10kW Solar System: Design, Output, and How to Plan Storage
A 10kW solar system can be a good fit for a larger home with substantial electricity use. But the 10kW rating describes the array's peak power, not how much electricity it produces in a day. Panel layout, inverter choice, roof conditions, and location all affect the system. Storage adds another design decision. The battery must work with the array's electrical limits or connect through a compatible inverter. Here's what to consider before choosing equipment or requesting installation quotes.
How a 10kW Solar System Is Designed
A 10kW solar system has a solar array rated to produce 10,000 watts under standard test conditions. The panels connect in groups called strings, which feed an inverter. The inverter converts the panels' DC electricity into AC power for household use.
How many panels does a 10kW system need?
This number will depend on how many watts your panels are. Divide 10,000 watts by the output rating of one panel. For example, a system with 400W panels would need 25 panels: 10,000W ÷ 400W = 25 panels. That's a planning example, not a fixed layout. Panel wattage, roof space, shading, and the installer's design can change the final count. Your roof also needs enough usable area for the panels, with room for required setbacks and access.
What does 10kW mean compared with 10kWh?
These two units measure different things:
Kilowatts (kW) measure power, or how much electricity a system can produce or supply at a given moment.
Kilowatt-hours (kWh) measure energy used or produced over time.
A 10kW array doesn't automatically produce 10kWh every hour or 10kWh per day. Its energy production changes with sunlight, weather, season, and system design. The EIA explains this distinction in its guide to measuring electricity.
Which inverter setup should you choose?
A solar installer might recommend a string inverter, microinverters, or power optimizers. The way panel output is handled varies with each setup. In a string configuration, connected module strings output direct current (DC) directly to a string inverter, which completes the DC-to-AC conversion for the entire group. By contrast, microinverters handle DC-to-AC conversion at the individual panel level, whereas power optimizers condition each panel's DC output before sending it to a central inverter. Shade, roof orientation, equipment compatibility, and the need for battery storage all affect the choice. The installer also must check the electrical limits of each string. The voltage and current must be within the operating range of the inverter. If you plan to add a battery, its solar input limits matter too. Compare system sizes before settling on an array.
Planning Storage for a 10kW Array
A home battery can connect directly to compatible solar strings or work alongside an existing inverter through AC coupling. The right setup depends on your array, inverter, and utility requirements. Have a solar designer and licensed electrician confirm compatibility before installation.
EcoFlow TITAN 5000 Plus for solar storage
The EcoFlow TITAN 5000 Plus accepts up to 8kW of DC solar input through two 4,000W ports. Since a 10kW array exceeds this limit, the entire array can't connect directly to the unit. A professional must verify system compatibility and determine whether to split the array or use AC coupling with the existing inverter. Note that AC coupling with an existing rooftop PV system requires configuring the Smart Home Panel 10 (SHP10, 240V) and CT sensors, and connecting the SHP10 to a residential electrical system must be performed by a qualified, licensed electrician. The EcoFlow TITAN 5000 Plus has a 5kWh LFP battery, expandable to 30kWh with additional batteries sold separately. It provides 7,200W of output, with up to 10,000W when PV and AC power are combined, according to EcoFlow.
Example storage estimate for a 10kW array
The EcoFlow TITAN 5000 Plus can accept up to 8kW of DC solar input, so a 10kW array needs a compatible system design. The remaining 2kW would stay connected to its own inverter or require a redesigned array. The figures below are estimates, not a wiring plan.
Example | Value |
Array rating | 10kW |
Maximum DC into one EcoFlow TITAN 5000 Plus | 8kW (two 4kW strings) |
Remaining 2kW | Stays on its own inverter or is redesigned |
Usable energy with 3 batteries (15kWh × 0.85) | about 12,750Wh |
The usable energy estimate applies an 85% factor to the batteries' combined rated capacity. Actual system design depends on string voltage, current, and inverter compatibility.
How Much Does a 10kW Solar System Produce?
A 10kW system's actual production depends on where you live, the direction and tilt of the panels, shading, weather, and the time of year. A system in Arizona won't have the same production pattern as one in the Northeast. Even two homes in the same city can get different results if their roofs face different directions or receive different amounts of shade.
