Utah Flooding: When Wildfire Season Turns Into Flood Season
- What's Happening in Utah Right Now?
- Why Wildfire Makes Utah's Flood Risk So Much Worse
- Staying Powered If You Have to Evacuate or Ride Out an Outage
- Flooding During a Drought? How That Actually Happens
- Zion, Slot Canyons, and Utah's Highest-Risk Spots for Visitors
- What to Do When Utah Issues a Flood Watch or Warning
- Conclusion
- FAQs
Utah just came through its worst wildfire season on record, and now some of the same areas that burned are dealing with flooding. A flood watch for southern and central Utah brought nearly 2.4 inches of rain to Huntington over one weekend. The Virgin River's North Fork reached its fifth-highest flow on record, and flooding in Orangeville forced about 100 people to evacuate. The shift from wildfire to flooding has left many Utah communities facing a new set of risks. Here's what's happening across the state, why burned land can make flooding worse, and how to stay safe and keep essential power running when conditions turn dangerous.
Utah is dealing with flooding across several parts of the state after a stretch of heavy rain. The National Weather Service issued a flood watch for southern and central Utah on August 31, 2026, covering the Sanpete and Sevier Valleys, Castle Country, and communities near Zion National Park.
The rain pushed water levels up quickly. Huntington received nearly 2.4 inches over the weekend, and Salt Lake City has recorded 2.57 inches this summer: more than 90% of it after July 20. The Virgin River's North Fork hit 5,920 cubic feet per second, its fifth-highest flow on record, and at one stream gauge the water climbed from 7 feet to 14 feet in a single hour.
In Orangeville, Cottonwood Creek rose over its banks and forced about 100 residents to evacuate. The Red Cross opened a shelter for people who had to leave.
The flooding has also reached areas scarred by earlier fires. Near Marysvale, heavy rain fell over the Silver King Fire burn scar. The fire happened two years ago, but burned hillsides still don't handle heavy rain the way healthy, vegetated ground does. A debris flow reached Deer Creek and washed out several road crossings. That is why Utah's recent fires matter so much during flood season.
A flood watch means flooding is possible. A flood warning means flooding is happening or expected soon. Conditions can change quickly in Utah, so knowing what each alert means helps you decide when to act.
Utah just came through its worst wildfire season on record, with 843 fires statewide burning more than 1 million acres. The Cottonwood Fire in Beaver County alone burned nearly 100,000 acres and destroyed over 150 structures. Now, some of those same burned areas are facing flooding as heavy rain moves across the state.
Wildfire changes the way the ground responds to rain. Once vegetation and root systems are gone, less is left to slow the water down or hold the soil in place. Rain moves downhill faster, carrying loose soil, rocks, ash, and debris with it, and on steep slopes that runoff can turn into a dangerous debris flow.
The amount of runoff after a fire is also far higher than normal. Peak flood flows are commonly about twice what they were before a wildfire, and extreme events can produce flows up to 39 times higher. Burned watersheds recover slowly — a University of Utah researcher says full recovery can take years, leaving the land exposed to heavy rain in the meantime.
The risk doesn't disappear when the fire is out. Burned hillsides remain vulnerable for years, and heavy rain can send water and debris into the areas below them. For homeowners near a recent burn scar, preparing for wildfire season also helps prepare for power outages and other problems that follow major storms. All of this helps explain why Utah can face flooding even while much of the state is still dealing with drought.
Debris flows and washed-out roads can damage power lines and make it harder for repair crews to reach homes. In rural parts of Beaver and Piute counties, that could mean longer power outages. Having backup power gives you another option while you wait for repairs. It can keep your phone charged and help run important devices, a refrigerator, or medical equipment when the power is out.
The evacuation in Orangeville is also a good reminder to prepare before you need to leave. If you have to evacuate quickly, a portable backup plan can help you keep essential devices powered without having to figure everything out at the last minute.
For a home, the DELTA Pro Ultra X provides whole-home backup while you wait for power to return. If you need something to take with you, the DELTA 3 Max offers portable power that can go from your home to your vehicle or temporary shelter.
