Storage Units With Electricity: What to Know Before Renting
Sometimes you need a storage unit with electricity so you can charge tools, do some packaging, or work on a project. But listings don’t always make it clear whether “electricity” means a light, a usable outlet, or a commercial power setup. If you need electricity, confirm what type of power the unit can actually support before you rent. Also find out how electricity is billed, and what the lease allows.
What Are Storage Units With Electricity?
The word “electricity” can describe several different types of setups. It could mean just a light that switches on when you enter, a standard wall outlet, or full power in a commercial storage bay. These options serve different needs, so ask the facility what’s available inside your specific unit before signing a lease. If you need short-term power for a light or small device, ask whether the facility allows you to bring a portable power station.
Storage Units With Electrical Outlets
Storage units with standard 120V outlets can support small devices, chargers, and some light-duty tools. Small business owners may use them for a computer or label printer. Hobbyists might need to charge batteries for tools or maintain a vehicle battery. Outlets are more common in larger drive-up units and contractor bays. Ask whether the circuit is shared and what equipment you’re allowed to use.
Storage Units With Built-In Lighting
Some units have only a hardwired ceiling light with a wall switch or pull-chain, but no wall outlets. The light can make it easier to sort through boxes or check equipment, but it won’t power tools or electronics. Don’t replace the bulb with an outlet adapter. Facilities generally prohibit this because it can create an electrical or fire hazard.
Climate-Controlled Storage Units
Units with climate control will maintain temperature and humidity to protect items such as wooden furniture, musical instruments, photos, and electronics. It usually comes in the form of a building-wide HVAC system. Don’t assume that climate-controlled means the individual unit has outlets. If you need outlets for power as well as temperature control, confirm that both features are included in the unit you’re renting.
How to Find Storage Units With Electricity?
Storage units that have power can be harder to find than standard storage units. This is because many facilities are designed only for storing belongings, not running equipment. Do an initial search online for potential locations, then confirm the electrical setup directly with the facility.
Search Online Storage Facility Directories
Start by searching for “storage units with electricity near me,” then narrow the results to facilities you can contact directly. Try filters like “drive-up access,” “commercial storage,” or “workshop.” If a listing has no outlet filter, ask the facility which units have working receptacles.
Check Storage Facility Websites
Review each facility’s unit descriptions for terms such as “interior outlets,” “individually metered power,” or “contractor flex units.” Drive-up units with roll-up doors may be more likely to have outlets than interior hallway access units. Note that the listing alone may not confirm specifically what’s installed.
Contact Local Storage Facilities Directly
Call the property manager to confirm that the specific unit you’re looking for has working outlets. If it has outlets, ask what you’re allowed to plug in. It’s also useful to find out whether the outlets share a circuit with neighboring units, and if there’s a waitlist for powered units.
If you plan to bring a battery, ask the manager whether the facility allows it and whether there is an approved outdoor area where you can recharge a solar generator with compatible panels between visits.
How Much Do Storage Units With Electricity Cost?
Adding electrical power access to storage units increases operating overhead and property insurance costs for facility owners. These costs get passed on in the monthly invoice for renters. Below is a breakdown of what you can expect to pay across major U.S. markets.
Monthly Rental Rates
Basic rent for powered units is generally higher than for standard, non-powered units of the same size. As a rough market estimate, expect to pay approximately 10% to 50% more per month for access to a wall outlet or dedicated commercial wiring. In some suburban markets across the Midwest and Sun Belt, a standard 10x20 drive-up unit may rent for around $220 to $380 per month, while a comparable powered unit could cost roughly $275 to $513. In higher-cost metro areas such as Los Angeles, Northern New Jersey, and Seattle, monthly rents for powered contractor spaces may reach approximately $450 to $650 or more. Actual prices vary by facility, location, electrical capacity, and lease terms.
Unit Type & Size | Typical Use Case | Average Monthly Rent (National Range) | Price Premium vs. Standard Storage |
Standard Non-Powered (10x10) | General boxes, boxed seasonal items, furniture | $100 – $160 | Baseline |
Climate-Controlled (10x10, No Outlets) | Artwork, wood furniture, boxed electronics | $130 – $210 | +25% to +35% higher |
Powered Unit w/ Light Only (10x15) | Evening visits, organizing personal gear | $150 – $230 | +10% to +15% higher |
Powered Unit w/ Receptacles (10x20) | Inventory management, light hobby work, battery maintenance | $220 – $380 | +30% to +50% higher |
Commercial / Contractor Bay (12x30+) | Small business operations, power tools, fleet gear staging | $450 – $750+ | Premium commercial tier |
Note: All prices and premiums are approximate market estimates, not official national averages. Actual monthly rents vary by location, unit size, facility, electrical access, and lease terms. Price premiums are illustrative and may differ when comparing units of the same size and specifications.
Electricity Fees and Additional Utility Charges
Billing structures for utility usage vary depending on the facility’s electrical setup and lease terms. Common arrangements may include:
Flat-Rate Utility Surcharges: A relatively straightforward option used by some facilities. The facility may add a fixed monthly charge, often estimated at around $15 to $50, to the base rent. This type of arrangement generally covers reasonable, intermittent power use for small devices and chargers.
Sub-Metered Billing: This arrangement may be available in modern contractor bays and commercial flex facilities. Each unit is fitted with its own electrical sub-meter, allowing the facility to track individual consumption. Tenants typically pay the base rent plus a separate electricity charge based on the kilowatt-hours (kWh) used during each billing cycle. Rates may be linked to prevailing local utility prices, depending on the property’s billing arrangement and lease terms.
