How Many Watts Are in a Horsepower? Complete HP to Watts Conversion Guide
Whether you’re setting up a garage workshop, preparing for outages caused by summer storms, ice storms, or high winds, or installing off-grid solar systems, you’ll likely run into two common power measurements: horsepower and watts. Knowing how these two units relate to each other is key to picking the right gear and avoiding overloaded circuits.
This guide covers everything you need to know about converting horsepower to watts. You will learn the history behind these measurements and why this conversion matters to Canadian homeowners. We will go over the exact formulas, provide handy conversion charts, and look at practical everyday examples to make your next electrical or energy project simpler.
Quick Answer
One mechanical horsepower equals 745.7 watts, commonly rounded to 746 watts.
Formula: W = HP × 746
For example:
1 HP = 746 W
2 HP = 1,492 W
5 HP = 3,730 W
What Is Horsepower?
Before exploring the mathematical calculations, it helps to know what horsepower actually means. While it may appear to be a legacy term from the days of horse-drawn carriages, it remains a dominant standard to measure mechanical power across North America. Even as modern homeowners increasingly transition to clean solar generator systems and smart battery backups, this classic baseline still dictates how heavy equipment operates.
The Definition of Horsepower
Horsepower is a unit of power, which measures the rate at which work is done. James Watt, a Scottish engineer, invented the term in the late 1700s to compare steam engines to real horses. One mechanical horsepower is the power required to lift 550 foot-pounds per second. In simple terms, it describes how quickly a machine can move a load over a distance.
Common Types of Horsepower
Here are the main horsepower standards you may come across in technical specifications:
  • Mechanical / Imperial Horsepower: The traditional standard used across North America for rating engines and industrial motors, representing true mechanical output rather than electrical input.
  • Metric Horsepower (PS): The continental European standard, primarily utilized for imported vehicle and specialized machinery specifications.
  • The “746 Watt” Rule: A rounded baseline reference used in North American industry to simplify commercial power calculations and electrical load estimations.
How Many Watts Are in One Horsepower?
Horsepower to watts conversion allows for accurate comparison between mechanical and electrical power. Watts are the official SI unit for measuring power. Let’s break down the exact numbers for each type of horsepower.
Mechanical Horsepower to Watts
For standard tools , lawnmowers, and older industrial equipment, one mechanical horsepower equals exactly 745.7 watts. In most real world engineering and everyday calculations, professionals round that number up to 746 watts for practical engineering calculations.
Metric Horsepower to Watts
If you are working with European imported vehicles or certain global automotive specifications, you are probably dealing with metric horsepower. It’s often abbreviated as PS (Pferdestärke), the standard horsepower rating used in Germany and several European countries. One metric horsepower equals about 735.499 watts. That is slightly lower than the Imperial version. So a car rated at 300 PS (metric horsepower) is slightly less powerful than a car rated at 300 mechanical horsepower due to different unit definitions.
Horsepower Ratings in Electric Motors
In North America, electric motors are typically labeled using mechanical horsepower, which refers to usable shaft output rather than electrical input. In practice, this helps users match motor ratings with circuit capacity and backup power systems when planning electrical loads.
EcoFlow DELTA Pro Ultra Whole-Home Backup PowerEcoFlow DELTA Pro Ultra Whole-Home Backup Power
Horsepower to Watts Conversion Formula
With a couple of simple formulas, you can quickly switch between mechanical potential and electrical draw. A proper calculation for wattage can also help when estimating power requirements for motors, generators, and other electrical equipment.
Convert Horsepower to Watts
To convert horsepower to watts, simply multiply the horsepower value by 746.
Formula:
Watts = HP × 746
For example, if you have a shop tool or an air compressor rated at 1.5 HP:
1.5 × 746 = 1,119 Watts
This represents the motor’s theoretical mechanical output power. Depending on motor efficiency and power factor, actual electrical input is typically higher due to efficiency losses, usually 10%–40% depending on motor type, size, and load conditions.
