What Battery Storage Regulations UK Homes Must Meet?
- Which Battery Storage Regulations Apply to Your Home?
- What Do G98, G99 and Ofgem Mean for Your Battery?
- Choosing Between the G98 and G99 Routes
- How BS 7671 Amendment 4 Changes Battery Installation
- Battery Energy Storage System Regulations for Siting and Fire Safety
- How to Prepare Before the Installer Arrives
- Solving the Compliance Worries That Put Homeowners Off Batteries
- Conclusion
- Frequently Asked Questions About Battery Storage Regulations UK
Buying a battery is the easy part. Knowing which battery storage regulations UK installations must meet is where it gets tricky. Will your installation pass inspection, satisfy your network operator and keep your insurer happy? Getting it wrong means facing a failed handover, missing certificates, awkward questions at resale and wasted investment.
There is no single law that guides battery storage installations in the UK. Batteries are guided by various overlapping rules covering wiring, fire safety, grid connection and Building Regulations. In the newly published BS 7671:2018+A4:2026, there is a dedicated chapter for batteries–chapter 57. This guide looks at:
Which rules apply to your setup
How the G98, G99 and Ofgem grid process works
What BS 7671 Amendment 4 changes for wiring and installers
Battery energy storage system regulations for siting and fire safety
How to prepare before work starts
How to solve compliance worries that put many homeowners off home energy storage
Battery storage regulations UK rules are the electrical, fire-safety and grid-connection requirements that decide whether your home battery can be installed and switched on. Which ones apply depends on your system configuration, its capacity and whether it runs in parallel with the grid. A lone 5kWh battery faces a different checklist from a 15kWh system sharing an inverter with solar panels. Work out which of the three setups below matches yours.
Standalone Battery Storage Rules
If you are installing a battery that you charge overnight using a time-of-use tariff and covers your evening peak with no solar panels at all, it still counts as a grid-connected source. This is because it can export electricity back to the national grid. Therefore, you need a compliant installation, grid notification and a certificate at the end.
Solar Battery Storage Regulations for New Systems
Solar battery storage regulations treat panels and a battery installed together as one job. One design, one commissioning visit, one set of paperwork. Your installer works out the combined AC export and sizes the grid application around it. This is also where MCS certification can come in. You’ll typically need it if you want Smart Export Guarantee (SEG) payments for the solar you export.
Adding a Battery to Existing Solar Panels
Retrofits have many surprises that they hide. Your existing inverter and your total export capacity both affect the grid paperwork. If you add battery storage to your setup, you can easily push beyond the threshold your solar panels can never achieve on their own. If your solar has an approved set export figure, your installer must consider it for the new setup. Some homes need an upgraded inverter or a fresh application, so find out before you order.
G98 and G99 are the Energy Networks Association engineering recommendations that govern how generating equipment connects to the UK distribution network. G98 is “connect and inform”. For smaller systems, your installer fits the equipment and tells your DNO within 28 days of commissioning. G99 is “apply first”. Larger systems need DNO approval before installation, and the DNO may run network studies.
The dividing line is generally 16A per phase, roughly 3.68kW on a single-phase supply. Here’s the bit people miss. The combined export of your solar and battery is what counts, not each on its own. That’s why these battery storage regulations UK thresholds catch out so many retrofits.
Note: Limits, timescales and procedures change from time to time. Always check the Energy Networks Association, Ofgem and your own DNO’s website for current requirements. |
Why Frequency Regulation Battery Storage Rules Reach Home Systems
Frequency regulation battery storage is the use of batteries to help hold grid frequency at 50Hz, and the same thinking runs through the standards covering your home system. Grid standards expect inverters to stay stable and behave properly when grid frequency or voltage shifts. They should ride through small disturbances and disconnect when they must. That’s why installers use only approved equipment, listed on the ENA’s type test register.
A bad inverter affects your supply and your neighbors too. Flexibility services, where your battery responds to grid signals for payment, are optional. You don’t need them to comply.
Where Ofgem Battery Storage Regulations and Your DNO Fit In
Ofgem battery storage regulations are, strictly speaking, market rules. Ofgem is the energy regulator for Great Britain, and it oversees suppliers and network operators rather than inspecting your wall. (Northern Ireland has its own regulator, the Utility Regulator.) Your DNO handles the connection. Your installer handles the notification.
Ofgem also oversees the Smart Export Guarantee, which links your battery to export payments. Larger suppliers must offer it, but tariffs and rates vary widely.
What the New Chapter 57 Requires
BS 7671 is the IET Wiring Regulations, the baseline standard for electrical installations in the UK. Battery energy storage system regulations within it now have their own dedicated chapter—Chapter 57. It covers two-way protection and isolation, because energy flows both into and out of the battery.
It also requires domestic installs to follow PAS 63100:2024, the fire-safety specification for home battery systems. So your installer can’t treat a battery as just another circuit. Design, protection and siting all need to be considered and documented.
