How to Run Wells and Water Pumps During a Winter Power Outage
Winter in Canada looks peaceful, but for homeowners on a well system, a power outage brings real risk. When the electricity cuts out, your well pump stops instantly. No pump means no running water, and in sub zero temperatures, that can quickly lead to frozen pipes and expensive repairs.
If you live in rural Ontario, the Prairies, or anywhere outside municipal water service, you already know how critical your well is. In this guide, we’ll walk through what happens to your water system during a winter outage, how to keep a well pump operating with backup power, and the key steps to prevent frozen plumbing when the temperature drops fast.
What Happens If Wells and Water Pumps Stop Running in Winter?
When the power goes out in freezing temperatures, your well system stops immediately. No electricity means no pump operation. In a Canadian winter, that can quickly lead to frozen plumbing and system damage if temperatures remain below zero for extended periods.
Frozen Wellheads, Pipes, and Pump Housing Damage
If water is not circulating, any standing water in the wellhead, pressure line, or pump housing can freeze. As water turns to ice, it expands. That expansion can crack cast iron housings, split PVC piping, or damage fittings. Once temperatures rise, those cracks often result in leaks that require repair or replacement.
In many parts of Canada, repairing burst pipes during winter can cost anywhere from $2,000 to $10,000, depending on structural damage and how difficult the plumbing is to access.
Loss of Water Pressure and Inability to Refill Pressure Tanks
Your home’s water pressure depends on the pressure tank being refilled by the pump. During an outage, the pump cannot recharge the tank. You may have limited stored water available, but once depleted, faucets and toilets will stop functioning until power returns.
Groundwater Contamination from Leaks or Valve Failure
A loss of pressure can sometimes allow backflow or sediment intrusion if check valves fail or fittings weaken. While not common, pressure changes increase the risk of contaminants entering the system. After restoration, flushing the system may be necessary.
Reduced Fire Protection and Emergency Response
For rural properties, well water often supports fire response. Without pump power, water pressure may not be available if an emergency occurs. Maintaining pump operation during winter outages supports both household needs and property protection, reducing the risk of system damage and unexpected repair costs.
How Can Wells and Water Pumps Operate During a Winter Power Outage?
Even if the grid is down, your well system can still operate, but only with the right backup setup. The key is matching your power source to the electrical requirements of your pump.
Use a Portable Power Station
A high-capacity home battery backup is one of the most reliable ways to keep a well pump running during a winter outage. The first step is confirming whether your pump operates on 120V or 240V. This information is usually listed on the pump control box or electrical panel.
120V Pumps:
These are more common in shallow wells or smaller residential systems. Many portable power stations can operate a 120V pump, as long as the unit can handle both the running watts and the higher startup surge required to get the motor spinning.
240V Pumps:
Most deep well submersible pumps in Canada run on 240V. A standard 120V-only power station will not operate these systems. You need a backup source that provides native 240V output and enough surge capacity to handle the high starting load typical of 1/2 HP to 3/4 HP pumps. A system like the EcoFlow DELTA Pro Ultra Whole-Home Backup Power is designed for this level of demand and can be connected through a properly installed transfer switch. With the correct setup, you can maintain steady water pressure for essential needs, even during a multi-day winter outage.
Install a Manual Backup Pump for Shallow Wells Only
If your well is shallow, typically under 25 feet, a hand operated pitcher pump can serve as a mechanical backup. It requires no electricity and provides direct access to groundwater. While output is limited and requires manual effort, it offers reliable water access during prolonged outages.
Use Pressure Tank Reserve Water Sparingly
If you do not yet have backup power, conserve the water stored in your pressure tank. Once the pump stops, the tank will only supply a limited amount. Use that water for drinking and essential hygiene only. Avoid high consumption tasks until power is restored. With the proper preparation, a winter outage doesn’t have to mean losing access to water.
How Do I Keep My Pipes From Freezing When the Power Goes Out?
Keeping your well pump running is one part of the equation. The other is protecting your plumbing when indoor temperatures begin to fall. In a Canadian winter, pipes can freeze sooner than many homeowners expect, especially in unheated spaces.
Drain Water Lines if Power Won’t Return Within 24 Hours
If an outage looks like it may last a full day or longer and indoor temperatures are dropping, shut off the main water valve. Open all faucets, including basement and outdoor taps, to drain water from the lines. Empty pipes cannot freeze and burst. This step is often the safest option when heating cannot be restored quickly.
Open Cabinet Doors for Better Heat Circulation
Pipes under kitchen and bathroom sinks are often located along exterior walls. Opening cabinet doors allows remaining room heat to circulate around the plumbing. Even small amounts of ambient warmth can slow freezing during short outages.
Insulate Exposed Pipes in Garages or Attics
Before winter, insulate any exposed pipes in garages, crawlspaces, or attics with foam sleeves. During an outage, this insulation reduces heat loss and buys valuable time. While insulation does not generate heat, it slows temperature drop inside the pipe.