Included “Fair Use” Models: Some facilities bundle basic power access into the premium unit rent without a separate electricity charge. This arrangement generally assumes intermittent, relatively low-amperage usage. Higher consumption or certain equipment may be subject to additional fees or restrictions, depending on the facility’s policies.
Other Fees to Consider When Renting
Beyond base rent and electricity surcharges, keep an eye on potential add-on expenses, such as:
Administrative Setup Fees: Some facilities charge a one-time, non-refundable administrative fee when signing the lease, often estimated at around $20 to $40.
Tenant Insurance: Many facilities require tenants to provide proof of coverage for stored belongings, either through an existing policy or a separate storage protection plan. Facility-offered plans may cost approximately $12 to $25 per month for $2,000 to $5,000 in property coverage. Commercial inventory or specialized machinery may require additional coverage through a separate commercial policy or rider.
Security / Utility Deposits: Facilities offering unmetered or higher-draw electrical bays may require an upfront, refundable security or utility deposit. Requirements and amounts vary by facility and lease terms.
Specialty Lock Costs: Budget roughly $15 to $25 for a high-security disc lock or facility-approved cylinder lock, depending on the required lock type and retailer.
What Should You Know Before Renting a Storage Unit With Electricity?
A storage unit with power can be useful for charging equipment or handling light tasks, but sometimes facilities set limits on how the electricity can be used. Check the rules, safety features, and lease terms before signing.
Understand Electricity Usage Rules and Restrictions
Most facilities restrict high-draw or heat-producing equipment, such as space heaters, hot plates, large air compressors, and welders. They may also prohibit equipment running continuously unattended, such as computers for cryptocurrency mining. These loads can overload shared circuits and create fire risks.
Use the wattage on each device’s label and your expected operating time to calculate power needs. Share your equipment list with the manager so you can confirm which devices you’re allowed to use.
Consider Backup Power for Storage Units
A power grid outage can leave a storage unit without lighting or working outlets. If you need power for brief visits or essential electronics, a portable power station may be the answer. But check the facility’s rules before bringing one in or recharging it on-site.
For Essential Lighting and Everyday Devices: The EcoFlow DELTA 3 Max Portable Power Station has a 2,048Wh capacity to power LED work lights, charge phones, and keep a laptop running during an outage. It gives you a practical way to stay connected and see what you’re doing while the facility’s power is out.
For Extended Outages and Small Business Workflows: When utility outages are extended, e-commerce sellers and small businesses storing commercial inventory can’t afford to stop operations. The EcoFlow DELTA 3000 Gen4 offers 3,072Wh of capacity for devices such as a desktop PC, monitor, and small label printer. Its UPS function switches compatible electronics to battery power within 10 ms when the grid goes out, helping prevent sudden shutdowns and lost work.
Check Facility Security and Fire Protection
Before renting, check the facility for working fire sprinklers, accessible extinguishers, and smoke or heat detectors. Check the facility’s security measures too, especially if you’ll store business inventory or tools. See if there is security gate access, cameras, and unit alarms that can help protect your belongings.
Review Lease Terms and Electricity Service Agreements
Read the utility terms carefully. Confirm when outlets are available, whether power is included in the rent or billed separately, and what happens if a circuit trips. Some facilities shut off electrical circuits overnight, and to reset a breaker may require staff assistance during office hours.
If the lease allows you to bring a battery, use the lights, chargers, and computer you plan to bring to test your power station runtime before an emergency. Check how long the battery lasts with those devices running together.
A storage unit with electricity can be handy for charging tools, organizing inventory, or doing light work. Before renting, confirm what power is available, how electricity is billed, and which devices the facility allows or does not allow. If you need backup power during an outage, check with the manager before bringing in a portable power station.
Can You Charge Batteries in a Storage Unit?
Yes, most storage facilities permit tenants to charge small consumer electronics, hand tool batteries, and low-draw power packs while they are actively inside the unit. However, facilities generally prohibit leaving unattended battery banks, lithium-ion e-bike packs, or heavy equipment batteries plugged in 24/7 due to thermal runaway and fire safety concerns. Always check your facility’s specific utility addendum for battery charging rules.
Can You Use a Space Heater in a Storage Unit?
No, using space heaters in a self-storage unit is strictly forbidden across virtually all commercial facilities. Space heaters can draw significant amounts of power, often 1,500 watts or more, placing a substantial load on electrical circuits. They also pose an unacceptable fire hazard in enclosed spaces packed with combustible storage materials.
Do Storage Units Have Dedicated Electrical Circuits?
No, standard storage units with electricity rarely have dedicated individual circuits. In most facilities, wall outlets are linked across a shared 15-amp or 20-amp branch circuit that spans several adjoining units. Only specialized commercial flex spaces, oversized contractor bays, or units featuring individual utility sub-meters typically provide dedicated circuits for higher, isolated electrical draws.
Can You Modify a Storage Unit After Renting It?
No, tenants are legally barred from making permanent structural or electrical alterations to a rented unit. Drilling into drywall or metal studs, installing permanent overhead lighting, tapping into existing conduit, or mounting hardwired junction boxes violates your lease and will result in forfeiture of your security deposit along with potential damage assessments. All organizers, task lighting, and temporary power setups must remain completely freestanding and removable.
