How to Choose a Deep Well Pump for Your Canadian Home
About 4 million people in Canada rely on a private well for their drinking water, according to Health Canada. For many rural homes and cottages, the deep well pump is the only link between the aquifer and the kitchen tap. Choosing the right one takes more than picking horsepower. This guide compares the main pump types and explains why power supply matters so much. It also covers how to size a pump for your well, solar and off-grid options, and simple care tips for Canadian winters.
Deep Well Pump Types: Submersible vs Deep Well Jet Pumps
The depth of your well decides which pump type will work. Most drilled wells in Canada are deep enough to need a deep well pump. Dug wells are the usual exception.
The Government of New Brunswick notes that drilled domestic wells often range from 100 to 200 feet deep. Dug wells are usually only 10 to 30 feet deep. That difference is why two neighbours can need completely different pumps.
Pump type | Typical depth | Where it sits | Pros | Cons |
Shallow well jet pump | Up to about 25 ft | Above ground | Easy access for service | Not for deep wells |
Deep well (convertible) jet pump | About 25 to 90 ft | Above ground | Serviceable without pulling the pump | Louder, needs priming, uses more power |
Submersible pump | About 25 ft to 300 ft and beyond | Inside the well casing | Quiet and efficient | Harder to service |
These depth ranges are typical industry guidance, not fixed rules. Always check the manufacturer's rating for the exact model.
Both kinds of deep well pumps work with a pressure tank and a pressure switch. Together, these start and stop the pump as you use water.
A jet pump pulls water up by suction from the surface. A submersible pushes it up from below the water line, which is why it copes with greater depths. Power use differs as well. In practice, how many watts a well pump uses depends heavily on the pump type and its horsepower.
Choosing the right pump type is only half the job. A deep well pump is only as reliable as the power behind it.
Why a Deep Well Pump Needs Reliable Power
An electric well pump stops the moment the power goes out. For rural homes, that can mean no running water, no flushing toilets and no pressure in the system. It can also affect water safety.
Health Canada explains that the pump keeps the water system under pressure, and that pressure helps keep contaminants out. Its guidance on well safety during emergencies says not to open faucets, shower or flush during an outage. Once power returns, let the water run for a few minutes to flush the lines.
Health Canada also advises testing the water before use if the system loses all of its pressure.
Electrical requirements are just as important when selecting a deep well pump. Residential submersible motors come in 115 V and 230 V versions, and many deep well pumps above 1/2 HP run on 230 V. Motors also draw far more current for a moment at start-up.
Motor size (230 V) | Maximum load amps | Starting (locked-rotor) amps |
1/2 HP | 6.0 | 32.2 |
3/4 HP | 8.0 | 40.7 |
1 HP | 10.4 | 48.7 |
1.5 HP | 13.1 | 66.2 |
These figures come from Franklin Electric data for 4-inch, 230 V single-phase motors. Starting current is roughly five times the running current. Any backup source has to handle that brief surge, not just the steady load.
That surge is the number most people overlook. In short, starting versus running watts for pumps decide what size of backup power will actually start the motor.
The EcoFlow TITAN series is a home battery backup option with 120 V/240 V split-phase output. Whether it suits a particular pump depends on the motor's starting requirements and on how the pump is wired. A qualified electrician should confirm both.
The automatic switchover applies only with the Smart Home Panel 10, and only to circuits selected for backup. It cannot guarantee that every pump will run without interruption. The standard EcoFlow TITAN offers the same split-phase output with a smaller solar input.
With the power question covered, the next step is sizing the pump itself so it matches your well and your household.
How to Size a Deep Well Pump
An oversized pump wastes power and cycles too often. An undersized one leaves you with weak pressure at the tap. Sizing comes down to a few measurements, and your well record lists several of them.
Well depth and water level: These tell you how far the pump must lift water. The pump is set below the water level, not at the bottom of the well.
Flow rate (GPM): Base it on the number of fixtures and people in the home. The well's own yield sets the upper limit.
Total dynamic head: This is the total workload on the pump. It adds the vertical lift, the friction in the pipes and the pressure your system needs.
Horsepower: Most homes use pumps in the 1/2 to 1.5 HP range. More depth or more demand pushes that number up.
