What Is Blowing Snow? Causes, Risks and Safety Tips
Some of the most treacherous driving conditions of a Canadian winter arrive under a perfectly clear sky. Blowing snow is a fact of life across the Prairies, open country, and any region exposed to strong winds. It can cut visibility in seconds, sculpt hard drifts across a highway, and make an ordinary drive dangerous long after the last flake has fallen. This guide walks through what blowing snow actually is, what sets it off, where it hits hardest, and what to do when the weather closes in.
If you are asking what is blowing snow, the key point is that it is a wind-driven visibility hazard rather than simply new snowfall. Weather reports distinguish it from falling snow and blizzards because each condition can create different travel risks.
Blowing Snow Definition
Blowing snow is snow lifted from the ground by wind to a height that reduces horizontal visibility at eye level. It differs from drifting snow, which stays close to the surface and usually does not reduce eye-level visibility as severely. Conditions can deteriorate even under a clear sky.
Blowing Snow vs. Falling Snow
What separates the two is where the flakes come from:
Falling snow is active precipitation on its way down from a cloud. On a calm day it descends more or less straight, so apart from a gentle haze your sightlines stay largely intact.
Blowing snow is a wind event. Strong gusts scoop up snow that has already settled and drive it sideways across rooftops, fields, and highways.
That is why you can still get intense blowing snow under brilliant winter sunshine, even hours or days after a storm has passed.
Blowing Snow vs. Blizzard: What’s the Difference?
Blowing snow is a hazard caused by wind lifting snow from the ground, while a blizzard describes a more severe combination of strong winds and widespread low visibility. Canada’s current public-alert system focuses on expected impacts and forecast confidence, so local alert details should guide travel decisions.
Criterion | Blowing Snow | Blizzard |
Snow Source | Ground snow lifted by wind (may occur without new snowfall) | Falling and/or blowing snow |
Wind Speed | Varies with snow conditions and exposure | Strong winds with widespread low visibility |
Visibility | Can fall sharply, including whiteout conditions | Widespread severely reduced visibility |
Duration Requirement | Assessed through current impact-based alert guidance | Assessed through current impact-based alert guidance |
Temperature / Wind Chill | Any freezing temperature | Often accompanied by dangerous wind chills |
What Causes Blowing Snow?
Blowing snow needs two main ingredients: wind strong enough to move snow and a loose, uncrusted surface. Blown snow becomes more likely when recent powder remains dry and exposed.
Strong Winds and Loose Snow
Strong winds can pick up loose snow from the ground and carry it across open country, which is why highways, farm fields, and other exposed ground see it first. What stops it is a crust: a thaw-and-refreeze cycle or a few hours of strong sun can seal the surface so that even a gale slides over it.
Why Cold, Dry Snow Blows More Easily
Short of a crust, how easily a snowpack takes flight comes down to its moisture content:
Wet, heavy snow (the kind that typically falls around 0°C) holds liquid water that glues the flakes into a dense pack the wind can’t get a grip on.
Cold, dry powder (falling at -10°C or colder) is made of delicate, low-density crystals that barely stick to one another, so even a modest gust can peel it off open ground and throw it into the air.
Ground Blizzards and Blowing Snow Without Falling Snow
A ground blizzard occurs when strong winds lift enough snow from the ground to create blizzard conditions even without new precipitation. The sky may be clear above the blowing snow while visibility near the surface becomes severely restricted.
Why Is Blowing Snow Dangerous?
Blowing snow turns dangerous the moment strong winds cut visibility and shove snow across driveways, roads, and other exposed ground. Driving is generally the biggest worry, though snow drifts and wind chill bring problems of their own.
Reduced Visibility and Whiteout Conditions
Once snow is blowing around at eye level, you lose the road edges, the lane markings, and the horizon itself. In a total whiteout, depth perception vanishes: sky, road, and ditch merge into one featureless white wall, and there is no way to tell whether you are tracking straight or wandering toward the shoulder.
Snow Drifts and Blocked Roads
Wind rarely lays snow down evenly. It scours exposed areas and packs snow into dense drifts across driveways, bridge approaches, and low-lying stretches of road. In open country, those drifts can strand vehicles and slow snow-clearing equipment, so conditions may remain hazardous after visibility improves.
Driving Risks During Blowing Snow
What makes blowing snow so hazardous is that a road can look perfectly clear one moment and vanish the next. Visibility can collapse within seconds, drifted snow and patchy ice may cut traction, and sudden gusts push semis and other high-profile vehicles out of their lane. Together, poor visibility and reduced grip leave drivers little room for error.
Wind Chill and Exposure Risks
Wind removes the thin layer of warm air next to exposed skin, increasing the risk of frostbite and hypothermia. Environment and Climate Change Canada classifies wind chills from -28 to -39 as high risk, when exposed skin can freeze in 10 to 30 minutes. A stranded driver or anyone clearing drifts should cover exposed skin and limit time outdoors.
