Maritime Electric Outage Map: How to Check PEI Outages
- How Do You Check the Maritime Electric Outage Map?
- Which Maritime Electric Outage Tool Should You Use?
- What Should You Do If Your Outage Is Not on the Map?
- Why Can Outage Counts and Restoration Estimates Change?
- What Should You Do While the Power Is Out?
- How Much Backup Power Do You Need After Checking the Map?
- Save the Map and Build the Load Plan Before the Next Outage
- FAQs
The Maritime Electric outage map shows reported outages across its Prince Edward Island service area. Use it to check whether the company knows about an outage near your address.
The map refreshes every 15 minutes, but outage totals, details, and repair times may change with each update.
This guide explains how to find your address, read the map, report an outage, and plan safe backup power.
Use Maritime Electric's official outage page to open its Maritime Electric power outage map. Search for your service address and select the marked area or navy line. Check the newest summary and details after each 15-minute refresh.
Start on the official utility page. Search for the service address instead of trusting an old screenshot or social post. A third-party counter may also lag behind the utility's own information.
The map highlights areas in green, yellow, orange, or red. These colours group outages by the number of customers without power. They don't show danger or weather-warning levels, so check the current legend for any changes.
Navy lines show an outage location within a community, and you can select a line for details. The Info Summary lists the affected communities and customer totals. On a phone, choose the correct address result and tap the circled arrow.
The map may not show a new fault right away. Check its update time, then report an unlisted outage if service doesn't return.
Use the outage map for a current local outage and the planned-outage page for scheduled work. Grid Status shows the wider state of PEI's power system.
Tool | What it answers | When to use it | Main limit |
Outage map | Is an outage reported near the service address? | When power is out or a local outage is suspected | A new report may not appear at once |
Planned outages | Is work scheduled in a listed community? | Before planned maintenance | Dates, timing, and scope may change |
Grid Status | What are the current PEI system load and grid condition? | During high demand or utility grid notices | It doesn't confirm service at one address |
A normal grid status doesn't prove that your local line works because a branch or transformer fault can still cut service. The planned-outage page may also be empty when no work is listed.
Maritime Electric says it usually contacts customers before planned work. A recorded call may provide notice, so keep your contact details current and check the official page.
First, check whether nearby homes or streetlights also lack power. If your address is missing, use this safe sequence:
Look outside from a safe place and check nearby homes or streetlights.
Watch for partial power, smoke, a burning smell, a bang, a flash, flooding, or damaged wires.
Check the main breaker only when the panel area is dry and safe.
Report the Maritime Electric power outage online or call 1-800-670-1012.
Keep your 16-digit Maritime Electric account number ready for the online form.
Stop and move away if you see a low or fallen power line. Maritime Electric tells you to stay at least 30 metres away. Keep clear of trees, vehicles, fences, and water touching the line.
Call 9-1-1 and Maritime Electric when a fallen line creates danger. Don't enter a flooded basement or touch a breaker from a wet floor. An electrician may need to fix a damaged service mast before power returns.
Maritime Electric serves most of PEI, but it doesn't serve every address. The City of Summerside runs its own electric utility. Check the provider shown on your power bill before reporting the outage.
Map details change as customers report faults and crews inspect damage, while repairs can restore one area before another.
The 15-minute refresh cycle doesn't show every new outage at once. Maritime Electric may spot a large system fault quickly. A broken local line may still need a customer report.
Homes on the same street can use different parts of the local grid. One side may regain power while crews fix a main line or substation elsewhere.
A larger repair can restore many homes while damage at one home keeps its power off. Weather, blocked roads, and new damage can also delay work.
Treat an estimated repair time as a planning aid because it isn't an appointment or promise. Check the map again before changing travel, heat, food, or care plans.
Once the map confirms an outage, focus on safety and your key needs:
Use flashlights or battery lights instead of open flames.
Unplug electrical equipment and leave one light switched on.
Keep refrigerator and freezer doors closed as much as possible.
Follow current PEI food-safety guidance before keeping or discarding food.
Close doors and drapes in cold weather, and protect water pipes.
Never use a fuel generator, barbecue, camp stove, or kerosene heater indoors.
Stay out of a flooded basement where electricity may contact water.
Follow utility, weather, municipal, 211, and emergency instructions.
A planned battery setup can run chosen devices without engine fumes in your home. EcoFlow TITAN Classic may support 120 V plug-in loads. These can include phones, a router, lights and a fridge.
EcoFlow TITAN Classic starts with 5 kWh and can expand from 5–30 kWh. It supplies up to 4 kW at 120 V. It doesn't support 240 V loads or automatic whole-home backup. Keep the IP20 unit indoors, dry, and clear of blocked vents.
For a broader PEI checklist, review how to stay safe while preparing for Maritime Electric power outages. It covers steps before, during, and after an interruption.
The map can't size backup power for your home. Your plan depends on chosen loads, starting demand, voltage, use time, and connection method.
Use these four steps:
List loads that protect health, heat, food, water, phone service, or the home.
Add the running power of loads that may operate together.
Add the largest extra starting demand from a motor or compressor.
Estimate the energy needed for the hours you plan to use it.
Use these formulas as planning tools:
Required output = simultaneous running power + largest additional starting demand
Estimated energy needed = average load (kW) × operating time (h)
EcoFlow TITAN may suit a larger plan with chosen 120 V and 240 V home circuits. It starts with 5 kWh and expands from 5–30 kWh.
Connecting EcoFlow TITAN to selected home circuits requires a compatible 120V/240V Smart Home Panel 10, installed by a qualified electrician in accordance with local codes.
Product | Planned outage role | Base capacity | Output and voltage | Main limit |
EcoFlow TITAN Classic | Selected plug-in essentials | 5 kWh | 4 kW at 120 V | No 240 V support or automatic whole-home backup |
EcoFlow TITAN | Larger selected household load plan | 5 kWh | 7.2 kW at 120 V/240 V | Hardwired use needs compatible equipment and qualified installation |
Neither capacity figure promises a fixed runtime. Appliance cycling, power loss, temperature, reserve settings, and changing loads affect use time. Added batteries store more energy, but they don't raise output by default.
Bookmark the official map and save Maritime Electric's reporting number. Confirm which utility serves your address. Then list essential loads and ask a qualified electrician about any circuit connection.
Once you know the loads and connection method, you can compare EcoFlow whole-home backup power solutions that fit your plan.
What is the current status of Maritime Electric outages in PEI?
Open the official Maritime Electric outage map and check its latest update time. Search your service address because any count in this guide would soon be old.
Why is there a power outage in my area right now?
The map may show details, though some causes remain unknown until crews check the system. Report the outage if your address or nearby area doesn't appear.
Where can I find the live Nova Scotia Power outage map online?
Use the official Nova Scotia Power outage map. Maritime Electric's map covers its service area in PEI, not Nova Scotia.
Where does Maritime Electric get its power?
Maritime Electric receives electricity through PEI's subsea links with New Brunswick. Its supply also includes on-Island wind and utility generation. The exact mix can change over time.
Does the Maritime Electric outage map cover Summerside?
Not every Summerside address appears because the City of Summerside runs its own electric utility. Confirm the provider listed on your bill before using an outage map or reporting service loss.
