Generator Maintenance Schedule and Checklist for Canada
Generator maintenance starts with your exact model, its manual, the hour-meter reading, and the last service date. Your next service may be due after a set time, a set number of operating hours, or whichever limit comes first.
Portable, automatic standby, and commercial generators don't share one schedule. Storage, long outage runs, dust, cold, moisture, and fuel type can also bring service forward.
For selected-load battery backup without engine oil, spark plugs, combustion exhaust, or fuel-system care, consider the EcoFlow DELTA 3 Ultra Series Portable Power Station (3072Wh). It still needs testing, safe storage, inspection, and care based on its manual.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
•3,600 W AC output with 7,200 W surge output •3072 Wh base capacity, expandable from 3–11 kWh •6 charging options, with 0–80% in 48 minutes using solar + generator dual charging • 10 ms auto-switch plus Smart Output Priority for critical backup planning
Start by identifying which type of equipment you own before you add any dates to your maintenance calendar.
What Maintenance Does a Generator Need?
A generator may need oil and filter changes, fuel-system care, starting-battery checks, cooling and exhaust inspections, and tests of its controls and electrical output. The exact work depends on the model, fuel, engine, and connection method, so its current manual sets the schedule.
Common maintenance areas include:
  • Engine oil and an oil filter, if fitted
  • Air and fuel filters
  • Spark plugs or diesel fuel and ignition parts
  • The starting battery and charger
  • Fuel, hoses, regulators, and visible connections
  • Coolant in liquid-cooled equipment
  • Cooling openings, exhaust, and ventilation
  • Alternator, receptacles, breakers, and controls
  • Automatic transfer equipment
  • Cords and plugs on portable units
  • Exercise history, fault codes, cleaning, and storage
Not every generator contains each part. An air-cooled gasoline model has different needs from a liquid-cooled diesel unit or a natural-gas standby system. Maintenance alerts can remind you that work is due, but they can't diagnose every fault.
Use the fluids and parts listed for your model. Routine care can reduce failures, but it can't guarantee operation during every outage.
What Is the Recommended Generator Maintenance Schedule?
Build your generator maintenance schedule around four triggers: operating events, calendar time, engine hours, and the manufacturer's instructions.
This table is a planning framework, not a universal service timetable.
Maintenance trigger
Safe owner checks
Possible technician work
Before use or an exercise cycle
Check the area, visible leaks, fluid levels, fuel, cords, vents, and warning lights
Diagnose active alarms or damaged equipment
After an exercise cycle
Confirm that the cycle finished and record any faults
Test automatic controls if the exercise failed
After extended outage use
Record hours, look for leaks or damage, and check the next manual interval
Service oil, filters, fuel, battery, cooling, or load-related parts
Before seasonal storage
Clean the exterior and follow the approved fuel and battery procedure
Service the fuel system if the unit will sit unused
After long storage
Look for corrosion, pests, stale fuel, damage, and a weak battery
Test the fuel and starting systems or recommission the unit
At a calendar or engine-hour limit
Review the log and manual
Replace scheduled parts and complete required tests
After severe weather or flooding
Keep the unit off and inspect only from a safe distance
Inspect electrical and fuel systems before reuse
Follow whichever manual limit arrives first. A heavily used generator can reach an engine-hour limit early. An idle unit can reach a calendar limit because oil, fuel, hoses, seals, and batteries age while it sits.
Dust, salt air, extreme temperatures, contaminated fuel, or long runs may require earlier attention. A new engine may also have a separate break-in service. Never copy an interval from another model.
Record the date, hour reading, work, parts, fluids, fault codes, technician, and both next-service limits. After a long outage, log the new hours before storage.
 Generator maintenance checks organized by use and service stage  Generator maintenance checks organized by use and service stage
Which Portable Generator Tasks Can an Owner Complete?
You can usually complete visual checks and basic care that the manual assigns to the owner. Shut the generator down, disconnect loads as directed, and let the engine cool before you begin.
  • Read the shutdown and maintenance steps first.
  • Check the oil by the stated method and on the surface the manual requires.
  • Inspect, clean, or replace the air filter only as directed.
  • Check the spark plug if the manual lists it as an owner task.
  • Look for wear or damage on visible fuel hoses and propane connections.
  • Check an electric-start battery for visible corrosion, swelling, or damage.
  • Clear cooling openings without forcing dirt into the unit.
  • Inspect cords, plugs, covers, wheels, and handles.
  • Use only the specified oil, filters, plugs, and fuel treatment.
  • Store the generator clean and dry under the stated storage procedure.
Don't open the alternator or control panel. Don't repair a fuel leak, change internal wiring, or bypass a safety device. Damaged fuel or electrical systems need professional attention.
Any exercise run must follow Health Canada's generator safety guidance. Keep a fuel-burning generator outdoors, at least 6 metres from buildings, with its exhaust directed away from doors and open windows. Never run it in a home, garage, shed, vehicle, camper, or tent.
How Does Standby Generator Maintenance Differ?
A standby generator adds automatic controls, a fixed fuel supply, a starting battery, and transfer equipment. These parts must work together, which is why standby care goes beyond portable-engine service.
You can confirm that scheduled exercise cycles finish, review controller alerts, and keep air intakes and exhaust openings clear. Remove leaves and snow without blocking airflow, and look for leaks, corrosion, animal activity, or enclosure damage. Check the service log after a long outage.