Convert Watts to Horsepower
Conversely, if you know the wattage of an appliance and want to determine its equivalent horsepower rating, divide the total wattage by 746.
Formula:
HP = Watts ÷ 746
For example, if a machine draws 3,000 watts of power:
3,000 ÷ 746 = 4.02 HP
This means the machine’s power output is approximately equivalent to 4.02 horsepower. This is especially useful when comparing electric and gas-powered equipment, where horsepower is still commonly used to describe engine performance.
Horsepower to Watts Conversion Chart
For quick reference during a project, here is a quick-look table showing the most common horsepower ratings found on household and workshop equipment translated directly into standard electrical wattage.
Horsepower (HP)Electrical Wattage (Watts)Approx. Kilowatts (kW)
0.25 HP186.5 W0.19 kW
0.5 HP373 W0.37 kW
0.75 HP559.5 W0.56 kW
1.0 HP746 W0.75 kW
1.5 HP1,119 W1.12 kW
2.0 HP1,492 W1.49 kW
3.0 HP2,238 W2.24 kW
5.0 HP3,730 W3.73 kW
10.0 HP7,460 W7.46 kW
Why Do Canadians Need to Convert Horsepower to Watts?
From basement sump pumps in Toronto homes to running a cabin in northern BC with no grid access , knowing how power converts from mechanical force to electrical load is a matter of safety and comfort.
Electric Motors and Pumps
Many Canadian homes rely on critical equipment with electric motors rated in horsepower, such as deep well pumps, sewage pumps, and HVAC systems. Check the nameplate on a typical residential sump pump, and you will typically see 1/2 HP or 3/4 HP, not a clear wattage number. Knowing how to convert horsepower to watts helps you estimate power requirements more accurately, including startup load considerations. That means no blown fuses or tripped breakers when those motors kick on. It also makes it easier to size backup power systems, including portable power stations, so that essential equipment can continue running during a power outage.
Portable and Backup Generators
Many parts of Canada experience prolonged power outages caused by severe summer weather, including heavy thunderstorms, tornadoes, and high winds. These volatile events, alongside hot-weather grid strain, can leave homes without electricity for days. When sizing a backup power system, homeowners often convert the horsepower ratings of pumps and other motor-driven equipment into watts to estimate startup surge requirements.
Take a 1 HP well pump or sump pump. It runs on about 746 watts. However, starting a motor from a complete standstill typically demands two to three times depending on motor type , sometimes more. If you pick a backup generator based only on continuous running watts, it will stall the moment that pump tries to kick on.
For homeowners who prefer a quieter and maintenance-free alternative to traditional generators, battery-based backup systems such as the EcoFlow DELTA Pro Ultra Whole-Home Backup Power have become increasingly popular. Designed for whole-home backup applications, it offers high output capacity and expandable battery storage, allowing it to support many high-surge appliances such as well pumps, furnaces, and refrigerators (depending on system configuration). Converting HP to watts in advance helps you map out electrical loads more accurately and choose a backup strategy that maintains essential power during outages, especially in severe summer weather.
The EcoFlow DELTA Pro Ultra is the only portable power station certified to both UL1973 and UL9540. It delivers 7.2-21.6kW, powerful enough to run your whole home even with a central AC. It features a scalable 6-90kWh capacity for weeks of backup. With Smart Home Panel 2 for auto-switchover, 5 charging modes, and self-heating for freezing weather, it’s the ultimate fail-safe power solution.
Solar Power Systems
More Canadian households are investing in sustainable energy. For them, converting horsepower to watts is a key step in system design. Many high-demand fixtures are rated in HP. Swimming pool pumps, agricultural water systems, heavy-duty garage workshop tools. But home solar systems are rated in watts for output and watt-hours for battery capacity.
Take a 2 HP pool filtration pump. It needs about 1,492 watts of continuous running power. If you want to run that pump on solar, you have to do the conversion first. Make sure your inverter can handle the load and your panels can harvest enough daily energy.