Having backup power ready can make an evacuation or extended outage easier to manage. But there's another part of Utah's current weather story that can seem contradictory: the state is still dealing with drought even as heavy rain causes flooding.
Simultaneous Drought and Flooding: Utah frequently experiences drought conditions alongside flash flood risks.
Current Water Shortage: Every part of the state is currently in a drought, with statewide reservoir storage dropping to around 52%.
Storm Impact: Strong, isolated storms can rapidly overflow rivers, streams, and washes without solving the broader statewide water deficit.
Slower Ground Absorption: Extended dry spells harden the soil, causing it to absorb rainwater more slowly and leading to fast-moving surface runoff in low-lying areas.
Limited Drought Relief: Recent localized rainfall offers slight temporary relief to specific water supplies, but it will not end Utah's overall drought.
Northern Arizona's monsoon season: Rapid swings from severe dry periods to intense downpours are a common weather pattern across the American Southwest, similar to Northern Arizona's sudden summer monsoon season.
Zion National Park and other parts of southern Utah can see flash flooding when heavy rain hits the area's steep terrain and narrow canyons. During the recent flood watch, Zion and Springdale were among the areas at risk. In a slot canyon, conditions can change quickly because rain falling miles away can send water into the canyon even when the weather overhead still looks clear.
That same risk applies to places such as Buckskin Gulch and the canyons around Escalante. A dry wash or narrow passage can fill with water quickly, leaving hikers with little time or space to get out of the way. If you're planning a Utah trip, check the weather and local alerts before heading out, and be ready to change your plans if storms are expected. When a flood watch is in effect, don't assume a trail is safe just because there's no rain where you are. In canyon country, conditions upstream can matter just as much as the weather overhead, so be prepared to turn around or move to higher ground if water starts rising.
A flood watch means conditions could lead to flooding, while a warning means flooding is happening or expected soon.
If you're in an area under a warning, don't wait to see how bad the water gets. Follow local evacuation instructions and move to higher ground as directed.
Never drive or walk through a flooded road, wash, or trail. Water can be deeper and faster than it looks, and conditions can change within minutes. If you're hiking or camping near a canyon or wash, move to higher ground as soon as flooding becomes a concern, even if the storm isn't directly overhead.
If you have to leave, take your emergency supplies and avoid damaged roads and washed out crossings. Stay away from flooded areas until local officials say they are safe after the water recedes. For more guidance, see what to do during a flash flood before you’re caught in one.
Utah's record wildfire season has changed the flood risk in some parts of the state. Burned hillsides can remain vulnerable to heavy rain long after a fire is over. If you live near a burn scar, pay attention to local flood alerts and keep your evacuation supplies ready. The EcoFlow DELTA Pro Ultra X can help keep your home powered during a longer outage. If you need to leave, the DELTA 3 Max gives you a portable power option for the essentials.
Is Utah flooding right now, and where is the highest risk?
Yes. Parts of southern and central Utah, including Orangeville and the area around Zion, have been affected by recent flooding. Communities below recent burn scars are at increased risk because heavy rain can cause rapid runoff and debris flows.
Why does wildfire make flooding worse afterward?
Wildfires burn plants and roots that help hold soil in place and soak up rain. After a fire, water can flow downhill faster and can take loose soil, rocks, ash and other debris with it. This can result in an increased risk of flash flooding and debris flows.
How can Utah be in a drought and flooding at the same time?
Drought describes longer-term water conditions, while flooding can happen during a single intense storm. Dry, hardened ground may also absorb heavy rain poorly, allowing more water to run across the surface and quickly fill streams, washes, and low-lying areas.
Is it safe to hike in Zion or a slot canyon during a flood watch?
A flood watch means conditions are favorable for flooding, so hiking in narrow canyons can be risky even if it's not raining where you are. Storms farther upstream can send water into a canyon quickly, leaving little time to get out.
What should I do if I'm told to evacuate because of flooding?
Leave as soon as officials direct you to evacuate and move to higher ground. Take essential medications, chargers, medical devices, and other emergency supplies if there's time, and never drive or walk through flooded roads or washes.
