Why Is My Furnace Not Working? A Troubleshooting Guide for Canadian Homes
Space heating accounts for 63.6% of the energy used in the average Canadian home, according to Natural Resources Canada. A furnace not working in January is more than an inconvenience. The good news is that many causes are simple to check, such as a thermostat setting, a tripped breaker or a clogged filter. This guide covers the quick checks to try first and the less obvious furnace issues. It also explains how power outages affect your heat, which warning signs matter, and when to call a technician.
Quick Checks When Your Furnace Stops Working
Before you book a service call, a few safe checks can solve the problem in minutes. None of them involve opening the furnace or touching gas equipment. Anything on the gas side belongs to a licensed technician.
Symptom | Likely cause | What to check |
No heat at all | Thermostat or power | Heat mode, setpoint, batteries, furnace switch and breaker |
Blowers run but the air is cold | Fan set to On, or an ignition or gas supply problem | Set the fan to Auto. If the air stays cold, call a technician |
Weak airflow | Dirty filters or blocked vents | Replace the filter and clear the supply and return vents |
Furnace won't restart after a reset | Startup delay or safety lockout | Wait a few minutes and check that the front panel door is closed |
Thermostat: Confirm it is in Heat mode. Set it a few degrees above room temperature, and replace the batteries if the screen is dim or blank.
Power: Check the furnace service switch, which often looks like a light switch. Then check the breaker panel for a tripped breaker.
Filter: A clogged filter restricts airflow and can trigger a safety shutoff. Swap it for a clean one of the same size.
These checks are easier to follow with a basic picture of the system. Knowing how your home's HVAC system works helps you tell a thermostat problem from an airflow problem.
If every setting looks right and the house has no power at all, the furnace itself may not be the problem.
When a Power Outage Is Why Your Furnace Stopped Working
Most gas furnaces still need electricity to run. The blower, igniter and control board all stop when the power goes out. That means many homes lose heat in a winter outage, even when the gas supply is fine.
The electrical load is smaller than many people expect. In a National Research Council Canada study, a standard furnace blower drew about 490 W in heating mode. A high-efficiency ECM motor drew about 284 W. The nameplate on your own furnace gives the figure that counts.
Safety comes first with any backup power. Never feed a furnace by plugging a generator into a wall outlet. Connections to home circuits must follow the electrical code and be done by a qualified electrician.
Sizing matters as well. A portable power station for a gas furnace needs enough output for the blower's startup surge, not just its running draw.
The EcoFlow TITAN series is a home battery option for backing up the furnace circuit and other priority loads. How well it suits your furnace depends on the model and on how the furnace is wired.
That automatic switchover needs context. It happens only when the EcoFlow TITAN Plus is paired with the Smart Home Panel 10. The furnace must also be on a compatible circuit that has been selected for backup.
Even then, no backup system can promise that every furnace will keep running without interruption. Furnace controls differ from model to model. Ask a qualified electrician to confirm the setup for your equipment.
The EcoFlow TITAN Classic is the 120 V entry model in the series.
Check two things before counting on it for heat. The first is your furnace's power rating, including the blower's startup draw. The second is how the furnace is connected.
Many gas furnaces are hardwired and cannot simply be plugged into a battery. To back up a compatible 120V furnace circuit with EcoFlow TITAN Classic, pair it with the compatible 120V Smart Home Panel 10. A qualified electrician must confirm the furnace’s running and startup requirements and install the system in accordance with local codes.
Common Furnace Issues Behind a No-Heat Call
Modern furnaces have several safety parts that shut the system down when something is off. You do not need to fix them yourself. Knowing them helps you describe the problem clearly to a technician.
Ignition problems: A failed hot surface igniter, or a pilot light that will not stay lit.
Dirty flame sensor: The furnace lights, then shuts off after a few seconds.
Blocked exterior vents: Snow or ice can cover the intake or exhaust pipes on a high-efficiency furnace. Health Canada advises checking vents for blockages after snowstorms.
Clogged condensate drain or pump: High-efficiency furnaces shut down when water cannot drain.
