What Is AC Power? A Plain-Language Guide for Canadian Homeowners
Every outlet in a Canadian home delivers AC power, yet few people know what that means or why it matters. The term covers two ideas. One is alternating current itself, and the other is the way power is measured in AC systems. This guide explains how AC works and what it is used around the house. It also covers why Canadian homes use 120/240 V at 60 Hz, and what watts, VA and power factor mean. Finally, it shows how batteries can supply AC power when the grid goes down.
What Is AC Power and How Does It Work?
AC stands for alternating current. The current reverses direction many times per second, instead of flowing one way like the direct current (DC) from a battery. In simple terms, AC power is electrical power supplied by alternating current, which periodically reverses direction.
Picture a smooth, repeating wave. The voltage rises, falls, reverses and rises again. Engineers call this shape a sine wave, and one full rise and fall is a cycle.
Frequency is the number of cycles per second, measured in hertz (Hz). The grid in North America alternates at 60 Hz. Europe and many other regions use 50 Hz.
AC became the standard for a practical reason. The U.S. Department of Energy notes, in its history of AC and DC, that a transformer can convert AC to different voltages relatively easily. That advantage helped AC win the "War of the Currents" in the 1890s.
Feature | AC power | DC power |
Direction of flow | Reverses many times per second | Flows in one direction |
Frequency | 60 Hz in North America | None |
Changing voltage | Simple, using a transformer | Needs electronic converters |
Common sources | The grid, generators and inverters | Batteries and solar panels |
Common uses | Home outlets, appliances and motors | Electronics, LEDs, electric vehicles and battery storage |
Storage | Cannot be stored directly | Stored in batteries |
Neither type is better in every situation, and most homes rely on both. A closer look shows that alternating current vs direct current differ in how they flow, where they are used and how they are stored.
With the basics in place, the practical question is what AC power actually does in your home.
What Is AC Power Used For?
AC power runs almost everything that plugs into a wall. It also drives the large appliances wired directly into the electrical panel. Even devices that run on DC inside usually start with AC from the outlet.
Everyday outlets: Lights, kettles, televisions and chargers use the 120 V supply found throughout the house.
Large appliances: Dryers, ranges and some heat pumps and pumps use the 240 V supply.
Motors: Fridge compressors, furnace blowers and well pumps are built around AC motors.
Electronics: Laptops and phones need DC, so their adapters convert the AC from the outlet.
The grid is not the only source of this power. Batteries and solar panels produce DC, and an inverter converts it to AC so household appliances can use it. Understanding how a power inverter works explains how stored DC becomes usable AC during an outage.
The quality of that AC matters. A pure sine wave inverter closely matches grid power. A modified sine wave inverter produces a stepped wave, which can make motors run hotter or noisier.
Home backup also needs the right voltage, including 240 V for larger appliances. EcoFlow TITAN Plus and the standard EcoFlow TITAN supply 120 V/240 V split-phase AC power. Connecting one to home circuits uses the EcoFlow Smart Home Panel 10, installed by a qualified electrician under local codes.
The standard EcoFlow TITAN offers the same split-phase output with a smaller solar input.
Batteries cover the gaps, but most AC power still arrives from the grid. Its journey explains a lot about the voltage at your outlet.
How AC Power Reaches Canadian Homes
AC power travels a long way before it reaches a plug. Transformers change its voltage at each stage to keep losses low. The path has seven main steps.
A generating station produces electricity.
A step-up transformer raises the voltage.
High-voltage transmission lines carry it across long distances.
A local substation lowers the voltage for distribution.
A pole or pad-mount transformer lowers it again for your street.
Your home's electrical panel divides it into circuits.
Outlets and hardwired appliances deliver it to your devices.
High voltage is used for the long haul because it lowers the current. Lower current means less heat lost in the wires. This is the main reason AC and transformers suit a country as large as Canada.
Canadian homes receive 120/240 V single-phase service, often called split-phase. Most outlets supply 120 V. Dryers, ranges and some heat pumps and pumps use 240 V.
