Is Gas Cheaper Than Electricity? A Complete UK Energy Guide
Dive into the cost comparison between gas and electricity in the UK, exploring which is more affordable for households. This guide also highlights how solar batteries can play a role in reducing overall energy costs by storing solar energy for use during peak times, offering an alternative to traditional electricity sources.
Is gas cheaper than electricity in the UK right now?
Yes, gas is still cheaper than electricity in the UK in 2026 when you compare the cost per kWh. Electricity prices remain significantly higher, mainly due to generation costs, network charges, and environmental levies, while gas is still widely used for heating and benefits from lower unit pricing.
However, the gap is not as simple as it looks. Electricity is more efficient (especially with heat pumps), while gas boilers lose more energy during combustion. So, the "cheapest" option depends on how energy is used, not just the unit price.
Average gas vs electricity prices per kWh (UK – 2026)
Energy Type
Average Price per kWh
Typical Use
Gas
£0.06 – £0.08
Heating, hot water
Electricity
£0.22 – £0.30
Appliances, lighting
Note: Prices vary slightly based on region, supplier, and tariff caps.
The reason gas is cheaper lies in how energy is produced and delivered. Gas has lower production and distribution costs, while electricity includes additional expenses such as grid infrastructure, renewable energy support, and transmission losses. These added costs make electricity significantly more expensive per unit.
Despite this, lower unit cost does not always mean lower overall spending. Gas boilers are less efficient because they lose energy during combustion, while electric systems—especially modern options like heat pumps—can convert energy more efficiently. As a result, electricity can sometimes offer better long-term value depending on how it is used in the home.
Why does electricity usually cost more than gas
Electricity usually costs more than gas in the UK because of the extra steps involved in producing and delivering it. Gas is supplied more directly and has lower production and distribution costs. Electricity, however, is generated from various sources and then transmitted through the national grid, with added costs for infrastructure, maintenance, and energy policies.
This difference is explained by the "spark gap," which shows the price ratio between electricity and gas. In the UK, electricity is typically 3 to 4 times more expensive per kWh than gas. This gap exists because electricity prices include network charges and environmental levies, while gas carries fewer additional costs.
As a result, when comparing whether gas is cheaper than electricity, the spark gap makes it clear why gas remains the cheaper option in most cases, even though electricity is becoming more important for future low-carbon energy use.
Gas vs electricity costs for different household uses
Energy costs in UK homes vary depending on how gas and electricity are used. While gas is generally cheaper per kWh, the real difference becomes clearer when comparing specific household activities like heating, cooking, and hot water. Efficiency, usage patterns, and appliance type all influence the final cost, not just the energy price itself.
Heating costs: gas boilers vs electric heating
Heating is the largest energy expense in most UK households, and gas boilers are usually more cost-effective than electric heating systems. Gas boilers heat water and distribute it through radiators with relatively low running costs per kWh. Electric heaters, on the other hand, use electricity directly, which is more expensive per unit of energy.
Heating Type
Average Cost (per kWh equivalent)
Efficiency
Typical Running Cost
Gas boiler heating
Lower (£0.06–£0.08 gas price)
Moderate
Generally cheaper
Electric heating
Higher (£0.22–£0.30 electricity)
High
Generally expensive
Although electric systems can be more efficient, the higher electricity price usually makes them more expensive to run unless using modern heat pumps.
Cooking costs: gas vs electric hobs
Cooking costs are relatively small compared to heating, but gas hobs are still cheaper to operate in most cases. Gas provides instant heat control, which reduces wasted energy. Electric hobs, especially older coil types, consume more electricity and take longer to adjust temperature, slightly increasing costs.
Cooking Type
Average Running Cost
Efficiency
Cost Level
Gas hob
Lower
High
Cheaper
Electric hob
Higher
Moderate
More expensive
Induction hobs are more efficient than standard electric hobs, but electricity prices still keep running costs above gas in most homes.
Water heating costs: gas vs electric systems
Hot water heating is another major energy use, and gas systems are usually cheaper for traditional storage tanks and combi boilers. Electric immersion heaters are simple but costly to run due to high electricity prices.
Water Heating Type
Average Cost
Efficiency
Overall Cost Impact
Gas water heating
Lower
Moderate
More affordable
Electric immersion
Higher
High
More expensive
Heat pumps can change this comparison, but in standard UK homes, gas remains the cheaper option for water heating.
When electricity can be cheaper than gas
Electricity is not always more expensive than gas. In certain situations, it can actually work out cheaper overall depending on the type of system, efficiency of appliances, and energy source. This is especially true in modern, energy-efficient homes where electricity is used in smarter ways.
