How Big of a Mini Split Do I Need? Sizing by BTUs, Load, and Climate
- How Mini Split Size Is Measured: BTUs, Tons, and Zones
- A Quick Starting Estimate, Then a Manual J Load Calculation
- After You Pick the Model: Voltage, Power Draw, and Backup Options
- How Long Could a Battery Run a Mini Split? A Labeled Estimate
- Common Mini Split Sizing Mistakes and Questions to Ask Your Installer
- Conclusion
- FAQs
A mini split that's too small runs flat out on the hottest afternoon and still can't keep up. One that's too big cools the room fast, shuts off, and leaves the air damp and clammy. If you've been asking "how big of a mini split do I need," know that square footage is only the start. Sun, ceiling height, insulation, how cold your winters get, and the number of zones all change the answer. This guide covers a quick BTU estimate and the load math pros use. It also covers the electrical details to check before you buy.
Mini split size is measured in British thermal units per hour (BTU/h). That's how much heat a unit can move out of, or into, a room each hour. Contractors often talk in "tons" instead. A ductless system can serve one room or several, and each indoor head needs its own size.
An Oklahoma State University fact sheet explains that one ton equals 12,000 BTU per hour. That makes the conversions simple:
Capacity (BTU/h) | Tons |
9,000 | 0.75 |
12,000 | 1 |
18,000 | 1.5 |
24,000 | 2 |
36,000 | 3 |
ENERGY STAR's ductless heating guide explains the setup. Refrigerant links one or more indoor heads to an outdoor unit. Mini splits suit homes without ducts and can add to an existing system.
Single-Zone vs. Multi-Zone Systems
One outdoor unit can feed one head or several. Size each head to its own room, then have the installer confirm the outdoor unit. So you answer "how big of a mini split system do I need" room by room.
Here's a simple example. Say a 280-square-foot bedroom and a 500-square-foot living room share one outdoor unit. The chart in the next section suggests about 7,000 BTU/h for the bedroom and about 12,000 BTU/h for the living room. That's roughly 19,000 BTU/h in total, before any changes for sun or people. The installer then checks that the outdoor unit can carry both heads.
Most mini splits are also heat pumps, so heating capacity matters as much as cooling in cold climates. Once you know what BTUs mean for cooling and heating, the numbers on a mini split box make a lot more sense. With the units sorted out, a square-footage chart gives a fast first guess. Just treat it as a starting point.
ENERGY STAR publishes a room-size chart that's a handy first pass for a single room. But it was made for room air conditioners, not ductless heat pumps. It also skips heating loads. For the final size, ENERGY STAR and the Department of Energy both point to a Manual J load calculation.
Think of the ENERGY STAR room AC chart as the quick answer to "how big of a mini split AC do I need" for one room's cooling. Its capacities assume an 8-foot ceiling.
Area to be cooled (sq ft) | Capacity (BTU/h) |
100 up to 150 | 5,000 |
150 up to 250 | 6,000 |
250 up to 300 | 7,000 |
300 up to 350 | 8,000 |
350 up to 400 | 9,000 |
400 up to 450 | 10,000 |
450 up to 550 | 12,000 |
550 up to 700 | 14,000 |
700 up to 1,000 | 18,000 |
1,000 up to 1,200 | 21,000 |
1,200 up to 1,400 | 23,000 |
1,400 up to 1,500 | 24,000 |
1,500 up to 2,000 | 30,000 |
2,000 up to 2,500 | 34,000 |
Then cut capacity 10 percent for a heavily shaded room, or add 10 percent for a sunny one. Add 600 BTU for each regular occupant beyond two, and add 4,000 BTU for a kitchen.
Mini splits come in set sizes, often 9,000, 12,000, 18,000 and 24,000 BTU/h. Round to the nearest size your brand offers, and don't jump two sizes "to be safe." ENERGY STAR says oversized units cost more, waste energy, and leave rooms damp and clammy.
