Peak and Off-Peak Hours: What They Mean, When They Happen, and What Shifting Saves
Two homes on the same street can pay different prices for the same kilowatt-hour simply because of when they use it. That's the idea behind peak and off-peak hours. However, the hours aren't universal. One utility may have higher rates every evening, while another has peak pricing just on summer weekdays. Knowing your schedule helps you manage your energy use each day, compare electricity plans and figure out if storing power can save you money. Here's how these rates work, what actual utility rate schedules look like, and how to estimate possible savings.
What Do Peak and Off-Peak Hours Mean?
Peak hours are the periods when your utility charges its highest energy rate per kilowatt-hour (kWh) on a time-of-use (TOU) plan. Off-peak hours are the periods when electricity costs less. Some utilities also offer a super off-peak period with an even lower rate. These schedules reflect changing electricity demand. Hot afternoons, air conditioning, evening cooking, and people returning home from work can increase demand. Meeting that demand may require more expensive generation and additional grid capacity.
Understanding the Common Terms
Time-of-use (TOU) electricity plans charge different rates depending on when you use electricity. Understanding the common terms can help you identify cheaper periods and plan energy-intensive activities accordingly. The following table explains key terms you'll encounter when reviewing your electricity plan.
Term
What it means on your bill
On-peak (peak)
The highest-priced hours on a TOU plan
Off-peak
All hours outside peak (and outside super off-peak, if your plan has it)
Super off-peak
An extra-cheap block on some plans, such as APS winter weekdays (see next H2)
Season
Months when a set of prices applies. Some plans have no peak price at all in winter
Demand charge
A charge based on your highest usage in kW during set hours, separate from TOU energy prices (APS offers a TOU plan with one, see next H2)
Remember that a time-of-use (TOU) energy rate isn't your complete electricity cost, as fixed charges, delivery fees, and other adjustments may also appear on your bill. Understanding what determines peak electricity demand can help you see how household routines and changing weather influence grid demand and electricity pricing.
Peak and Off-Peak Times at Three US Utilities
There is no single national schedule for peak and off-peak hours. The following examples show how schedules differ across California, Arizona, and Georgia. Your actual charges depend on your utility, rate plan, billing season, and applicable adjustments.
Utility and plan
Peak hours
Off-peak details
PG&E E-TOU-C, California
4–9 p.m. every day
All other hours, including weekends
APS TOU-E, Arizona
4–7 p.m., Monday–Friday, year-round
All other hours, with a winter super off-peak period
Georgia Power TOU-REO
Summer weekday afternoon peak
No winter peak window under this schedule
Under APS TOU-E, the winter super off-peak period runs from 10 a.m. to 3 p.m. on weekdays during November through April billing cycles. Georgia Power's other plans have different schedules, so check the specific plan rather than assuming all customers follow the same hours. Seasonal prices also matter. PG&E's peak window stays the same on E-TOU-C, but the price difference between peak and off-peak electricity changes between summer and winter. Weekends are off-peak under APS TOU-E, whereas PG&E E-TOU-C applies peak pricing every day.
How to find your own peak and off-peak times
Your electricity bill lists a rate schedule code that you can search on your utility's website alongside terms such as "tariff" or "rate schedule." Review the official tariff's time periods, seasonal rates, and holiday rules rather than relying on a marketing summary. Your state utility commission may also publish approved tariffs and pending rate cases, so distinguish current rates from proposed changes. Once you understand how time-of-use rates are structured, compare each plan's energy charges, fixed fees, and additional riders before switching. Knowing your off-peak window is the first step; planning how to use stored energy during expensive hours can help you manage electricity costs.
Where a Home Battery Fits: EcoFlow TITAN 5000 and EcoFlow TITAN 5000 Plus
Moving laundry or dishwasher cycles is relatively simple. The harder part is reducing electricity use during peak hours when your air conditioner, refrigerator, cooking appliances, and other household equipment are all needed. A home battery offers another option: charge it during lower-priced hours and use stored electricity during the expensive window. Whether that saves money depends on your rate difference, how much electricity you shift, battery losses, and your overall system costs.
EcoFlow TITAN 5000
When a home uses substantial electricity during peak hours, shifting a portion of that consumption may be more practical than changing every household routine. The EcoFlow TITAN 5000 is one option to evaluate when planning a home energy storage system.
EcoFlow TITAN 5000
Homes with larger rooftop solar arrays or more demanding energy setups may need additional flexibility. The EcoFlow TITAN 5000 Plus supports up to 8,000W of solar input and AC coupling with compatible existing rooftop solar systems, helping homeowners plan around available solar production and their utility's rate schedule.
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
Both systems require appropriate system design and connection to home circuits through the EcoFlow Smart Home Panel 10, installed by a licensed electrician. Before choosing a system, consider how home battery backup systems can help optimize time-of-use electricity rates and compare the potential savings with installation and equipment costs. The key is to size the battery around your actual electricity use during peak hours rather than assuming a larger system will automatically deliver greater savings.
What Moving Usage to Off-Peak Hours Can Actually Save
Savings depend on the price difference between peak and off-peak electricity, minus the energy lost while charging and discharging a battery. The following is a planning illustration, not a forecast or a claim about any utility's actual rates.
