Mobile Home Furnace: Types, Costs, and How to Choose the Right Model
Replacing a furnace in a manufactured home is rarely as simple as ordering another unit with the same heat output. The new cabinet must fit the compartment, connect to the supply and return-air system, and work with the home’s electrical service, fuel line, and venting. The installation must also follow the equipment listing and manufacturer instructions.
Those details explain why a standard residential furnace is not automatically an acceptable substitute, even when it appears to fit. This guide reviews gas, electric, and oil furnaces, the costs that may appear in an estimate, and the measurements and compatibility questions to settle before replacement work begins.
What Types of Furnaces Are Available for Mobile Homes?
Mobile home furnaces may use natural gas, propane, electricity, or heating oil. The existing utility connection usually narrows the choice. Changing fuels may be possible, but added electrical, piping, venting, or storage work can outweigh the difference between furnace models.
Gas Furnaces
Natural gas and propane furnaces remain common where winters are cold, and fuel service is readily available. They can deliver strong heat through a compact forced-air system, but the equipment must be approved for the intended installation and matched with the correct gas supply, combustion-air arrangement, and vent components. A gas furnace without electricity generally cannot operate its controls, igniter, or blower.
Fuel-burning furnaces must vent outdoors, with the combustion system separated from the home’s interior atmosphere through a sealed-combustion design or approved enclosure. The contractor should inspect the heat exchanger, gas pressure, vent assembly, roof opening, and return-air path rather than assuming every old connection can be reused.
Electric Furnaces
A mobile home electric furnace uses resistance elements to heat air that the blower distributes through the ducts. It needs no gas line, fuel tank, or combustion vent, which can simplify replacement in a home already wired for electric heat. Its electrical load is substantial, so the panel, breaker, conductors, and disconnect must suit the selected furnace.
Operating cost depends heavily on local electricity rates and winter demand. In a mild climate, an electric furnace may run only occasionally. In a colder region, long operating hours can make resistance heat expensive. A heat pump can reduce much of that seasonal electricity use while leaving electric resistance heat available for backup, provided the equipment and controls are designed to work together.
Electric furnace wattage and cost calculation helps translate heating demand and local electricity rates into an operating-cost estimate.
Oil Furnaces
Oil furnaces are still found in parts of the Northeast, Appalachia, and rural areas without natural gas service. They provide dependable heat in cold weather and may be practical when the home already has a sound tank, oil line, and compatible vent system.
Oil requires scheduled deliveries and more equipment to maintain. Tank condition, burner service, filters, nozzles, venting, and delivery access all affect cost. Have the contractor evaluate the full installation; an aging tank or vent problem can materially change the project total.
How Much Does a Mobile Home Furnace Cost?
Equipment price is only the starting point; request a model-specific quote from a local installer. A straightforward replacement that reuses sound, compatible connections costs much less than a project requiring a panel upgrade, new gas piping, duct repair, or roof-jack work. Access also matters because many furnaces sit in narrow hallway compartments where removal and reconnection take additional time.
Treat broad cost comparisons as budgeting context, not quote targets. Labor, permits, equipment availability, fuel type, and the home’s condition vary by location.
Furnace Prices by Fuel Type
Electric furnaces generally occupy the lower end of the range. Models rated from 10kW to 20kW may cost about $900 to $1,800 before installation. Selection should reflect the calculated heating load and available electrical capacity, not simply the old furnace’s rating.
Gas models around 80% AFUE commonly fall between $1,400 and $2,200, while condensing models rated at 90% AFUE or above may run from $2,200 to $3,200. Oil furnaces have a broad planning range of $2,200 to $4,000. These figures exclude controls, fuel work, venting, and compatibility modifications.
Electrical and Gas Line Modification Costs
A fuel change or capacity increase can turn a simple replacement into a larger utility project. Before accepting a price, ask the contractor to separate the furnace cost from each required modification.
Electrical Upgrades: A replacement electric furnace may require a dedicated 50- to 100-amp, double-pole circuit. If the existing panel has adequate capacity and space, the electrical work may cost roughly $300 to $800. A service or panel upgrade would be a separate and potentially much larger expense.
