What Is a Tropical Storm and Could It Affect the UK?
Is there a tropical storm right now? Not one that threatens anyone. The Atlantic is quiet and the season officially ends on 30 November. A tropical storm is a rotating storm that forms over warm ocean water, with sustained winds of 39 to 73mph. The UK doesn't get them, but the remnants of one can still bring wind and rain, and the real worry is usually a power cut. A portable power station can keep phones and your router running through one, so we'll cover both.
Satellite-style view of a swirling storm over the Atlantic heading towards the UK, with a lit window in the foreground.
Tropical Storm Update Today: Where to Find the Latest Information
What Is Happening in the Tropics Right Now?
The short answer to any tropical storm update today is that things are calm. By early November the Atlantic had produced just 10 named storms and one hurricane, Isaias, against 30-year averages of 14 named storms and seven hurricanes. El Niño wind shear helped hold the season back, which we explain in our El Niño article. AccuWeather said on 9 November that Atlantic activity looked to be over, although the official season runs to 30 November.
The only named system recently in view was Tropical Storm Pena in the Central Pacific. After forming south-west of Hawaii's Big Island earlier in the week, it weakened into a tropical depression with 35mph winds by 13 November as it moved west toward the International Date Line, posing no threat to land as it dissipates.
How to Track Active Storms and Read Official Warnings
Go to the official source. The US National Hurricane Center (NHC) covers the Atlantic and East Pacific, the Joint Typhoon Warning Center and PAGASA cover the West Pacific, and the India Meteorological Department covers the Bay of Bengal. When you look at a forecast cone, remember it shows the likely track of the storm's centre, not how far its wind and rain will reach. Damaging weather can fall well outside it.
What Is a Tropical Storm?
Tropical Storm Definition: Wind Speeds and Key Features
A tropical storm is a rotating storm system that forms over warm tropical seas. Meteorologists classify these systems by their sustained wind speeds. The categories are used to describe the development of a storm as its winds increase.
Storm classification
Sustained wind speed
What it means
Tropical depression
Up to 38mph
An organised tropical system with relatively weaker winds.
Tropical storm
39–73mph
Stronger sustained winds, heavy rain and an official storm name in naming regions.
Hurricane
74mph or more
A more powerful tropical cyclone with the potential for destructive winds and severe impacts.
The same type of storm has different names depending on where it forms. In the Atlantic and north-east Pacific, the strongest systems are called hurricanes. In the north-west Pacific, they're typhoons, while the Indian Ocean and South Pacific use the term cyclones.
Tropical Storm vs Hurricane, Typhoon and Cyclone: What Is the Difference?
Nothing, apart from where it happens. It's the same type of storm with a different name in each region. In the Atlantic and north-east Pacific it's a hurricane, in the north-west Pacific it's a typhoon, and in the Indian Ocean and South Pacific it's simply a cyclone. That's why the Bay of Bengal gets cyclones rather than hurricanes.
How Are Tropical Storms Named?
Tropical storm names come from rotating lists kept by the World Meteorological Organization for each region, and the names of especially deadly storms are retired. The 2026 Atlantic list had reached Josephine, the tenth name, by early November. UK storm names are a separate system. Austen, Boelo and the next on the list, Chloe, come from a list shared by the Met Office, Met Éireann and KNMI, and a UK name only means a storm could cause amber or red warning impacts. It doesn't mean the storm is tropical.
How Does a Tropical Storm Form?
What Conditions Create a Tropical Storm?
So, how does a tropical storm form? Several things have to line up: sea surface temperatures of at least 27°C, moist air, converging surface winds, low wind shear, and enough distance from the equator for the Earth's rotation to give the storm its spin. A cluster of thunderstorms becomes a tropical depression, then a tropical storm once winds reach 39mph. That's tropical storm formation in a nutshell, and it's why storms are most common in late summer and autumn, when the sea is at its warmest.
Tropical Storm Diagram: Eye, Eyewall and Rainbands
Picture a spinning ring. In stronger storms the centre is the eye, a calmer patch with light winds. Around it sits the eyewall, a ring of towering thunderstorms where the strongest winds and heaviest rain are found. Spiralling out from there are the rainbands, which can bring squalls and heavy showers a long way from the centre.
Diagram showing the main structures of a tropical cyclone: the eye, eyewall and outer spiral rainbands.
What Are the Main Risks of a Tropical Storm?
The most obvious tropical storm risk is wind and rain. Even before it reaches hurricane strength, a tropical storm can drop enough rain to cause flash flooding and landslides, and strong gusts bring down trees and power lines.
Storm surge, where the wind pushes sea water ashore, is often the most dangerous part for coastal areas. Add flooding and wind damage together and power outages can last days, which is why the damage so often reaches homes far from the coast.
Power cuts can leave households without lighting, internet access or a way to charge their phones. A portable power station offers another source of electricity for essential devices. The EcoFlow DELTA 3 Plus provides compact backup for phones, routers and lights when the mains supply goes down. Later in this guide, we'll compare it with larger options for households that need more power.
