Seattle City Light Outage Map: How to Check, Report, and Prepare for Outages
A strong windstorm moves through Seattle on a dark November evening. Trees sway, branches hit power lines, and the lights suddenly go out. Seattle City Light, the city-owned electric utility, provides an online outage map to help customers track service problems. The map shows reported outages, affected areas, and estimated restoration times. This guide explains how to use the Seattle City Light outage map, report an outage, understand common causes, prepare backup power, and stay safe when the power goes out.
How to use the Seattle City Light Outage Map?
Seattle City Light has a live outage map on its website. It shows current reported outages and provides updates as crews assess damage. City Light says the map is updated every five minutes, but information can change during major storms.
Seattle City Light serves Seattle and several nearby areas. It does not serve every community around Seattle. Many nearby suburbs receive electricity from Puget Sound Energy instead. Check your utility provider before using the wrong outage map.
What does the map show?
The Seattle City Light outage map can help you quickly understand the situation in your area. Look for:
Affected area: See where the reported outage is located.
Customers without power: Check how many customers are affected.
Cause: The map may show the cause when City Light has identified it.
Estimated restoration time: Check the current estimated time for power to return.
Keep refreshing the map during a storm. Restoration times can change as crews learn more about the damage. City Light notes that initial restoration estimates are based on the type of outage and may change after crews inspect the site.
How to report an outage?
If your power goes out, check the map first. If your outage is not listed, report it to Seattle City Light. You can report an outage online or call 206-684-3000. Have your City Light account number or the phone number linked to your account ready.
Your online utility account can also help you manage billing and account details. This can be useful when tracking household energy costs alongside your regular power use. For context, see this guide to the average electric bill in Seattle.
If you see a downed power line, stay at least 30 feet away. Do not touch the line or anything it may be touching. Call 911 to report the hazard.
Tip: Seattle City Light also has outage alerts by text and email for eligible customers. These alerts can provide outage and restoration updates without requiring you to keep checking the map.
The map tells you what’s happening now. Knowing why outages happen helps you prepare for the next one.
Common causes of power outages in Seattle
Seattle’s wet and windy weather can put stress on power lines. Trees and branches are a major cause of outages in the area. City Light also lists snow, ice, equipment failures, damaged poles, and human activity among the causes of power outages.
Cause | When It Happens | What to Expect |
Windstorms | Fall and winter | Strong winds can bring down trees, branches, poles, and power lines. Large storms can affect many neighborhoods at once. |
Atmospheric rivers | Fall and winter | Heavy rain can saturate the soil. This can make trees less stable and increase the risk of falling trees and branches. |
Snow and ice | Winter | Heavy snow or ice can weigh down branches and bring them into contact with power lines. |
Equipment or pole damage | Any time | A damaged pole, transformer, cable, or other equipment can cause a local outage. |
Windstorms can cause some of the largest outages in the region. During a November 2024 storm, winds near 60 mph knocked down trees and power lines and damaged poles and equipment. More than 114,000 City Light customers lost power at the peak of the storm.
A damaged pole can also affect thousands of customers at once. In October 2024, a damaged pole caused an outage that affected about 10,000 customers in Seattle’s Central District and South Seattle.
Why do West Seattle and North Seattle see storm damage?
Tree cover is an important factor during severe weather. Trees are the leading cause of power outages in City Light’s service area. Wind, snow, and ice can cause branches or entire trees to fall onto power lines.
North Seattle and nearby areas have also seen major storm impacts. During the November 2024 windstorm, northern communities such as Shoreline and Lake Forest Park were among the hardest-hit areas. Fallen trees, blocked roads, and damaged poles made some repairs more complex.
The location of an outage does not always mean the same cause will happen again. City Light investigates each outage and updates its information as crews identify the damage.
Preparing before severe weather can reduce problems at home. Review what to do before, during, and after a winter storm before the next major weather event.
Seattle weather can change fast. A backup power plan can help keep essential devices running when an outage lasts longer than expected.
Keeping your home powered during a Seattle outage
Many Seattle homes use electricity for heating, lighting, cooking, and other daily needs. When a winter outage lasts for hours, an unheated home can become uncomfortable quickly. A backup power source can keep key appliances and devices running until utility service returns.
Backup power for houses and apartments
Gas generators can work for some houses, but they are not a good fit for every home. They must run outdoors because their exhaust contains carbon monoxide. Fuel storage can also be difficult. In apartments, generators may be impractical because of limited outdoor space and building rules. Local noise rules can also limit when generators can run.