Gas Line Extensions: Extending CSST or black iron pipe to the furnace compartment may cost approximately $15 to $25 per linear foot, with a typical small project totaling $250 to $600. Distance, access, pipe sizing, pressure testing, and permit requirements can move the price outside that range.
Fuel Conversion Kits: A natural-gas furnace should be converted to propane only when the equipment listing allows it and the specified manufacturer kit is used. The conversion may add $75 to $200, including technician setup.
Mobile Home Furnace Installation Labor Costs
Installation labor often falls between $1,000 and $2,500, depending on access and connection work. The job may involve removing the old cabinet through a tight opening, adapting the base to the floor duct, sealing the return-air path, reconnecting controls, and completing fuel or electrical testing.
Roof work can add time when an existing vent assembly is corroded, incorrectly sized, or incompatible with the replacement furnace. A written estimate should identify whether the roof jack, flashing, thermostat, duct transition, drain, or disposal of the old unit is included. Otherwise, two quotes that appear similar may cover very different scopes of work.
Permit Fees for Furnace Replacement
Mechanical, electrical, and fuel-gas permits are handled locally, and a manufactured-home community may have an approval process of its own. A broad allowance of $75 to $350 may cover permit and inspection fees in some jurisdictions, but the actual amount depends on location and project scope.
Do not assume the contractor included those charges. The estimate should state who obtains the permits, schedules inspections, and corrects any issue found at final inspection. Unpermitted work can create problems with safety, warranties, insurance, and a future sale.
Note: All prices listed in this section are approximate market estimates for reference only, not fixed quotes or official pricing. Actual costs may vary depending on location, contractor rates, equipment specifications, installation complexity, and local code and permit requirements. Contact a licensed HVAC or electrical contractor for an accurate estimate.
How Do You Choose the Right Furnace for a Mobile Home?
Choosing a furnace for mobile home use starts with the home’s calculated heat loss. It must also fit the compartment, match the ducts, and work with the available fuel, electrical service, and venting. A higher AFUE rating cannot correct poor sizing or an incompatible installation.
Factor | Key Recommendation | Why It Matters |
Heating Capacity | Use 30–50 BTU per sq. ft. only as an early estimate; confirm with a heating-load calculation. | Reduces the risk of short cycling, long runtimes, and uneven temperatures. |
Fuel Source | Compare the utilities already serving the home with local energy prices. | Avoids an expensive panel, fuel-line, tank, or vent conversion that offers little return. |
Efficiency (AFUE) | Compare compatible models using efficiency ratings, installed cost, and expected fuel use. | Shows whether the efficiency premium makes sense for the local climate and heating season. |
Airflow Direction | Verify the existing cabinet orientation and duct connection; many systems are downflow. | Prevents a mismatch between the furnace outlet and the below-floor duct trunk. |
Determine the Required Furnace Heating Capacity
An oversized furnace may heat the thermostat area quickly, shut down, and leave distant rooms cool. An undersized unit may run for hours without holding the set temperature. Matching the old input rating is not always correct, particularly if insulation, windows, ducts, or additions have changed.
Rules of thumb such as 30 to 45 BTU per square foot in moderate climates and 50+ BTU per square foot in colder northern zones can provide a preliminary range. They cannot account for wind exposure, ceiling height, window area, air leakage, belly insulation, duct losses, or local winter design temperature.
For example, a 1,200-square-foot double-wide in Indiana or Pennsylvania might initially be discussed in the 50,000- to 65,000-BTU range. The final selection should come from a recognized heating-load calculation, followed by equipment selection that matches the calculated load. Ask the contractor to show the assumptions instead of relying on floor area alone.
Choose the Right Furnace Fuel Type
Existing infrastructure usually provides the most economical starting point, but operating costs and the condition of that infrastructure still deserve review.
If the site has metered natural gas and a compatible vent system, a gas furnace may offer steady output without the need for on-site fuel storage.
If the community provides electric service but restricts exterior fuel tanks, an electric furnace may be the simpler installation. Pairing it with a compatible heat pump can reduce reliance on resistance heat.
A portable power station may support selected low-power essentials during an outage, but an electric resistance furnace requires a separate load assessment.
