Moving Out Checklist: A Step-by-Step Plan for Your Next Move
A moving out checklist starts 6 to 8 weeks before the move. Give notice, book movers, schedule utilities, file a USPS change of address, pack, clean, and finish with a walk-through. Skipped steps cause trouble fast. Mail keeps going to the old address. The power at the new place isn't on yet. The deposit depends on a cleaning job that got rushed. This post covers the weeks before the move, the cleaning, and move day, plus a plan for a power gap between homes.
Moving Out Checklist: Weeks Before the Move
Start early with the tasks that take time to process. Utilities, mail, and notices to a landlord all have lead times. Get them in motion first.
Timeline at a glance
When
Task
6 to 8 weeks out
Give notice to landlord per lease; book movers or a truck; start decluttering
3 to 4 weeks out
Schedule utility shutoff at the old place and start service at the new place; file USPS change of address
2 weeks out
Pack non-essentials; label boxes by room; update address with banks, employer, and agencies
1 week out
Pack an essentials bag; confirm movers; plan cleaning
Notice, movers, and decluttering
A moving out of apartment checklist usually begins with the lease. Most leases spell out a notice period. Reading that clause first helps avoid surprise rent charges.
Movers and rental trucks book up, so reserve one early. A moving out for the first time checklist should also leave room for surprises, such as a late truck or a missed utility call.
Decluttering comes next. Fewer boxes mean a smaller truck and less packing time. One of the easiest tips for moving out is to sort items into keep, donate, and toss piles before any box is taped.
Donation centers often need a few days' notice for pickups, so book those early too. Selling larger items online can take weeks. Starting now spreads the work across the schedule instead of piling it onto the last weekend.
Packing and updating addresses
Pack the rooms that are used least first. Label every box by room so unloading goes faster. Basic supplies matter too. The things you need to move out include sturdy boxes, packing tape, markers, and furniture pads.
Banks, employers, insurers, and government agencies all need the new address. Do not count on forwarded mail to do that job.
USPS rules to know
Mail is the step most people forget. These USPS points are worth knowing before filing a USPS change of address.
  • Filing options: A change of address can be filed online or at a Post Office. Online filing has a $1.25 identity verification fee, per USPS.
  • Processing time: Allow at least 7 to 10 business days after approval for the change to take effect. Filing 3 to 4 weeks out leaves room for delays.
  • Forwarding limits: Standard forwarding lasts 12 months. Some mail, such as IDs, financial documents, and medical documents, isn't forwarded, so notify those senders directly.
Power isn't always on at the new place either. Plan ahead for what to do with no power on move-in day.
Sometimes the timing doesn't line up. One home has power off while cleaning continues, or the other isn't on yet. A short plan for that gap helps.
Handling a Power Gap Between Homes
Schedule utilities so they overlap by a day if possible. If a gap remains, a day without power still calls for light, a charged phone, and Wi-Fi. Cleaning tools like a vacuum need much more power than lamps do.
Setting up utilities comes first, and for most moves that settles the issue. Temporary power only matters when there is a real gap between the old and new homes.
Ideally, power at the old and new places overlaps. When it doesn't, an EcoFlow portable power station can cover the gap. It can supply light for empty rooms, keep phones charged, and run Wi-Fi at the new place. It isn't a moving must-have. It is a fix for a real gap.
For a short power gap, a 1kWh unit can run a lamp, a router, and phone charging together for about 22 hours of continuous use (an estimate at a 40W load). Used on and off over two days, that works out to roughly 11 hours per day. It also rides along in the car.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Move-out cleaning without power is harder. A vacuum can draw over a thousand watts. A 3,000W unit can run a verified vacuum for the time needed.
EcoFlow DELTA 3 Max Plus (2048Wh)
•3,000W Output: 6,000W surge. X-Boost mode can run some appliances up to 3,800W, though results vary by device. •Fast Recharging: 5 ways to charge, reaching 0 to 80% in 43 minutes with generator charging. • Expandable Capacity: 2kWh base, expandable to approximately 10kWh with two DELTA Pro 3 Smart Extra Batteries and the EcoFlow Smart Extra Battery Expansion Adapter (sold separately). Pairing with a compatible EcoFlow Smart Generator adds automatic start and stop for longer runtime.
How the two products divide the job
  • EcoFlow DELTA 3 Classic: lights, phones, and the router.
  • EcoFlow DELTA 3 Max Plus: verified cleaning loads like a vacuum.
The table below shows estimated run times. These are estimates, not guarantees. Real results depend on the exact device and its label watts.
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
EcoFlow DELTA 3 Max Plus (1,741Wh usable est.)
