How Much Does an Immersion Heater Cost to Run in the UK?
A 3kW immersion heater costs about 79p for every hour it runs at the current Ofgem average electricity rate. That sounds manageable until you realise a full hot-water cylinder can take more than two and a half hours to heat from cold. Do that every day and the cost soon becomes noticeable. The amount you spend also depends on the size of your cylinder, how much hot water your household uses and how well the tank holds its heat. A few changes to your heating schedule, better insulation and the right use of home energy storage can help bring the bill down.
Hot-water cylinder, immersion heater switch and home battery storage in a typical UK home utility room
What Is an Immersion Heater and How Does It Work?
An immersion heater, also called an immersion water heater, is an electric element fitted inside a hot-water cylinder. It heats the water directly, without relying on a boiler to do the job. You will find them in many UK homes, particularly properties without mains gas, homes with electric hot-water systems and houses where the cylinder needs a backup heat source.
For anyone asking what is an immersion heater, think of it as a large electric kettle element fitted inside a storage tank. Electricity passes through the element and heats the surrounding water. A thermostat controls the temperature and switches the power off when the water reaches its set point.
The arrangement is simple, but the details matter. Element position, cylinder capacity and insulation all affect how quickly the water heats and how long it stays hot. Some have a single element, others have two so that a full heat can be given at night and a smaller amount during the day.
Single-Element and Dual-Element Set-Ups
Most immersion heaters use a single element, usually rated at 3kW. It is often fitted near the bottom of the cylinder, where it heats most of the stored water. The exact area heated depends on the length and position of the element.
Some cylinders have two immersion heater elements: a shorter one near the top and a longer one near the bottom. The upper element heats just the water needed for a shower, so there is no need to warm the entire tank. The lower element heats the full cylinder. This setup works well with Economy 7. You can use the lower element to heat the water overnight when electricity is cheaper, then switch on the upper one for an extra boost during the day.
An electric immersion heater is a fixed appliance connected to the home's electrical installation. It is wired through a suitable double-pole switch and dedicated circuit. It is not designed to run from an ordinary three-pin plug. The same applies to a hot water immersion heater fitted as a backup to a boiler.
How Does an Immersion Heater Work? Element and Thermostat Explained
The immersion heater element works by using an electrical coil to heat the water around it. As the water gets warmer, it rises to the top of the cylinder, while cooler water moves down towards the element. This helps heat the water throughout the tank. The immersion heater thermostat controls the temperature and switches off the element once the water reaches the setting you choose. A separate safety cut-out steps in if the thermostat fails. Nearly all of the electricity consumption used is for heating the water, with a small amount of heat lost through the cylinder and pipework. In hard water locations limescale can also accumulate around the element reducing its heat transfer efficiency.
How Much Does an Immersion Heater Cost to Run?
The immersion heater running cost is straightforward to calculate. You need the element's power rating, the time it runs and your electricity unit rate. A 3kW element running for one hour uses 3kWh.
Ofgem's average Direct Debit electricity rate is 26.32p per kWh for 1 October to 31 December 2026 (including 5% VAT). At that rate, one hour of heating costs just under 79p. Your actual unit rate will depend on your region, payment method and tariff.
Use this calculation:
Electricity used (kWh) × electricity rate (p/kWh) = running cost
Note: 26.32p/kWh for electricity and 7.97p/kWh for gas are Ofgem’s price cap rates for October to December 2026, and they change each quarter. For the purpose of illustration the costs given in this article are estimates only. Compare both the cap and your particular tariffs with Ofgem's.
How Much Electricity Does an Immersion Heater Use?
The cost of running an immersion heater rises with every hour the element operates. The table shows the electricity used by a 3kW element over different heating periods. The night rate is an illustrative 12p per kWh, not a rate available on every tariff.
Heating time
Electricity used
Cost at 26.32p/kWh
Cost at 12p night rate
30 minutes
1.5kWh
39p
18p
1 hour
3kWh
79p
36p
2 hours
6kWh
£1.58
72p
3 hours
9kWh
£2.37
£1.08
4 hours
12kWh
£3.16
£1.44
The size of the cylinder makes a difference, too. Heating 120 litres of water takes less energy than heating 210 litres, assuming both start at the same temperature. For a comparison, the figures below assume water enters at 15°C and heats to 60°C. They exclude heat lost through the cylinder and pipework.
