How to Use Tech to Save Energy at Home and Lower Your Bills
In many Canadian homes, the biggest energy costs come from the same few places: heating, cooling, standby electronics, lighting, and the appliances that work the hardest. Learning how to use tech to save energy starts with matching each device to how you live and what your utility charges. This article explains how to save energy at home with useful controls, careful measurement, and a clear role for home batteries in bill management and outage planning.
What Technologies Can Help Save Energy?
You don’t need to rewire the house to see a difference. Go after space heating, standby power, and lighting first, and you may see savings sooner. A power station can provide backup electricity, while reducing consumption still depends on how household equipment is used.
Smart Thermostats Adjust Heating Automatically
Space heating is generally the largest energy use in a Canadian home, which is why the thermostat tops this list. Smart thermostats from ecobee and Google Nest can adjust heating around your schedule and occupancy, depending on the model and settings. Instead of maintaining the same temperature while the home is empty, a compatible system can ease back and restore the setting before occupants return.
Energy Monitors Track Household Electricity Use
Measuring household electricity use makes it easier to find practical reductions. Some systems, such as Emporia Vue, monitor individual circuits with clamp sensors, while others, such as Sense, estimate appliance-level usage from whole-home electrical patterns. A quick look can indicate whether that mid-afternoon jump is coming from the clothes dryer, an aging deep freeze in the basement, or an engine block heater that’s been plugged in since breakfast.
Smart Plugs Reduce Unnecessary Standby Power
Put a smart plug on compatible equipment that stays within its rated load, and a schedule can trim standby power or shift use into off-peak hours. Televisions, game consoles, and cable boxes may draw power while they sit idle, and an overnight schedule can reduce some of that use. High-draw appliances are a different matter. Dryers, dishwashers, heat pumps, and EV chargers need their own delay-start setting, a manufacturer-approved controller, or a properly rated smart switch installed by a licensed electrician.
Smart Lighting Controls When Lights Are Used
Smart bulbs and smart switches put your lights on a schedule and let them respond to whether anyone’s in the room. Tie the hallway and unfinished basement lights to motion sensors, and they stop burning all night because someone forgot to turn them off. Set the soffit lights to shut off at sunrise, and put the holiday lights on a smart plug so they come on at dusk and go off at bedtime.
How to Use Smart Tech to Lower Energy Bills
The gadgets on their own won’t do much for your bill. The savings come from setting them up around your family’s routine and your utility’s rate plan.
Set Heating Schedules Around Daily Routines
If you heat with a natural gas furnace or electric baseboards, a suitable temperature setback while you’re at work or overnight may reduce energy use. Put it on a schedule so nobody has to remember, and have the house warm back up before anyone’s out of bed. Cold-climate air-source heat pumps may respond differently: warming the house after a deep setback can activate backup electric resistance heat. Follow the equipment manufacturer’s guidance and use modest setbacks where appropriate.
Monitor High-Consumption Appliances
Circuit-level tracking can flag a problem with an appliance before it leads to a costly service call. If the old beer fridge in the basement uses twice the electricity it should over a weekend, worn door gaskets or a failing compressor probably have it running almost nonstop. Once you see the numbers, you can fix it or retire it, which beats discovering the problem on a bill you can’t argue with.
Schedule Appliances Around Electricity Rates
In Ontario, Time-of-Use (TOU) and Ultra-Low Overnight (ULO) pricing reward households that move what they can out of peak hours. Since the big appliances can’t go on a standard smart plug, use the dishwasher’s or dryer’s delay-start timer, your EV charger’s schedule, or the manufacturer’s app to run them off-peak. You pay less per kilowatt-hour, and your routine barely changes.
Ontario hydro customers can choose among TOU, Tiered, and ULO plans. Ontario electricity rates vary by plan, and TOU and ULO prices change by time period, so confirm your current plan and schedule before shifting appliance use.
Automate Lighting and Standby Power Controls
Plug the TV setup, computer monitors, and chargers into a smart power bar that cuts power at bedtime. Put the entryway and laundry room lights on motion sensors, so they’re only on when someone’s there.
Home Energy Storage Helps Manage Household Electricity Use
A home battery won’t make your appliances use fewer kWh. What it does is let you store extra solar power for the evening, charge up when grid power is cheap, and keep the essentials running through an outage. That matters most if you have rooftop solar, or you’re on TOU or ULO pricing. Panels often make more than the house needs on a sunny afternoon, and a battery holds that extra for cooking dinner and running the lights, so less of your evening power comes from the grid. On TOU or ULO rates, it can charge overnight at the lowest price and run the house when prices peak.
Model | Battery Capacity | Output Details | Ideal Household Role |
EcoFlow TITAN 5000 Classic | 5 kWh (expandable to 30 kWh) | Up to 4 kW AC output | Critical backup: fridge, Wi-Fi router, task lighting, device charging |
EcoFlow TITAN 5000 | 5 kWh (expandable to 30 kWh) | Up to 7.2 kW | Higher-output backup: selected heavy-draw loads and compatible solar pairing |
For households planning backup for selected essential circuits, the EcoFlow TITAN 5000 Classic Whole-Home Backup Power delivers up to 4 kW of AC output with a 5 kWh base capacity. Additional battery modules can expand overall capacity up to 30 kWh. Connecting it to household circuits requires a compatible 120V Smart Home Panel 10 (SHP10), installed by a qualified electrician in accordance with local electrical codes.
