Microinverters for Solar Panels: How Do Microinverters Differ from String Inverters
- Microinverters vs. String Inverters: How Do They Work
- Microinverters vs. String Inverters: Cost
- Microinverters vs. String Inverters: Lifespan
- Microinverters vs. String Inverters: Safety
- Microinverters vs. String Inverters: Efficiency
- Microinverters vs. String Inverters: Solar Panel Selection
- Microinverters vs. String Inverters: Malfunction and Maintenance
- Microinverters vs. String Inverters: Monitoring Options
- Microinverters vs. String Inverters: Expansion Possibilities
- Microinverters vs. String Inverters: How to Choose
- Making the Right Choice: Microinverters vs String Inverters
- FAQs about Microinverters
Solar panels help people save money and use clean energy. But solar panels cannot work alone. They need a device called an inverter to turn their power into usable electricity. Two popular choices are microinverters and string inverters. Both do the same basic job but work in very different ways. Knowing the difference can help you pick the right system for your home.
A solar panel produces direct current (DC) electricity. Your home uses alternating current (AC) electricity. An inverter changes DC into AC so your home can use the power.
A microinverter connects to one solar panel. It changes the DC to AC right at the panel. Each panel in the system works alone. If one panel stops working or gets shaded, the others keep working at full power.
A string inverter connects a group of solar panels together in a “string.” The DC power from all panels goes to one inverter. The inverter changes the whole string’s DC power into AC power. If one panel in the string has a problem, the whole string produces less power.
Cost is a big factor in choosing between microinverters and string inverters. Microinverters cost more because each solar panel needs one. For a 5-kilowatt (kW) system, the price of microinverters can range from $1,500 to $3,000. String inverters cost less, from $750 to $1,250 for the same system size.
Microinverters may increase total energy output, especially if some panels get shade or face different directions. This extra power can help cover the higher cost over time. But for flat roofs with no shade, string inverters can give you good performance at a lower cost.
Microinverters usually last about 20 to 25 years, matching the lifespan of most solar panels. String inverters usually last 10 to 15 years. That means you might have to replace a string inverter once during the system’s life. Some string inverters come with warranties of 5 to 10 years, while many microinverters offer warranties of 20 to 25 years.
When planning your system, consider the extra cost of replacing a string inverter after 10 or 15 years.
Microinverters change DC to AC right at the panel. This reduces the length of high-voltage DC wiring in the system. Lower-voltage DC is safer to handle and less likely to cause fires.
String inverters use longer high-voltage DC wires between the panels and the inverter. If these wires are damaged or poorly installed, they can pose a higher fire risk.
For homes with safety concerns, microinverters may be the safer choice.
Efficiency tells you how much sunlight your system turns into usable electricity.
Microinverters let each panel work on its own. If one panel gets shade or dirt, it does not lower the output of the others. This design helps systems achieve up to 5%–25% more total energy over a year in shaded or mixed-orientation setups. Microinverters are a smart choice for roofs with complex shapes, trees, or chimneys.
String inverters connect multiple panels in a series. If one panel’s output drops (for example, due to shade or debris), the entire string’s power drops to the level of the weakest panel. This means a 10% shading loss on one panel can cause up to 10% loss across the whole string. String inverters work best on flat, sunny roofs with no shading. In these cases, string inverters can reach system efficiencies of 95% or higher.
Microinverters allow flexibility in panel choice. You can combine panels with different wattages or brands. This is because each microinverter manages its own panel’s output. For example, you can use a mix of 400W, 420W, and 450W panels in one system if needed. This makes microinverters good for system expansions.
String inverters require panels with the same electrical properties (voltage, current, wattage) to work properly. Mixing panels can reduce system efficiency or damage the inverter. Most installers use panels with identical ratings, like all 400W panels, for best performance.
When a microinverter fails, it affects only its own panel. The rest of the system keeps working. Microinverter systems often include 25-year warranties, matching the typical lifespan of solar panels. However, microinverters are mounted under or behind panels, so replacing one may require temporarily removing the panel, which could add 1–2 hours of labor.
When a string inverter fails, the entire system stops producing power. But the inverter is usually installed in a convenient spot, like a garage or exterior wall. Many string inverters come with 10–12 year warranties, and replacing one takes less time than replacing multiple microinverters.
