Backup Power Generator for Home: How to Choose the Right One
Storms knock down power lines, ice weighs on infrastructure, and grid failures can happen without warning. The Government of Canada identifies extreme weather, including freezing rain and high winds, as common outage causes. When an outage lasts hours, a backup power generator for the home can keep food cold, heating systems running, and essential basement equipment powered.
Choosing the right setup is less about brands and more about your household. Start with the things you cannot afford to lose during an outage. Then weigh local fuel access, space around the property, and what you can spend.
The options fall into three groups: standby generators, portable units, and battery systems. EcoFlow DELTA Pro Ultra represents the battery route here. Your expected outage length will help narrow down which setup makes sense.
Choose Quiet, Expandable Home Backup with EcoFlow DELTA Pro Ultra
Starts with 6 kWh of storage capacity and can expand up to 90 kWh. Supported configurations provide 7.2 to 21.6 kW of output for home appliances. Supports charging from solar, the grid, EV charging points, and generators. EcoFlow specifies 0 dB operation below 2,000W output. Designed for indoor installation with IP54 protection. Accepts between 5.6 and 16.8 kW of solar input, depending on the setup. Provides a fuel-free battery backup option for households that want quieter operation than combustion generators.
What Is a Home Backup Power Generator?
Grid power can fail without warning, leaving a home without electricity for hours. For a smaller setup, the priority might be keeping food cold, lights on and Wi-Fi available. More capable backup power generators for homes may also cover pumps, heating equipment or extra circuits.
Standby units are permanently positioned outdoors and can respond automatically when utility service fails. Portable models need to be brought out and set up before they can run. Our home backup generator options guide explains both setups in more detail.
ecoflow power backup generator optionecoflow power backup generator option
Standby vs Portable vs Battery Backup: Which Type Fits Your Home?
Household power needs and local outage patterns help narrow down backup power generators for homes. Canada’s official advice for preparing for power outages also covers generator safety during an emergency. Here is how standby, portable, and battery options compare in practical terms:
Factor
Standby Generator
Portable Generator
Battery Backup
Power Source
Burns natural gas or propane
Burns gasoline or propane
Stored electricity
Startup
Automatic within seconds
Manual every time
Automatic, near-instant
Installation
Permanent, professionally fitted
Portable; connection method varies
Varies by system and configuration
Fuel
Continuous or stored supply
Refueled by hand
Recharged from grid or solar
Noise
Loud, audible outdoors
Loud
Very quiet
Operation
Outdoors only
Outdoors only
Safe indoors
Maintenance
Scheduled servicing
Oil, filters, fuel care
Minimal
Best Suited To
Long outages with fuel access
Occasional short outages
Quiet, fuel-free backup
Battery backup works differently from fuel-burning generators because it stores electricity for later use. The EcoFlow DELTA Pro Ultra is one example designed for home backup, providing stored power without burning fuel during operation.
How Much Generator Power Does Your Home Need?
The right backup power generator for home capacity depends on essential appliances and their wattage. The table below provides a practical starting point for estimating your household power needs:
Appliance
Typical Running Watts
Typical Starting Surge
Refrigerator or Freezer
150 to 800W
Two to three times running
Lighting
60 to 100W per fixture
None
Internet and Router
Around 10 to 20W
None
Sump Pump
800 to 1,000W
2,000 to 2,500W
Furnace Blower
500 to 800W
Around 2,500W
Central Air Conditioner
Around 3,500W
Well Pump
700 to 2,000W
2,000W and upward
Kitchen Appliances
1,000 to 1,500W
Usually none
These figures offer a starting point because actual wattage varies by appliance and model. Natural Resources Canada’s energy-efficiency guidance provides additional information about household energy use. Always check each appliance label before calculating your total power requirement.
For accurate sizing, consider both an appliance’s running watts and starting watts. Once running, an appliance draws its regular wattage. Some appliances need an extra burst of power when they first switch on.
Which Fuel Type Is Best for a Home Backup Generator?
