Virtual Net Metering: How Shared Solar Bill Credits Work
Not everyone can put solar panels on their own roof. Renters, condo owners, and tenants in multifamily buildings often can't. Virtual net metering lets the output of one solar system be shared as bill credits across several utility accounts, such as the apartments in a building. The rules are set by each state's utility commission, and they change over time. This guide explains how virtual net metering works, uses California's current VNEM and VNBT rules from the CPUC as an example, covers who qualifies, and explains what it doesn't do.
What Is Virtual Net Metering?
Virtual net metering allows one shared solar installation to generate electricity bill credits for multiple utility accounts. Instead of installing separate panels for each apartment, the system sends electricity to the utility grid, which distributes credits according to a pre-arranged allocation. According to the California Public Utilities Commission (CPUC), this virtual net energy metering (VNEM) arrangement allows property owners to share solar benefits with tenants and common areas, making renewable energy more accessible to apartment residents.
How Does Virtual Net Metering Work?
Virtual net metering works by connecting a shared solar installation to the utility grid and distributing the resulting bill credits among participating electricity accounts. The process is similar to how community solar works, allowing multiple households to benefit from one renewable energy system. The property owner sets the credit allocation, and the utility applies each participant's share to their electricity bill according to the program's rules.
Install a shared solar system: A property owner installs a renewable energy system, usually on the building's rooftop or another suitable location.
Generate electricity: The solar installation produces electricity and sends it through its designated utility connection.
Allocate bill credits: The property owner establishes how the available solar benefits are divided among participating accounts.
Apply credits to utility bills: The utility calculates and applies the appropriate credits to individual tenant and common-area accounts.
What Does Reverse Metering Mean?
Reverse metering is an informal term used to describe how solar electricity exports can earn utility bill credits through net metering. When a qualifying solar system sends excess electricity to the grid, a bidirectional meter records the energy flow, although modern meters do not literally run backward. Unlike traditional net metering, virtual net metering distributes eligible solar credits across multiple utility accounts rather than one account. These credits can reduce electricity bills, but they do not provide backup power during a grid outage.
Bill Credits vs Backup Power: A Separate Need
Virtual net metering is a billing arrangement, not an emergency electricity supply. Even when a shared solar installation continues generating electricity, participating apartments generally cannot use that generation directly when the utility grid goes down. Most grid-connected solar installations shut down during a grid outage unless they have appropriately configured backup equipment and isolation controls. This protects utility workers from unexpected electricity flowing into power lines during repairs.
What Can You Do When the Grid Goes Down?
If your main goal is to reduce monthly electricity bills, review your virtual net metering allocation agreement and utility tariff first, as you do not need a battery to receive solar credits. However, if you also want backup power during outages, you can explore battery backup options for apartment living to keep essential devices such as LED lamps, Wi-Fi routers, smartphones, and laptops running. A portable power station operates separately from the property's solar installation and does not affect your virtual net metering eligibility, generate additional bill credits, or send electricity to the grid.
A Separate Backup Option for Essential Devices
Virtual net metering can help with electricity expenses, but it cannot replace a practical outage plan. If you also want to keep your lights, phones, and internet equipment running, a portable power station offers a way to supply those devices independently. For tenants who cannot install permanent backup equipment, the EcoFlow DELTA 3 Classic provides a portable option. It can supply power directly to compatible appliances and electronics without requiring changes to apartment wiring.
Estimated Backup Runtime for Essential Devices
A portable power station can help keep essential devices running during a grid outage, even when your apartment participates in virtual net metering. The following figures are estimates based on assumed wattage and 85% usable battery capacity. Actual runtime will vary depending on device consumption, power conversion losses, and usage.
Load (example) | Estimated power use | EcoFlow DELTA 3 Classic (870Wh usable est.) |
Router + LED lamps + phones | About 40W | About 22 hours |
Estimation method: (Battery capacity × 0.85) ÷ Load (W) = Runtime (hours).
These figures are illustrative examples, not guaranteed runtimes. To estimate your battery life, use the actual power consumption (wattage) of your connected devices. Keep in mind that power conversion losses and changes in device usage may reduce the actual runtime.
California VNEM and VNBT: Current Rules
California has made important changes to its virtual solar credit policies. The state introduced the Virtual Net Billing Tariff (VNBT) as the successor to the traditional Virtual Net Energy Metering (VNEM) tariff for most new applicants. The change was adopted through CPUC Decision 23-11-068. Since February 15, 2024, most new applicants have been placed under VNBT unless they qualify for the remaining SOMAH or MASH VNEM arrangements. The Solar on Multifamily Affordable Housing (SOMAH) program remains available through 2032 for eligible affordable multifamily properties.
What Changed Under California's VNBT?