Fully Drain Plumbing During Extended Freezing
If you’re dealing with a multi-day outage during a deep Canadian cold snap, draining lines alone may not be enough, especially in larger homes with complex heating and plumbing systems. In prolonged sub-zero conditions, maintaining indoor heat becomes critical. A high capacity power station like the EcoFlow DELTA 3 Ultra Plus Portable Power Station (3072Wh) can support essential heating loads, such as running a furnace blower motor or a few energy efficient space heaters. By keeping interior temperatures above freezing, you reduce the risk of water inside pipes turning to ice. Preventing frozen lines can avoid significant structural damage and costly repairs once temperatures rise.
Know the Freezing Risks for Different Pipes
Different pipes freeze at different temperatures depending on exposure and insulation. Understanding those thresholds helps you prioritize protection:
Indoor pipes in unheated areas (crawlspaces, attics) can freeze around -5°C (23°F).
Exposed outdoor pipes are at higher risk when temperatures fall below -10°C (14°F).
Buried pipes below the frost line are better insulated by soil, but in parts of Canada where frost depth reaches 1.5 to 2 metres (5-6.5 feet), additional insulation or heat tracing may still be required.
Knowing which areas are most vulnerable allows you to focus heating or insulation efforts where they matter most during a winter power outage.
Essentials for Winter Emergency Backup Power and Well Pump Safety
Before temperatures plunge, it’s important to winterize your home for safety, especially if you rely on a private well system. Cold-weather preparation isn’t only about comfort, it’s about protecting critical infrastructure like your pump, plumbing, and backup power setup.
Preparation is what separates a manageable outage from a major repair bill. When temperatures drop to -20°C and wind pushes through rural Ontario, the Prairies, or the Maritimes, small details matter. A simple checklist followed before winter can prevent serious system failure later.
Inspect Your Well Pump Before the Freeze
Have your well system inspected in the fall. A technician should check the pressure switch, electrical connections, and tank bladder. If a pressure switch is faulty, the pump may cycle too frequently, which wastes energy and drains backup batteries faster during an outage. A properly pre-charged pressure tank improves efficiency and reduces unnecessary pump starts.
Stay Within Rated Power Limits
Well pumps require high “starting watts” to begin operating. This surge can be several times higher than the pump’s running wattage. Your backup power source must handle both values. Undersized systems may shut down when the pump attempts to start. Choosing a unit with sufficient surge capacity ensures stable operation during outages.
For example, a typical 3/4 HP deep well pump may draw 800–1,200 watts while running, but startup surge can exceed 3,000 watts for a brief moment. If your backup system cannot support this surge rating, the pump may fail to start even if the battery has adequate stored energy.
In terms of energy consumption, if the pump operates for about 10 minutes per hour, it would use approximately 130–200 watt-hours (Wh) per hour, depending on its running load. Over a 24-hour outage, total consumption could range between 3–5 kWh, depending on household water usage patterns.
Practice Strategic Water Conservation
Even with backup power, use water carefully. Limit showers, postpone laundry, and avoid unnecessary usage. Reducing demand extends battery runtime and ensures water remains available for drinking, cooking, and sanitation if the outage continues longer than expected.
Monitor Winter Storm Alerts
Canadian weather can shift quickly. Monitor Environment Canada updates and local alerts. Before a major storm arrives, fully charge portable power stations, confirm transfer switch operation, and ensure any solar panels or auxiliary systems are clear and functional. Preparing early prevents last-minute scrambling.
Know When to Call a Professional
If water flow drops significantly or you suspect freezing has already occurred, shut off the main supply to reduce the risk of flooding during thaw. Never use open flames to thaw frozen pipes. Contact a licensed plumber who has proper thawing equipment and understands safe recovery procedures. Advance preparation and proper equipment reduce risk and help maintain water access throughout a winter power outage.
A winter power outage in Canada can quickly disrupt both heating and water access, especially for homes that rely on a well system. Without electricity, pumps stop, pressure drops, and pipes become vulnerable to freezing. Understanding your pump’s electrical requirements and having a properly sized backup solution in place helps maintain water flow during an outage. Systems like the EcoFlow DELTA series can support essential loads when configured correctly. Preparing before severe weather arrives reduces the risk of pipe damage, water loss, and costly repairs. Backup planning is not optional in cold climates, it is preventive protection.
1. Will pipes freeze if water is not running?
Yes. Standing water in pipes is far more likely to freeze than moving water. When water sits still, it gradually drops to the same temperature as the surrounding air. If that space falls below 0°C, the water inside the pipe can freeze and expand. That expansion creates pressure inside the pipe, which may lead to cracks or bursts once temperatures rise.
2. What temperature should a house be so pipes don't freeze?
To reduce the risk of frozen pipes, keep your home at or above 13°C (55°F), even if you’re away. Although water freezes at 0°C, pipes located inside exterior walls, crawlspaces, or basements can become much colder than the room air. Maintaining steady indoor heat helps prevent hidden plumbing from dropping below freezing.
3. How do you tell if a water pipe is broken underground?
Common signs of an underground pipe break include a sudden drop in water pressure, a noticeable increase in your water bill, or wet or soft patches in your yard during winter thaws. If your well pump continues running when no fixtures are in use, it may indicate water is escaping underground and the system is trying to compensate.