A Worked Example
Let's put the chart to work. A sunny 500-square-foot living room starts at 12,000 BTU/h. The sun adds 10 percent, which brings it to about 13,200 BTU/h. If three people use the room most days, add 600 BTU for the third person. That lands near 13,800 BTU/h.
Now compare that to the sizes you can buy. A 12,000 BTU/h unit is the closest step, and an 18,000 BTU/h unit is a big jump up. This is where a load calculation earns its keep. It tells you whether the smaller unit is enough for your walls, windows and climate.
Why a Manual J calculation decides the final size
ENERGY STAR says your contractor should check the size with Manual J. It works out your home's heating and cooling needs. The DOE's Building Science Education Solution Center adds a warning. Rules of thumb often lead to systems that are too big and cycle on and off too much. Manual J looks at your local weather, insulation, air leaks and windows. It also counts ceiling height, people and heat from appliances.
Size for winter, too, in cold climates
To earn the ENERGY STAR Cold Climate designation, heat pumps must meet specified performance requirements at 5°F. Cold climate units keep working below 5°F. When it gets even colder, ENERGY STAR says pairing them with a back-up energy source heats most efficiently.
In cold regions, heating can set the size. Ask for the unit's heating capacity at your winter design temperature. Also ask if backup heat is part of the plan. If your home has ducts, you might compare mini splits versus heat pumps first.
Your winter design temperature is the cold outdoor temperature your area plans heating around. Your installer can look it up for your location. If the unit's heating output at that temperature falls short of your home's heat loss, you'll need a bigger unit or another heat source.
Once Manual J points to a model, check its nameplate. It lists the voltage and power that unit needs.
The model you pick also decides your electrical needs. Smaller mini splits may run on 115V, while larger ones need a dedicated 208/230V circuit. Those same details decide which home battery, if any, can keep it running during a power outage.
What the Nameplate Tells You
GREE's mini split wiring guide says the breaker must match the MOCP (max overcurrent protection) on the nameplate. NEC 440.14 also requires a disconnect within sight of the outdoor unit.
Use that to check your nameplate, not as a wiring guide. A licensed electrician should handle all wiring. From the submittal sheet, note the voltage, capacities, input watts, MCA (the circuit's minimum amps), MOCP and any starting current. If the sheet lists none, ask the installer.
Voltage matters most if you plan a DIY install. A 115V unit and a 208/230V unit need different circuits, and the larger ones need a dedicated circuit and space in your panel. If your panel is full, that can add cost and time. Check with an electrician before you buy, not after.
Estimating Watts From BTUs
The Oklahoma State fact sheet defines EER as cooling output in BTU divided by watts used. It's measured at a set temperature, usually 95°F. So watts ≈ BTU/h ÷ EER. A made-up 12,000 BTU/h unit with an EER of 12 would draw about 1,000W. Real draw shifts with weather and setpoint.
Matching a Home Battery to Your Mini Split
Your mini split's voltage and watts tell you which home battery fits. EcoFlow's TITAN home batteries come in a 120V-only model and split-phase 120V/240V models. Each one links to your home circuits through an EcoFlow Smart Home Panel 10, wired by a licensed electrician. The EcoFlow TITAN 5000 Classic fits a 115V single-zone mini split if its running and starting watts stay within 4,000W. It can also cover critical loads like the fridge and Wi-Fi.
Does your load calculation call for a larger head or a multi-zone system on a 208/230V circuit? Then a 120V-only battery is off the table. You'll need a split-phase system like the EcoFlow TITAN 5000 Plus that can carry a 240V home circuit.
A battery can't change your mini split's capacity or load calculation, so size the mini split first. The rules for sizing a home battery backup apply to a mini split just as they do to a fridge.
To check the fit, list everything you want running at once during an outage. Add up their running watts, and make sure the total stays under the battery's rated output. Then check the largest starting watts on top of that. If you're unsure of any figure, confirm it with the installer or the product label. Next, a simple estimate shows how long stored energy would last.