  1. More efficient electric appliances
Electric systems like heat pumps and induction hobs can use energy far more efficiently than traditional gas systems. Heat pumps, for example, can produce multiple units of heat for every unit of electricity used, significantly reducing overall energy consumption and lowering running costs despite higher electricity prices.
  1. Lower installation and maintenance costs
Electric systems often have simpler setups compared to gas boilers. They usually require less maintenance, no flues or gas pipework, and fewer safety checks. Over time, this can reduce overall household expenses, making electricity more cost-effective in the long run even if unit prices are higher.
  1. Using renewable energy to reduce electricity costs
Households that use renewable energy sources such as solar panels can significantly cut electricity bills. When electricity is generated on-site, reliance on grid electricity decreases, making electric heating and appliances much cheaper compared to gas-dependent systems.
What determines whether gas or electricity is cheaper for your home
The cost of gas versus electricity in a home is not fixed, and it depends on several personal and external factors. While gas is generally cheaper per kWh, the actual bill you pay is influenced by how energy is priced, how efficiently your home uses energy, and the type of systems you rely on daily.
1. Energy tariffs and supplier pricing
Energy tariffs play a major role in determining whether gas or electricity is cheaper for your home. Suppliers set different unit rates and standing charges for both fuels, and these can vary depending on your contract, region, and the UK energy price cap. Some tariffs may reduce electricity costs during off-peak hours, which can make electricity usage more affordable in specific time periods.
2. Home insulation and overall efficiency
When considering whether electric heating is cheaper than gas, home insulation plays a key role. Well-insulated homes retain heat better, meaning less energy is required regardless of whether you use gas or electricity. Poor insulation increases energy demand, making both gas and electric systems more expensive to run.
3. Types of appliances you use
The type of appliances in your home significantly affects energy costs. Gas boilers are usually cheaper for heating, while electric appliances like heat pumps and induction hobs can be more efficient in converting energy into usable heat. Older electric systems tend to be more expensive to run, while modern high-efficiency devices can reduce overall electricity consumption.
4. Daily energy usage habits
Your daily habits also influence whether gas or electricity feels cheaper. Using heating only when needed, cooking efficiently, and avoiding unnecessary energy waste can lower costs. Time-of-use electricity tariffs can also make electricity cheaper during off-peak hours, especially if you shift usage to those periods.
Practical ways to reduce your energy costs
Reducing your energy bills doesn't just mean using less — it also means producing and storing your own electricity, improving your home's efficiency, and choosing smarter systems. With solutions like EcoFlow, you can harness solar energy and store it for later use, cutting down on both gas and grid electricity costs. The options below will help you save over time, empowering you to manage your energy use more effectively and reduce your reliance on expensive energy sources.
Solar home battery solutions for long-term energy savings
  1. 450W solar panel and STREAM Ultra X
The 450W Rigid Solar Panel + STREAM Ultra X form a high-capacity home solar system designed to power demanding household appliances, including washing machines. With up to 2000W solar input and four MPPT trackers, the system efficiently captures and converts sunlight even in low-light or cloudy conditions, ensuring a more stable and continuous energy supply throughout the day.
This setup delivers 1200W AC output, making it capable of handling peak energy loads when multiple appliances run at the same time. Any excess solar energy is stored in the 3.84kWh LFP battery inside the STREAM Ultra X, allowing you to operate appliances like washing machines during the night or when sunlight is unavailable. This reduces dependence on grid electricity and helps lower long-term energy bills.
Built for durability and long-term use, the system is designed with LFP battery technology rated for around 6000 cycles and a lifespan of up to 15 years. This ensures reliable performance over time while minimizing maintenance concerns. Additionally, the STREAM Ultra X is compatible with third-party devices that use Tiber, Matter, and Shelly protocols, allowing seamless integration into smart home systems for greater convenience and control.
- Save up to £1,734 annually on your electricity bills. - Enjoy 1200W AC output, easily powering high-demand appliances. - Expandable capacity from 3.84 to 23kWh provides energy coverage throughout the day and night. - With a 2000W solar input, 4 MPPTs, and Low-Light Cells, this system captures more solar energy. - Features a 15-year lifespan, ensuring high safety and long-term reliability. - Set up is effortless and requires no electricity. - Compatible with third-party devices that use Tiber, Matter, and Shelly protocols.
