Concentrated Solar Power: How CSP Plants Work and How They Differ From Solar Panels
Concentrated solar power, or CSP, doesn't use solar panels at all. Mirrors concentrate sunlight onto a receiver. Many plants use the heat to make steam for a turbine, while a dish system can drive a Stirling engine. Because heat can be stored, some CSP plants keep producing power after sunset. That's a big difference from photovoltaic panels, which turn light directly into electricity. This guide explains how CSP works, the main CSP types according to DOE and EIA, thermal storage, and how CSP compares to the solar panels and batteries used at home.
What Is Concentrated Solar Power and How Does It Work?
CSP plants use mirrors to focus sunlight onto a receiver. A fluid in the receiver gets very hot. In common trough and tower plants, that heat makes steam to drive a turbine and generator. Dish engines work differently, using the heated fluid to move pistons that power a generator.
The Basic Steps Inside a Steam-Cycle Plant
Mirrors and a receiver: The U.S. Department of Energy (DOE) says CSP technologies reflect sunlight with mirrors and concentrate it onto a receiver. The sunlight heats a high-temperature fluid inside.
Heat-transfer fluid: The U.S. Energy Information Administration (EIA) explains that this fluid is heated and circulated in the receiver. It is then used to produce steam.
Turbine and generator: The steam is converted into mechanical energy in a turbine. The turbine powers a generator, and the generator makes electricity.
Tracking systems: Mirrors shift as the sun moves across the sky. EIA notes that tracking keeps sunlight focused on the receiver through the day.
A CSP solar power plant usually spreads a large field of collectors across open land. Some U.S. facilities have two or more plants on one site, each with its own array and generator.
Heat Has Other Uses Too
Concentrated solar energy is not only for making electricity. DOE lists industrial uses for the heat, including water desalination, food processing, chemical production, and mineral processing.
Photovoltaic panels skip the heat step completely. The basics of solar photovoltaic versus solar thermal explain the split.
Most CSP plants operate at utility scale. At home, solar means panels and, often, a battery. Here's how that small-scale route works.
CSP vs Solar Panels With Battery Storage at Home
Households typically choose photovoltaic panels, which make electricity directly. Small dish/engine CSP systems can serve distributed needs, but they are rare in residential settings. Many PV owners add storage, though a battery is optional. A portable power station with solar input is one simple version.
Two Different Routes From Sunlight to Power
Utility-scale solar CSP makes heat first. In a steam-cycle plant, that heat boils water and the steam spins a turbine. PV panels skip all of that. Sunlight hits the cells, and the cells produce electricity.
Because the methods differ, PV efficiency figures do not apply to CSP plants. Panel ratings also say nothing about how much heat a mirror field can collect.
Solar Storage for Small Loads
Home solar systems typically use photovoltaic panels. Adding a battery allows the household to store electricity. EcoFlow DELTA Gen4 power stations accept PV panel input and store the energy for later use, such as evening hours. They have nothing to do with CSP plants. They are a small-scale solar route for lights, laptops, and household appliances. Panels are sold separately.
Small loads are the easiest place to start. With compatible panels, a 3kWh unit stores daytime solar for lights and laptops after dark. Panel voltage and current still need to match the input limits, so the specs below deserve a close read.
Refrigerators ask for more. A fridge cycles on and off around the clock, so a larger battery helps. A 3.7kWh unit with two solar inputs stores more and can expand later.
How the Two Units Divide the Job
EcoFlow DELTA 3000 Gen4: Pairs with compatible PV panels for lights and laptops.
EcoFlow DELTA 3800 Gen4: Fits fridges, longer use, and expansion.
The table below shows estimated runtimes. Both columns use the same method: usable capacity (Wh × 0.85) divided by the load in watts. The lights and laptop figures are example loads, not measured ones.
Load (example) | Watts used | EcoFlow DELTA 3000 Gen4 (2,611Wh usable est.) | EcoFlow DELTA 3800 Gen4 (3,199Wh usable est.) |
Lights + laptop (20W + 60W) | about 80W | about 33 hours | about 40 hours |
13.9 cu ft fridge (ENERGY STAR, about 38W average) | about 38W | about 69 hours | about 84 hours |
Real runtime shifts with temperature, inverter losses, and how often a load cycles. Treat these numbers as estimates.
Both units are listed with shipping windows. The EcoFlow US pages showed early December for the DELTA 3000 Gen4 and late November for the DELTA 3800 Gen4 when checked in November 2026. Delivery timing should be confirmed for the delivery address. Neither unit is a fix for an outage that is happening now.
Panel output depends on shading, tilt, and local sun hours, so it helps to calculate solar panel output before buying panels.
Back to CSP: the main plant types.
Types of Concentrated Solar Power Systems
Concentrating solar power comes in three main designs. They differ in how mirrors focus the light. Every CSP solar design needs strong, direct sunlight.
EIA names the three main types as linear concentrating systems, solar power towers, and solar dish/engine systems. Linear systems include both parabolic troughs and linear Fresnel reflectors.
