Adding Battery Storage in California in 2026: Pros, Cons and What the Solar Tax Credit Still Covers
In 2026, a California home battery pays off mainly by moving solar power to evening hours under the Net Billing Tariff and by giving outage backup. The main con is cost: the 30% federal credit covers only systems whose installation was completed by December 31, 2025, and most SGIP residential budgets are closed or waitlisted.
Picture a Bay Area homeowner who already has rooftop solar and is now pricing a battery. One neighbor says the California solar tax credit is gone. A coworker says you can still claim it this year. Here's the thing: both people can be right, just for different homes. It depends on when the installation was completed, not when the tax return is filed. Below, you'll find the pros and cons, a timing table, the real SGIP status, and a way to judge a battery by your loads and bills.
Pros of Adding a Battery in California in 2026
In 2026, the case for a battery rests on billing rules and outages, not on a federal credit. The benefits of solar and battery storage Bay Area homeowners talk about mostly come down to timing. Here's what the official sources say.
  • Better use of your solar under the Net Billing Tariff (NBT). The CPUC's net billing page says customers "can maximize bill savings under the NBT by installing battery storage along with their generation."
  • Exports can be worth more at certain times. The same CPUC page says export value "can rise above the retail rate on late summer evenings." A battery lets you shift daytime solar into those hours.
  • Backup during outages. A solar battery backup California homeowners install can keep the circuits it's wired to running during a storm outage or a Public Safety Power Shutoff.
  • It's a common choice. The CPUC reports that nearly 70 percent of NBT customers had paired batteries with their solar by the end of 2024.
Why So Many California Homes Add Batteries
If you're checking public opinion on solar panels and home battery California options or reading store energy California reviews, the CPUC is a firmer guide. Its data shows batteries are now common under NBT, since they move daytime solar into high-value evening hours and back up wired circuits. That's why the pros and cons of solar panels in California shift once you add a battery.
Matching a Battery to Your Home's Loads
What does your home need to run when the power goes out? For readers judging a battery by real loads instead of a tax rule, two EcoFlow TITAN models split the job by voltage and solar input.
If you mainly want your fridge, internet and lights running through an outage, a 120V system may be all you need. The EcoFlow TITAN 5000 Classic covers those basics with 4,000W of rated output (120V only) and 3,200W of solar input.
• 4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. •5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don't even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • North America Highest Safety Standards. UL 9540 certified and tested to UL 9540A, UL 1741 compliant, with EV-grade LFP cells, 24/7 BMS monitoring, and a 5-year warranty.
If your home relies on 240V circuits like central air, you'll need more output and more room for solar. The EcoFlow TITAN 5000 Plus is rated at 7.2kW, reaches up to 10kW only when paired with solar, and accepts 8kW of solar input.
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
Still not sure which one fits your home? The table below puts the two models side by side, so you can match each spec to the loads you need to run.
Spec
What it means for you
Output voltage
120V only
120V/240V split-phase
240V lets you back up circuits like central AC or a well pump
Rated output
4,000W
7.2kW from the battery; up to 10kW only when paired with solar
Higher output runs more appliances at the same time
Solar input
3,200W
8kW
More solar input refills the battery faster on sunny days
Battery capacity
5kWh base, expandable to 30kWh
More capacity means longer runtime, not more output
Smart panel
Smart Home Panel 10 (120V)
Smart Home Panel 10 (240V/120V)
The panel must match the unit and is installed by a licensed electrician
Best fit
120V essentials: fridge, Wi-Fi, lights
Homes with 240V circuits and larger solar arrays
Pick by your loads, not by a tax rule
With either model, home circuits connect through a Smart Home Panel 10 (SHP10) installed by a licensed electrician, and rates, eligibility and installed cost are checked for each home. If you're wondering why evening power costs so much here, our guide on high California electric bills breaks it down. The benefits are real, but 2026 changed the cost side of the math.
Cons of Adding a Battery in California in 2026
The biggest change this year is that new installations no longer get the federal credit. On top of that, California's main state battery rebate is mostly unavailable right now.
Reviewing Home Battery CostsReviewing Home Battery Costs
  • No federal credit for a battery installed in 2026. The residential solar tax credit (Section 25D) ended for expenditures made after December 31, 2025. The IRS Form 5695 instructions put it plainly: "You can't claim residential clean energy credits for expenditures made after December 31, 2025." Under the tax code, an expense counts as made when the original installation is completed.
  • SGIP money is limited. SCE's SGIP program page says the ratepayer-funded budgets are closed to new applicants and the Residential Solar and Storage Equity funds are exhausted and on a waitlist. As of October 26, 2026, the statewide SGIP budget tracker showed the Small Residential Storage budget closed for every administrator and most equity budgets closed or waitlisted.
  • Upfront and installation cost. A battery adds equipment, electrical work and permits. The full installed quote matters more than the battery's sticker price.
