Are Heat Pumps Worth It in Canada? A Fuel and Region Decision Guide
Heat pumps get a lot of attention in Canada right now. Ottawa announced a new national heat pump rebate in October 2026, and many homeowners are weighing an upgrade before winter. So, are heat pumps worth it in Canada? The honest answer depends on two things: the fuel you heat with today and where you live. This guide walks through cold weather performance, costs by fuel, current rebates, and regional fit. It also covers one point many buyers overlook. A heat pump runs on electricity, so it stops during a power outage.
How Do Heat Pumps Perform in a Canadian Winter?
Cold weather is the first worry for most Canadian buyers. Modern units handle far more cold than older models did. Performance still drops as the temperature falls, so it helps to know what to expect.
How a Heat Pump Moves Heat
A heat pump does not burn fuel. It pulls heat from the outdoor air or the ground and moves it inside. In summer, the same system runs in reverse to cool your home.
Ductless heat pump indoor unit mounted on a living room wallDuctless heat pump indoor unit mounted on a living room wall
Cold-Climate Models and COP at Low Temperatures
Efficiency is measured as the coefficient of performance (COP). A COP of 2 means two units of heat for each unit of electricity. Natural Resources Canada's Heating and cooling with a heat pump guide puts air-source COPs at 2.0 to 5.4 at 8°C. At minus 8°C, they range from 1.1 to 3.7.
NRCan's Heat Pump Basics pamphlet says cold-climate air-source models can work down to minus 30°C. Knowing how cold-climate models handle deep freezes helps you shortlist units for your region.
Backup Heat and Balance Points
Most Canadian installs still include backup heat. NRCan notes that newer air-source units cut out somewhere between minus 15°C and minus 25°C.
  • Electric backup: Resistance elements in the ductwork or baseboards.
  • Hybrid backup: An existing gas or oil furnace.
  • Thermal balance point: The temperature where the heat pump can no longer meet the full heating need.
Cold performance is only half the picture. For most households, the bigger question is money.
What Does a Heat Pump Cost and Save by Heating Fuel?
Savings are not the same for every home. NRCan says lower bills depend greatly on the price of electricity compared with other fuels. The table below gives a fuel-by-fuel starting point.
Fuel being replaced
How a heat pump compares
Typical verdict
Heating oil
Up to 3 times as efficient as an oil furnace or boiler, per NRCan (winter average)
Strong case in most homes
Electric baseboard or furnace
Up to 2 times as efficient as electric resistance heat, per NRCan
Strong case
Propane
No single NRCan figure; compare your local price per litre with your power rate
Often worth it
Natural gas
Heat pumps are the lowest-cost option in many Canadian Climate Institute modelled cases, but gas heating or a hybrid system can remain competitive in colder regions with low natural gas prices
Mixed; compare local electricity and gas rates
The federal National Heat Pump Rebate announcement estimates average savings above $1,400 a year for homes leaving oil, propane, or electric resistance heat. The running costs of electric baseboard heat add up quickly, which makes those homes a clear comparison point.
Upfront Costs to Plan For
Installed price varies by system type, home size, and ductwork. Get at least two written quotes and ask how each contractor sized the system.
  • Electrical upgrades: NRCan says panel and other upgrades can take as long as a year.
  • Air sealing and insulation: NRCan notes that fixing these first can allow a smaller heat pump.
Rebate Status as of November 2026
The Government of Canada's Canada Greener Homes Initiative page shows which federal programs have closed.
  • Canada Greener Homes Grant: Closed. December 31, 2025, was the last day to submit documents.
  • Canada Greener Homes Loan: Closed to new applications.
  • Oil to Heat Pump Affordability (OHPA): Federal intake for Alberta, Manitoba, Saskatchewan, Quebec and the Northwest Territories closed on July 31, 2026. Other provinces deliver it through local partners.
  • National Heat Pump Rebate: Announced October 8, 2026. It offers $2,000 for eligible homeowners and up to $10,000 for households below the median income.
  • Provincial programs: Ontario's Home Renovation Savings lists heat pump rebates up to $12,000. BC's Home Renovation Rebate offers up to $4,000 for whole-home heating.
News reports say the federal portal should open in early 2027, and installs from November 1, 2026, may qualify. Following the new federal heat pump rebate rules closely is wise until final details arrive.
Cost and rebates cover the financial side. One practical limit applies to every heat pump, however efficient.
Will a Heat Pump Keep Working During a Power Outage?
A heat pump runs on electricity, so it stops when the grid goes down. In a Canadian winter, that makes outage planning part of the "worth it" decision.
Why Outages Matter More With All-Electric Heat
A gas furnace also stops in an outage, since its blower needs power. All-electric homes, though, lose every heat source at once. Building a backup power plan for your heat pump before winter avoids rushed decisions.