What to Do During Blowing Snow
If blowing snow is in the forecast, check conditions before leaving and avoid unnecessary trips when visibility is poor. Prepare at home as well in case winter weather interrupts electricity; portable power stations can support selected plug-in essentials when used within their rated limits.
Check Weather Alerts Before You Travel
Before heading out, check Environment and Climate Change Canada’s public weather alerts and your provincial road-conditions service, such as Ontario 511, Alberta 511, or DriveBC. A winter storm warning in Canada may cover blowing snow, heavy snowfall, freezing rain, or dangerous wind chill, so read the alert details and postpone non-essential travel when conditions are hazardous.
Avoid Driving in Poor Visibility
The surest way to deal with blowing snow is to stay off the road entirely. When conditions deteriorate, authorities often close major highways, the Trans-Canada and the 400-series among them. Respect those closures, because driving around a barricade endangers not only you but the first responders who may have to come get you.
What to Do If You Get Caught in Blowing Snow While Driving
If a sudden whiteout catches you on the highway, stay calm:
Slow down smoothly and switch your headlights on fully. Daytime running lights can leave your taillights dark, so turn the low beams on and leave the high beams off; high beams bounce off the airborne snow and make it harder to see.
Resist the urge to stand on the brakes. A hard stop can trigger a spinout or get you rear-ended.
If you have to pull over, get your vehicle as far onto the shoulder as you safely can, then put your hazards on right away.
Stay in your vehicle. Setting out on foot in a whiteout is how people end up overcome by cold or struck by passing traffic.
Keep the tailpipe clear of snow. If you are running the engine now and then for heat, check regularly that snow has not plugged it, since a blocked tailpipe lets carbon monoxide seep into the cabin. Crack open a window on the downwind side a finger’s width for fresh air.
Prepare for Blowing Snow at Home
When severe blowing snow reaches a community, the effects can extend beyond blocked roads. Strong winds may damage power lines, heavy drifts can delay travel, and extreme cold can increase electricity demand. Keep emergency supplies for a power outage accessible before conditions deteriorate.
Getting your home ready means planning for warmth, food safety, lighting, and communication during an outage. A suitable power station can support selected plug-in household essentials when its output and capacity match the planned loads.
Everyday Home Reliability
For many suburban and urban households, preparing for blowing snow does not necessarily mean backing up the entire home. During a shorter winter outage, the priority is often to keep a few everyday essentials running until grid power returns. In this case, the EcoFlow TITAN 5000 Classic Whole-Home Backup Power can power devices such as a refrigerator, Wi-Fi router, phones, emergency lighting, and other small appliances. It can be charged from a standard wall outlet before severe weather arrives, providing a straightforward backup option for essential 120V loads during an outage.
Extended Outages & Rural Settings
For rural homes, remote acreages, and winter cottages, blowing snow can block roads and delay power restoration, making longer outages more difficult to manage. The EcoFlow TITAN 5000 Whole-Home Backup Power starts at 5kWh and provides the high output needed to run essentials such as refrigerators, water pumps, communication devices, and heating system components. Its expandable capacity also gives households more flexibility when backup power is needed beyond a few hours.
Blowing snow can develop quickly and make a drive dangerous even when no new snow is falling. Check the forecast and the road reports, keep off the road when visibility is poor, and have your home ready for a possible winter outage. A few precautions taken while the sky is still clear go a long way once the wind picks up.
Can Blowing Snow Happen When It Is Not Snowing?
Yes, and it happens often. As long as a strong wind is blowing and cold, uncrusted snow covers the ground, gusts can pick that snow up and send it several metres into the air, cutting visibility even under a completely clear sky.
What Is the Difference Between Blowing Snow and Drifting Snow?
Drifting snow stays close to the ground, while blowing snow is lifted high enough to reduce horizontal visibility at eye level. The practical difference is the effect on what drivers and pedestrians can see.
How Strong Does the Wind Need to Be for Blowing Snow?
There is no single wind speed that applies in every situation. Fresh, cold powder can lift more easily than wet or crusted snow, so exposure, snow condition, terrain, and gusts all affect when visibility begins to deteriorate.
Can Blowing Snow Cause Whiteout Conditions?
Yes. Severe blowing snow is one of the most common causes of a total whiteout. Once the airborne snow is dense enough, ambient light scatters evenly in every direction, and the horizon, the surface contours, and every landmark disappear entirely.
What Does a Blowing Snow Advisory Mean in Canada?
A Blowing Snow Advisory means winds are expected to lift loose snow and reduce visibility enough to create hazardous travel. Environment and Climate Change Canada now uses impact-based guidance rather than the former fixed public-alert thresholds, so the alert text for your location is the best source for expected severity and timing.
Since November 26, 2025, every Environment and Climate Change Canada weather alert has carried a yellow, orange, or red colour. The colour reflects the expected impact and forecast confidence, so read the full alert for local timing, travel risks, and safety guidance.
