Understanding Wattage and Amperage in Your Canadian Home
Ever wondered why the kettle and the toaster trip the breaker when they run together? The answer comes down to wattage and amperage. Watts tell you how much power a device uses. Amps tell you how much current flows through the wire to deliver it. In Canadian homes, most outlets run at 120 volts, while big appliances like dryers use 240 volts. Once you understand how these numbers connect, you can avoid overloaded circuits and choose backup power that fits your home.
Volts, Amps, Watts and kWh in Plain Language
Electrical labels can look like alphabet soup. The good news is that four terms explain almost everything. Picture electricity as water moving through a garden hose.
Unit
Symbol
What it measures
Water analogy
Volt
V
Electrical pressure that pushes current
Water pressure in the hose
Amp
A
How much current flows
How much water moves through the hose
Watt
W
The rate of power being used
How much work the water does, like spinning a wheel
Kilowatt hour
kWh
Energy used over time
The total water that flowed through in an hour
Watts and amps are linked, but they are not the same thing. Amps describe flow. Watts describe the power that flow delivers at a given voltage.
Kilowatt hours add time to the picture. A 1,500 W heater running for four hours uses 6 kWh. Your utility bills you for kWh, not watts. Understanding the difference between power and energy makes your hydro bill much easier to read.
Canada's EnerGuide labels also list yearly energy use in kWh. Natural Resources Canada's EnerGuide appliance page explains how to use that number to compare fridges, washers, dryers and other major appliances.
With these four terms in hand, the next step is the formula that ties them together.
The Wattage and Amperage Formula With Canadian Examples
One simple formula connects amperage and wattage. It works for most household math, as long as you use the right Canadian voltage.
The Basic Formula
  • Watts = Volts x Amps
  • Amps = Watts ÷ Volts
  • Volts = Watts ÷ Amps
Canadian homes run on 60 Hz alternating current. Most standard outlets supply 120 volts. Larger appliances, such as dryers, ranges and central air, use 240 volts. Some online calculators default to 230V, the UK and European standard, so their answers won't match a Canadian home.
Worked Examples at 120V and 240V
Here is how the formula plays out with everyday appliances. Wattages are typical figures, so always check your own appliance label.
  • Electric kettle, 1,500 W at 120V: 1,500 ÷ 120 = 12.5 amps.
  • Portable space heater, 1,500 W at 120V: also 12.5 amps.
  • Toaster, 900 W at 120V: 7.5 amps.
  • Clothes dryer, 5,000 W at 240V: about 20.8 amps.
Notice the dryer. At 120V, the same 5,000 W would need about 41.7 amps. Doubling the voltage cuts the current in half for the same power. That is why heavy appliances use 240V circuits. Working through converting volts to watts by hand gets easier once these examples click.
Watts to Amps Conversion Table
Wattage
Amps at 120V
Amps at 240V
500 W
4.2 A
2.1 A
1,000 W
8.3 A
4.2 A
1,500 W
12.5 A
6.3 A
2,000 W
16.7 A
8.3 A
3,000 W
25.0 A
12.5 A
5,000 W
41.7 A
20.8 A
Figures are rounded to one decimal and assume a power factor of 1.
A Quick Note on Power Factor
The basic formula is exact for resistive loads like kettles, toasters and baseboard heaters. Appliances with motors or compressors behave a little differently. Their real power can be lower than volts times amps suggests.
The gap is called power factor. For these devices, real watts = volts x amps x power factor. So a fridge may draw more amps than its wattage implies, and the label beats your math.
Now that the math is clear, it is easier to see why output and voltage both matter when choosing backup power.
Why Output and Voltage Matter When Choosing Home Backup Power
Backup power systems are rated in the same units you just learned. Two numbers matter most: how many watts the system can deliver, and at what voltage. Comparing two home battery models shows why.
A backup system's output rating caps how many appliances can run at once. Its voltage decides which appliances it can run at all. A 120V-only system cannot power a 240V dryer or well pump, no matter how large its battery is.
Battery capacity in kWh is a separate number. It affects how long things run, not how much can run together. Sizing a battery for your home starts with separating these two ideas.
The TITAN 5000 Plus delivers 7.2 kW from the battery at 120V and 240V, reaching 10 kW only with compatible solar. Added battery capacity extends its runtime without raising output.
EcoFlow TITAN 5000 Plus
•100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $1,100 per year. • Only 50% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
The TITAN 5000 Classic provides up to 4,000W of rated AC output at 120V. Dividing 4,000W by 120V gives an equivalent current of about 33.3A across the total output, but this does not mean a single outlet can supply 33A. Check the rating of each outlet and the system's total output limit. The Classic is a 120V system and cannot directly power 240V appliances.
EcoFlow TITAN 5000 Classic
•4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. •5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <30 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don’t even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
Both models run plug-in devices directly. Home circuits and hard-wired appliances need the compatible SHP10 panel, installed by a qualified electrician. The Classic uses the 120V SHP10, and the 5000 Plus uses the 120V/240V version. SHP10 covers up to 10 selected circuits, not every appliance at once. Keep units indoors in a dry spot.