A battery power station offers another option. It can run indoors without fuel, exhaust, or engine noise. This makes it useful for apartments and smaller homes. It can also keep key devices such as a refrigerator, lights, phones, and Wi-Fi running during an outage.
For remote workers, keeping your internet connection available can be important during a blackout. A battery system can power a modem and router while you work or wait for service to return. See how to keep your internet on during a blackout.
EcoFlow DELTA Pro 3 for larger backup needs
The EcoFlow DELTA Pro 3 is designed for higher-power backup needs. It provides up to 4,000W of output, with up to 6,000W using X-Boost. Its 120V and 240V outlets can support larger appliances and some central AC systems.
The EcoFlow DELTA Pro 3 can handle 240V loads and larger appliances. If you only need to keep a refrigerator, lights, phones, and Wi-Fi running, a smaller power station may be enough.
EcoFlow DELTA 3 Max for essential appliances
The EcoFlow DELTA 3 Max has a 2,048Wh capacity and provides up to 2,400W of output. X-Boost can support appliances rated up to 3,400W. Its size makes it a practical option for essential home backup without moving to a larger system.
Seattle power outage safety tips
Staying safe matters more than staying comfortable during a power outage. Simple steps can reduce the risk of fire, food spoilage, falls, and other common problems. Keep a flashlight and basic emergency supplies where you can reach them easily.
Use flashlights, not candles. A flashlight lowers the risk of an accidental fire.
Unplug electronics. Power can surge when service returns. Unplug sensitive devices until the power is stable.
Keep the refrigerator closed. Opening the door lets cold air escape and can shorten food storage time.
Dress in layers. Add blankets and warm clothing if indoor temperatures drop.
Check on older neighbors. A long outage can create extra risks for people who need medical equipment or have limited mobility.
Ready.gov power outage guide also recommends using flashlights, avoiding candles when possible, and keeping refrigerator and freezer doors closed during an outage.
Carbon Monoxide safety
Carbon monoxide is a serious risk during a power outage. Never use a grill, camp stove, or fuel-burning generator inside your home, garage, basement, or other enclosed space. Keep generators outdoors and away from doors, windows, and vents. Install carbon monoxide alarms on every level of your home.
The CDC warns that carbon monoxide is a colorless and odorless gas that can cause sudden illness or death.
Food safety also matters when the refrigerator loses power. Keep the door closed as much as possible. Perishable food can become unsafe if it stays warm for too long. Learn how long food lasts without power before an outage occurs.
If you smell gas, see a damaged power line, or notice signs of carbon monoxide exposure, leave the area and contact the appropriate emergency service.
Seattle power outages can happen when wind, rain, snow, trees, or equipment damage affects the local power network. Use the Seattle City Light outage map and hotline to check service updates and report problems. Preparing before winter storms can also make long outages easier to manage.
Keep basic safety supplies ready and consider backup power for essential devices. For larger loads, the EcoFlow DELTA Pro 3 and EcoFlow DELTA 3 Max can provide portable backup power during an outage.
How do I check the Seattle City Light outage map?
Visit the Seattle City Light website and open its outage map. You can see reported outages, affected areas, customer counts, and estimated restoration times. Check the map again during a storm because outage details can change as crews inspect damage.
What number do I call to report a power outage in Seattle?
Call 206-684-3000 to report a power outage to Seattle City Light. You can also report outages online. Keep your account number or phone number ready. If you see a downed power line, stay away and call 911.
Why does West Seattle lose power so often?
Storm damage is one common reason for outages in West Seattle. Strong winds can bring down trees and branches near power lines. Heavy rain can also weaken soil around trees. However, the cause varies by outage and may also include equipment or pole damage.
Does Seattle City Light serve all of King County?
No. Seattle City Light does not serve all of King County. It serves Seattle and some nearby areas, while other communities use different utilities. Puget Sound Energy serves many areas outside the City Light service territory.
How long do Seattle power outages usually last?
There is no fixed outage length. A small equipment problem may be repaired quickly, while major storms can cause longer outages. Restoration time depends on the damage, weather, location, and number of affected customers. Check the outage map for current estimates.
What should I do if I see a downed power line?
Stay at least 30 feet away from a downed power line. Do not touch the line or nearby objects. Keep other people and pets away from the area. Call 911 to report the hazard and wait for trained crews to handle it.