An exercise cycle proves that the engine started under those conditions. It may not prove that the generator and transfer system can support the planned electrical load.
Professional work can include battery, fuel, internal electrical, transfer-switch, controller, and load testing. EcoFlow's explanation of how an automatic standby generator operates shows why the engine, controls, fuel supply, and transfer switch form one system.
For Generac generator maintenance, find the exact model and serial number, check the controller alert, and follow Generac's current maintenance guidance. Use an authorized provider when the manual or warranty requires one. Don't apply one service interval to all air-cooled and liquid-cooled Generac models.
What Does Commercial Generator Maintenance Include?
Technician reviewing commercial generator maintenance records Technician reviewing commercial generator maintenance records
Commercial generator maintenance needs a documented program based on the site, generator, critical loads, operating hours, manufacturer requirements, and rules that apply to the building.
The program may cover:
  • Equipment details and serial numbers
  • Calendar and engine-hour limits
  • Fuel quality and storage
  • Lubrication and cooling systems
  • Starting batteries and chargers
  • Exhaust and ventilation
  • Alternators, controls, and alarms
  • Automatic transfer switches
  • Remote-monitoring records
  • Load or load-bank testing where required
  • Parts, fluids, reports, and corrective work
  • Emergency service and temporary-power plans
CSA C282:24 covers the design, installation, operation, maintenance, and testing of certain emergency electrical power systems for buildings. It doesn't place every business generator on one legal schedule. Facility managers must confirm the building's use, the adopted edition, provincial requirements, and any rules from fire, building, electrical, or health authorities.
Electrical generator maintenance involving alternators, breakers, grounding or bonding, controls, and transfer equipment belongs with workers who hold the qualifications required for that job and location. Use the applicable standard rather than copying a generic online timetable.
When Should You Call a Generator Service Provider?
Stop using the generator and call a qualified provider when a problem involves fuel, combustion, internal electrical parts, transfer equipment, abnormal output, or physical damage.
Warning signs include leaks, repeated failure to start, persistent alarms, unusual smoke, smells, heat, noise, or vibration. Get help for unstable output, damaged wiring, water entry, flood exposure, a failed transfer, or an unknown service history.
When looking for a local generator service provider, choose a company that can service the exact make, fuel system, transfer equipment, and installation type.
Factory authorization may matter for warranty work. Local rules and provider availability vary by province, so verify credentials instead of choosing only by distance or the first open appointment.
Do Battery Power Stations Need the Same Maintenance?
Battery power stations don't need combustion-engine service. They still need inspection, testing, suitable storage, firmware care, and approved electrical connections.
Maintenance area
Fuel generator
Engine oil, filters, and ignition
Follow the model schedule
Not applicable
Stored fuel
Needs safe handling and fuel care
Not applicable
Exhaust and carbon monoxide
Requires outdoor operation
No combustion exhaust at the point of use
Battery
Starting battery on many models
Main energy-storage system
Connections
Inspect cords and transfer equipment
Inspect charging, output, and integration equipment
Storage
Follow engine, fuel, and battery steps
Follow charge and temperature instructions
Testing
Exercise and load testing
Charge, output, switchover, and planned-load testing
The DELTA 3 Ultra Series has 3,072 Wh capacity, 3,600 W continuous output, 7,200 W surge output, and 10 ms switchover for compatible connected equipment. Check its cables, ports, firmware, charge level, storage conditions, and planned loads under the current manual. The 3 to 11 kWh expansion claim applies to the DELTA 3 Ultra Plus variant, not every model in the series.
For a larger integrated circuit plan, consider the EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated).
•7.2 kW AC output, expandable up to 21.6 kW with supported configurations •6 kWh starting capacity, expandable up to 90 kWh • Supports automatic home backup switchover with EcoFlow Smart Home Panel 2 • Automatic battery self-heating below 0°C for cold-weather operation
Its base inverter-and-battery configuration provides 6,144 Wh capacity, 7,200 W continuous output, 10.8 kW surge output, and 120 V/240 V output. An integrated home setup needs compatible equipment, such as Smart Home Panel 2, and a qualified electrician must inspect or service hardwired connections.
Battery systems aren't maintenance-free, and capacity alone can't guarantee outage runtime. Follow our advice on how to maintain a portable power station, while the current model manual controls charging and storage details.
Record the Next Service Before the Next Outage
Record your model, serial number, engine hours, last service date, and next time and hour limits today. Complete overdue service and testing before severe weather or remote use, when getting parts or qualified help may take longer.
If you want selected-load backup without combustion-engine care, compare EcoFlow portable power stations after you calculate the power and energy your essential equipment needs.
What maintenance is required for a generator?
Maintenance may include oil, filters, ignition parts, starting batteries, fuel, coolant, ventilation, controls, cords, and electrical connections. The exact list depends on the generator's model, engine, fuel, cooling system, and connection method.
How often should I service my generator?
Use the earlier of the calendar or operating-hour limit in the manual. Service may be due sooner after a long outage, extended storage, severe weather, dusty use, salt exposure, contaminated fuel, or a fault.
What is the recommended maintenance schedule for a generator?
Include before-use inspections, exercise checks, post-outage reviews, storage preparation, and model-specific part replacement. Track calendar time and engine hours instead of relying on dates alone.
How many hours should a generator run before servicing?
There is no universal number. Break-in service and later intervals vary by manufacturer, model, fuel, load, and operating conditions. Check the hour meter against the schedule for your exact unit.
Home Backup