MCS, Part P and Installer Qualifications
Electrical work in your home must be carried out and certified by a competent person. In England that falls under Part P of the Building Regulations, while Wales, Scotland and Northern Ireland have their own equivalents. Electricians registered with schemes such as NICEIC or NAPIT can self-certify their work. MCS applies when your job includes solar generation you want to register for export payments.
Here’s a tip. Ask your installer straight out whether they design to Amendment 4. A vague answer is a red flag.
Where a Home Battery Can and Cannot Go
Storage of batteries regulations under PAS 63100:2024 exist mainly to keep a battery fire away from the people in your home. So there are restrictions on sleeping areas, escape routes and lofts. Ventilation matters, and so does distance from combustible materials. Garages and external walls are typical options, since heat and smoke have somewhere to go.
Your product manual adds its own limits too, including clearances and operating temperatures. Follow whichever requirement is stricter.
Isolation, Warning Labels and Emergency Procedures
A battery can stay live even when the grid is down. Firefighters need to know that. Your installation should have clearly marked isolators, warning labels at the battery and consumer unit, and information left for occupants and emergency services.
The labels should say where the system is and how to shut it down safely. Ask for a simple system diagram and keep it with your records.
Choosing a Qualified Installer
Check your potential installer’s registrations first, including NICEIC, NAPIT or a similar scheme for electrical work, plus MCS if solar is involved. Ask them about Amendment 4 and PAS 63100. Request, in writing, the siting plan showing where the battery will be installed and why. A good installer can easily explain storage of batteries regulations in a simple way that you can easily understand.
Checking Product Documentation
Before the work commences, request datasheets and installation manuals. Check the batteries’ chemistry (LiFePO4 is recommended for home uses), usable capacity (kWh), maximum charge and discharge power, and ingress protection (IP) rating. If you are adding the battery to your existing solar setup, confirm whether it can work with the existing infrastructure (inverter and solar).
Certificates and DNO Paperwork to Expect
Your installer must provide an electrical installation certificate, confirmation of DNO notification or approval, and commissioning records during a handover. These documents are important. Therefore, keep them safely because your insurer and buyers (if you are selling the property) request for them.
Every worry above comes down to one question—will the right system fit within the right rules? Two EcoFlow examples show how that can work in practice.
Planning Solar and Storage Together Without Compliance Gaps
Planning solar and storage together raises one big worry: will every component work as one compliant system? Take the EcoFlow STREAM 5000 as an example. It pairs a 5kWh battery with up to 5,000W of solar input, so panels and storage are planned around a single setup. It’s supplied for hardwiring, so a registered electrician installs it in line with the battery storage regulations UK households must follow. With a Smart Meter Dual CT for overload protection, IP65 protection and room to expand, it suits homes that want to plan once and build up later.
Adding Storage to Existing Panels Without Starting Over
If you have already installed solar panels on your roof and you want to add storage, your main problem comes down to, will adding storage require ripping everything out? That’s where retrofit battery storage comes in. For example, the EcoFlow STREAM AC 5000 is an AC-coupled 5kWh battery that can sit alongside your existing solar installation. You don’t have to replace anything. You need a certified electrician to connect it and handle the DNO notification process under the battery storage regulations UK rules. If your needs grow, expansion batteries can take it to 15kWh.
The battery storage regulations UK are put in place to protect homeowners from electrical accidents. Compliance relies on accurate export calculations for G98 or G99 DNO notifications, ENA-approved inverters, and meeting Ofgem battery storage regulations. These are necessary if your plan is to access Smart Export Guarantee tariffs. For safe siting, isolation and labeling, choose a registered, competent electrician who understands and designs your setup according to BS 7671 Amendment 4 (Chapter 57) and follows strict storage of batteries regulations under PAS 63100:2024. Finally, verify product documentation upfront and secure your electrical certificates and DNO paperwork at handover to ensure you have relevant documentation for your insurer and for future sale of the property.
Do You Need Planning Permission for Battery Storage?
Many domestic installs fall under permitted development, but conditions apply. Listed buildings, conservation areas and external installations are the usual sticking points. Rules also differ across England, Scotland, Wales and Northern Ireland. Check with your local planning authority before work begins.
Is IEC 62133 Mandatory?
Yes. IEC 62133 is a safety standard for cells and batteries, not a standalone home-battery law. Product safety standards like it are evidenced through test reports and certification, which should appear in the manufacturer’s documentation. Ask your installer to show you that paperwork for your chosen battery.
How Much Does a DNO Application Cost?
G98 is free (costs £0) for standard residential systems. Larger and complex installations require network assessments and the fee ranges between £200 to over £1,182.
Note: DNO fees change. Always confirm current figures on your DNO’s website or through the Energy Networks Association.
Can Lithium Batteries Start a Fire When Not Plugged In?
The risk is low, but it isn’t zero. It comes mainly from damaged or defective cells. That’s why siting rules and quality products matter. Buy from reputable manufacturers, follow PAS 63100:2024 for placement and use a registered installer.