Knowing a system's limits is only half the job. The other half is knowing what your own appliances and circuits draw.
Reading Appliance Labels and Breaker Limits
Every appliance and breaker in your home carries its own rating. Reading them helps you avoid nuisance trips and gives you accurate numbers for backup planning.
Where to Find the Rating
Most appliances have a nameplate or sticker on the back, bottom or inside the door. It usually lists volts, amps, watts, or a mix of these. If only two values appear, use the formula to find the third. Chargers and adapters may list maximum input current rather than typical operating current, so actual consumption can be lower.
Some appliances surprise people. Knowing how much electricity space heaters use helps explain why one heater can fill most of a circuit.
Kitchen counter with a kettle, coffee maker and other small appliancesKitchen counter with a kettle, coffee maker and other small appliances
What Your Breakers Can Handle
Each breaker in your panel is marked with an amp rating. Multiply it by the circuit voltage to see its maximum wattage.
Circuit
Maximum
80 percent guideline
15 A at 120V
1,800 W
1,440 W (12 A)
20 A at 120V
2,400 W
1,920 W (16 A)
30 A at 240V
7,200 W
5,760 W (24 A)
Many electricians suggest keeping loads that run for hours to about 80 percent of the breaker rating. This leaves a margin for heat buildup. The Canadian Electrical Code applies an 80 percent limit to continuous loads on standard breakers. Its definitions vary by installation, so ask a licensed electrician about specific circuits.
Common Overload Situations
  • A 1,500 W kettle and a 900 W toaster together draw about 20 amps, well over a 15 amp circuit.
  • Two 1,500W space heaters on the same 120V circuit would draw about 25A in total, exceeding the rating of a typical 15A circuit.
  • Technical Safety BC notes that most 120V power bars are rated for a maximum of 12 amps.
  • High-draw devices like heaters should never run through power bars or extension cords.
The Health Canada electrical product safety page gives the same warning about plugging portable heaters into power bars. A breaker that trips again and again is a warning sign. Repeated resets can be a fire hazard, so call a licensed electrical contractor instead.
Running watts tell only part of the story. Motors add one more twist when you plan for an outage.
Starting vs Running Watts and Sizing Your Backup Power
Some appliances need a burst of extra power just to get going. This is called starting or surge wattage. It is a common reason a backup system trips when a fridge or pump kicks on.
Running Watts vs Starting Watts
Running watts are what an appliance uses during normal operation. Starting watts are the short spike when motors and compressors switch on. Fridges, sump pumps and well pumps are common examples, and your backup system must handle that surge.
Resistive appliances like kettles and heaters have little or no surge. Their starting and running watts are about the same.
Hand plugging a cord into a wall outletHand plugging a cord into a wall outlet
A Simple Five-Step Sizing Method
  1. List your essentials. Think fridge, furnace blower, lights, router, sump pump and phone chargers.
  2. Note the running watts. Use labels first, and convert amps to watts at the right voltage.
  3. Add up running watts. This total must stay under the system's continuous output.
  4. Add the largest starting surge. Not every motor starts at once, so add only the biggest one.
  5. Check voltage and runtime. Confirm 240V support if needed, then multiply watts by hours to estimate kWh.
The same steps apply to fuel generators. Matching generator size to your appliances follows the same running and starting watt logic.
Quick Example
Say you want to run a fridge, furnace blower, lights and a router during a winter outage. Their running watts might total around 1,200 W. The fridge compressor adds a short surge at startup. A 120V system with enough output can handle this mix. Adding a 240V well pump means you need 240V output and more headroom.
Wattage and amperage are two views of the same power. Watts show what an appliance uses, and amps show the current it pulls at a set voltage. In Canada, that means 120V for most outlets and 240V for heavy appliances. Read labels, respect breaker limits, and count starting surges. If you are planning home backup, EcoFlow TITAN models offer a useful way to match output and voltage to what your household really needs.
Is Wattage or Amperage More Important?
Both matter for different reasons. Wattage tells you how much power a device uses. Amperage tells you whether a circuit, cord or breaker can carry it safely.
How Many Watts Can a 15 Amp Circuit Handle in Canada?
A 15 amp, 120V circuit can handle up to 1,800 W. For loads that run for hours, aim to stay near 1,440 W.
How Many Amps Does a 1,500 Watt Heater Draw?
At 120V, a 1,500 W heater draws about 12.5 amps. That leaves little room for anything else on a 15 amp circuit.
Why Do Some Appliances Use 240 Volts?
Higher voltage delivers the same power with less current. That allows heavy appliances like dryers and ranges to use practical wire sizes.
Does a Bigger Battery Mean I Can Run More Appliances at Once?
No. Battery capacity in kWh affects how long things run. The output rating in watts decides how much can run at the same time.
Home Solutions
