Solar Panel Kit with Battery and Inverter: What Size Do You Need?
A solar panel kit with a battery and inverter provides backup power when you’re off the grid or during power outages. Plus you can reduce your reliance on the local power utility. One of the main challenges is how do you choose the right size.
This guide explains how you can calculate the solar panel wattage, battery capacity, and inverter output you need. This is based on your daily energy use, local sunlight, and the appliances you want to run.
What Is a Solar Panel Kit with Battery and Inverter?
An off-grid solar panel kit with battery and inverter is like a miniature, self-sustaining utility company tailored to your specific needs. You can purchase the necessary components individually, and hope they all work together. Or you can purchase an integrated kit that combines generation, storage, and power delivery into one cohesive system.
Solar Panels Generate Power
Since sunlight doesn’t last all day, and it fluctuates during overcast days, you need an energy storage system (ESS) to store power for use all day. The ESS stores surplus energy you don’t use during the day and makes it available around the clock. The ESS is made of batteries that typically utilize safe, long-lasting Lithium Iron Phosphate (LiFePO4) chemistry.
Battery Stores Solar Energy
Since sunlight doesn’t last all day and solar output fluctuates with weather, an energy storage system (ESS) can store surplus solar energy for use later, including at night or during an outage. The ESS typically uses batteries with long-lasting Lithium Iron Phosphate (LiFePO4) chemistry.
Inverter Supplies AC Power
Standard wall outlets in American homes typically supply 120V alternating current (AC) at 60Hz. Batteries and solar panels provide only DC power. The inverter serves as the bridge that converts raw DC power into clean, pure-sine wave AC electricity. With this AC power you can run your blender and laptop charger safely without electrical noise or damage.
How Many Solar Panels Do You Need?
There’s no fixed number of panels that work for every setup. A home that uses more electricity will generally need a larger array, while stronger local sunlight can reduce the capacity needed to produce the same amount of energy. When working out how many solar panels it takes to power a house, start with daily energy use, then account for peak sun hours and expected system losses.
Estimate Your Daily Solar Energy Needs
To estimate your power needs, start by adding up how many kilowatt-hours (kWh) (or watt-hours, Wh) you consume in a typical 24-hour cycle. On your monthly utility statement, or online account, you can find your daily average consumption. For specific appliances, you can use an inline watt meter at the outlet. As an example, a small off-grid cabin might need 3,000Wh (3 kWh) per day, whereas an RV might only require 800Wh daily.
Account for Peak Sun Hours
A common misconception is assuming eight hours of daylight equates to eight hours of full solar production. The sun’s intensity varies throughout the day, so solar sizing should account for Peak Sun Hours (PSH) rather than daylight hours alone. Because available solar radiation varies by location, season, and weather, use local solar resource data when estimating the solar capacity needed for your system.
Allow for System Energy Losses
Some of the power your panels produce is lost before it reaches your appliances. Heat, dust, wiring, the charge controller, and the inverter all take a small share. A practical way to leave room for these losses and less-than-perfect sunlight is to add about 25% to your daily energy requirement when sizing the solar array.
Match Solar Input to Battery Capacity
Your panels must produce enough energy during peak hours to replenish whatever power you pulled from the battery since the sun went down. If your battery holds 2,000Wh and you have 20% left, this means you used 1,600Wh.
As an example, a solar array rated at 400W in a location with 4 peak sun hours will generate roughly:
400W × 4 hours × 0.80 (efficiency) = 1,280Wh
Under the same assumptions, about 500W of solar input would be needed to replace 1,600Wh in four peak sun hours, while additional solar capacity can provide more margin for variable conditions. Actual recharge time still depends on sunlight, system losses, battery charging limits, and any loads running at the same time.
EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
How Much Battery Storage Do You Need?
Battery size determines how long you can run your appliances without solar or grid power. A small camping setup may need around 1 kWh, while home backup can require several kilowatt-hours or more.
Application
Typical Daily Energy Needed
Recommended Battery Capacity
Recommended Solar Input
Weekend Camping / Tailgating
400Wh – 900Wh
~1,000Wh (1kWh)
160W – 220W Portable Panel
Off-Grid RV / Van Life
1,500Wh – 3,000Wh
2,000Wh – 3,000Wh (2–3kWh)
400W – 800W Roof or Ground Mount
Critical Home Essentials Backup
3,000Wh – 6,000Wh
4,000Wh – 8,000Wh (expandable)
800W – 1,600W Array
Calculate Your Essential Energy Loads
It’s necessary to separate luxuries from your survival necessities. A typical home refrigerator uses 1,000Wh to 1,500Wh per 24-hour cycle. Charging mobile phones, keeping an internet router running (10–20W), and powering a couple of LED lights adds another 400Wh to 600Wh.
Make a list of items you definitely need to run, and ones that are optional. Also, look for devices that can be turned completely off if running on battery.
Power Small Loads for Outdoor Trips
For campsite setups or beach outings, power demands remain light and mobility is key. You need a portable power station that slides neatly into a trunk or back seat to leave room for your other gear. When choosing an RV solar panel kit with battery and inverter, balance available storage space, expected loads, and recharge time.
Units like the EcoFlow DELTA 3 Classic can suit this type of setup. Its compact footprint and ~1,024Wh capacity provide portable power for weekend escapes. You can use it to help keep a compatible portable car fridge running and recharge smartphones and other small electronics. Its 1,800W AC output can also support compatible appliances such as an electric kettle or travel coffee maker, provided their power requirements stay within the unit’s limits.
