What a Tankless Water Heater Really Costs Once Installed in 2026
Tankless water heater cost is where a lot of homeowners hit sticker shock, especially compared to what a traditional tank runs. The upfront number can look steep next to a $600 tank replacement, even though the math often works out differently over time. This guide breaks down what a tankless system actually costs installed in 2026, by fuel type, by installation factor, and against a traditional tank.
How Much Does a Tankless Water Heater Cost?
If you only need one number to start with, here it is, though it varies more than most single quotes suggest.
Total installed cost typically runs $1,400 to $5,600, depending heavily on fuel type, according to HomeGuide. A separate estimate from Angi puts the average at $2,638, with a typical range of $1,404 to $3,901. A third estimate averages around $2,600, with a $1,400 to $4,000 range for most homes. All three cluster in the same broad window, so it's more useful to treat $1,400 to $4,000+ as the realistic planning range rather than quoting one precise average as universal.
Whatever the fuel type, there's one part of a tankless system that a lot of buyers don't think about until a storm knocks the power out.
Keeping Your Tankless Water Heater Running During an Outage
Gas and propane tankless water heaters still need electricity for their ignition control board, pump, and digital display, typically well under 200W, even though gas does the actual water heating. This means a power outage stops a gas tankless heater from producing hot water too, unless that small control load has backup power of its own, a detail worth understanding in more depth before you assume gas alone protects you during a blackout.
EcoFlow DELTA 3 Classic (1024Wh)
Sized specifically to keep gas tankless water heater ignition controls and basic electronics running during outages, the EcoFlow DELTA 3 Classic features a 1,024Wh capacity and 1,800W continuous output. Its ultra-fast 10ms UPS switchover prevents control boards from resetting mid-cycle, providing continuous, uninterrupted operation for low-wattage household loads.
EcoFlow DELTA 3 Max (2048Wh)
A robust step-up option for broader emergency coverage, the EcoFlow DELTA 3 Max delivers a 2,048Wh capacity with 2,400W continuous AC output (4,800W surge). It provides ample headroom to power gas tankless heater controls, refrigerators, and Wi-Fi routers at the same time without capacity bottlenecks.
With that outage-planning detail covered, here's how the sticker price actually breaks down by fuel type.
Tankless Water Heater Cost by Fuel Type
Fuel type is the single biggest lever on total cost, and the gap between options is bigger than most people expect going in.
  • Electric units run $600 to $1,000 for the unit alone, $1,400 to $3,000 installed, though a separate source puts electric-only installed cost as low as $500 to $1,200.
  • Natural gas units run $1,500 to $2,600 for the unit, $2,100 to $5,600 installed.
  • Propane units run $1,000 to $2,000 for the unit, $1,600 to $4,500 installed.
  • Solar units run $1,800 to $5,700 installed on average, though a separate source cites $1,500 to $3,800, a spread worth noting rather than collapsing into one number.
Electric units run on a dedicated circuit and are rated by kW. Small units (5 to 8kW) suit a single bathroom, mid-size units (10 to 24kW) suit a two-bedroom home, and large units (27 to 36kW) are needed for bigger households. This is also part of why electric tankless units draw far more continuous power than gas models do, closer to the kind of load that shows up among the biggest electricity consumers in a home generally, not just during a water heater cycle.
The fuel type sets the baseline. Installation itself is where a lot of the total actually comes from.
Tankless Water Heater Installation Cost Breakdown
The unit itself is often the smaller half of the bill. Labor, supplies, and the less obvious line items usually make up the rest.
The unit itself makes up roughly 40 to 45 percent of total project cost. Installation labor, supplies, and permits add another $800 to $3,000 on top. Labor typically runs $600 to $2,500 for 3 to 10 hours of work, though a separate estimate puts labor at $600 to $1,850 for around 3 hours. A dedicated electrical circuit installation runs $250 to $900, and a full panel replacement, if needed, runs $850 to $1,700. Gas line upgrades run $350 to $2,000, or up to $2,000 for a brand-new gas line where none existed. Permits typically run $50 to $200, and old unit removal and disposal runs $75 to $500.
DIY installation isn't recommended by any of the reference sources for this guide. All cite carbon monoxide risk on gas units, high-amperage electrical work on electric units, and voided manufacturer warranties as reasons to hire a licensed pro instead of tackling it yourself. The same caution applies broadly across high-draw home appliances, where incorrect wiring or sizing tends to cause more problems than it solves.