Fuel choice for backup power generators for home depends largely on local availability. Each option below brings different trade-offs in storage, runtime, cost, and convenience:
Factor
Natural Gas
Propane
Gasoline
Dual-Fuel
Availability
Piped supply only
Delivered and stored
Widely sold
Either source
Storage
None needed
On-site tank
Cans, limited shelf life
Depends on fuel used
Runtime
Effectively unlimited
Limited by tank size
Limited by cans on hand
Extended by switching
Long Outages
Strongest option
Good with a large tank
Weak, needs refueling trips
Flexible
Maintenance
Cleanest burning
Clean, stable in storage
Fuel degrades, needs care
Mixed requirements
No single fuel wins in every situation. Natural gas is the obvious choice on a serviced street, while propane suits rural properties without a gas line. Gasoline remains the default for portable units. Our comparison of gas vs solar backup generator covers the non-combustion alternative.
How Does a Standby Generator Power Your Home During an Outage?
The entire sequence happens automatically without anyone needing to operate the equipment. Once the utility supply drops out, the standby unit comes on automatically. The selected circuits keep receiving generator power until the utility supply comes back.
An automatic transfer switch controls this handoff without manual operation. It also isolates generator power from utility lines, helping protect crews restoring service. The Consumer Reports generator buying guide can help homeowners evaluate the best generator for home backup power.
Permanent standby installation requires electrical and fuel-system work that should follow local codes and manufacturer requirements.
Generator vs. Battery Backup for Home Power
This is the comparison most homeowners are actually weighing. Our detailed battery backup vs generator breakdown goes further than the summary below:
Factor
Generator
Battery Backup
Electricity
Generated on demand
Stored ahead of time
Fuel
Required continuously
None
Noise
Audible across the property
Near-silent
Exhaust
Carbon monoxide, outdoors only
None, safe indoors
Automatic Backup
With a transfer switch
Usually built in
Solar Integration
Not applicable
Charges directly from panels
Long Outages
Continues while fuel lasts
Limited by capacity and recharging
Maintenance
Regular servicing needed
Minimal
Expandability
Fixed at purchase
Capacity often modular
EcoFlow DELTA Pro Ultra as a Whole-Home Battery Alternative
Homeowners who prefer battery backup can consider the EcoFlow DELTA Pro Ultra. It stores electricity instead of burning fuel, avoiding combustion exhaust during normal operation. Power comes from stored electricity, so there is no fuel burning during use. That makes it a quieter option than a combustion backup power generator for home.
ecoflow delta pro ultraecoflow delta pro ultra
Storage starts at 6 kWh and can grow to 90 kWh with added capacity. Supported configurations deliver between 7.2 and 21.6 kW of output for home appliances. EcoFlow also supports several charging methods, including solar, grid, EV chargers, and generators.
Key Specs
  • EcoFlow specifies near-silent operation (0 dB claimed) below 2,000 W output.
  • Designed for indoor installation, with IP54 protection.
  • Accepts 5.6 to 16.8 kW of solar input.
Neither technology suits every outage. Fuel can extend a generator’s runtime, but batteries must recharge once their stored power runs low.
What Should a Home Backup Generator Keep Running?
Before sizing anything, work out what you would miss most when the power goes out:
  • Refrigerator and freezer, protecting stored food during extended outages.
  • Essential lighting throughout the main living areas.
  • Internet, router, and phone charging for essential communications.
  • Heating equipment compatible with your backup power system.
  • Sump or well pumps, especially on rural properties.
  • Medical equipment that cannot tolerate extended interruptions.
Comfort loads can increase power requirements considerably. Air conditioning, water heating, cooking, dryers, and EV charging add substantial demand. Generac’s home standby generator options distinguish between selected-circuit and whole-home backup. The best generator for home backup power should cover essentials before optional comfort loads.
What to Check Before Buying a Backup Generator for Home
The best generator for home backup power should match today’s loads without limiting practical future needs. Check these 8 factors before choosing a system:
  • Continuous and starting power against your calculated load.
  • Fuel availability at your address, not just regionally.
  • How long typical outages last where you live.
  • Whether you need essential circuits or whole-home coverage.
  • Transfer-switch requirements and their installation costs.
  • Where the unit can legally and practically operate.
  • Noise, particularly on smaller lots and in dense neighborhoods.
  • Warranty terms and availability of local service.
Your needs may change after the initial purchase. Solar or extra storage could matter later, making a system that accepts upgrades useful. Our home backup generator checklist covers what else to look at before buying.
Home Generator Installation and Safety
A backup power generator for home use requires careful placement, connection, and ventilation. Follow these essential safety practices:
  • Never run a fuel-burning generator indoors, in a garage or in any enclosed space.