Tripped limit switch: Overheating from poor airflow causes the furnace to short cycle.
Blinking error codes: The control board light flashes a code, usually explained on the furnace door panel.
Blower motor or belt failure: The burner runs, but little air moves through the vents.
Snow-covered vents are most likely during a deep freeze. Preparing your home for a cold wave should include clearing the furnace intake and exhaust after every storm.
Some furnace issues are more than an inconvenience. A few warning signs mean you should stop troubleshooting and get to safety.
Safety Warning Signs: Gas Smells and Carbon Monoxide
A malfunctioning furnace can release carbon monoxide, which you cannot see or smell. Health Canada notes it can only be detected with a carbon monoxide alarm. The signs below mean you stop troubleshooting right away.
Rotten egg smell: Leave the home. Call your gas utility or 9-1-1 from outside.
CO alarm sounding: Get everyone out immediately. Call 9-1-1 from outside the building, as Ontario's carbon monoxide safety guidance directs.
Symptoms of exposure: Headaches, nausea, dizziness, confusion and drowsiness can all point to carbon monoxide.
Alarm placement: Install CO alarms next to sleeping areas. In Ontario, updated requirements effective January 1, 2026, require CO alarms on every storey of applicable homes, in addition to those near sleeping areas. Requirements vary by province and territory, so check your local rules.
Outages raise the risk, because people improvise heat. Advice on staying safe and warm through outages starts with never running outdoor fuel-burning equipment inside the home.
Once any safety risk is ruled out, the last step is knowing when to call a professional. A little prevention then helps you avoid the next breakdown.
When to Call a Technician and How to Prevent Furnace Issues
Some repairs need a licensed gas technician. Regular care prevents many mid-winter failures. Knowing which is which saves both time and money.
Call a professional when any of these happen:
The breaker keeps tripping, or the furnace short cycles.
You hear banging or grinding, or you smell burning.
Water pools around the unit.
The same error code keeps coming back.
A short prevention checklist covers most of the rest:
Replace or clean filters regularly. Many manufacturers suggest every one to three months.
Book regular servicing. Natural Resources Canada says gas and propane furnaces should be serviced at least every two years, and oil furnaces every year.
Consider a yearly visit. Health Canada's carbon monoxide guidance recommends a professional inspection of fuel-burning appliances at least once a year.
Keep exterior vents clear of snow and ice all winter.
Test CO alarms, and replace them at the end of their lifespan.
While you wait for a repair, safe electric heat can keep one or two rooms comfortable. Budget for it, because space heater electricity use adds up quickly if the repair takes several days.
Most cases of a furnace not working start with the thermostat, power, filter or vents. Many are quick to check safely. Work through the quick checks, watch for gas and carbon monoxide warning signs, and book maintenance before winter. For winter outages, the EcoFlow TITAN Plus and EcoFlow TITAN Classic can back up a compatible furnace circuit and other essentials. Have a qualified electrician confirm the right setup for your home.
Why is my furnace running but not blowing hot air?
The fan may be set to On, which runs the blower between heating cycles. Switch it to Auto. If the air stays cold, an ignition or gas supply problem is likely, and that needs a technician.
How do I reset my furnace?
Follow your owner's manual. In most cases, you turn the furnace off at its service switch, wait a few minutes and turn it back on. If it locks out again, stop and call a technician.
Why does my furnace turn on and then shut off?
A dirty flame sensor is a common cause when the burner lights and quits within seconds. Overheating from a clogged filter can also trip the limit switch.
Can a dirty filter stop a furnace from working?
Yes. A clogged filter restricts airflow, which can overheat the furnace and trigger a safety shutoff. Replace it and see whether normal operation returns.
Does a gas furnace work during a power outage?
Usually not. Most gas furnaces need electricity for the blower, igniter and control board. Backup power can help, but only when it is correctly connected to a compatible furnace circuit.
How often should a furnace be serviced in Canada?
Natural Resources Canada says gas and propane furnaces should be serviced at least every two years, and oil furnaces every year. Health Canada recommends a yearly professional inspection of fuel-burning appliances.