A rural property with an existing propane or oil tank may benefit from keeping that fuel, provided the tank, piping, clearances, and delivery access meet applicable requirements.
Request comparable installed-cost and operating-cost estimates before changing fuel. The least expensive furnace on a product sheet may become the most expensive option once a new electrical service, gas line, tank, or vent system is included.
Compare Furnace Efficiency Ratings
AFUE describes how much of a gas or oil furnace’s annual fuel energy becomes useful heat under the federal test procedure. An 80% AFUE rating and a 95% rating can be compared, but the rating does not include every household cost. Blower electricity, duct leakage, local fuel prices, maintenance, and installation quality still affect the bill.
Standard Efficiency (80% AFUE): These furnaces usually cost less initially. Many manufactured-home installations use a compatible metal vent or roof-jack assembly, but the correct venting is determined by the furnace listing and manufacturer instructions, not by AFUE alone.
High Efficiency (92% to 96% AFUE): Condensing furnaces recover more heat from the exhaust and produce condensate that must be drained without freezing. They also require a listed vent and combustion-air system compatible with the furnace and home. Before buying one, confirm that an approved installation path exists and include any drain, vent, and roof work in the quote.
A higher-efficiency model is easier to justify where the furnace runs through a long winter or fuel is expensive. In a mild climate, the fuel savings may take longer to recover the higher installed cost.
Check Furnace Size and System Compatibility
Measure the opening and the usable interior space, including cabinet width, depth, and height. Check door swing, service access, return-air clearance, the furnace-base opening, and the location of gas, electrical, drain, and thermostat connections. The vent or roof-jack model and diameter also need to match the listed furnace configuration.
Many manufactured homes use downflow furnaces that take in return air near the top and discharge heated air into a floor duct below. That arrangement is common, but it is not universal. Verify the actual airflow direction and duct location in the home before ordering equipment. A contractor should also inspect the duct trunk for loose joints, crushed sections, excessive leakage, or restrictions that could keep a new furnace from delivering its rated airflow.
What Should You Consider When Replacing a Mobile Home Furnace?
A furnace replacement affects combustion safety, electrical loading, ventilation, and air distribution. Compatibility matters as much as price or efficiency. The work must follow the appliance listing and instructions along with applicable federal, state, and local requirements.
Understand Mobile Home Furnace Installation Requirements
Federal manufactured-housing rules require heat-producing appliances and the venting components needed for their installation to be listed or certified for residential use by a nationally recognized testing agency. The rules also require the installation to follow the appliance listing and manufacturer instructions. In practice, the contractor should verify the furnace, vent components, combustion-air system, clearances, and duct connections as one installation rather than treating them as interchangeable parts.
Zero-Clearance Closets: Do not assume a compact furnace compartment permits contact with framing. Maintain the clearances stated on the appliance label and in its listing. A zero-clearance or near-clearance arrangement is acceptable only when the selected furnace is listed for that installation.
Isolated Combustion Air: Fuel-burning furnaces must keep their combustion system separate from the home’s interior atmosphere. That may be accomplished with a direct-vent sealed-combustion appliance or an approved enclosure, with combustion-air inlets and flue outlets listed as furnace components.
Approved Roof Jacks: Fuel-burning equipment must vent outdoors through an integral listed system or listed vent components installed according to the furnace instructions. A roof jack may be part of that system. Do not assume every old roof jack fits a new furnace, or that every high-efficiency model uses the same termination arrangement.
Keep Your Furnace Running During Power Outages
A gas furnace still relies on electricity for the controls, igniter, and blower. If utility power fails, an available gas supply alone will not keep most modern furnaces operating. Backup planning should begin with the furnace’s running wattage, startup demand, voltage, and the method used to supply it.
For a mobile home used as a weekend cabin or seasonal retreat, a portable power station may support a compatible gas furnace and several essentials during a shorter outage. The EcoFlow DELTA 3800 Gen4 Portable Power Station has a rated capacity of 3,763Wh, 3,600W of AC output, and 7,200W of surge power. Check the furnace’s starting and running wattage before connecting it because blower startup demand can exceed normal operating draw.
