How to Calculate the Best Solar Panel Tilt Angle for Your Home
Have you ever wondered why two homes with the same panels produce very different amounts of power? Often, it comes down to the angle of the panels. Solar panels capture the most energy when sunlight hits them close to straight on, and the ideal tilt depends mostly on your latitude. The good news is that finding the right angle is not guesswork. In this guide, you will learn how a solar panel angle calculator works, the formula behind it, a worked example, what to pair your panels with, and how the best angle shifts by US region.
Why Solar Panel Angle Matters
Imagine you install a set of panels, but they sit almost flat on a low roof. On paper, they should power your home, yet your energy app shows less than you hoped for. Angle is often the reason.
Panels work best when sunlight strikes them close to straight on. The further off that angle is, the more light bounces away instead of converting into power, and the less of the panel actually faces the sun.
The sun also moves. Its height in the sky changes with the seasons and with your latitude, so there is no single angle that is perfect everywhere and all year. A tilt that works well in Florida is not the same one that works well in Maine.
Even a moderately wrong angle can quietly shave off part of your yearly output. According to the U.S. Department of Energy, panels in the northern hemisphere produce the most annual energy when they face south and tilt at an angle close to the local latitude. That is exactly why this is worth calculating instead of guessing.
The good news is that the math is simple once you know your latitude.
The Solar Panel Tilt Angle Formula
You might be worried that this involves complicated math. It does not. A basic solar panel tilt angle calculator rests on one number: your latitude.
Here are the three common rules:
  • Year-round average: set your tilt roughly equal to your latitude in degrees.
  • Optimized for winter: use your latitude plus about 15 degrees.
  • Optimized for summer: use your latitude minus about 15 degrees.
Perfect Angle, Better Solar OutputPerfect Angle, Better Solar Output
Let's look at a quick example. Say your home sits at 40 degrees latitude. For balanced output across the whole year, you would tilt your panels around 40 degrees. If you care most about winter performance, closer to 55 degrees works better. If summer is your priority, around 25 degrees does the job.
Finding your latitude is easy. Any mapping app, or a quick lookup by zip code, gives you a figure that is accurate enough for a tilt angle for solar panels calculation. Once you have that number, the rest is basic addition and subtraction.
If you want to go a step further and turn your angle into an actual output estimate, our guide on how to calculate solar panel output walks through the next part. The U.S. Department of Energy's Homeowner's Guide to Solar also links to free tools for estimating production at your location.
Once your panels are angled correctly, it is worth thinking about what they are actually charging.
Pairing Correctly-Angled Panels with the Right Power Station
Getting the angle right maximizes what your panels generate. But that energy still needs somewhere to go. Correctly angled panels feed a power station or battery, and the size of that unit should match your setup. A station that is too small will fill up and waste extra sun, while one that is far too large costs more than your panels can fill.
Are you charging a small, portable panel setup, or running a larger array with more to store? Here are two EcoFlow options, one for each kind of build.
EcoFlow DELTA 3 Classic: for compact, portable setups
If you mainly want dependable backup for the essentials, a compact unit is often the smarter match. It keeps key devices running without taking up much space, and it tops back up quickly between sunny stretches.
About 1kWh (1,024Wh) of capacity, enough to keep your key devices running through a shorter outage. Recharges to full in roughly 45 minutes, so it is ready quickly when you need it. Compact, all-in-one design that suits smaller panel setups and portable use.
EcoFlow DELTA 3 Ultra: for larger arrays and longer outages
Running a bigger panel array, or want more stored capacity for longer outages? A larger station makes more sense. It can handle heavier loads while your panels feed it back up during the day.
3,072Wh of capacity for longer outages, with room to store more of what your panels generate. Delivers up to 3,600W of AC output, and up to 4,600W with X-Boost for heavier loads. Recharges from the sun with up to 800W of solar (PV) input. Built on long-life LFP cells, backed by a 3+2 year warranty.
To match panel size to the right unit, see our guide on how to size a solar system.
The formula above gives a solid baseline. But the exact right angle still shifts depending on where in the US you are.