  • More paperwork. Adding a battery to existing solar means your utility will need to review the updated system before you switch it on.
Checking SGIP Before You Buy
Budgets open and close, so check the status on the day you buy. You can see how the program works when funds are available in our California SGIP rebate guide. The tax question causes the most confusion of all, so it needs its own timing table.
The Solar Tax Credit and Batteries: Tax Year vs Installation Date
The IRS ties the credit to the date installation is completed. Your tax return is filed the following year. That's why "claiming in 2026" and "installing in 2026" are two very different things.
Solar Tax Credit Eligibility ExplainedSolar Tax Credit Eligibility Explained
Installed vs Purchased: What the IRS Says
The IRS clean energy credit page says you "must claim the credit for the tax year when the property is installed, not merely purchased." It also says battery storage "must have a capacity of at least 3 kilowatt hours" to qualify. Here's how it plays out.
Situation
Installation completed
Return and form
Federal 25D credit?
Source
Solar plus battery installed in 2025
2025
2025 return (filed in 2026), 2025 Form 5695
Yes, 30% of qualified costs; battery must be at least 3 kWh
IRS 25D page; Form 5695 (2025)
Paid in 2025, installation completed in 2026
2026
None for 25D
No
IRS FS-2025-05 FAQ 7
Battery installed in 2026
2026
None for 25D
No
Form 5695 instructions, What's New
Unused credit from a 2025 installation
2025
2026 Form 5695 for the carryforward only
Carryforward of the unused 2025 amount only
Form 5695 instructions (2025), carryforward rules
What Filing in 2026 Can and Can't Do
Filing in 2026 doesn't make a 2026 installation eligible, and paying a deposit in 2025 doesn't help if the work wrapped up in 2026. If your 2025 credit was bigger than your tax bill, the 2025 instructions say you can carry the unused portion to 2026. Check IRS.gov/Form5695 for the final 2026 form.
California's Missing State Solar Credit
What about a state credit? There's no solar panel tax credit California offers on state income taxes right now. The Franchise Tax Board credit table lists solar credits only as repealed credits with carryover provisions. Confirm your own situation with a tax professional.
For a deeper look at the 2025 filing season, see our guide to the 2025 solar tax credit. With the tax question settled, the battery decision comes down to the home itself.
How to Decide Whether a Battery Makes Sense for Your Home
Judge a battery by what it must run and what it can save, then price the full installed quote. Solar battery storage California homeowners buy works best when it's sized to real life, so start with four checks.
Four Checks Before You Buy
  • List your outage loads. Do you only need 120V essentials, or 240V circuits such as a well pump or central AC?
  • Read your bill. Find your time-of-use rate and the hours when your home uses the most power.
  • Check incentives on the day you buy. Look up SGIP status and ask whether your utility runs its own program.
  • Get an installed quote. Make sure it covers panel work and permits, since home circuits are connected by a licensed electrician.
Estimating Runtime From Your Loads
For a rough runtime estimate, use usable energy × 0.85 ÷ load watts. For example, a 5 kWh battery running 300W of essential loads gives about 5,000 × 0.85 ÷ 300 = 14.2 hours. The 300W load and 0.85 factor are example assumptions, so use your own appliance labels.
Don't assume any battery will run your whole house, since starting a 240V load depends on rated output and the appliance's starting power. For the full price picture, see our solar battery cost breakdown. Once you've done the math, the answer fits in three points.
In 2026, a California battery is mainly about evening bill savings under the Net Billing Tariff and reliable outage backup, while the 25D credit only helps systems whose installation was completed by December 31, 2025. Before you file, check the installation completion date on your paperwork, and before you buy, check SGIP status that same day. From there, size a battery by your real loads, such as the EcoFlow TITAN 5000 Classic for 120V essentials or the EcoFlow TITAN 5000 Plus for 240V circuits and higher solar input, and compare full installed quotes.
Can I claim the solar tax credit for a battery installed in 2026?
No. The IRS doesn't allow the 25D credit for expenditures made after December 31, 2025, and an expense counts as made once installation is complete.
I installed solar and a battery in 2025. Can I claim it in 2026?
Yes. You claim it on your 2025 federal return, which you file in 2026, using the 2025 Form 5695. Just make sure your battery has a capacity of at least 3 kWh, since smaller batteries don't qualify.
Is SGIP still available in 2026?
As of October 26, 2026, the SGIP budget tracker showed the general residential storage step closed and most equity budgets closed or waitlisted. Check selfgenca.com for the latest status before you sign a contract.
Does California have its own solar tax credit?
Not right now. California doesn't offer a state income tax credit for home solar, and the Franchise Tax Board lists its old solar credits only as repealed. You can check the FTB credit table for the most current list.
Is a battery worth it under California's Net Billing Tariff?
It can be. The CPUC says adding storage can help you maximize bill savings under the Net Billing Tariff. The real value comes down to your rate plan, when you use power and what the full installation costs.
Solar Energy