A full-time home may need more storage during a long winter outage. The EcoFlow TITAN 5000 Plus Portable Power Station provides 240V split-phase power, with storage starting at 5kWh and expandable to 30kWh. A qualified electrician can determine whether it can connect to the home through compatible transfer equipment. Confirm that the furnace’s voltage and power requirements match the system before including it in the backup plan.
Know When to Repair or Replace an Old Furnace
A dirty flame sensor, failed capacitor, worn igniter, or faulty thermostat may justify a routine repair when the rest of the furnace is sound. Age alone does not decide the issue, but a unit beyond about 15 years deserves a closer comparison between repair cost, reliability, efficiency, and the availability of replacement parts.
Some findings change the decision quickly. A cracked heat exchanger can allow combustion gases to enter the air stream and requires the furnace to be shut down until a qualified professional evaluates the equipment. Repeated rollout-switch trips, scorching, persistent combustion problems, or several major failures in a short period also warrant a replacement discussion. A failed blower motor can be repairable, so compare the quoted repair with the condition and remaining value of the entire furnace rather than treating one component as an automatic verdict.
A home battery planned alongside furnace replacement still needs separate checks for circuit voltage, startup demand, and safe transfer equipment.
Find a Qualified HVAC Installer
Fuel-burning equipment and high-amperage electric heat should not be treated as general handyman work. Look for a licensed HVAC contractor with documented experience in manufactured homes and the furnace type being considered.
Confirm the contractor’s active state license, general liability insurance, and workers’ compensation coverage where required.
Verify who will obtain local permits, arrange inspections, and provide the final approval records.
Request an itemized written estimate covering the furnace, duct transition, vent or roof-jack work, fuel or electrical connections, thermostat, testing, old-equipment disposal, and warranty terms.
Ask the installer to record the furnace model, load calculation, airflow requirements, and compatible vent components on the proposal. That makes competing bids easier to compare and provides a useful service record.
Choosing a mobile home furnace begins with the installation that already exists. The replacement must fit the compartment, match the airflow direction and ducts, and work with the home’s electrical service, fuel supply, combustion-air system, and listed vent components. Heating capacity should come from a load calculation rather than square footage alone.
Compare complete installed quotes, not furnace prices in isolation. A lower-priced model may require more electrical, fuel-line, or roof work, while a more efficient furnace may not fit the existing vent arrangement without significant changes. With compatible equipment, documented permits, and an installer familiar with manufactured housing, the home is more likely to heat evenly and operate safely through the winter.
How Long Does a Mobile Home Furnace Typically Last?
A mobile home furnace typically lasts around 15 to 20 years, although its actual lifespan depends on the furnace type, installation quality, operating conditions, and maintenance history. Units that run frequently during long, cold winters or receive inadequate maintenance may experience more wear and require replacement sooner. Regular professional inspections and timely air filter changes can help maintain reliable operation and extend equipment life.
Are Mobile Home Furnaces Different from Regular Furnaces?
Yes, mobile home furnaces are specifically engineered, tested, and HUD-certified to fit compact spaces and accommodate high-static-pressure downflow duct configurations. Standard residential furnaces cannot pull combustion air correctly in manufactured home utility closets and are legally prohibited under federal manufactured home construction codes.
Is It Safe to Run a Mobile Home Furnace Overnight?
A properly installed and maintained mobile home furnace can operate overnight when used according to the manufacturer’s instructions. Make sure the furnace is listed for use in manufactured homes, its venting and combustion air systems meet applicable requirements, and the heating system is professionally inspected and serviced annually. Keep combustible materials out of the furnace compartment, and install working smoke alarms and carbon monoxide (CO) alarms near sleeping areas and on each level of the home.
How Much Electricity Does a Mobile Home Furnace Use?
An electric mobile home furnace typically draws between 10 and 20 kW of power while its heating elements are operating, depending on the unit’s capacity. This translates to approximately 10–20 kWh of electricity for each hour of continuous operation at full rated power. By comparison, gas and oil furnaces use considerably less electricity because fuel combustion generates the heat, while electricity powers components such as the blower motor, combustion fan or draft inducer, ignition system, and control board. Their actual electrical consumption varies by model and component specifications.
