Battery Backup: What Size Do You Need for Your Home?
A home battery provides time to keep selected loads operating during an outage. The right size depends on what must keep running, the backup duration you are planning for, and whether you need plug-in equipment or panel-level coverage. This article explains how to estimate energy needs in kWh and choose a practical battery backup for essential household loads.
What Factors Affect Your Home Battery Backup Needs?
Size comes down to the planned backup duration, the loads that must keep running, and whether the system can cover startup surge. A backup power supply needs enough stored energy for the desired runtime and enough inverter output to start connected motors and compressors.
Outage Duration and Frequency
Start with the duration you want the system to cover, since time turns watts into watt-hours. A short urban outage may require only Wi-Fi, a few lights, and phone charging. Rural or storm-prone locations may face harder access and more extensive damage, so planning for a longer interval or a secondary charging source may require more usable kWh.
Essential Appliances and Household Electricity Use
For most households, the first priorities are keeping food cold, staying connected, and lighting occupied rooms after dark. A sump pump keeping the basement dry or a furnace blower circulating warm air can add substantial output and runtime requirements. A household covering only a refrigerator and phones needs less capacity than one also running pumps, heating equipment, or a home office. Sump pump battery backup must be sized for the pump’s running watts, startup surge, and expected cycling time.
Seasonal Weather and Heating or Cooling Needs
Winter is where sizing mistakes show up. A gas or propane furnace burns fuel, but its blower, igniter, and control board still run on household electricity and often draw several hundred watts together while the furnace is running. A battery stored in an unheated garage or entryway may not perform as well, and the cold can limit charging.
Daily Electricity Consumption and Peak Loads
Whole-home electricity use varies widely with climate, heating fuel, household size, and appliances, and backing up every circuit is often unnecessary. Use utility bills, appliance labels, or measured circuit data to estimate daily watt-hours for essential loads. Then check peak demand from sump pumps, furnace blowers, well pumps, electric ranges, and dryers. When evaluating battery backup on a sump pump, include both surge output and cycling frequency. A portable power station may suit selected plug-in loads when its output and capacity match them.
EcoFlow TITAN 5000 Classic Whole-Home Backup PowerEcoFlow TITAN 5000 Classic Whole-Home Backup Power
How Do You Calculate the Battery Backup Size You Need?
A first estimate doesn’t need a formal load study. Write down what you want running, note each item’s running watts, and estimate how many hours it actually runs each day. Account for conversion losses when sizing the battery and startup demand when choosing the inverter.
Identify the Appliances You Need to Keep Running
Walk the house as you would on the first night without power, sorting must-haves from things you can live without:
  • Full-sized kitchen fridge or freezer
  • Router, modem, laptops, and phones
  • LED lights in the main living areas
  • Blower fan on a gas or propane furnace
  • Basement sump pump
Calculate Running Watts and Startup Power
Electrical appliances may have different running and startup demands. Running watts describe normal operation, while surge wattage describes the brief demand when some motors or compressors start. Steady loads such as LED lights and phone chargers have little startup surge, but refrigerators, sump pumps, and furnace fans may require more power at startup. Verify each appliance label or manual and size the inverter for the largest realistic simultaneous demand. The table below contains planning examples only.
Appliance
Running Watts
Starting (Surge) Watts
Daily Usage Profile
Kitchen Refrigerator
150 W – 200 W
800 W – 1,200 W
Cycles ~8 hours/day
Gas Furnace Blower
400 W – 600 W
1,200 W – 1,800 W
Intermittent (winter)
Sump Pump (1/3 HP)
700 W – 800 W
1,500 W – 2,200 W
Intermittent (rain/thaw)
Wi-Fi Router & Modem
15 W – 25 W
15 W – 25 W
Continuous (24 hrs)
LED Lighting (5 fixtures)
50 W
50 W
5 hours/evening
Laptop / Mobile Phones
60 W
60 W
As needed
Estimate How Many Hours of Backup You Need
Decide how long you want the selected loads to operate, using local outage history and utility information as planning inputs rather than guarantees. Home backup battery runtime depends on usable capacity, load, duty cycle, temperature, and surge events. For longer interruptions, add capacity or a secondary charging source, such as a compatible solar panel or generator, according to the system manufacturer’s instructions.
Calculate the Required Battery Capacity in kWh
Energy capacity is measured in watt-hours (Wh) or kilowatt-hours (kWh). Multiply each running wattage by actual run hours, then add the results.
Total Daily Watt-Hours=∑(Appliance Running Watts×Hours Run per Day)
That result is only a first estimate. Available energy may be lower after inverter losses, reserve settings, temperature effects, and battery-management limits. Apply the manufacturer’s usable-capacity and efficiency data, then include a planning margin appropriate to the household:
Planning Battery Capacity (kWh) = Total Daily Watt-Hours ÷ 1,000 × selected loss-and-reserve factor
Example: Using planning assumptions of a 150W refrigerator for 8 hours, a 500W furnace blower for 6 hours, 20W of Wi-Fi equipment for 24 hours, and 50W of lighting for 5 hours produces 4,930Wh before losses and reserve. Apply the specific system’s usable-capacity, efficiency, and reserve settings before selecting a battery.
An inverter may consume energy even when connected loads are small. Check the manufacturer’s idle-consumption specification and include it in longer runtime estimates. Turning off unused outputs and using supported standby or low-power modes can reduce this additional draw.