A simple battery savings example
Suppose a home battery delivers 4 kWh to your home during each peak window. Assume it needs 4.71 kWh of off-peak electricity to deliver that amount, using an illustrative 85% efficiency assumption. The daily energy-charge calculation is:
Savings per day = (4 kWh × peak rate) − (4.71 kWh × off-peak rate)
For illustration, using Georgia Power TOU-REO's summer energy charges of 30.3495 cents per kWh on-peak and 7.7702 cents off-peak:
  • Peak-period electricity avoided: 4 × $0.303495 = $1.214.
  • Off-peak electricity used to charge: 4.71 × $0.077702 = $0.366.
  • Illustrative daily difference: approximately $0.85.
Shifting 4kWh on each eligible peak weekday could save about $0.85 per day at the example rates. Exclude weekends and the tariff's off-peak holidays when calculating a seasonal total. Actual savings depend on battery losses, fees, and usage. Before you calculate your home's kWh usage, check your utility's interval data to identify peak-hour consumption. Timers and thermostat adjustments can also help reduce peak electricity use without additional equipment.
Simple Ways to Use Off-Peak Hours Without Extra Equipment
You don't need a home battery to start taking advantage of off-peak electricity rates. Simple adjustments to your daily routine can help shift energy use away from expensive peak hours. Running appliances at lower-cost times and adjusting your thermostat can reduce unnecessary consumption during peak periods. These small changes can help manage electricity costs without purchasing additional equipment.
Run household appliances during off-peak hours to save on electricity costsRun household appliances during off-peak hours to save on electricity costs
  • Run laundry and the dishwasher later: Use delay-start settings to move flexible loads beyond the peak window.
  • Pre-cool your home: In hot weather, cool the house before peak pricing begins, then adjust the thermostat modestly during peak hours. Keep comfort and health needs first.
  • Schedule EV charging overnight: Check whether your utility offers an overnight plan and whether its lower rate outweighs any plan-specific fees.
  • Use appliance timers: Scheduling a task is more reliable than trying to remember the right hour every day.
  • Avoid stacking large loads: On plans with demand charges, running several high-power appliances simultaneously can increase the measured peak demand.
Watts measure an appliance's power demand at a given moment, while kilowatt-hours measure the energy it uses over time. Understanding the difference between kW and kWh can help you interpret electricity charges and plan energy use more effectively. With these basics in mind, review your household's routines and rate options to decide whether a time-of-use plan suits your needs.
Is a Time-of-Use Plan Right for Your Home?
TOU plans tend to suit households that can move a meaningful share of electricity use away from peak hours. If your home needs substantial cooling, heating, or cooking during the most expensive period, a TOU plan could cost more than a flat or tiered alternative.
Review your electricity usage to identify peak-hour savings opportunitiesReview your electricity usage to identify peak-hour savings opportunities
  • Review your usage history: Download 12 months of hourly or 15-minute electricity usage data from your utility account to understand your consumption patterns.
  • Check peak-hour usage: Estimate how much of your electricity use falls within peak-price periods, accounting for seasonal changes.
  • Compare available plans: Use your utility's rate comparison tool, if available, and verify the results against the official tariff sheets.
  • Check commitment rules: Review plan requirements before enrolling. For example, Georgia Power's Nights & Weekends plan requires a 12-month commitment.
  • Review upcoming rate changes: Check your state utility commission for pending rate cases. For APS customers, proposed changes expected in early 2027 could affect current TOU-E prices.
  • Confirm solar and battery eligibility: If you're planning to install solar panels or a home battery, ask your utility which rate plans remain available after interconnection.
Electricity prices and available rate plans vary by location, so a time-of-use plan that works well in one state may not offer the same savings elsewhere. Comparing residential electricity rates by state can help you understand local pricing differences before choosing a plan that fits your household's energy use.
Peak and off-peak hours depend on each utility's tariff, varying by time, day, and season. PG&E E-TOU-C peaks each evening, APS TOU-E on weekday evenings year-round, and Georgia Power TOU-REO on summer weekday afternoons. Check your rate schedule, review the tariff's time periods, and measure your peak-hour usage before switching plans or buying equipment. If your usage and rate difference justify it, consider an EcoFlow TITAN 5000 or EcoFlow TITAN 5000 Plus with a Smart Home Panel 10 installed by a licensed electrician.
What are peak and off-peak hours?
Peak hours are the periods when a time-of-use plan charges its highest price per kWh. Off-peak hours are lower-priced periods. Exact schedules depend on your utility and rate plan.
Are weekends off-peak?
No. APS TOU-E treats weekends as off-peak, but PG&E E-TOU-C applies its 4–9 p.m. peak window every day. Check your tariff for weekend and holiday rules.
Is there a peak window in winter?
It depends on the plan. APS TOU-E retains a weekday 4–7 p.m. peak in winter and adds a 10 a.m.–3 p.m. weekday super off-peak period. Georgia Power's TOU-REO has no winter peak window.
What does super off-peak mean?
Super off-peak is an additional low-price period offered by some utilities. It can provide another opportunity to schedule flexible electricity use at a lower rate.
Does a home battery always lower a TOU bill?
No. Savings depend on the price difference, energy use during peak hours, conversion losses, and equipment and installation costs. A battery cannot guarantee savings or a particular payback period.
Save Bills
