Which Solar Tiles Integrate Best With Home Batteries and Inverters? A Spec-Based Guide
Solar tiles integrate best with a home battery when the installer designs tiles, inverter, and battery as one system. GAF Energy Timberline Solar ES 2 and SunStyle use MC4-type connectors and standard solar electronics, so they can feed a hybrid inverter or an AC-coupled battery once voltage, current, and rapid-shutdown rules check out.
Solar tiles turn your roof into a clean power plant. Yet electrically, solar tiles are simply small photovoltaic modules. They still need an inverter to convert DC power to AC power. They also need a battery storage system if you want home backup power during blackouts.
Below, we break down verified manufacturer specs for leading US solar roof brands. You will also find plain explanations of AC versus DC coupling, a step-by-step string calculation, and essential questions for your installer.
Top Solar Tiles in the US and Their Electrical Specs
Connecting a solar roof to a battery starts with hard numbers. The tile's voltage and current dictate your string size. These specs also decide which inverter or battery input will safely accept the array.
The comparison table below gathers verified electrical specifications directly from official manufacturer data sheets (checked October 2026).
Solar tile
Power per tile
Electrical data for inverter matching
Connectors / electronics
Warranty (maker)
Source
57 W (about 1.7 kW per roofing square, about 30 shingles)
Voc 10.85 V, Isc 6.63 A, Vmp 9.04 V, Imp 6.30 A; max system voltage 1,000 V; max 48 in series, 2 parallel strings
Staubli MC4 / EVO2; rapid shutdown listed to NEC 690.12 and UL 3741
25-year product against defects that cause leaks; 25-year power output; 15-year wind up to 130 mph
GAF Timberline Solar data sheet SM512
SunStyle (sold through CertainTeed)
110 W per active tile
Voc around 16.1 V, Isc around 9.2 A on representative data; max system voltage 1,000 V
Standard MC4; module-level power electronics (often 3 tiles per unit); “no proprietary equipment”
25-year tile; 90% output at 10 years, 80% at 25 years
CertainTeed SunStyle page and datasheets
Luma Solar
100 W per shingle
Confirm exact Voc/Isc on current sheet; max system voltage typically 600 V
Confirm current connector type
5-year product; 25-year power at 80%
Luma Solar home page
Tesla Solar Roof
72 W (confirmed on Tesla materials)
Voc ~14.2 V per diode section, Isc ~6.8 A; max system voltage 1,000 V
Staubli MC4 type; Tesla power electronics and rapid-shutdown options
25-year tile and power
tesla.com/solarroof and related docs
If you're still weighing your roofing options, take a moment to understand what solar shingles are and how they function as both weather protection and clean power generation. It also helps to compare solar shingles vs solar panels to see how integrated tiles stack up against traditional rack-mounted arrays in cost, efficiency, and aesthetics.
The tile's data only matters once you know where its power goes: into an inverter, a battery, or both.
How Solar Tiles Connect to Inverters and Home Batteries
Solar tiles generate direct current (DC), just like conventional solar panels. An inverter converts that electricity into alternating current (AC) for household use. A battery stores energy for later, but the way it connects depends on the system design.
How tiles connected to inverters and home batteriesHow tiles connected to inverters and home batteries
Two common approaches are DC coupling and AC coupling. Each has different equipment requirements and compatibility checks.
Set-up
How it works with a tile roof
Battery examples (maker data)
What must match
DC-coupled (hybrid inverter or battery with solar input)
Tile strings wire into the battery system's solar input
Tesla Powerwall 3: up to 20 kW DC, 6 MPPTs, 60 to 550 V DC; EcoFlow TITAN 5000: up to 4,000 W, 40 to 450 V, 16 A; EcoFlow TITAN 5000 Plus: 2 inputs of 4,000 W each
String voltage (including cold weather), current, total watts, rapid shutdown
AC-coupled (battery added next to the solar inverter)
Tiles keep their own inverter or microinverters; the battery connects on the AC side
Enphase IQ Battery 10C (AC-coupled); FranklinWH aPower 2 (AC-coupled); EcoFlow TITAN with Smart Home Panel 10 (240V) and a CT sensor
Battery listed as compatible with the existing inverter; panel space; utility rules
DC-coupled architecture
In a DC-coupled build, tile strings feed directly into the battery system. The battery houses its own internal solar charge controller and inverter.