What Backup Power for a Heat Pump Involves
A backup system needs enough output to start and run the heat pump.
  • Most central heat pumps are hard-wired on a 240V circuit, so plug-in setups cannot run them.
  • Runtime depends on load, and heat pumps draw more power in deep cold.
  • Electric backup strips may exceed what a battery can support.
Home Battery Options to Compare
The TITAN 5000 Plus suits larger homes backing up a heat pump circuit with other essentials. In EcoFlow's defined setup, it can start a 3-ton central AC without a soft starter.
EcoFlow TITAN 5000 Plus
1. 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. 2. 100% Whole-Home Savings. Save up to $1,100 per year. 3. Only 50% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle. 4. OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
The TITAN 5000 offers 120V/240V output at a lower starting price, plus generator charging for long outages.
EcoFlow TITAN 5000
1. 100% Whole-Home Backup. 7.2kW powers your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter needed. 2. 100% Whole-Home Savings. Save up to $1,000/year. 3. Only 50% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle. 4. OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
Plug-in devices run directly from either unit. A hard-wired heat pump and other home circuits need the compatible SHP10, installed by a qualified electrician. The SHP10 covers up to 10 selected circuits, not every appliance at once. Card savings figures are modelled Toronto estimates on Ontario's Ultra-Low Overnight plan and do not apply in other provinces.
With outages covered, the next question is where you live.
Which Canadian Regions Get the Most From a Heat Pump?
Climate and energy prices vary a lot across Canada. A heat pump that pays off quickly in one province may take longer in another.
Region
Climate and price factors
General outlook
Coastal BC
Relatively mild coastal winters; electricity and natural gas rates vary by utility
Strong potential for air-source heat pumps
Alberta and Saskatchewan
Very cold; higher power prices and cheap gas in many areas
Mixed; hybrids often win
Manitoba and Quebec
Cold; among the lowest electricity prices
Strong fit for baseboard homes
Ontario
Cold to moderate; time-of-use plans common
Good fit except some gas homes
Atlantic Canada
Moderate coastal winters; PEI among higher prices
Strong fit for oil homes
Price notes follow the Canada Energy Regulator's market snapshot on electricity prices, based on rates as of November 2025. The Canadian Climate Institute found heat pumps beat gas with AC in Montréal, Halifax, and Vancouver, even under worst-case assumptions. In Edmonton, gas or a gas hybrid was often cheaper. Checking electricity rates that vary by province shows how your plan could shift savings.
Region and fuel give most of the answer. The last step is weighing your own home.
When Is a Heat Pump Worth It, and When Is It Not?
No heating system suits every home. A heat pump makes sense when savings, comfort, and rebates outweigh the upfront cost.
Pros and Cons at a Glance
Pros
Cons
Heats and cools with one system
Higher upfront cost
Cold-climate models work to minus 30°C
Stops in a power outage
Weighing the benefits and downsides of heat pumps against your fuel and budget makes the choice clearer.
It Is Likely Worth It If You
  • Heat with oil, propane, or electric baseboards.
  • Need to replace an old furnace or AC soon.
  • Qualify for the federal rebate or a provincial program.
Family relaxing under a blanket in a warm living room in winterFamily relaxing under a blanket in a warm living room in winter
It May Not Be Worth It Yet If You
  • Have a newer gas furnace and low gas prices.
  • Need envelope work or a costly service upgrade first.
  • Live in a remote area with very high power costs.
An EnerGuide evaluation from a registered energy advisor can help confirm the numbers.
Heat pumps are worth it in Canada for many homes, but not for every home. The strongest cases are homes leaving oil, propane, or electric baseboards. Homes on low-cost natural gas need a closer look at local prices. Check rebate timing, get a proper sizing, and plan for outages. To keep selected circuits running during an outage, compare the EcoFlow TITAN 5000 or TITAN 5000 Plus with the compatible SHP10.
Is a heat pump worth it if I already have natural gas?
It depends on local prices. Where gas is cheap, as in much of Alberta, a hybrid that keeps your furnace as backup often wins.
Do heat pumps work at minus 30°C?
Cold-climate models can, according to NRCan. Efficiency is lower at that point, so very cold regions usually keep backup heat.
Can I still get a federal heat pump grant?
Not from the Greener Homes Grant or Loan, which are closed. OHPA federal intake also closed in July 2026. The new National Heat Pump Rebate is expected to open in early 2027.
How long does a heat pump last?
NRCan says air-source heat pumps last 15 to 20 years. Ground-source units usually last 20 to 25 years, and the ground loop itself can approach 75 years.
Can a home battery run my heat pump during an outage?
It can with enough 240V output and a compatible panel installed by a qualified electrician. The TITAN 5000 and TITAN 5000 Plus back up selected circuits this way, with runtime depending on load.
Home Solutions