The voltage is not perfectly fixed. Hydro Ottawa's technical guideline cites CSA standard C235 on this point. Normal 120 V service ranges from 110 V to 125 V at the service entrance.
Most of this electricity starts as moving water. According to Natural Resources Canada's energy facts, 57% of Canada's electricity came from hydroelectric sources in 2023. Nuclear plants generate about 14%.
Homes and factories are also wired differently. The contrast between single-phase vs three-phase power explains why a house needs two hot wires while a factory needs three.
Once AC power reaches a device, measuring it gets a little more complex than volts times amps.
Real, Reactive and Apparent Power Explained Simply
In AC systems, not all the current flow does useful work. Some of it only moves back and forth between the source and the load. That is why equipment is often rated in both watts and volt-amperes.
Term | Unit | What it means in plain language |
Real (active) power | Watts (W) | Power that does useful work, such as heat or motion |
Reactive power | Volt-amperes reactive (var) | Power that moves back and forth, used by motors and transformers |
Apparent power | Volt-amperes (VA) | Voltage times current, which wires and equipment must be sized for |
Power factor | A ratio from 0 to 1 | Real power divided by apparent power |
A UPS or generator shows why this matters. It often lists both a VA rating and a watt rating. The VA figure covers the total current it must carry, and the watt figure covers the useful work it can deliver.
A heater has a power factor close to 1, so its watts and VA nearly match. A motor's power factor is lower. In practice, power factor and how to calculate it affects how much current a load draws for the same useful output.
Those terms connect directly to the ratings on your appliances and backup equipment.
Reading AC Power Ratings on Appliances and Backup Equipment
Nameplates list volts, amps, watts and sometimes VA. Reading them correctly prevents overloaded circuits and undersized backup power. Here is what to check.
Voltage: 120 V or 240 V. A 240 V appliance will not run from a 120 V source.
Running watts and starting surge: Motors need extra power for a moment as they start.
Amps: This figure matters for circuit and breaker sizing.
VA versus W: Inverters and UPS units may list both, and the watt rating is the one to match to your loads.
Continuous versus peak output: Backup equipment can hold its continuous rating for hours, but its peak rating only briefly.
One simple formula covers most household math. For resistive loads, watts equal volts multiplied by amps. A 120 V kettle drawing 12.5 amps uses 1,500 watts.
Energy is a separate idea. A kilowatt-hour (kWh) measures power used over time, and it is the unit on your electricity bill. Run that kettle for one hour and it uses 1.5 kWh.
These numbers appear on every label. Once you are comfortable with volts, amps, and watts, the ratings on appliances and backup systems become easy to compare.
AC power is alternating current, delivered to Canadian homes at 60 Hz and 120/240 V. It is measured as real, reactive and apparent power. Read nameplate ratings, match voltage and output to your loads, and use clean sine wave power for sensitive devices. When the grid is down, stored energy can fill the gap. The EcoFlow TITAN Plus and EcoFlow TITAN supply split-phase AC backup power for selected home circuits.
What is the difference between AC power and DC power?
AC reverses direction many times per second, while DC flows one way. The grid and home outlets supply AC. Batteries, solar panels and most electronics work with DC.
Why do Canadian homes use AC power instead of DC?
Transformers can change AC voltage easily. That lets utilities send power long distances at high voltage, then lower it safely for homes.
What voltage and frequency is AC power in Canada?
Homes receive 120/240 V single-phase service at 60 Hz. Most outlets supply 120 V, and large appliances such as dryers and ranges use 240 V.
What does AC in power mean on an appliance label?
It means the appliance is designed for alternating current. The label usually shows the voltage and frequency beside it, such as 120 V and 60 Hz.
Is watts the same as VA?
Not always. Watts measure the power doing useful work, while VA measures voltage times current. They match only when the power factor is 1.
Can a battery provide AC power to my home?
Yes, through an inverter that converts the battery's DC to AC. Home battery systems such as the EcoFlow TITAN Plus supply 120 V/240 V split-phase AC for selected circuits.