Casing diameter: A 4-inch casing fits most residential submersible pumps.
Voltage and wiring: Motors are 115 V or 230 V, and either 2-wire or 3-wire. A 3-wire motor uses a separate control box above ground.
Pressure tank: A larger pump may need a larger tank to prevent short cycling.
Replacing an old pump is simpler. WAYNE Pumps advises choosing the same horsepower and voltage, unless your water needs have changed. A new bathroom or a larger household may justify stepping up.
Pump ratings can be confusing, because some are listed in horsepower and others in watts. A quick calculation helps here, and converting horsepower to watts makes it easier to match a pump with a power source.
For cottages and off-grid properties, the power source can shape the pump choice as much as the well itself.
Solar and Off-Grid Options for Deep Well Pumps
Not every well has a reliable grid connection nearby. Solar options have made deep well water possible in remote spots. There are two main ways to set one up.
DC solar well pumps: These run directly from solar panels, often filling a storage tank. They pump mostly during daylight, so the tank carries you through the night.
AC pumps with solar and battery storage: A standard deep well water pump runs from a battery system. The battery stores solar power, so water is available at any hour.
Canadian conditions shape the design. Winter days are short, and snow can cover panels for days at a time. Storing extra water or extra power is what gets a property through a cloudy stretch.
Sizing matters even more off the grid. A smaller, efficient pump that runs longer is often easier to power than a large one working in short bursts.
The pump is only one part of the setup. A wider look at off-grid solar power systems explained in plain terms covers the panels, batteries and inverters a pump relies on.
Whatever powers your pump, a little routine care keeps it running for years.
Deep Well Pump Care, Winter Protection and Water Testing
A deep well pump can last many years, but Canadian winters and dry running are hard on it. Water quality needs regular attention too. A few habits cover most of the risk.
Winter protection: Keep water lines below the frost line. Use a frost-protected pitless adapter, and insulate exposed pressure tanks and pipes.
Pump protection: Avoid running the pump dry. Dry-run or low-water protection is worth considering on low-yield wells.
Warning signs: Sputtering taps, low pressure, constant cycling or a higher power bill all deserve a closer look.
Water testing: Health Canada's well water testing advice is to test bacteria at least every 6 months. General water quality should be tested every 2 years.
Responsibility sits with the owner. In Ontario, for example, provincial rules for wells on your property require owners to protect their well water from contamination. Unused wells must be plugged and sealed.
Keep a copy of your well record with the pump's model, depth setting and voltage. It saves time when you need to call a contractor.
Outages are the other seasonal risk. Planning for running well pumps during winter outages is far easier before the first storm than during it.
Well depth decides the pump type. Sizing depends on flow, head and voltage, and reliable power keeps the water flowing. Measure your well, size the pump to your household, protect it from frost and test your water on schedule. For backup power, the EcoFlow TITAN Plus and EcoFlow TITAN provide 240 V output for a compatible deep well pump. Ask a qualified electrician to confirm the fit for your motor before you rely on it.
What is the difference between a submersible and a deep well jet pump?
A submersible pump sits inside the well casing and pushes water up. A deep well jet pump sits above ground and draws water up with an ejector assembly. Submersibles are quieter and reach greater depths.
How deep does a well need to be for a deep well pump?
Shallow well jet pumps typically work to about 25 feet. Beyond that, you need a deep well jet pump or a submersible. Check the manufacturer's rating for your exact depth.
What size deep well pump do I need?
It depends on your well depth, water level, required flow rate and total dynamic head. Most homes use pumps between 1/2 and 1.5 HP. A licensed well contractor can size it from your well record.
Do deep well pumps need 240 V power?
Many do. Residential submersible motors come in 115 V and 230 V versions, and many pumps above 1/2 HP run on 230 V. The motor nameplate or control box confirms which you have.
How long does a deep well pump last?
There is no single figure. Lifespan depends on water quality, how often the pump cycles, and whether it ever runs dry. A correctly sized pump with a suitable pressure tank generally lasts longer.
Can I run a deep well pump on battery backup during a power outage?
Yes, if the backup can supply the pump's voltage and starting surge. The EcoFlow TITAN Plus and EcoFlow TITAN provide 120 V/240 V split-phase output. Have an electrician confirm compatibility and install the connection.
