EcoFlow STREAM Series
Solar Savings, Made Simple <star>**</star>
Solar Savings, Made Simple **
Solar Savings for Everyone
What's New in STREAM
  • Lightest.
Most compact.
Highest energy density
    Up to 40% smaller footprint.
    Lightest. Most compact. Highest energy density
    among 5kWh solutions
  • Capacity
    5kWh
  • 5000W Solar Input
    5000W Solar Input
  • Up to 3000W Output
    Up to 3000W Output
  • Expand Up to 90 kWh
    Compatible with Last Generation
    Expand Up to 90 kWh
    Coming Soon
  • No cloud required.
Keeps working locally.
    Local Mode²
    No cloud required. Keeps working locally.
  • 2 x Pressure relief valves
v.s. industry standard
    Safe & Reliable
    2 x Pressure relief valves v.s. industry standard
Model
Easy to Choose
Designed for You. Just Right.
Enough solar and storage to power your home all day.
  • 5000W Solar Input
    5000W Solar Input
    Connecting up to 12 solar panels can generate around 5,600kWh annually, covering the electricity consumption of a typical family of four.
    * Annual electricity generation is based on average consumption of a 4-person household in Germany. Actual usage may vary.
  • 5kWh Capacity
    5kWh Capacity
    No waste. Just the right fit.
    From day to night, it supports your energy needs throughout the day. Scale up to 90kWh, as easily as stacking building blocks.
    Up to 3000W Output
    Powering high-demand home appliances, even a dishwasher or a washing machine.
    3000W is a well-designed balance between powerful performance and everyday safety **.
    *Up to 3000W output is available when PV generation occurs simultaneously or when paired with an Expansion Battery.
    • [object Object]
      Operates Reliably from -20°C to 55°C
    • [object Object]
      Lightning Surge Protection
    • [object Object]
      Corrosion-Resistant
    • [object Object]
      Continues Operating in Standing Water⁷
  • Solar Generation
  • Storage
  • Usage
  • 5000W Solar Input
  • 5kWh Capacity
  • 5000W Solar Input
    5000W Solar Input
    Connecting up to 12 solar panels can generate around 5,600kWh annually, covering the electricity consumption of a typical family of four. *
  • 5kWh Capacity
    5kWh Capacity
    From day to night, it supports almost all of your energy needs. Scale up to 90kWh, as easily as stacking building blocks.
    Up to 3000W Output
What STREAM Users Are Saying
0
Installation
Easy to Start
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
  • EcoFlow Image
  • EcoFlow Image
  • EcoFlow Image
Installation
Easy to Start
Compact Footprint. Place It Anywhere.
  • Compact Footprint. Place It Anywhere.
    Fits Where You Need It
    Takes up to 40% less floor space, with a built-in handle for easy placement, indoors or out.
Simple Setup
Designed to Help You Save from Day One
  • Step 1
    Place
     Place
  • Step 2
    Connect & Install
     Connect & Install
  • Step 3
    Set Up the App
     Set Up the App
Operation
Easy to Use
No. 1 Global Smart Home Energy Storage System App by Registered Users ⁸
  • 01 ASK
    Define Your Goal
    No technical expertise is needed. Just express your intent.
  • 02 PREDICT
    Plan the Path
    Tailored insights to optimise your specific energy usage.
  • 03 ACT
    You Approve, We Execute
    EcoBot handles the heavy lifting after your confirmation.
EcoFlow Image
Whole-Home Energy Management System
Your Energy, Your Way
  • Custom Mode
  • Self Consumption Mode
  • Intelligent Mode+
Track Your Savings, Every Day
Clear Energy Dashboard
See how much you've saved
Stay Powered, Even Offline
No internet? No problem. With Local Mode, your system keeps working and your devices stay connected.
Safe & Reliable
Easy to Trust
Smart Home Energy
Storage Solutions⁹
No.1Smart Home Energy Storage Solutions⁹
  • 140+
    Countries & Regions
  • 1524
    Patents
  • 6Million+
    Global Users
Reliable for the Long Run
  • [object Object]
    0 ms UPS
  • [object Object]
    100%
    State-of-Charge
  • [object Object]
    15-year
    battery lifespan
  • [object Object]
    IP65
    dust & water resistant
  • [object Object]
    10,000
    charging cycles
  • [object Object]
    10-year
    warranty
Efficient Cooling Structure and Rugged Aluminum Housing
46%
better heat dissipation compared with the previous generation
24 NTC temperature sensors detect temperature deviations early, while the rear cooling structure efficiently dissipates heat. A rugged, fire-resistant, CNC-machined aluminum housing encloses the entire system and provides additional protection.
EcoFlow Image
EcoFlow Image
Pressure-Relief Valves
2 x
instead of the industry-standard single valve
Two valves release excess pressure faster and more effectively—providing additional safety even in the rare event of an emergency.
Proactive overload protection
Smart Meter Dual CT solution for circuit protection
  • Smart Sensing
    Continuously monitors circuit current and identifies overload risks in real time.
  • Dynamic Adjustment
    Immediately signals the balcony power system to stop power output when unsafe conditions are detected.
  • Hardware Failsafe
    Automatically disconnects the circuit if current exceeds the safe threshold, providing an additional layer of physical protection.
  • Continuously monitors circuit current, proactively prevents overload by adjusting feed-in, and works with your certified breaker for an added layer of protection.
    * Expected to launch in September 2026. For illustration purposes only. Actual installation must follow UK regulations. The battery system requires connection by a certified professional or qualified electrician and should not be connected to a household socket for power feed-in.
    15 Layers of  Protection
      • 1
        Reverse Current and Anti-Islanding Protection
        Helps protect your home and devices during grid abnormalities
      • 2
        Data Logging Module
        Monitors real-time performance data for smarter maintenance
      • 3
        Metal Plate and Steel Banding
        Prevents cell swelling and dampens vibration
      • 4
        Thermal Runaway Containment
        Helps contain heat and limit cell-to-cell propagation
      • 5
        Aluminum Alloy Enclosure
        Corrosion-resistant and built for harsh environments
      • 6
        Floating Terminal Design
        Protects connectors during installation and use
      • 7
        Fully Integrated Waterproof Design
        Seamless waterproofing from top to bottom
      • 8
        Ceramic Cell Coating
        Resists high temperatures and helps prevent internal short circuits
      • 9
        Aerogel and Thermal Foam Barrier
        Helps slow heat propagation between cells
      • 10
        Two Pressure Relief Valves
        Enables safe venting during pressure build-up
      • 11
        Insulation Fault Detection
        Continuously monitors for electrical leakage and short-circuit risks
      • 12
        PV Overvoltage Protection
        Ultra-fast hardware cut-off helps prevent overcharging
      • 13
        AFE Protection Chip
        80+ built-in protection protocols for safer operation
      • 14
        24 NTC Temperature Sensors
        Continuous temperature monitoring across every cell
      • 15
        Enlarged Heat Sink and Optimised Thermal Structure
        46% better heat dissipation — runs cooler, lasts longer
    • EcoFlow Image
    • EcoFlow Image
    • EcoFlow Image
      EcoFlow Image
    • EcoFlow Image
    • EcoFlow Image
    EcoFlow Image
    Choose
    EcoFlow STREAM Series to Scale Across Ecosystems
    1000+
    Compatible with existing PV systems and leading third-party meters, including Shelly, HomeWizard, everHome, Tibber, and Homey.
    • Smart Home Ecosystems
    • Energy & Metering Partners
    Explore EcoFlow STREAM Series
    Terms & Conditions