Solar Panel Angle by Location in the US
Here's a question that comes up a lot: does your state actually change the ideal angle? It does, because your state sets your latitude, and latitude drives the tilt.
Harness More Sun With EcoFlowHarness More Sun With EcoFlow
Understanding solar panel angle by location helps you sanity-check the formula. As a rough guide:
  • Northern states such as Washington, Minnesota, and Maine sit at higher latitudes, so they generally call for steeper angles.
  • Southern states such as Florida, Texas, and Arizona sit at lower latitudes, so they generally call for flatter angles.
These regional buckets are a helpful starting point. Federal data backs this up: the U.S. Energy Information Administration reports that most fixed-tilt solar systems in the country are set between 20 and 30 degrees, with latitude as the main factor. In practice, many roofs are installed at a slightly shallower tilt than latitude would suggest, because roof pitch, shading, and layout all play a role. Still, the latitude formula from earlier gives you a more precise starting number than a broad regional range.
For a deeper regional breakdown, our solar panel angle guide for North America covers how the ideal tilt shifts across the map.
Knowing the ideal angle is one thing. Deciding how precisely to chase it in your actual install is another.
Fixed vs. Adjustable Mounts: How Much Does Precision Matter?
So you know your ideal angle. Now comes a practical choice: do you lock your panels at one angle, or set them up to adjust through the year? Here's how the two mount types compare.
Feature
Fixed Mounts
Adjustable / Seasonal Mounts
Setup
Set once during installation
Repositioned a few times a year
Cost and effort
Simpler and cheaper, with nothing to adjust later
Higher cost, and needs seasonal tweaks
Angle
Locked at one angle all year
Shifts toward winter (latitude plus 15) or summer (latitude minus 15)
Best suited for
Most home installs, where one good angle captures most of the benefit
Off-grid or portable setups, where every extra percentage point of output counts
For most homes, a single well-chosen angle near your latitude is plenty, and you never have to think about it again. Seasonal adjusting pays off most when you are leaning on stored power rather than the grid, since small output gains add up over time. If you are weighing your options, our step-by-step guide to mounting solar panels breaks down the setup in more detail.
Here's how it all comes together.
The right solar panel tilt angle starts with your latitude, with seasonal adjustments available if you want to squeeze out a little more, and getting it right has a real effect on how much energy your panels produce. To put this into practice, find your latitude, apply the simple formula (latitude for a year-round setting, plus 15 for winter, minus 15 for summer), and then pair your correctly angled panels with a power station sized to your setup. A smaller build fits well with the EcoFlow DELTA 3 Classic, while a larger array pairs naturally with the EcoFlow DELTA 3 Ultra. Both give your panels a reliable place to send the energy they work so hard to capture.
Does solar panel angle matter if I have adjustable mounts?
Yes, angle still matters, but adjustable mounts give you more room to optimize. Instead of one fixed setting, you can shift your panels toward your winter or summer target through the year, which helps you capture more energy as the sun's position changes.
What's the easiest way to find my exact latitude?
The simplest way is to search your zip code or city in any mapping app, which shows your latitude in degrees. For a location-based output estimate to go with it, NREL's free PVWatts tool is a reliable option.
Does a flatter or steeper angle work better for portable solar panels?
It depends on the season and your goal. Portable panels are easy to reposition, so you can tilt steeper in winter and flatter in summer to follow the sun. Since portable setups often feed a battery like a DELTA 3 Classic, chasing the best angle helps you store as much power as possible.
How much energy can a poorly angled panel lose compared to an optimal one?
It varies with how far off the angle is, but even a moderately wrong tilt can noticeably cut annual output. Federal guidance notes that panels collect energy most efficiently when sunlight hits them close to perpendicular, so staying near your ideal angle protects your production.
Should I adjust my panel angle seasonally, or pick one angle and leave it?
For most homes, a single angle near your latitude captures the majority of the benefit with no ongoing effort. Seasonal adjusting is worth it mainly for off-grid or portable systems, where small output gains make a bigger difference.
Home Backup