  • Position portable units according to the manufacturer's clearance and ventilation requirements.
  • Connect backup power to household circuits only through approved transfer equipment.
  • Install carbon monoxide alarms inside the home and test them regularly.
  • Shelter the generator from weather without restricting its airflow.
  • Store fuel in approved containers, following applicable safety requirements.
Use a qualified professional for permanent electrical or fuel connections. Never plug a generator into a wall outlet because dangerous back-feeding can occur. Canada’s official generator and power outage safety guidance provides additional installation and operating precautions.
How to Prepare Your Backup Power System Before an Outage
Even the best generator for home backup power needs routine preparation before an outage occurs:
  • Run the system periodically rather than waiting for an outage.
  • Keep the required fuel on hand and safely stored.
  • Check oil and work through the scheduled maintenance items.
  • Confirm the transfer equipment operates as intended.
  • Review which household circuits actually receive backup power.
  • Keep the manufacturer's instructions somewhere you can find them.
Battery systems require a different routine. Check charge levels, review backup settings, and test any solar charging you rely on.
How Much Does Home Backup Power Cost?
The cost of a backup power generator for home involves more than the equipment itself. The table below breaks down the main expenses for generator and battery setups:
Cost Element
Generator Setup
Battery Setup
Rated output in kilowatts
Storage in kilowatt-hours
Equipment Type
Standby costs far more than portable
Scales with the number of units
Home Integration
Transfer switch required
Panel integration where fitted
Electrical Work
Wiring and panel connection
Fuel
Gas line or propane tank
None
Installation
Professional for permanent units
Professional for integrated systems
Permits
Electrical and often gas
Electrical
Ongoing Maintenance
Servicing, oil and fuel
Minimal
Expansion
Replace the unit
Add batteries or solar
A permanent standby installation costs well beyond the generator itself, once the transfer switch, electrical work, fuel connection and permits are added. Our comparison of home battery backup vs generator cost shows how the totals differ over time rather than at purchase.
Which Backup Power Setup Is Right for Your Home?
The best generator for home backup power depends on the loads and outage conditions you expect. Match your household needs to the most suitable setup below:
What You Need
Setup That Fits
Basic Emergency Essentials Only
Smaller portable generator or battery system
Frequent Short Outages
Automatic standby or integrated battery backup
Long Outages with Reliable Fuel Access
Standby generator
Quiet Backup Without Combustion
Home battery system
Existing or Planned Solar Panels
Compatible battery storage
Whole-Home Coverage
Sized standby generator or expandable battery
Some households want whole-home backup, later expansion, solar charging and automatic operation together. A system such as the DELTA Pro Ultra covers those requirements in one piece of equipment.
The best generator for home backup power should match essential loads, outage duration, fuel access, and installation needs. Work out how much power your essentials actually draw before choosing a system. Once you know the required wattage, the choice becomes easier to narrow down. Standby, portable, and battery setups each suit different homes. For quieter backup with capacity that can grow, EcoFlow is one option to consider.
1. Can a home generator run continuously for several days?
Standby units on natural gas can run for days, though manufacturers specify rest periods and oil checks during extended operation. Portable generators are limited by the fuel you can store and safely refill. Follow the manufacturer's guidance on continuous runtime rather than assuming indefinite operation.
2. How often should you exercise or test a standby generator?
Most standby systems run a self-test weekly or monthly on a set schedule. Beyond that cycle, an annual professional service covering oil, filters, and the transfer switch is usual. Portable units benefit from being started every few months, so fuel and components stay in order.
3. Can you install a home backup generator yourself?
Portable units need no permanent installation, but connecting a backup power generator for home to household circuits requires approved transfer equipment. Permanent standby systems involve electrical and fuel connections that generally require qualified professionals, permits, and inspections. Always check local requirements and warranty terms before attempting installation yourself.
4. Does a backup generator increase home value?
A permanently installed standby system is generally viewed as a desirable feature, particularly in areas with frequent outages. How much value it adds varies with the local market and buyer expectations. Portable generators are treated as equipment rather than as part of the property.
5. Can a generator damage sensitive electronics?
Conventional generators can produce fluctuating output that computers and other sensitive devices tolerate poorly. Inverter generators deliver cleaner power and are the safer choice for electronics. Battery systems supply consistent output by design, which is one reason households running medical or computing equipment often prefer them.
Home Backup