  1. STREAM Ultra + AC Pro
For homes with solar panels, STREAM Ultra + AC Pro not only helps lower your electricity bills but also ensures that excess energy is stored and protected from power surges. During the day, excess solar energy is captured and stored, rather than being exported to the grid. This stored energy can then be used when electricity prices are highest, reducing the need to rely on expensive grid electricity and making solar a more affordable option than gas.
STREAM Ultra acts as the central hub for your home's energy system. With a battery capacity of 3.84 kWh and a continuous output of 1200W, it efficiently stores solar energy and powers essential appliances, like washing machines, when needed. By tapping into stored solar energy during peak hours, you avoid high electricity costs, which often surpass the cost of gas.
For larger households with higher energy demands, the STREAM AC Pro expands both storage capacity and output power. Offering 3.84 kWh of energy storage and 2300W of output power, this system can easily power multiple high-demand appliances simultaneously, like running a full laundry cycle, without drawing power from the grid.
Designed for flexibility, the STREAM Ultra + AC Pro system can be placed anywhere in your home without the need for stacking, giving you more options for installation and convenience. By integrating smart solar energy systems with intelligent energy management, the STREAM Ultra + AC Pro makes it easier to optimize energy consumption and lower energy bills, providing a more sustainable and cost-effective alternative to traditional energy sources.
- Save up to £358 on your electricity bills. - Compatible with EcoFlow STREAM Ultra X, Ultra, and AC Pro. - AI‑driven experience via the EcoFlow app for intelligent monitoring and control. - Operate seamlessly with 99% of solar panels on the market.
Improve insulation to reduce heat loss
Improving insulation in your walls, loft, and floors reduces heat loss, meaning your heating system, whether gas or electricity, doesn't have to work as hard to keep your home warm. Better insulation cuts overall energy demand, which lowers bills and makes both gas and electric systems more efficient.
Choose energy-efficient appliances
Replacing old appliances with energy-efficient models, such as A-rated ovens, fridges, and heat pumps, reduces the amount of energy needed for everyday tasks. Efficient devices convert more of the energy they consume into useful output, helping to cut both gas and electricity costs over time.
Monitor and manage your energy usage
Tracking your energy use with smart meters or apps helps you understand when and how you consume the most energy. By shifting high-use activities to off-peak times or reducing unnecessary consumption, you can lower your overall costs and make both gas and electricity more affordable in practice.
Gas or electricity: which is the better choice for your home?
Choosing between gas and electricity depends on your home type, energy usage, and long-term goals. While gas is often cheaper per unit, electricity can offer better efficiency and future flexibility, especially with renewable energy systems. The best choice is not universal. It depends on how you heat, cook, and power your home.
Factor
Gas
Electricity
Running cost per kWh
Usually cheaper
Usually more expensive
Heating efficiency
Moderate (boiler losses)
High (especially heat pumps)
Installation cost
Often higher (gas system required)
Lower for simple systems
Maintenance
Requires regular servicing
Lower maintenance needs
Environmental impact
Higher carbon emissions
Cleaner, especially with renewables
Best suited for
Traditional heating-heavy homes
Energy-efficient or solar-powered homes
Gas is still generally cheaper than electricity in the UK, but the answer to whether gas is cheaper than electricity depends on how efficiently energy is used in your home. Gas remains cost-effective for traditional heating, while electricity can become more competitive with efficient appliances and renewable energy systems. Ultimately, the best choice depends on your home setup, insulation, and long-term energy goals.
For reducing overall energy costs and improving efficiency, EcoFlow solutions like the STREAM Ultra X and STREAM Ultra, and AC Pro paired with solar panels, offer a practical way to generate, store, and manage clean electricity for greater savings and energy independence.
  1. How much does it cost to run gas central heating for 1 hour?
The cost of running gas central heating for 1 hour depends on your boiler efficiency, home size, and insulation. On average, it can cost around £0.30 to £1.00 per hour in the UK. Well-insulated homes use less energy, which reduces overall running time and cost. Older or less efficient systems may increase hourly expenses.
  1. Will gas cost more than electricity?
In most cases, gas is still cheaper than electricity per kWh in the UK. However, total bills depend on how efficiently energy is used in the home. Electricity can sometimes be cheaper in very efficient homes using heat pumps or solar support. So while gas is usually cheaper per unit, overall costs vary by usage and technology.
  1. What's the cheapest way to heat my home?
The cheapest way to heat a home is to combine good insulation with efficient heating systems. Gas boilers are often cheaper for running costs, but heat pumps and solar-supported electric systems can reduce long-term expenses. Using smart heating controls and avoiding heat loss can also significantly lower overall energy bills.