If you need one flexible package that balances solar generation, campsite power, and home emergency backup, the EcoFlow DELTA Pro 3 Portable Power Station is a versatile option to consider. Its high-output design can support a wide range of household appliances and tools, depending on load requirements. It also integrates with residential solar panels. Perfect for off-grid cabins, RV trips through Canada’s national parks, or as a reliable home backup you can deploy anytime.
Delivers both 120V and 240V outputs with up to 4000W in a single unit, capable of powering a 3-ton central AC and all other essential appliances. Exclusive X-Boost technology allows the unit to exceed its rated output, providing up to 6000W of power when needed.
Electric Vehicles and E-Bikes
As Canada shifts toward greener transportation, moving from gas vehicles to EVs and e-bikes has created a mix of terms. Car commercials still brag about horsepower. But EV spec sheets focus on kilowatts and battery size. Knowing that 100 kW is roughly equivalent to about 134 horsepower (mechanical output) can help Canadian buyers better understand power ratings when comparing electric vehicles and traditional gas engines.
EcoFlow DELTA Pro 3 Portable Power StationEcoFlow DELTA Pro 3 Portable Power Station
Horsepower vs. Watts: Which Unit Is Better?
Neither unit is universally superior; rather, they serve distinct roles depending on the task at hand. Both units coexist in the Canadian market to describe different aspects of energy and performance.
Advantages of Horsepower
Horsepower works best when you are describing the big picture performance of mechanical systems. It gives you an instant, intuitive sense of power for car engines, heavy machinery, and large industrial pumps. It also saves you from dealing with huge numbers. It’s far more practical to say a truck has a 300 HP engine than to say it puts out 223,800 watts.
Advantages of Watts
Watts are much better for precise scientific calculations, electrical grid design, and tracking energy efficiency. A watt measures energy transfer directly across all disciplines. Electrical, thermal, mechanical. It is the universal unit. It lets you connect how much solar energy you are capturing to exactly how long your appliances can run.
Common HP-to-Watt Conversion Examples
To help you visualize these numbers in context, here are a few common real-world examples of tools and appliances found around Canadian properties:
  • Small Sump Pump (0.5 HP): Draws roughly 373 running watts. However, you should allocate around 1,000 watts of startup capacity to handle the initial motor surge.
  • Workshop Table Saw (1.5 HP): Produces about 1,119 watts of mechanical output power. However, due to standard motor efficiency and power factor, it actually draws around 1,400 to 1,800 watts of electrical input from your wall.
  • Commercial Air Compressor (5 HP): Demands 3,730 running watts. This scale of equipment typically requires a 240-volt electrical connection rather than a standard household plug.
Learning to convert horsepower to watts is a handy skill for your home, workshop, or off-grid setup. 1 HP is about 746 watts. That helps you read tool labels, size your circuits, and plan backup power. Always account for startup surges on motors. Give your generator or power station some breathing room. With accurate conversions and properly sized equipment, you can better prepare for most household and emergency power needs.
How Many Watts Are in a 5 HP Motor?
A 5 HP motor delivers approximately 3,730 W of mechanical output power. You get this number by multiplying 5 by the standard 746-watt electrical conversion factor.
How Many Horsepower is 1,000 Watts?
1,000 watts is equal to approximately 1.34 horsepower. To find this value, you divide 1,000 watts by the conversion factor of 746.
Why Are There Different Horsepower Standards?
Different industries came up with their own ways to measure mechanical work, electrical output, and metric force. Over time, those regional and technical definitions got standardized so engineers could safely translate metrics between different global markets.
Is Horsepower Still Used in Canada?
Yes, horsepower is still common across Canada. You see it on gas vehicle engines, industrial electric motors, lawnmowers, and heavy-duty shop tools. Even though Canada officially uses the metric system, many industries still follow North American standards, so horsepower remains widely used.
Home Backup