Lamps (10W) + router (15W) + phones (15W)
about 40W
about 22 hours
about 44 hours
Upright vacuum (about 1,200W)
about 1,200W
about 0.7 hours
about 1.5 hours
Method: usable capacity (Wh × 0.85) ÷ load (W).
Renters face their own outage needs. Some of the same apartment blackout preparedness tips apply on moving day.
Next comes the cleaning that gets a deposit back.
Move-Out Cleaning Checklist
Most leases expect the place to be left clean. Photos before and after protect the renter. Work top to bottom, room by room.
Cleaning kitchen counters before moving outCleaning kitchen counters before moving out
The cleaning part of a moving out checklist for an apartment follows the same order every time. A moving out list for cleaning keeps rooms from getting skipped.
Cleaning supplies add up, so a short list helps. Gather all-purpose spray, sponges, a scrub brush, trash bags, and a mop before starting. Keeping everything in one bucket keeps the job moving.
  • Photos first: Take dated photos of each room before cleaning and again after. Many moving out tips come down to this one habit, because pictures settle deposit disputes quickly.
  • Cabinets and shelves: Wipe them inside and out. Crumbs and shelf liner residue are common reasons for deductions.
  • Appliances: Clean the oven, fridge, and microwave. Grease and food spills are easy to spot during inspections.
  • Bathrooms: Scrub the tub, toilet, sink, and tile. Soap scum and mildew are the usual problem areas.
  • Floors. Vacuum or sweep first, then wash. Floors go last so dust doesn't settle on clean surfaces.
  • Small repairs: Patch small nail holes if the lease allows it. Replace burned-out bulbs so lights work at the final inspection.
  • Trash: Remove all trash and anything left behind. Leftover items can lead to disposal fees.
When cleaning without power, it helps to know the watts a microwave uses before plugging anything in. Small appliances add up fast on a battery.
Check the lease and local tenant rules for deposit return timelines. Those rules differ by state, so a quick look at the local law is worth the time.
Finally, the day itself.
Move Day Checklist
Keep essentials with the household, not on the truck. Do a final walk-through before leaving. Hand off keys and record meter readings.
Essentials bag packed with checklistEssentials bag packed with checklist
  • Essentials bag: The things you need when you move out on day one fit in one bag. Pack documents, medications, chargers, snacks, and toiletries.
  • Final walk-through: Check every closet, drawer, and cabinet. Take photos of each room as it is left.
  • Keys: Return all keys, fobs, and garage openers to the landlord. Ask for a written note that they were received.
  • Meter readings: Note electric, gas, and water meter readings if possible. They help settle final bills.
  • Long-day supplies: Water, snacks, and a phone charger make the afternoon easier for everyone helping. Keep valuables and paperwork in the essentials bag, not in a moving box.
  • New address notices: USPS says senders and agencies must be told of a new address directly. Forwarding alone doesn't cover everyone.
Another piece of advice for moving out is to keep the bag within reach all day. A small kit also keeps devices charged. The essentials bag can guide the choice of an emergency power supply later.
A solid plan covers notice, utilities, a USPS change of address (allow 7 to 10 business days; forwarding lasts 12 months), packing, cleaning, and a final walk-through. The best habit is to start 6 to 8 weeks out, overlap utilities by a day, and keep essentials close. If there's still a power gap, an EcoFlow DELTA 3 Classic covers lights and phones. An EcoFlow DELTA 3 Max Plus can handle a vacuum.
When should I start my moving out checklist?
About 6 to 8 weeks before the move. Begin with notice to the landlord, booking movers or a truck, and decluttering, since these steps have the longest lead times and carry the most deadlines. Early planning also leaves room for delays.
How do I change my address with USPS?
File online or at a Post Office. Online filing has a $1.25 identity verification fee. Allow at least 7 to 10 business days after approval for the change to take effect, per USPS. Filing 3 to 4 weeks before the move leaves a buffer.
How long does USPS mail forwarding last?
Standard forwarding lasts 12 months, per USPS. Some mail, such as IDs, financial, and medical documents, isn't forwarded, so notify those senders and agencies of the new address directly instead of relying on forwarding alone.
When should I set up utilities at my new place?
Two to four weeks ahead, with service starting a day before arrival. Overlapping service at the old and new homes by a day avoids a gap in lights, heat, and Wi-Fi, and it leaves time to fix any scheduling mistakes or missed calls.
What should be in a moving day essentials bag?
Documents, medications, chargers, toiletries, snacks, and a change of clothes. Keep the bag with the household, not on the truck, so it stays reachable all day. Add spare keys, a small tool kit, and some cash for tips if needed.
Tips