Ultra-fast AC recharging achieves full power in just fifty-six minutes to minimise downtime during urgent preparations Dual MPPT solar inputs support rapid green energy replenishment for completely off-grid living and camping trips High 1800W continuous output easily handles heavy household appliances like coffee makers, fridges, and kettles simultaneously Expandable capacity scaling up to 5kWh allows you to tailor your backup duration for extended power outages Advanced uninterrupted power supply switches over in under ten milliseconds to protect sensitive office and NAS equipment Whisper-quiet operation running below 30 decibels ensures disturbance-free indoor and nighttime usage without annoying fan noise Durable LFP battery chemistry delivers over 4000 charge cycles for a decade of dependable everyday power performance Comprehensive smart app connectivity lets you conveniently monitor statistics, adjust settings, and automate schedules from afar
Can Tropical Storms Affect the UK?
Can a Tropical Storm Reach the UK?
Not as a tropical storm. UK seas are too cool to keep one going, so by the time a hurricane gets this far north it has usually changed character. Meteorologists call that extratropical transition. Its energy now comes from warm and cold air meeting rather than warm sea water, so it's no longer a hurricane, but the remnants can still be powerful.
How Ex-Tropical Storms Bring Strong Winds and Heavy Rain
When remnants of a tropical storm or hurricane cross the Atlantic, the UK keeps the tropical name and calls it an "ex-hurricane" followed by that name. The Met Office says ex-Hurricane Ophelia still brought hurricane-force winds in 2017. In 2025, ex-Erin was expected to send large waves and swell towards western UK coasts. Remnants like these are the exception, though. Most UK storms, including Austen and Boelo this autumn, go through the UK storm-naming system and aren't being described here as ex-tropical.
How UK Households Can Prepare for Storm-Related Power Cuts
Power cuts are what hurt most. The Energy Networks Association says 838,700 properties lost power across Austen and Boelo. Save 105, the free number for reporting a power cut, check whether you can join your supplier's Priority Services Register, and keep a torch and charged power banks to hand. If you want phones and a router running for longer, that's where the next section comes in.
Which EcoFlow DELTA Power Station Is Suitable for Storm Backup?
If a storm causes a power cut, focus on the devices your household needs most rather than trying to run everything. The right capacity depends on what you plan to power, how long the outage lasts and whether you have a way to recharge the unit. Never connect a portable power station directly to your home's wiring.
Keep More Essential Appliances Running
If several people at home need power, the EcoFlow DELTA 3 Max Plus offers more room for essential devices and selected appliances. Its 2,048Wh capacity and 3,000W AC output give households more flexibility during a longer outage.
2kWh capacity giving you dependable backup power during home outages. 3000W output letting you run multiple heavy-duty appliances simultaneously. LFP battery chemistry ensuring over a decade of safe daily usage. Expandable extra battery design letting you scale up your total power. Fast home charging getting you fully powered up in record time. Smart app integration offering effortless remote monitoring and energy control. Robust build quality making it reliable for both indoor and outdoor use. Versatile port options letting you plug in various electronics at once.
Have More Backup Power for Extended Outages
For households preparing for longer power cuts or greater electricity needs, the EcoFlow DELTA Pro 3 offers a higher-capacity option. It provides 4,096Wh of capacity, 4,000W AC output and expansion up to 12kWh.
EcoFlow DELTA Pro 3
Massive 4,096Wh capacity handles heavy household appliances during extended power outages Robust 4,000W output effortlessly powers high-demand devices like washing machines Expandable system scales up to 12kWh for growing long-term energy needs Rapid charging technology powers the battery from zero to eighty percent quickly Dual solar input supports high-capacity green energy arrays for off-grid living Lightning-fast ten millisecond switchover keeps sensitive electronics running seamlessly during blackouts Whisper-quiet thirty decibel operating noise ensures peaceful indoor and bedroom use Durable LFP battery chemistry delivers over four thousand cycles for long-lasting reliability
Tropical storms stay in the tropics, their remnants can occasionally reach the UK, and today's picture is quiet. The sensible move is to follow the Met Office and NHC rather than speculation. If you'd like some backup for phones, a router and a few lights, explore the DELTA range at EcoFlow UK.
FAQs About Tropical Storms
How long does a tropical storm usually last?
There's no fixed answer. Some fade within a day or two, while others last a week or more, depending on the sea temperatures, land and wind shear they meet. For a live storm, check the NHC advisories rather than relying on averages.
Are tropical storms becoming more frequent?
Not clearly. Scientific assessments generally point to stronger storms and heavier rainfall in a warming climate rather than more storms overall. This year's Atlantic season has been below average, so a single season is not a good indicator.
Does UK travel insurance cover a tropical storm?
Often only in part, and it depends on your policy. Many cover cancellation or delays caused by severe weather but may exclude a storm that was already named when you booked. Read the details of your policy and the FCDO travel advice for the country you are travelling to.
What are the three types of tropical storms?
They're usually graded by wind speed. A tropical depression has winds up to 38mph, a tropical storm 39 to 73mph, and a hurricane 74mph or more. In other regions, the strongest are called typhoons or cyclones.
Why doesn't the UK get tropical storms?
UK seas are too cool. Tropical storms need sea surface temperatures of around 27°C or more, and the waters around the UK stay well below that, so the storms fade before they get this far.
Can the UK ever have a hurricane?
Not a true one, but the remnants of a hurricane can arrive with hurricane-force winds. Ex-Hurricane Ophelia in 2017 is the Met Office's example. The UK calls these "ex-hurricanes".