This approach minimizes power conversion losses. Power flows straight from tiles into battery cells. However, string voltage must strictly match the battery's maximum DC input limits.
AC-coupled architecture
In an AC-coupled setup, your tiles connect to their own dedicated solar inverter. The battery connects separately to your home breaker panel.
This setup works well when retrofitting storage to an existing solar roof. You do not have to rewire the roof array.
Before choosing a system, compare microinverters vs. string inverters to understand how each handles roof shading. Explore the complete solar inverter resource to learn how different inverter types affect solar system performance.
For homes adding storage to a tile roof, here is where EcoFlow's TITAN fits, and what has to be checked first.
Where EcoFlow TITAN Fits With a Solar Tile Roof
Before picking a battery, verify your solar tile layout and inverter plans. Once your rooftop electrical specs are set, shortlist batteries your installer can configure.
The EcoFlow TITAN 5000 and EcoFlow TITAN 5000 Plus are strong candidates for this shortlist. Each base unit supplies 5 kWh of storage capacity, expandable up to 30 kWh. Both provide 7,200 W continuous split-phase output at 120V/240V using long-lasting LFP cells.
They can take DC solar power directly. Alternatively, they can tie into an existing solar roof via AC coupling using the Smart Home Panel 10 (240V) and a CT sensor.
Two EcoFlow TITAN models split by how much direct solar input the tile roof needs.
The EcoFlow TITAN 5000 offers reliable whole-home backup power for everyday household appliances and central air conditioning during unexpected outages.
EcoFlow TITAN 5000
For homes with larger roof sections, the EcoFlow TITAN 5000 Plus provides expanded surge capacity and dual high-capacity solar inputs.
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
Choosing between the two models
The two models divide solar capacity clearly:
  • EcoFlow TITAN 5000: Best suited for sub-panels and direct solar arrays up to 4,000 W (single MPPT port, 40–450 V, 16 A).
  • EcoFlow TITAN 5000 Plus: Best suited for larger roof arrays requiring up to 8,000 W of direct solar (dual 4,000 W MPPT ports, up to 16 A each).
Never assume every solar shingle connects directly to an EcoFlow TITAN battery. Direct DC input and AC coupling are evaluated separately. AC coupling requires the Smart Home Panel 10, a CT sensor, and an approved solar inverter.
Before planning a direct DC tie-in, your electrician must verify rapid-shutdown compatibility under NEC 690.12. If rooftop rapid-shutdown devices are not directly controlled by the battery port, use AC coupling instead.
If your roof already has tiles installed, learn how to add battery storage to an existing solar system. That path keeps your current setup intact while giving you reliable backup power during blackouts.
Whatever battery you select, your installer must run a string check. Let us look at how that math works.
How an Installer Checks a Solar Tile String Against a Battery Input
Here is an illustrative calculation showing why tile counts, operating voltage, and current ratings matter.
This example uses standard test conditions (STC). It demonstrates design math rather than an approved, universal system blueprint.
Step
Example: GAF Timberline Solar ES 2 tiles to a 4,000 W, 40 to 450 V, 16 A input
Result
Tiles for about 4 kW
4,000 W / 57 W = 70.2
70 tiles = 3,990 W
One string of 70
70 x 10.85 V (Voc)
759.5 V: above 450 V, so not possible
Two parallel strings of 35
35 x 10.85 V; current 2 x 6.63 A (Isc)
379.75 V and 13.26 A at STC: inside 450 V and 16 A
Cold-weather voltage
Voc rises about 0.26% per degree C below 25 C; at -10 C: 379.75 V x 1.091
About 414 V: still under 450 V in this example
Important code and installation warnings
This mathematical exercise does not prove compatibility with any single battery. EcoFlow specifications list a 16 A limit. Your installer must verify whether that figure represents operating current or short-circuit current.