Runtime depends on how many watts the mini split really draws. That number moves with the weather, your setpoint and how hard the compressor works. A simple estimate still helps set expectations.
The formula uses 0.85 to allow for conversion losses: hours ≈ battery Wh × 0.85 ÷ load W. One 5kWh EcoFlow TITAN unit holds 5,017.6Wh. That leaves about 4,265Wh to use.
Average draw (illustrative, not a specific model) | Estimated runtime, one 5kWh unit | Estimated runtime, two 5kWh units (10,035.2Wh × 0.85) |
600W | about 7.1 hours | about 14.2 hours |
1,000W (the hypothetical 12,000 BTU/h, EER 12 example) | about 4.3 hours | about 8.5 hours |
1,300W | about 3.3 hours | about 6.6 hours |
Use your unit's rated input watts if known. Other loads cut these hours, and heating can draw more than cooling. Solar can extend daytime runtime, depending on weather.
Adding a second 5kWh battery doubles the stored energy in this estimate, as the table shows. It doesn't raise the battery's output, though. EcoFlow notes that extra batteries add kWh, not kW, so they stretch runtime without letting you start a bigger unit.
Starting watts matter too, especially for older non-inverter units. Before running an air conditioner on battery power, ask the installer for its starting and running watts. And before you sign a quote, a few questions can catch common sizing mistakes.
Most sizing problems come from shortcuts. Think of one big head for an open floor plan, a chart number with no changes, or a cooling-only estimate in a cold climate. Plenty of people search "how big of mini split do I need" and stop at the first chart. A short list of questions keeps the quote honest.
Mistakes to Avoid
Oversizing "to be safe": A bigger unit can leave the room cool but clammy.
One head for rooms split by walls or doors: Air from one head won't reach a closed room well.
Ignoring low-temperature heating capacity: In cold places, winter can set the size.
Skipping sun, ceiling and occupancy adjustments: These can move the number up or down.
Buying a DIY unit before checking voltage and circuits: Your panel may not have room.
Questions to Ask Before You Sign
Did you run a Manual J for each room or zone? Can I see it?
What is the unit's heating capacity at our winter design temperature?
Is this model 115V or 208/230V, and does my panel have room?
Is it ENERGY STAR certified, and cold climate certified if needed?
If I add battery backup later, what are the starting and running watts?
Quotes vary with the number of zones and line-set length. Knowing what mini split systems cost helps you compare them.
Start with the ENERGY STAR chart, then adjust it for sun, people and kitchens. Let Manual J set the final size, and check heating capacity if you live somewhere cold. Once you pick a model, write down its voltage, input watts, MCA and MOCP for planning circuits or backup. For outage backup, compare the EcoFlow TITAN 5000 Classic for 115V units and critical loads with the EcoFlow TITAN 5000 Plus for 240V circuits. Both connect through an EcoFlow Smart Home Panel 10 installed by a licensed electrician.
What size mini split do I need for a 500 square foot room?
About 12,000 BTU/h, based on ENERGY STAR's chart. Adjust for sun, people or a kitchen, then confirm with a load calculation. A sunny room with three regular occupants might land closer to 13,800 BTU/h.
How many square feet does a 1-ton mini split cool?
One ton is 12,000 BTU/h, or roughly 450 to 550 square feet on ENERGY STAR's chart. Insulation, climate and ceiling height can shift that.
Is it better to oversize a mini split?
No. An oversized unit costs more and wastes energy. It can also cool the room before removing humidity.
Do mini splits need 240V?
Not always. Some smaller 9,000 to 12,000 BTU models run on 115V. Larger systems need a dedicated 208/230V circuit, so check the nameplate.
Can a home battery run a mini split during a power outage?
Yes, if the battery's voltage and output match the unit. A licensed electrician also needs to connect it through a proper panel. Runtime depends on actual draw and stored kWh. Other devices on the same battery will shorten that time.
