10 Must-Have iPhone Accessories to Buy
You have the new iPhone 17, and now you need the right gear for it. Your iPhone is a great tool by itself. And the right iphone accessories can make it even better. These ten items are the best iphone accessories to buy. They protect your phone and add new features to make your life easier.
MagSafe Case
A good case is the first thing you should buy. It is something you must have. A case protects your phone when you drop it. It absorbs the force from a fall and keeps the phone’s body and screen from breaking. You should get a case that works with MagSafe. MagSafe is a ring of magnets inside the phone. It helps other apple iphone accessories attach perfectly every time.
When you look for a case, find one with raised edges. The edges should be higher than the screen and the camera lenses. This small detail keeps the glass from getting scratched when you put your phone down. Cases are made of different materials. A soft material like rubber is good for absorbing shock from drops. A hard plastic shell is good for stopping scratches and giving the case strength.
Tempered Glass Screen Protector
Your iPhone's screen looks amazing, and you want it to stay that way. A tempered glass screen protector is the best way to do this. It covers your screen and protects it from scratches from things like your keys. If you drop your phone, the protector might break, but your real screen will be safe. This helps your phone look new and keeps its value high.
You should look for a screen protector with a 9H hardness rating. This is a measure of how well it resists scratches. A 9H rating offers strong protection from most everyday objects. You should also look for a protector with a special coating that keeps off oily fingerprints. This makes your screen easier to see and clean. Most screen protectors now come with a plastic guide. This guide helps you put the protector on perfectly without any air bubbles.
Magnetic Wireless Power Bank
Your phone’s battery running out is a big problem, especially when you are not home. A magnetic wireless power bank is the easiest way to solve this. It is a portable battery that sticks to the back of your iPhone with magnets. It charges your phone without any wires. This setup lets you keep using your phone anywhere, so you do not need to look for a wall plug.
The EcoFlow RAPID Mag Power Bank is a very good choice. It is very thin and light, so you will not notice it in your pocket. It also has a system to keep it from getting too hot while it charges your phone. This is important for keeping your iPhone's battery healthy for a long time. The bigger 10,000mAh model also has a built-in stand. You can use the stand to prop your phone up, so you can watch videos or make video calls while it charges.
EcoFlow RAPID Mag Power Bank (10,000mAh,7.5W,Magnetic Charging)
Stay powered anywhere with EcoFlow RAPID Mag. Enjoy 10,000mAh capacity, 7.5W magnetic wireless charging, and sleek portability for all-day use.
Fast USB-C Cable and Wall Adapter
The simple charger that comes with some phones is slow. Your iPhone can charge much faster, but you need better gear. A USB-C wall adapter with 20 watts of power or more is what you need for fast charging. It can charge your battery up to 50% in about 30 minutes. This is a big help when you are in a hurry.
You should also look for a charger that uses GaN technology. GaN chargers are much smaller than older chargers, but they are just as powerful and create less heat. You also need a good cable. A braided nylon cable is stronger and lasts longer than a plain plastic one. And make sure the cable is MFi-Certified. This means Apple has tested it, so you know it is safe for your iPhone.
3-in-1 Wireless Charging Stand
Having separate cables for your iPhone, Apple Watch, and AirPods makes your desk or nightstand look messy. A 3-in-1 charging stand is a simple way to fix this. It is a single device that charges all three of your main gadgets at once. It uses only one wall plug, so it cleans up your space and keeps everything organized and ready to go.
When you buy a stand, pick one that uses MagSafe for the iPhone spot. MagSafe magnets will hold your phone in the perfect position for the best charge. A good stand also holds your phone at an angle. This is great because you can see notifications easily. You can also use your iPhone as a bedside clock with StandBy mode.
MagSafe Wallet
Carrying a big, thick wallet can be uncomfortable. A MagSafe wallet is a thin card holder that attaches to the back of your iPhone with magnets. It is made to hold two or three of your most important cards, like an ID and a credit card. It lets you carry your essentials without a bulky wallet, so you have less to worry about.