Your electrician must also confirm:
  • National Electrical Code conduit fill rules.
  • Maximum series fuse ratings on the roof.
  • Record cold temperatures for your specific ZIP code.
  • Rapid-shutdown receiver compatibility.
Never attempt rooftop high-voltage DC wiring yourself. Hire a licensed, insured solar contractor to handle the installation safely. Before signing a contract, learn how to choose a solar installer and what to check when comparing contractors.
The checks above turn into a short list of questions for any solar roof installer.
Questions to Ask Your Solar Roof Installer
Before signing a solar roofing or battery contract, ask for clear answers to these questions.
Questions to ask solar roof installerQuestions to ask solar roof installer
  1. Which inverter or module-level electronics will the tiles use? Ask for the exact model and its electrical specifications.
  2. Is my preferred battery approved for this configuration? Request confirmation from the manufacturer, not just a verbal assurance from the installer.
  3. Will the system be DC-coupled or AC-coupled? Ask why that arrangement suits your existing equipment and backup goals.
  4. How will the installation meet rapid-shutdown requirements? Request details about the listed equipment and the applicable electrical code.
  5. Which circuits will remain powered during an outage? Confirm whether the solar roof can recharge the battery when the grid is down.
  6. Who handles utility interconnection, building permits, and manufacturer warranty claims? Get warranty terms in writing for the shingles, roofing underlayment, inverter, and battery cells.
Those answers decide which tile and battery pairing makes sense.
Note on federal tax incentives
When budgeting for home solar, keep federal tax timelines in mind. Under IRS guidelines, the federal Residential Clean Energy Credit is not available for property placed in service after December 31, 2025.
Systems installed in 2026 do not qualify for this credit. Ask your certified tax professional about state credits or utility rebates.
If you're deciding between replacing your roof with solar tiles and installing traditional panels, compare solar panels vs. solar roofs to understand the differences in appearance, installation, and energy production.
The best solar tiles share clear electrical specs. GAF Energy Timberline Solar ES 2 and SunStyle publish standard MC4 details. They also list open-circuit voltages upfront. This transparency helps electricians calculate accurate string sizes.
Never buy solar shingles based solely on curb appeal. Ask for the manufacturer's data sheet first. Request your contractor's inverter blueprint. Also, get written battery compatibility specs before signing.
Review your home battery choices once the solar array is verified. The EcoFlow TITAN 5000 supports direct solar up to 4,000 W. For larger roofs, the EcoFlow TITAN 5000 Plus handles up to 8,000 W. Both models also work in an AC-coupled setup. You simply pair them with the Smart Home Panel 10 and a CT sensor.
Do solar tiles work with home batteries?
Yes. Solar tiles work with home batteries through a hybrid inverter or the battery's own solar input for DC coupling, or by connecting the battery on the AC side next to the tile system's inverter. The installer must always confirm full compatibility and code compliance.
How many watts does a solar tile produce?
Power output varies by manufacturer. GAF Energy rates its Timberline Solar ES 2 at 57 watts per energy shingle. SunStyle rates its active tile at 110 watts. Always check the latest maker data sheet for the exact model being installed.
Do solar tiles need a special inverter?
Not always. SunStyle uses standard MC4 connectors and states it requires no proprietary equipment. GAF Energy also uses Staubli MC4-type connectors. Still, match voltage, current, and rapid-shutdown rules to the chosen inverter's input limits on the data sheet.
Will my solar tile roof work during a power outage?
Not by itself. Grid-tied solar is designed to switch off when utility power fails. It needs a properly configured inverter plus a storage system such as a home battery to keep running and potentially recharge during an outage.
Can I add a battery to an existing solar tile roof?
Yes, typically through AC coupling. Adding an EcoFlow TITAN battery to an existing solar roof requires the Smart Home Panel 10 (240V), an external CT sensor, and a compatible solar inverter verified by an electrician.
Solar Panels