Estimate production with the NLR PVWatts Calculator
The National Laboratory of the Rockies (NLR, formerly NREL) provides the PVWatts Calculator to estimate solar production for a specific location. Enter your address or ZIP code, then provide the system size and other details requested by the tool. For a useful estimate, review:
Location: Enter the installation address or a nearby location.
System size: Set the DC system size to 10kW.
Array direction and tilt: Use the proposed roof layout when you have it.
System losses: Use the calculator's default assumptions unless your installer provides better project-specific values.
Monthly and annual output: Review both. Seasonal changes can affect how much electricity you have available.
PVWatts provides estimates, not a production guarantee. Ask your installer to explain the assumptions and compare the estimate with your home's annual electricity use. For context, the EIA reported that the average U.S. residential electric-utility customer purchased about 10,791 kWh of electricity from power companies in 2022 (which differs from total household electricity consumption for homes with on-site solar). Your own utility bills are a better guide to system sizing. Review a full year of usage, including high-demand months, before deciding whether a 10kW array makes sense. For a closer look at production estimates, read how much power a 10kW system produces.
10kW solar system cost and incentives
The cost of a 10kW solar system depends on more than the panels. Final quotes will depend on equipment choices, roof condition, labour, permitting, and electrical work. Adding a battery increases the project scope, so ask installers to price the solar array and storage separately.
What affects the installation price?
When comparing proposals, look at the full equipment list and installation work. Ask each installer to explain:
Panels and inverter: Compare equipment models, ratings, and warranty terms.
Roof work: Repairs, roof material, pitch, and layout can affect labor.
Electrical work: Panel upgrades, wiring, and battery integration may add costs.
Permits and inspections: Requirements vary by city and utility.
Battery storage: Check battery capacity, solar input limits, backup circuits, and installation costs separately.
Request itemized quotes from more than one qualified installer. Make sure each proposal covers the same system size and equipment scope. Otherwise, the lowest total may not represent the same installation. You can also compare the estimates with this guide to home solar system costs. Use local quotes for your decision because prices vary by location and project.
Is there a federal solar tax credit in 2026?
According to the IRS Residential Clean Energy Credit guidance, the credit is not available for property placed in service after December 31, 2025. That means homeowners should not include the federal Section 25D residential clean energy credit in the financial plan for a system placed in service during 2026. Check the current IRS guidance and ask your tax professional about any other incentives that may apply to your location or circumstances. State, local, and utility programs have their own eligibility rules and deadlines.
A 10kW solar system starts with a 10,000W array, but panel count, inverter design, roof conditions, and location determine how it performs. Use NLR's PVWatts Calculator to estimate production for your address, then compare that estimate with your electricity bills. If you want battery storage, check the array's string configuration and the battery's solar input limits before choosing equipment. The EcoFlow TITAN 5000 Plus can accept up to 8kW of DC solar input as part of a professionally designed system. Ask an installer to review the wiring, inverter compatibility, and backup loads before making a decision.
How much power does a 10kW solar system produce?
The output of a 10kW solar system will depend on your location, the direction of the roof, the tilt, shading, and the season. Enter your address and system information into NLR’s PVWatts Calculator to estimate your monthly and annual production. Then compare the results to your home’s annual electricity usage to see how much of your demand the system could serve.
How many panels are in a 10kW system?
The number of panels depends on the wattage of each panel. For example, a 10kW system requires 25 panels at 400W each or 20 panels at 500W each. The final layout will be determined by your roof space, shading, and inverter design.
Is a 10kW solar system the same as 10kWh?
Nope. A kilowatt (kW) is a measure of power. A kilowatt-hour (kWh) is a measure of energy. A 10kW array has a peak power rating of 10,000W. Its energy production depends on how long it receives usable sunlight and the conditions at the site.
Can one battery store all of a 10kW array's output?
Not necessarily. The EcoFlow TITAN 5000 Plus accepts up to 8kW of DC solar input across two ports. A 10kW array needs a compatible design, which may involve keeping part of the array on its own inverter or using an AC-coupled setup.
Per the IRS Residential Clean Energy Credit page, the credit isn't available for property placed in service after December 31, 2025. Check the IRS website for current guidance before making a purchase decision.