Microinverters allow you to check the output of each panel. You can see if one panel produces less energy and fix it fast.
String inverters usually show the total system output. They don’t tell you how each panel is doing. If something goes wrong, it may take longer to find the problem.
If you plan to expand your solar system later, microinverters offer more flexibility. You can add more panels with their own inverters without affecting the system.
String inverters require careful planning when adding panels. You may need to upgrade the inverter or add more equipment.
Choosing between microinverters and string inverters depends on your roof, budget, and energy goals.
Choose string inverters if:
- Your roof is flat, sunny, and free of shading (system can reach 95%+ efficiency).
- You prefer a lower upfront system cost ($750–$1,250 for a 5kW system).
- You want the inverter installed in an easy-to-access location for maintenance.
Choose microinverters if:
Your roof has complex angles or partial shading (can increase output by 5–25%).
You want detailed monitoring of each panel’s performance.
You plan to expand your system with mixed panels in the future.
If you go with microinverters, finally, don’t miss out on the EcoFlow STREAM Microinverter, enabled by its distinctive features:
Optimized for Complex Roofs: Supports installations on roofs with multiple angles or shading; microinverters work independently per panel.
Panel-Level Monitoring and Control: With the EcoFlow app, users can monitor each panel’s output in real time.
Scalable System Design: Allows for easy expansion if you plan to add more solar panels later.
High Efficiency (23%): Converts more sunlight into usable electricity, even in partial shading.
Low-Light Activation: Starts generating power with just 3W of solar input—perfect for shaded or less sunny areas.
Plug-and-Play Simplicity: Ideal for DIY setups, even on complex rooftops or non-standard locations (balcony, garden, etc.).
NEMA 6 & IP68 Durability: Withstands rain, dust, and tough weather conditions, maintaining steady performance in varied roof types.
| Aspect | Microinverters | String Inverters |
| Setup | One inverter per panel | One inverter for the whole panel group |
| Initial Cost | Higher | Lower |
| Lifespan | 20–25 years | 10–15 years |
| Safety | Low-voltage DC wiring | High-voltage DC wiring |
| Efficiency | Good in shade and different panel angles | Best for flat, sunny, no-shade roofs |
| Panel Choice | Mix different panel types and brands possible | All panels must be the same type and wattage |
| Failure Impact | Only one panel affected | Whole string affected |
| Monitoring | View each panel’s output | View system’s total output only |
| Expansion | Easy to add more panels | May need inverter upgrade or more planning |
The right choice depends on your home, budget, and energy goals. Taking time to understand these differences helps you pick the best system for your needs.
Q1: Are microinverters compatible with battery storage systems?
A: Yes, microinverters can work with battery storage systems, but they usually require an AC-coupled battery setup. This means the battery system connects on the AC side, after the microinverters convert DC to AC. If you want DC-coupled batteries, string inverters with hybrid capability might be a better fit.
Q2: How do temperature changes affect microinverters and string inverters?
A: Microinverters, placed on the back of each panel, operate in higher temperatures. Excessive heat can reduce their efficiency slightly. However, many models are designed to withstand panel surface temperatures of 65–85°C. String inverters, usually installed in cooler spots like garages, face fewer temperature fluctuations, which can help maintain stable performance in hot climates.
Q3: Can microinverters be used in commercial-scale solar projects?
A: Yes, microinverters can be used in commercial settings, but they are more common in small or medium-sized projects. For very large installations (hundreds of kW or more), string inverters or central inverters are usually preferred because they handle large volumes of power more cost-effectively and simplify system design.
Q4: What certifications or standards do quality inverters need to meet?
A: Inverters, both micro and string types, should meet safety and performance standards such as UL 1741 (for the US), IEEE 1547 (interconnection standard), and NEC Article 690 (solar PV system wiring). Compliance with these standards helps ensure safe and reliable operation, especially for grid-tied systems.
Q5: How do power optimizers compare to microinverters and string inverters?
A: Power optimizers are similar to microinverters in that they attach to each panel and adjust its output for optimal performance. However, unlike microinverters, they do not convert DC to AC at the panel. Instead, they send optimized DC to a central string inverter. This approach offers many of microinverters’ benefits—like panel-level monitoring and improved performance in shading—while keeping costs closer to string inverter systems.
