3 Best iPhone 17 Chargers for Fast and Reliable Charging
There is nothing worse than being left with an uncharged phone. At the end of the day, these helpful, technologically advanced devices are completely useless without power. To ensure you stay connected and powered up all day long, we have compiled a list of the best EcoFlow iPhone chargers available on the market.
Below, we will cover a range of products that will help ensure you won’t be left without a phone, even when you’re on the go.
EcoFlow’s Top iPhone 17 Chargers
While all phone chargers provide a similar service, there are varying types of chargers that may be better suited to your specific needs. Whether you’re looking for something to take with you when you have places to be or are searching for a device that can charge your phone as fast as possible, EcoFlow has just the thing.
Here are the top three iPhone chargers with varying benefits for you to take into consideration before making your purchase.
  1. EcoFlow RAPID Power Bank (25,000mAh, 170W)
  2. EcoFlow RAPID 65 W GaN Charger
  3. EcoFlow RAPID Magnetic Power Bank (10,000mAh)
EcoFlow RAPID Magnetic Power Bank (10000mAh)
Best for On-the-Go: EcoFlow RAPID Power Bank (25,000mAh, 170W)
For reliable, on-the-go power, look no further than the EcoFlow RAPID Power Bank (25,000mAh, 170W). This compact device is multi-purpose and can be used to charge your phone, tablet, or laptop while you’re out and about.
This device works great in a pinch and can have your phone charged in little to no time. The sleek style makes this charger travel-friendly and perfect for those who are constantly running around.
Best for Multiple Devices: EcoFlow RAPID 65 W GaN Charger
While keeping your iPhone charged may be one of your priorities, it’s safe to assume that a lot of professionals and hobbyists need access to chargers that can power more than just their phones.
This multi-port device can charge up to three devices simultaneously, saving space and ensuring all your devices are powered up and ready for use. This compact design is easy to take on the go and is universally compatible with all Apple, Google, and Samsung devices.
Under 10ms UPS protection, 600W output (1200W with X-Boost), and expandable up to 858Wh—perfect for light appliances. Enjoy 1-hour fast charging, up to 220W solar input, and ultra-quiet <30dB operation in a compact, wire-free design.
Best for Speedy Charging: EcoFlow RAPID Magnetic Power Bank (10,000mAh)
If fast charging is what you are after, look no further. This power bank is known for its incredibly fast charging speeds for phones, tablets, and laptops. In under an hour, your battery will reach at least 70% of its full charge, ensuring you can rely on your device to stay powered up for hours even once it has been disconnected from the charging cable.
This unique portable charger comes with a built-in kickstand and is easy to use wherever and whenever you may need it.
What to Consider When Choosing an iPhone 17 Charger
When purchasing a charger for your device, it’s essential to consider a few key factors. There are many types of chargers and portable power stations on the market today, and it can be overwhelming to choose the best one for your needs.
Here are some key factors to consider before selecting your charger.
  • Connector Type: The first thing to consider when choosing the proper charger for your iPhone is the connector type required. The iPhone 17 requires a USB-C charger, whereas older phone models may still use USB-A or Lightning models.
  • Compatibility: Charging cords are not all made the same, and it’s key to find a cord that’s compatible with your phone. The wattage output is an important consideration, as we will discuss in the next point, but it’s not the only indicator that a charging cord is fully compatible with your phone. Purchasing your cord from a reputable source, like the company that manufactures your phone, is a safe way to ensure you are getting the correct charger for your device.
  • Wattage Output: Pay close attention to the wattage output listed on the charger you plan to use for your phone. If charging speed is your top concern, consider purchasing a charger with a wattage output of 40W or higher USB-C adapter, as it will help your iPhone charge at a significantly faster rate. Lower-wattage output chargers will still charge your phone, although they will take longer to fully charge your phone’s battery.
Person using EcoFlow RIVER 3 Plus at desktop
What Charger Does the iPhone 17 Use?
This newer model of the iPhone uses a USB-C charging port, unlike the older, more outdated models that used a traditional Lightning port. This style of charger enables faster charging capabilities and is commonly used on newer devices, such as laptops and tablets.
Can I Use My Old Charger for My New iPhone 17?
In most cases, you can use an older USB-C charger for your new iPhone. That being said, these chargers are typically not nearly as powerful as the newer cables and may take longer to charge your phone. To be on the safe side, only use an old charger if it’s listed as 20W or higher on the cord or power box.
iPhone 17 Chargers Deliver Speed, Reliability, and Everyday Convenience
The iPhone 17 is an incredible device that boasts numerous unique features, designed to make the day-to-day experience incredibly user-friendly and enjoyable. Keeping your device charged and powered up is a surefire way to stay connected and enjoy all the benefits of this technologically advanced phone.
Interested in learning about more backup power tools you can add to your collection? Take a look at EcoFlow’s RIVER 3 Plus, a powerful, yet compact backup power solution for your home or on the go.
Smart Devices