Linear Concentrating Systems
These plants use long, curved mirrors. The mirrors focus sunlight onto tubes that run the length of each row. A fluid in the tubes carries heat to a heat exchanger, which boils water for a steam turbine.
EIA notes that these fields usually run north to south. That layout lets the mirrors track the sun from east to west and keep sunlight on the receiver tubes through the day.
Parabolic troughs: The receiver pipe sits along the focal line of each mirror. EIA reports that a trough can focus sunlight from 30 to 100 times its normal intensity, with operating temperatures above 750°F.
Linear Fresnel reflectors: One receiver tube sits above several mirrors. That setup gives the mirrors more freedom to track the sun. EIA puts the concentration at roughly 30 times normal intensity.
Solar Power Towers
DOE describes power towers as mirrors arranged around a central tower that acts as the receiver. EIA calls the sun-tracking mirrors heliostats. Sunlight can be concentrated as much as 1,500 times. Some towers use water as the heat-transfer fluid, while newer designs test molten nitrate salt.
Two tower facilities were operating in the U.S. in 2025, according to EIA. Ivanpah in California has three towers and 393 MW of net summer capacity. Crescent Dunes in Nevada has 110 MW and an energy storage component.
Solar Dish/Engine Systems
A dish of mirrors focuses sunlight onto an engine at its center. The most common engine is the Stirling engine. Per DOE, single dish/engine systems can produce 5 to 25 kilowatts per dish. That size suits smaller, distributed uses.
EIA adds that the U.S. has no utility-scale dish/engine projects in commercial operation.
Type | How mirrors focus light | Concentration or temperature (EIA) | Scale |
Parabolic trough | Curved mirror to a pipe on its focal line | 30 to 100 times; above 750°F | Solana: 296 MW (Arizona) |
Linear Fresnel | Several mirrors to one tube above them | About 30 times | Puerto Errado 2: 30 MW nominal (Spain); EIA's U.S. demo near Bakersfield is not operational |
Power tower | Heliostats to a receiver atop a tower | Up to 1,500 times | Ivanpah: 393 MW (California) |
Dish/engine | Dish to an engine at the focal point | Above 1,380°F | 5 to 25 kW per dish (DOE) |
Panel types matter at home, too. Rooftop owners often weigh options such as bifacial solar panel advantages against standard modules.
Finally, storage: CSP's biggest strength.
CSP Thermal Energy Storage
CSP solar power can store heat instead of electricity. That lets some plants generate in the evening. Some plants also burn natural gas as a backup.
Why Storage Matters
DOE calls reduced output when the sun sets or clouds block it a core challenge for solar. Thermal energy storage is one answer.
EIA explains the process. A storage system collects heat during the day. That stored heat later produces electricity in the evening or in cloudy weather.
What Stores the Heat
Molten nitrate salt is one storage medium. EIA says advanced tower designs are testing it for its heat transfer and storage traits. DOE's thermal storage page shows molten-salt tanks at the Solana plant in Arizona.
Concentrated solar plants with storage are still a minority. EIA lists Solana, a 296 MW trough plant near Gila Bend, and Crescent Dunes as U.S. plants with a storage component.
Hybrid Plants and Backup Fuel
Some solar thermal plants are hybrids. EIA says they usually add natural gas during periods of low solar radiation. The gas supplements the sun rather than replacing it.
Storage size varies by plant, so evening output is a possibility, not a promise. Home batteries work differently. They store electricity, not heat, and thermal storage versus home batteries shows how the two compare.
CSP uses mirrors to focus sunlight, heat a fluid, and power a turbine or engine. EIA lists troughs, linear Fresnel, towers, and dish/engine systems, and thermal storage can extend output into the evening. Large plants account for most CSP installations. Homes typically use PV panels and can add battery storage. For home solar storage, the EcoFlow DELTA 3000 Gen4 or EcoFlow DELTA 3800 Gen4 pairs with compatible panels. Shipping windows vary by address, so delivery timing is worth checking first.
What is concentrated solar power?
Concentrated solar power uses mirrors to focus sunlight on a receiver. Trough or tower plants commonly use the heat to make steam for a turbine. A solar dish can instead power an engine that drives a generator.
How is CSP different from solar panels?
CSP concentrates sunlight to produce heat for a turbine or engine. Photovoltaic cells convert sunlight directly to electricity. Homes usually use PV, while small dish/engine systems can also supply distributed power.
Can CSP store energy?
Yes, as heat. DOE notes that thermal energy storage helps when the sun sets or clouds block it. EIA adds that stored heat can produce electricity in the evening or during cloudy weather, though storage size varies by plant.
What are the types of CSP?
EIA lists three main types: linear systems (parabolic troughs and linear Fresnel reflectors), solar power towers, and solar dish/engine systems. They differ in how the mirrors focus sunlight, whether onto tubes, a tower, or an engine.
Can I use CSP at home?
Households usually choose photovoltaic panels. A small CSP dish can generate power at a single site, but residential installations are uncommon. A battery is optional with home PV. A portable power station with compatible panels can store electricity for lights and laptops.