EcoFlow TITAN 5000 Plus Whole-Home Backup PowerEcoFlow TITAN 5000 Plus Whole-Home Backup Power
What Can Different Battery Backup Sizes Power?
Once your target kWh is settled, the next job is matching it to real outage use. Smaller systems may cover electronics and lights, mid-size systems may handle selected essentials, and larger systems can provide longer runtime or support selected high-power loads. A compatible solar panel may provide supplemental charging when weather, placement, and daylight permit.
Small Battery Backup for Essential Electronics (1 kWh – 3 kWh)
Units in this range are generally intended for portable electronics, lighting, networking equipment, and short disruptions. Actual runtime depends on usable capacity and the combined load. These smaller systems are less suited to prolonged operation of large heating appliances, pumps, or other heavy motor loads.
Medium Battery Backup for Refrigerators and Essential Devices (5 kWh – 10 kWh)
For households that want the everyday essentials covered, this is the range to start with, since it can keep the fridge cold, the Wi-Fi on, and the main rooms lit while basic home-office gear keeps running.
In this range, the EcoFlow TITAN 5000 Classic Whole-Home Backup Power fits households that mainly want to cover standard 120V essentials such as a refrigerator, Wi-Fi, lighting, a gas furnace blower, and small electronics. Its 5 kWh base capacity gives a practical starting point, while expansion batteries leave room to add runtime later if longer winter outages are a concern.
4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, and lighting all at once. 5–30kWh Expandable Capacity. Quiet enough for indoor use—quieter than a whisper.
Large Battery Backup for High-Power Appliances (15 kWh – 30+ kWh)
From 15 kWh up, the question is how much of the house keeps running normally, and for how many days. Systems in this range put some 240V equipment back in play, whether that’s a well pump, a compatible heat pump, or a major kitchen appliance, but only if inverter output, surge capacity, and panel integration have been sized for those loads.
How Do You Choose a Battery Backup for Your Home?
Capacity affects runtime but does not determine which loads can start. Inverter output, supported voltage, surge capability, and installation method also matter. A UPS battery backup may protect selected electronics from brief interruptions, while longer home backup requires capacity and output matched to the intended loads.
Match the System to Your Calculated Load
Whatever you buy has to cover the running watts of everything going at once and the surge those appliances could ask for together. If the gas furnace blower draws 1,500W at startup while the well pump kicks in at 2,500W, the inverter has to shoulder both at once without tripping.
Compare Portable and Whole-Home Backup
Portable setups are plug-and-play, so you can run an extension cord to the fridge, charge phones off the unit, and use low-draw heating options such as an electric blanket, without permanent installation. Whole-home systems connect to the breaker panel and feed the circuits you picked ahead of time, so you can use the lights and furnace on those circuits as usual, with no cords across the floor.
For backup across selected existing home circuits, the EcoFlow TITAN 5000 Plus Whole-Home Backup Power can be paired with a compatible 120V/240V Smart Home Panel 10 (SHP10). The panel can manage up to 10 pre-wired circuits, subject to system design and compatibility. Its transfer time is rated at up to 20 milliseconds for compatible loads, but device operation should be confirmed individually. Runtime depends on the selected circuits, active loads, battery capacity, and configuration. The integration of Smart Home Panel 10 requires professional installation that complies with provincial and local electrical requirements.
7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. 50% lower upfront cost. Smarter choice.
Evaluate Expansion Options for Future Needs
Household electricity needs can change over time. A heat pump might go in next fall, your next car might be an EV, or finishing the basement might mean adding a second sump pump. A modular platform with stackable packs lets you keep the inverter you paid for and add capacity, provided its output covers the additional loads.
Sizing a battery starts with the loads that must remain on and the duration they need to operate. A 5kWh system may be a starting point for some households, but measured loads, surge requirements, usable capacity, and backup goals determine the final size. Compatible panel-integrated systems can transfer selected circuits automatically when professionally designed and installed. Review the calculation before winter storms and again before spring thaw increases sump-pump use.
How long does a battery backup last when power goes out?
Runtime depends on usable battery capacity, the combined load, appliance duty cycles, temperature, inverter losses, and reserve settings. Estimate it from measured energy use rather than a universal hour range. High-wattage heating or cooking appliances can reduce runtime much faster than networking equipment, lighting, or intermittently cycling refrigeration.
Can a battery backup run a furnace?
A battery backup may run a natural-gas or propane furnace when its output, surge rating, voltage, waveform, and connection method match the furnace. Check the furnace nameplate and manufacturer instructions instead of assuming a fixed wattage. Hardwired equipment generally requires approved transfer equipment or panel integration installed by a qualified electrician, with grounding and neutral arrangements confirmed for the specific system.
How much does it cost to install a whole-home battery backup system?
Installed cost varies with battery capacity, inverter output, transfer equipment, panel condition, permits, labour, and site requirements. Obtain current written quotes from qualified installers and confirm that the proposed equipment and installation satisfy the applicable provincial electrical requirements.
How long will a 10kWh battery power a house?
A 10kWh battery does not have one fixed household runtime. Divide usable energy by the average combined load, then account for conversion losses, reserve settings, temperature, and appliance cycling. Refrigeration, networking equipment, lighting, pumps, heating, and cooking loads can produce very different results, so measure or verify the intended loads before relying on an estimate.
Home Backup