Cylinder capacity
Energy required
Heating time at 3kW
Cost at 26.32p/kWh
120 litres
6.28kWh
2.1 hours
£1.65
150 litres
7.85kWh
2.6 hours
£2.07
180 litres
9.42kWh
3.1 hours
£2.48
210 litres
10.99kWh
3.7 hours
£2.89
These are calculated figures rather than promises about what will appear on your meter. In practice, the starting temperature changes with the season, and the cylinder loses some heat while it is warming up.
What a 3kW Immersion Heater Costs to Run
Searches for how much does immersion heater cost to run and how much do immersion heaters cost to run often come down to one question: is it cheaper to heat the whole tank or just replace the hot water that has been used? The answer is clear in a 150-litre cylinder. A full heat from 15°C to 60°C needs 7.85kWh, while raising the same tank from 45°C to 60°C needs only 2.62kWh.
Heating scenario (150L)
Energy used
At 26.32p/kWh
At 12p/kWh
Full heat, 15°C to 60°C
7.85kWh
£2.07
94p
Top-up, 45°C to 60°C
2.62kWh
69p
31p
Shower boost, 30–45 minutes
1.5–2.25kWh
39–59p
18–27p
The annual figures put those amounts into perspective. Heating a full cylinder from cold every day works out at roughly £754 a year at 26.32p per kWh, or £344 at 12p. After it has dropped 15°C, topping it up daily costs approximately £252 a year at the standard rate.
That is the difference between a full heat and replacing the warmth lost through use. The phrase 3kw immersion heater cost to run is often searched as if there were one fixed answer, but the amount of water being heated matters just as much as the element's rating. A shorter boost for a shower will use less electricity than reheating the entire tank.
How to Cut Your Immersion Heater Costs
The immersion heater bill is affected by more than the element itself. A poorly insulated cylinder loses heat throughout the day, while a large household empties the tank faster than a single occupant. The thermostat setting and the time you choose to heat the water also make a difference.
What Pushes Electricity Use Up
Cylinder heat loss is one of the costs that often goes unnoticed. The element switches off when the water reaches the set temperature, but the tank gradually cools. One ErP class C cylinder lists standing heat loss of 2.26kWh over 24 hours. At 26.32p per kWh, replacing that lost heat would cost about 59p a day.
Household demand matters as well. A family using several showers and baths will draw more hot water than someone living alone. Each time hot water leaves the cylinder, cold water enters to replace it. The element then has more work to do.
A tank in a cold garage or an unheated cupboard also loses heat faster than one in a warmer space. When the switch is on, it does not mean the element consumes 3kW every second of the day, it just means that the thermostat can call for heat if the stored water temperature drops.
Thermostat Settings and Insulation
Set the cylinder thermostat to 60°C. The Health and Safety Executive recommends storing hot water at 60°C or above to control the risk of Legionella bacteria. Turning the temperature down to reduce electricity use is not a sensible saving. If hot water at the tap needs to be cooler to prevent scalding, a thermostatic mixing valve is the appropriate solution.
Now look at the cylinder itself. If the factory insulation is thin or damaged, fit a suitable hot-water cylinder jacket. Energy Saving Trust recommends insulation at least 80mm thick. Its guidance estimates that adding an 80mm jacket to a cylinder with only 25mm of factory foam insulation could save around £45 a year in Great Britain. Insulating accessible hot-water pipes helps reduce losses between the cylinder and the taps, too.
If the water is suddenly much hotter than usual, the element keeps switching off or the tank takes longer to heat, have the thermostat and element inspected. Limescale or a faulty control could be behind the change.
Timers, Economy 7 and Off-Peak Heating
A timer gives the cylinder a set heating window. Rather than keeping the supply available all day, programme it to heat before the household's usual morning or evening demand. Check how long the water stays hot and adjust the schedule to avoid reheating a full tank unnecessarily.
Economy 7 and other time-of-use tariffs offer cheaper electricity at selected times. For example, a 150-litre full heat costs about 94p at an illustrative 12p night rate. The same heat costs £2.07 at 26.32p per kWh.
The immersion heater running costs uk households pay therefore vary with their tariff, not just the size of the element. Check the actual day and night rates, the length of the cheap-rate window and any standing charge before changing supplier or tariff. A low night rate is useful when the cylinder and other major loads can run during those hours. It is less attractive if the daytime rate is high and most of your electricity use remains outside the cheap window.