1800W Powerful Output: 3600W surge output. With X-Boost™ tech, it supports high-demand devices up to 2600W, such as microwaves, refrigerators, laptops, and heated blankets.
Match Battery Capacity to Home Backup
Winter ice storms and severe weather can knock down neighborhood power lines. Without power, a whole home backup system requires substantial reserves and high output wattage.
A unit with more battery capacity and higher output, like the EcoFlow DELTA 3 Max, can handle these heavier demands. Its 2,048Wh capacity can support full-size household refrigerators and home Wi-Fi. It can also handle compatible higher-draw appliances like induction cooktops, microwave ovens, or hair dryers within its output limits. During longer outages, prioritizing essential loads and monitoring total power consumption can help make the available battery capacity last longer.
EcoFlow DELTA 3 Max Portable Power Station (2048Wh)
Built for durability and performance, this system features automotive-grade LFP cells and an EV-grade structure, providing 10 years of reliable power with 24/7 BMS protection. It ensures seamless continuity for critical devices with a 10ms auto-switch and operates at a whisper-quiet ≤25dB.
What Size Inverter Do You Need?
Your inverter needs to handle both the combined running wattage of your appliances, but also the short startup surges from motors in equipment such as refrigerators, pumps, and air conditioners. A solar inverter guide can help you compare inverter types once you know your continuous and surge power requirements.
Add Up Your Running Power
Continuous running wattage refers to the baseline power an appliance draws while operating normally. Make a list of every device you plan to power at the same time, for example:
  • Wi-Fi Router: 15W
  • 50" LED TV: 80W
  • Refrigerator: 150W
  • Laptop Charger: 65W
  • Total Continuous Requirement: 310W
An inverter rated at 500W to 600W handles this continuous load comfortably.
Account for Appliance Starting Loads
Appliance motors are used in sump pumps, power tools, air conditioners, and kitchen refrigerators. These draw an initial surge of power to start up from a dead stop. This initial surge is often 2 to 3 times their running wattage for simple tools, but can reach 5 to 8 times for compressors. A refrigerator drawing 150W running power may briefly spike to 1,200W for a fraction of a second. This is why you need an inverter whose surge rating exceeds your single largest motor startup load.
Match Inverter Output to Your Loads
Always add a 20% safety margin above your peak anticipated load. If your combined running appliances total 1,800W, choose an inverter rated for at least 2,200W to 2,400W continuous output. Operating an inverter right at its thermal limit leads to noisy internal cooling fans, higher standby losses, and premature component fatigue.
EcoFlow DELTA 3 Max Portable Power Station (2048Wh)EcoFlow DELTA 3 Max Portable Power Station (2048Wh)
How Do You Choose the Right Solar Power Kit?
Once you know your solar panel, battery, and inverter requirements, compare systems based on capacity, compatibility, installation type, and total cost. A solar generator can simplify component matching when its capacity, solar input, and AC output meet the intended loads.
Compare Power and Storage Ratings
Evaluate battery capacity (Wh), inverter output (W), and solar input (W) together as an integrated system. A high-power inverter paired with a small battery may handle large loads but only for a short time.
Check Component Compatibility
For a DIY kit, make sure the panels, charge controller, battery, and inverter are compatible. Cables and connections must all be consistent. Keep the solar array’s open-circuit voltage (Voc) below the controller’s maximum input and match the battery, controller, and inverter system voltage.
Consider Portable or Fixed Installation
Portable all-in-one systems work well for camping, renters, and emergency backup. Fixed rooftop or ground-mounted systems are better for permanent setups that need more solar capacity and higher output.
Estimate Total System Costs
Include cables, fuses or breakers, mounting hardware, and any transfer switch or electrical work in your budget. These costs can add noticeably to the price of the panels and battery.
Choosing the right solar panel system depends on finding the best balance between how much energy you consume and how much energy independence you need. Before purchasing, determine your essential appliance power needs, and identify your local sunlight hours. Then give yourself some comfortable headroom on battery capacity and inverter output to size your system. It’s the same approach for a lightweight portable power pack for camping or a high-output backup system for your family home during severe weather. The result is a right-sized system that gives you quiet, dependable power whenever the grid lets you down.
Can a House Run on Solar Power Alone?
Yes, a house can run entirely on solar power, provided the solar array, battery bank, and inverter are sized adequately to match total household electrical demand throughout day and night. Homes in low-sun regions or those running central HVAC systems typically require large, high-capacity battery banks and substantial rooftop arrays to sustain complete off-grid reliability.
Can a Solar Panel Be Connected Directly to a Battery?
A standard solar panel generally should not be connected directly to a battery. A compatible charge controller regulates the panel’s voltage and current to charge the battery safely and helps prevent overcharging and other battery damage.
How Can I Use My Solar Panels During a Power Outage?
You can use solar power during a blackout if the system is designed for backup operation, with compatible equipment that can safely isolate the home from the grid and supply designated loads. Standard grid-tied solar systems typically shut down during outages to prevent backfeeding the utility grid.
Can I Just Plug a Solar Panel into an Outlet?
No, you cannot safely plug a standard solar panel directly into a household wall outlet. Household outlets supply 120V AC power, whereas solar panels generate unregulated DC voltage; attempting to connect them directly creates severe short circuits, fire hazards, and equipment damage.
Can I Buy a Solar System and Install It Myself?
Portable solar kits and some standalone off-grid systems may be suitable for DIY setup when installed according to the manufacturer’s instructions. However, if you plan to tie a fixed solar and inverter system into your home’s main service panel, local building codes generally require permitting and installation by a licensed electrician.
Home Backup