Beyond fuel type and labor, a handful of other factors swing the final number up or down.
What Affects Your Tankless Water Heater Cost
Two households buying a similar unit can still land on very different final bills. Here's what usually explains the gap.
  • Size and flow rate (GPM): a small apartment unit (1 to 2 GPM) runs $150 to $250, while an 8+ GPM whole-home unit for a large household runs $600 to $2,000 or more
  • Condensing vs. non-condensing: condensing units cost roughly 25 percent more to install but are more energy efficient; non-condensing units are cheaper upfront but less efficient over time
  • Brand: budget brands like EcoSmart run as low as $170, while premium brands like Rinnai or Navien can run $1,000 to $2,300
  • Location: regional labor rates and local permit requirements both affect the final number
  • Tax credits: the federal Energy Efficient Home Improvement Credit covered 30 percent of project cost up to $600 for ENERGY STAR-certified gas tankless units, but it expired for equipment installed after December 31, 2025, so it no longer applies to a 2026 purchase; state and utility rebates are worth checking instead.
With the cost drivers covered, it's worth comparing the full picture against a traditional tank water heater.
Tankless vs. Tank Water Heater Cost Comparison
Cost alone doesn't tell the whole story here. Lifespan and efficiency shift the comparison once you look past the installed price tag.
Feature
Tankless
Tank
Installed cost
$1,400 to $5,600
$600 to $3,100
Lifespan
15 to 20 years
8 to 12 years
Energy use vs. tank
24 to 34% less
Baseline
Hot water supply
On-demand, unlimited
Limited by tank size
Space needed
Compact, wall-mounted
Larger footprint
Traditional tank water heaters cost $600 to $3,100 installed, lower upfront than tankless, but with a shorter 8 to 12 year lifespan compared to 15 to 20 years for tankless. Tankless units cut water heating energy use by roughly 24 to 34 percent compared to tank models. For a broader look at where tankless systems tend to win and lose against tanks day to day, see EcoFlow's guide to tankless water heater pros and cons.
With the full cost and lifespan picture in view, the last question is whether the upfront premium is worth paying.
Is a Tankless Water Heater Worth the Cost?
This comes down to how long you plan to stay in the home and how much hot water your household actually uses, more than any universal better-or-worse answer.
A tankless water heater is generally worth it for households that use a lot of hot water, have limited installation space, or plan to stay in the home long enough, roughly 5 to 7 years, to recoup the higher upfront cost through energy savings. It's less clearly worth it for anyone on a tight budget, planning to move within a few years, or currently satisfied with a working tank unit. If lowering the ongoing bill is the main driver, pairing efficient water heating with smart home energy storage can compound those savings further beyond what the water heater switch alone delivers.
Between the fuel-type breakdown, installation factors, and the tank comparison, here's the short version to budget around.
A tankless water heater typically costs $1,400 to $4,000+ installed, depending mainly on fuel type and household size. Gas units cost more upfront but handle larger households better, while electric units are cheaper but limited in capacity. Gas tankless heaters still need backup power for their ignition system during an outage, a detail worth planning for separately from the water heater purchase itself.
If backup power for your tankless heater's ignition system is on your radar, the EcoFlow DELTA 3 Classic covers the essentials, while the EcoFlow DELTA 3 Max leaves room for a fridge or router alongside it.
How much does a tankless water heater cost installed?
Total installed cost typically runs $1,400 to $5,600 depending on fuel type, with most homes landing somewhere in the $1,400 to $4,000 range.
Is a gas or electric tankless water heater cheaper?
Electric units are generally cheaper to install, running $1,400 to $3,000 installed compared to $2,100 to $5,600 for natural gas, though gas units typically handle larger households better.
Does a gas tankless water heater work during a power outage?
Not on its own. Gas tankless heaters still need a small amount of electricity, typically under 200W, to run their ignition control board, pump, and display, so a power outage stops hot water production unless that control load has backup power.
Is a tankless water heater worth the extra cost over a tank model?
It depends on your household's hot water use and how long you plan to stay in the home. It's generally worth it for higher hot water use or longer-term homeowners, and less clearly worth it on a tight budget or for a short-term stay.
Home Backup