With a dual-element cylinder, the lower element can heat the full tank overnight. The upper element is then available for a smaller boost if the household runs short during the day.
Immersion Heater vs Gas Boiler, Electric Boiler and Heat Pump
The immersion heater running cost is higher per unit of heat than the gas boiler and heat pump examples below. The difference is accounted for by fuel costs and the efficiency of the two systems in converting the energy to useful heat.
Heating method
Assumed efficiency
Approx. cost per kWh of heat
Cost to heat 150L from 15°C to 60°C
Immersion heater
Nearly 100%
26.32p
£2.07
Electric boiler
99%
About 26.6p
£2.09
Gas boiler and cylinder
90%
About 8.9p
70p
Heat pump cylinder
COP 3
About 8.8p
69p
These estimates use Ofgem's October–December 2026 average rates of 26.32p/kWh for electricity and 7.97p/kWh for gas. The gas calculation assumes 90% efficiency, while the heat pump example assumes a coefficient of performance (COP) of 3. They exclude additional system losses and standing charges.
A gas boiler is often the practical choice for a home already connected to the mains and using wet central heating. An electric boiler is suitable for properties not connected to gas supplies where there is a requirement for both space heat and hot water generation, although the cost of operating these boilers will depend on the cost of electricity. A heat pump transfers heat to the building, but does not create it, which allows it to provide more heat per unit of electricity.
Installation is another consideration. Replacing an element is a much smaller job than changing a boiler or installing a heat pump. In England and Wales, the Boiler Upgrade Scheme offers eligible households £7,500 towards an air-source or ground-source heat pump.
Note: Grant amounts, eligibility and availability change over time. Check current GOV.UK guidance before applying.
Can Solar Power Heat Your Hot Water?
Solar panels produce electricity during daylight, but many households use most of their hot water in the morning and evening. That leaves a timing gap. A solar diverter sends surplus generation to the cylinder while the panels are producing electricity; a battery stores some of that energy for later.
How Solar Diverters Heat Water With Surplus PV
A solar diverter measures electricity leaving the property and redirects surplus power to the hot water immersion heater. A CT clamp is used to measure the flow at the supply. Then the diverter diverts the electricity to the element when the solar power increases or decreases.
The cylinder acts as a store for heat. Instead of exporting all the spare electricity and buying power later to heat water, the household uses some of its own solar generation.
There is a limit to what this arrangement does. It heats water, not the rest of the house, and it needs enough surplus generation to make a useful contribution. During a grey UK winter, solar output falls and grid electricity or an off-peak tariff will still be needed. A qualified installer should check the cylinder, element and electrical connections before fitting a diverter.
Can a Home Battery Run a 3kW Immersion Heater?
A home battery can store solar electricity for use after sunset, but a 3kW element is a demanding load. The battery system needs a continuous AC output capable of supplying the element, along with enough usable stored energy. The electrical circuit and any backup arrangement also need professional assessment.
Heating job
Energy required
Time at 3kW
Compared with 5kWh nominal battery capacity
Full 150L heat from cold
7.85kWh
2 hours 37 minutes
Exceeds one battery
Daily top-up
2.62kWh
52 minutes
Within nominal capacity
Shower boost
1.5–2.25kWh
30–45 minutes
A 5kWh battery has less usable AC energy once conversion losses and reserve settings are taken into account. It also needs to supply any other loads connected at the same time. A full cold-start heat for a 150-litre cylinder therefore exceeds the nominal capacity of one 5kWh unit.
Output is just as important as capacity. A 3kW element needs a supply that can deliver that load continuously. There is little headroom left for other appliances if the battery's maximum output is also 3kW. An electrician must check the circuit, isolation, system configuration and whether the intended connection is supported.
A diverter and battery can be used together. The installer sets which takes priority, for example charging the battery first and sending remaining surplus to the cylinder. The right order depends on the household's hot-water use and electricity needs.
How to Use More of Your Solar for Hot Water
A diverter uses surplus electricity while the panels are generating. It does not solve the evening gap on its own. Home energy storage holds some of that daytime generation for later, giving the household another source of electricity after the sun has gone down. The best arrangement depends on whether solar is being installed from scratch or added to an existing system.
