a balcony, indoors, or in a basement or utility room—so power is delivered exactly where it's needed, while reliably supporting high-demand appliances in busy households.
450W Rigid Solar Panel + STREAM AC Pro + STREAM Ultra The
- The 450W solar panel has a durable, weather-resistant design, built to withstand wind, rain, and outdoor conditions. - 450W solar panel delivers reliable power even in cloudy or low-light conditions. - Slash up to £963 off your electricity bills. - Fully compatible with EcoFlow STREAM Ultra X, Ultra, and AC Pro. - AI‑driven monitoring and control via the EcoFlow app.
  1. For high-energy homes with existing solar panels: STREAM Ultra + AC Pro
If you already have solar panels installed, the STREAM Ultra + STREAM AC Pro setup helps you store and manage that energy more efficiently. The STREAM Ultra, with 3.84 kWh of battery capacity, serves as the main storage hub, while the STREAM AC Pro adds flexibility and extra capacity, enabling up to 2,300 W of total AC output. This allows you to run high-demand appliances directly from stored solar energy and maximise self-consumption of your solar power.
Together, they work with your existing solar array to store excess energy during the day for use when tariffs are high or demand peaks, reducing what you buy from the grid. This setup is perfect for sustainability-focused households looking to maximise solar savings and energy independence without adding more panels.
- Seamlessly integrates with over 99% of solar panels on the market. - Slash up to £963 off your electricity bills. - Fully compatible with EcoFlow STREAM Ultra X, Ultra, and AC Pro. - AI‑driven monitoring and control via the EcoFlow app.
How to make the most of off-peak electricity times
Making smart use of UK off-peak electricity times is one of the easiest ways to cut energy bills without changing your lifestyle. With a few practical adjustments, UK households can shift demand, lower costs, and improve overall energy efficiency.
  1. Schedule high-energy appliances during off-peak hours
Run washing machines, dishwashers, tumble dryers, and immersion heaters overnight when unit rates are lowest. Even shifting just a few weekly cycles can noticeably reduce monthly electricity costs on time-of-use tariffs.
  1. Charge electric vehicles (EVs) during off-peak periods
Set EV charging to start after off-peak hours begin, typically late evening or overnight. This reduces charging costs significantly and avoids adding expensive peak-time demand to your household bill
  1. Use timers and smart plugs for devices
Timers and smart plugs automate energy use, so appliances operate only during cheaper hours. This is especially useful for heaters, water boilers, and dehumidifiers that otherwise run during peak periods.
  1. Leverage home energy storage systems
Charge home batteries during off-peak times and use the stored electricity during peak hours. This helps avoid high daytime rates and smooths energy use without affecting comfort or appliance usage.
  1. Monitor and adjust energy consumption patterns
Regularly check smart meter data or energy apps to identify peak electricity usage. Identifying peak-time spikes makes it best to use off-peak electricity prices in the UK, which makes it easier to shift specific habits to cheaper periods.
  1. Combine off-peak usage with renewable energy
Pair off-peak charging with solar or other renewables to maximise self-consumption. Storing low-cost or self-generated energy reduces reliance on the grid and delivers longer-term savings.
To summarize, understanding what time is off-peak for electricity in UK households can help lower energy bills and use power more efficiently. UK electricity off-peak times typically fall overnight, making them ideal for running appliances and charging EVs at lower rates. By shifting usage to electricity off-peak times in the UK, households can reduce peak-rate spending without changing daily routines. Pairing this approach with renewable energy and storage further strengthens savings and cuts grid dependence. EcoFlow solutions help store low-cost power for use when prices rise.
  1. How do I know my off-peak electricity times?
Your off-peak hours depend on your tariff and meter type, such as Economy 7 or other time-of-use plans. You can find the exact times on your energy bill, in your supplier app, or on your online account dashboard. Smart meters also display when cheaper rates apply. If unsure, contacting your supplier is the most accurate way to confirm.
  1. What is the simple trick to cut your electric bill?
The easiest way is to shift high-energy use to off-peak hours, when electricity costs less per kWh. Running appliances overnight, using timers, and charging EVs during off-peak periods can quickly reduce bills. Pairing this with energy-efficient appliances and mindful usage amplifies the savings over time.
  1. Who is the cheapest electricity supplier in the UK now?
There is no single cheapest supplier for everyone, as prices vary by region, usage, and payment method. The most affordable option often changes with Ofgem's price cap and market conditions. Using a trusted comparison site and reviewing current tariffs regularly is the best way to find the lowest deal for your household.
Saving Bills