California's Virtual Net Billing Tariff (VNBT) changes how solar generation credits are calculated and distributed among participating utility accounts. It introduces updated eligibility requirements, time-of-use (TOU) rate rules, and 15-minute interval netting for residential customers. It also bases export compensation on the Avoided Cost Calculator (ACC), rather than automatically crediting exported electricity at the full retail rate.
New applications: Most new applicants must use VNBT rather than the general VNEM tariff.
Eligible programs: Qualified Solar on Multifamily Affordable Housing (SOMAH) and MASH successor tariff properties can continue using applicable VNEM arrangements.
Residential accounts: Benefiting residential accounts must use an eligible time-of-use (TOU) electricity rate.
15-minute interval netting: Residential accounts receive 15-minute interval netting between their electricity consumption and allocated generation.
Export compensation: Under VNBT, exported electricity is compensated using values based on the Avoided Cost Calculator (ACC), rather than automatically receiving the full retail electricity rate.
Are SOMAH and MASH Still Available?
Solar on Multifamily Affordable Housing (SOMAH) supports qualifying affordable multifamily properties with eligible solar installations, helping extend solar benefits to residents. The program provides incentives for eligible properties and is currently listed by the CPUC as available through 2032. The original Multifamily Affordable Solar Housing (MASH) program operated from 2008 to 2021, but qualifying properties in participating utility territories may still use the MASH successor VNEM tariff if they meet the applicable eligibility and interconnection requirements.
Do Other States Follow California's Rules?
No. Virtual net metering policies vary across the United States, with some states offering shared solar programs and others following different billing arrangements or limiting participation. Utility providers may also set their own eligibility requirements. Since these rules can affect solar savings and billing, understanding California electric bills and changes to NEM can help illustrate why you should check your state's public utility commission and local electricity provider before joining a shared solar arrangement.
Who Benefits From Virtual Net Metering?
Virtual net metering is useful for people who want to benefit from solar energy but cannot install panels on their own properties. Multifamily buildings are a natural fit because they often have several utility meters but limited shared rooftop space. Unlike traditional net metering arrangements for grid-tied solar systems, virtual net metering allows eligible solar credits from one installation to be allocated across multiple utility accounts.
1. Tenants in Apartment Buildings
Renters often cannot install rooftop solar panels or make permanent electrical modifications to their apartments. Virtual net metering provides another way to access solar-related financial benefits without purchasing or maintaining a solar system. If their property participates in an eligible program, tenants may receive allocated credits directly on their electricity bills.
2. Affordable Housing Communities
Affordable multifamily housing communities can benefit from shared solar arrangements that extend financial savings to eligible residents. For example, California's SOMAH program supports qualifying properties by helping make solar benefits available to tenants and common areas. This approach allows property owners to use available rooftop space while potentially reducing electricity expenses for participating residents.
3. Property Owners With Multiple Utility Meters
Property owners managing buildings with several separately metered units may also benefit from virtual net metering. A qualifying property can have individual meters for apartments, separate accounts for hallway lighting, and additional meters for shared facilities. The solar credits generated by one installation can then be allocated across eligible accounts according to the program's rules and the property's agreed allocation structure.
How Can You Find Out If Your Apartment Qualifies?
If you live on a multifamily property, don't assume that rooftop solar automatically means you receive bill credits. Start by speaking with your property manager or owner. Ask these questions:
Does the building participate in virtual net metering or a virtual net billing arrangement?
Which utility tariff applies to the property?
How are solar credits divided among individual apartments?
Are common-area accounts included in the allocation?
Where will the credits appear on my electricity bill?
What happens to my allocated credits if I move out?
Virtual net metering allows multiple utility accounts to share bill credits from one solar installation, making solar benefits more accessible to apartment tenants and multifamily properties. In California, the CPUC's VNBT (D.23-11-068) replaced VNEM for most new applicants starting February 15, 2024. Before participating, check your state's rules and ask your property owner how credits are allocated. For separate backup power during outages, the renter-friendly EcoFlow DELTA 3 Classic is another option.
What is virtual net metering?
Virtual net metering is a billing arrangement that allows electricity credits from one shared solar installation to be distributed across multiple utility accounts. It is commonly used in multifamily buildings and other qualifying properties.
Who qualifies for virtual net metering?
Eligibility depends on the state, utility provider, property type, and applicable tariff. Multifamily buildings, apartment communities, and affordable housing properties are common participants.
Is VNEM still available in California?
Yes. VNBT replaced general VNEM for most new applicants on February 15, 2024. Eligible SOMAH and MASH properties can continue using their applicable VNEM tariffs.
Does virtual net metering give me power in an outage?
No. Virtual net metering is a billing arrangement, not a backup electricity supply. A separate battery system or appropriately configured backup installation is needed to provide electricity during grid outages.
What is reverse metering?
Reverse metering is an informal expression sometimes used when discussing solar electricity exports and credits. Virtual net metering specifically refers to distributing eligible solar bill credits among multiple utility accounts rather than physically sending electricity to each participating property.