For Homes Without Solar Panels Yet
Starting from scratch gives a household the chance to plan solar generation and battery storage together. The EcoFlow STREAM 5000 is intended for a new solar-plus-storage set-up, with a 5kWh / 5024Wh capacity that is expandable up to 90kWh. Its 5000W PV input is divided across four MPPT channels rated at 1,250W each, and its stated AC output is up to 3000W. Intelligent Mode+ manages household energy automatically, helping the home use stored solar after daylight hours. One unit cannot cover a full 150-litre cold-start heat requiring 7.85kWh, so an electrician must assess the immersion heater circuit and the proposed connection.
EcoFlow STREAM 5000
Installed home battery for homes without solar. UK rules require installation, and the setup is designed to be simple 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for high-demand appliances like stoves, dryers or kettles (when solar is generating or an Expansion Battery is paired) 5,000W solar input makes full use of your solar generation Up to 2500W AC charging for fast recharge Smart meter, main unit and solar panels are designed to connect easily, with step-by-step app guidance for setup Compact 45.4kg body with a built-in handle for easier placement during installation Residential-grade protection with pressure-release and fire-resistant materials, designed to reduce thermal runaway risk with high-voltage solar panels Rated for 10,000 cycles Local Mode keeps the system running and communicating even if the network drops
For Homes With Solar Already Installed
If you already have solar panels, you might send unused electricity to the grid during the day, then buy electricity back in the evening when your household needs more. The EcoFlow STREAM AC 5000 lets you add battery storage to your existing solar setup. It has a 5kWh (5,024Wh) capacity, which you can expand to 90kWh, and a stated AC output of up to 3,000W. Intelligent Mode+ helps manage how you use stored energy, while Local Mode works without an internet connection. Before using the battery to power an immersion heater, ask your installer to check compatibility and make sure it works properly alongside any existing solar diverter.
Installed home battery for homes with existing solar. UK rules require installation, and the setup is designed to be simple Works with existing rooftop PV systems, home battery systems and leading third-party meters 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for heavy household appliances (when solar is generating or an Expansion Battery is paired) AC coupling adds storage alongside your current solar setup, and a Gateway simplifies expanding later Compact 44.6kg body designed to fit into spaces around the home Rated for 10,000 cycles
Note: Compliant generation-only plug-in solar kits have been legal to buy and use in Great Britain since 27 August 2026, but these rules do not cover plug-in batteries or solar-plus-storage systems. Home batteries, including the EcoFlow STREAM 5000 and STREAM AC 5000, are not plug-in solar products. They must be professionally installed and must comply with the IET Wiring Regulations (BS 7671) and DNO connection requirements. Follow GOV.UK guidance, and obtain professional advice and guidance from a qualified installer to determine the type of work your home requires.
A 3kW immersion heater uses 3kWh of electricity for every hour it runs. At 26.32p per kWh, heating a 150-litre cylinder from cold costs around £2.07. That drops to about 94p at an illustrative night rate of 12p per kWh. You can keep costs down by insulating the cylinder, heating water only when needed and setting the thermostat correctly. Gas boilers and heat pumps cost less per unit of heat in the examples above. Solar diverters and batteries also help you make better use of the electricity your panels generate.
Home energy storage gives solar households another way to use daytime electricity after dark, rather than relying entirely on grid power. To explore storage options for new solar installations and existing systems, visit EcoFlow UK. Explore the EcoFlow STREAM range to find a home energy storage set-up that suits your household.
Is a 6kW immersion heater cheaper to run than a 3kW one?
No. A 6kW element uses twice the electricity each hour but heats the same amount of water in roughly half the time. The overall amount of energy required for the same temperature increase remains more or less the same. A 6kW element also requires an appropriate circuit which is specified and installed by a qualified electrician.
How much does it cost to replace an immersion heater?
The element itself is only part of the bill. A replacement part can cost around £20–£45, while labour, draining the cylinder and replacing the thermostat add to the total. UK cost guides put a full replacement at around £300 on average, although access and the type of cylinder affect the final quote.
Should I leave my immersion heater on when I go on holiday?
For an absence of several days, switch it off at the double-pole isolator rather than heating water nobody will use. When you return, heat the cylinder to 60°C before using the hot water. If your home has a more complex hot-water arrangement, follow the manufacturer's instructions or ask a qualified heating engineer.