When a home needs higher output, the EcoFlow TITAN 5000 Whole-Home Backup Power delivers 7.2 kW of AC output with a 5–30 kWh expandable battery capacity. It supports up to 4 kW of PV input through one PV channel and uses LFP battery chemistry for home backup and everyday energy management.
Before you pick a system, work out which circuits really have to stay on, and make sure your electrical setup can handle a battery. What a battery saves you comes down to the gap between your peak and off-peak rates, whether you charge it from solar or the grid, and when you use the stored power.
Can Smart Technology Really Save Energy?
Automation can save energy when it controls a meaningful load, but it helps to know what it can and can’t do. A solar panel changes where some electricity comes from, while monitoring and automation help reduce or shift demand.
Compare Energy Use Before and After Changes
To see what difference the smart tech made, compare energy use rather than dollar totals, and allow for the weather. This is also how the energy used at home can be saved more deliberately: pull the kilowatt-hour (kWh), cubic metre (m³), or gigajoule (GJ) figures from your utility portal and compare similar billing periods year over year. A colder winter can push the numbers up even after an upgrade, so avoid drawing conclusions from one month.
Consider Equipment Costs and Potential Savings
Every device costs money up front, and it takes time to earn that back:
Smart Thermostat: Upfront cost and payback vary by model, heating system, climate, existing habits, and available utility or provincial rebates.
Smart Plugs: Savings are usually modest and depend on the plug’s own power use, the connected load, and how long standby power is actually disconnected.
Whole-Home Battery: Installed cost and bill savings vary widely. Rate savings depend on plan design, usable capacity, conversion losses, solar production, and how loads are shifted.
Understand the Limits of Smart Home Automation
Automation cannot correct every problem caused by single-pane windows, thin attic insulation, or a drafty exterior door. A smart thermostat can improve control, but heat loss through the building envelope still matters. Pair suitable controls with air sealing or insulation improvements where an assessment identifies a need.
How to Start Saving Energy With Technology?
Go one upgrade at a time, and you won’t end up with a drawer full of gadgets that do little for your bill.
Assess Your Home’s Energy Use
Start by pulling up last winter’s and last summer’s bills to see where the big seasonal jumps are. A measure-first plan to save energy at home helps identify whether space heating, water heating, or other appliances are driving them. For anyone asking how to save energy in a house, a home energy assessment and a careful walk-through can reveal drafts, cold spots, and the loads worth addressing first.
Understand Your Local Electricity Rates
Look at your bill to see whether you’re on flat-rate, tiered, or time-of-use pricing. If the price is the same all day, running the dishwasher at midnight won’t save you anything, so put the effort into using less instead.
Confirm Smart Device Compatibility
Homes heated with electric baseboards need a line-voltage smart thermostat, such as one from Mysa, because standard low-voltage models from ecobee and Nest won’t work on 240V lines. Before buying a thermostat for a furnace or heat pump, turn off power to the system at the breaker, pull the old thermostat off the wall, and check for standard 24V control wires and a common wire (C-wire).
Begin With Simple, Affordable Upgrades
Start small and make one change at a time:
Swap the main thermostat for a smart one.
Put smart plugs on the home office setup and the TV and game console.
Replace the halogen pot lights you use most with dimmable smart LEDs.
Fine-Tune Settings as Your Needs Change
About a month after setup, check the app’s history to see whether the automations still fit your day-to-day life. Shrink the geofence if the heat kicks on too early, or widen it if it doesn’t come on until you’re already in the driveway, and adjust the schedules as your routine changes with the seasons.
The best results usually come from small, targeted moves rather than a whole-house overhaul: control the heating first, measure the biggest loads, cut standby waste, and move what you can to off-peak hours when your rate plan rewards it. Battery storage belongs in the conversation when you have solar, you’re on TOU or ULO pricing, or you worry about outages, but size it for the circuits you need to keep running and how much power you use, rather than buying it as a generic bill-saving device.
Is It Safe to Have a Smart Home?
Yes, as long as the hardware is installed following the manufacturer’s instructions and local electrical code. On the security side, use strong, unique passwords, turn on two-factor authentication, and keep the firmware updated so your home network stays locked down.
How Much Energy Can a Smart Thermostat Save?
Savings vary by climate, heating and cooling equipment, insulation, occupancy, settings, and previous thermostat habits. Compare normalized energy use before and after installation rather than assuming a fixed percentage or dollar amount.
Do Smart Homes Work Without the Internet?
It depends on the device and how it is configured. Some thermostats retain local schedules, and compatible Zigbee, Z-Wave, or Matter hubs may keep local automations running when the internet goes down. Remote phone control and alerts usually stop, while cloud-dependent Wi-Fi plugs may lose schedules or controls until the connection returns.
What Smart Home Devices Are Suitable for Renters?
Smart plugs, screw-in smart bulbs, plug-in power meters (to see how much power a device uses), and battery-powered sensors need no wiring and move with you to your next place. Unlike whole-home monitors that go inside the electrical panel, these plug-and-play tools let you track phantom power and automate lighting without touching anything the landlord would have to sign off on.
Are You Allowed to Install a Smart Thermostat in an Apartment?
Get your landlord’s permission, ideally in writing, before replacing any hardwired thermostat. Many apartment buildings run on central boilers or proprietary fan-coil systems that standard smart thermostats won’t work with, so find out what your building uses before you buy anything.