Many of these wallets also have RFID blocking. This is a special material that helps protect your credit card information from being stolen by scanners. The wallets are made from strong materials like leather that last a long time. The magnets are strong, so the wallet stays on your phone. But it is still easy to take off when you need to use your cards.
MagSafe Phone Grip and Stand
New iPhones are big, and it can be hard to hold them with one hand. A MagSafe grip gives you a safe and comfortable way to hold your phone. It sticks to the back of your phone and gives your fingers something to hold onto. This makes it easier to text and take pictures, and it helps you avoid dropping your phone.
Most grips also work as a small stand. You can pop the grip open and use it to set your phone on a table. This is great for watching movies or for hands-free video calls. When you are done, the grip folds down flat. This means it does not make your phone bulky, so it can still fit in your pocket easily.
MagSafe Car Mount with Charging
Using maps on your phone for driving directions uses a lot of battery. A MagSafe car mount with a built-in charger solves this issue. It holds your phone in a place where you can see it safely. And it charges your phone at the same time. This means you can use your GPS and still have a full battery when you get where you are going.
The magnetic mount is also very safe and easy to use. You can attach your phone with just one hand. This is much better than old mounts that you had to fiddle with. The magnets are very strong, so your phone will stay in place even if you drive on a bumpy road. You can find these mounts in different styles that attach to your air vent or your dashboard.
Quality Wireless Earbuds
Wires are a hassle. Wireless earbuds give you total freedom when you listen to music or take phone calls. Good earbuds connect to your iPhone instantly as soon as you open their case. They are great for many situations, like working out at the gym or taking a call while you are busy doing something else.
You should look for earbuds with Active Noise Cancellation (ANC). This feature uses tiny microphones to listen to the noise around you and then creates an opposite sound to cancel it out. This lets you hear your music clearly, even in a loud place. A "transparency mode" is also a useful feature. It lets you hear what is going on around you, so you can be aware of your surroundings when you need to be.
Item Tracking Tags
Losing your keys or wallet is very frustrating. An item tracker is a small tag you can put on your things to help you find them. You can attach it to your keychain, put it in your bag, or slide it into your wallet. Then you can use the Find My app on your iPhone to see where your items are.
If you lose something nearby, you can make the tag play a loud sound from your phone to help you find it. If you left it somewhere else, the tracker uses Apple's secure Find My network to locate it. It sends out a signal that other Apple devices can pick up, and it will show you the location on a map.
Conclusion about Most Important Accessories
A new iPhone is just the start. The accessories in iphone catalogs help you protect it and do more with it. From a case that saves your phone from a drop to a power bank that keeps you charged all day, these tools are very useful. When you choose the right ones for your needs, you make your great phone even better.
A smiling man holds an iPhone connected to a white magnetic power bank with a clear blue sky and white clouds in the background.A smiling man holds an iPhone connected to a white magnetic power bank with a clear blue sky and white clouds in the background.
Q1. Where can I find iPhone accessories near me?
You can find many iphone accessories near you at stores like Best Buy, Target, and the Apple Store. Going to a store is good because you can see the products yourself. For more choices, you can look online. Websites like Amazon have a huge selection, and you can read reviews from other people before you buy.
Q2. Do I need to buy all new accessories for the iPhone 17?
No, you do not. Many accessories will work with new phones. For example, any MagSafe charger or wallet will work perfectly with the new iPhone 17. The one main thing you will need to buy is a new case. This is because the new phone will have a different size and camera shape, so you will need iphone 17 accessories that fit it perfectly.
Q3. How do I know if an iPhone accessory is good and safe?
You should buy from brands that are well-known and have good reviews. For any chargers or cables, you should look for the "MFi Certified" label on the box. This means Apple has tested the product and says it is safe for your iPhone. You should stay away from very cheap, no-name electronics because they might not work well and could even damage your phone.
