RV Solar Power: How to Go Off-Grid in Your Camper
RV solar power makes it possible to travel farther, camp longer, and rely less on hookups or noisy generators. With the right combination of solar panels, batteries, and supporting equipment, you can keep essential appliances running while enjoying the freedom of off-grid camping.
This guide explains how RV solar systems work, how to size one correctly, and what to consider before making the switch.
Why Are More RVers Going Off-Grid with Solar Power?
More RV owners are embracing solar power because it offers greater independence, lower operating costs, and a quieter camping experience.
Advances in battery technology and portable energy storage have made solar more practical than ever. Modern power stations such as the EcoFlow DELTA 3 Ultra Plus (3072Wh) can pair with solar to provide substantial energy storage while remaining easier to install and manage than many traditional electrical systems.
Solar power also reduces fuel consumption and maintenance compared to conventional generators. While many travelers still compare solar systems with the best RV generators, renewable energy provides silent operation, eliminates exhaust emissions during use, and allows batteries to recharge every day the sun is shining.
An EcoFlow DELTA 3 Ultra Pluss Portable Power Station with solar panels in a garden
What Do You Need to Power in Your RV?
Your power requirements will depend on your RV's size, the appliances you rely on, your travel style, and how often you camp without electrical hookups.
Common RV power needs include:
  • LED lighting
  • Water pumps
  • Vent fans
  • Smartphones and tablets
  • Laptops
  • Wi-Fi routers
  • RV refrigerators
Depending on your camping style, you may also want enough power to run:
  • Televisions
  • Coffee makers
  • Microwaves
  • Induction cooktops
  • Electric water heaters
  • Entertainment systems
A single power station can realistically cover this range. The EcoFlow DELTA Pro Portable Power Station, for instance, handles everyday charging for phones, cameras, and drones, keeps a car fridge or speaker running, and can power a projector for movie nights at the campsite. Built-in wheels, an extendable handle, and a dedicated 30A Anderson port also make it easy to move between your tow vehicle and campsite, or to charge an EV on the road.
If you're planning a pop-up camper power setup, your energy needs will usually be much lower than those of a fifth wheel or Class A motorhome.
In many cases, a smaller solar system is enough to support lighting, refrigeration, device charging, and a few small appliances.
RV appliances that can be powered by an EcoFlow DELTA Pro Portable Power Station
How Does an RV Solar Power System Work?
An RV solar system captures sunlight and converts it into usable electricity that charges your batteries. Those batteries then supply power to your RV whenever you need it.
Solar Panels: Portable vs. Roof-Mounted
Solar panels are responsible for collecting sunlight and producing electricity. Roof-mounted panels generate power automatically whenever the sun is available, which makes them convenient for travelers who move frequently. They save storage space and require little daily setup.
Portable panels offer greater flexibility because they can be positioned in direct sunlight even when your RV is parked in the shade.
Charge Controllers
A charge controller regulates the electricity flowing from the solar panels into your battery bank. Without one, batteries could become overcharged or damaged.
Modern MPPT (Maximum Power Point Tracking) controllers are highly efficient because they optimize energy production across changing weather conditions and varying sunlight levels.
Although PWM controllers remain a lower-cost option, MPPT technology generally delivers better performance for most RV solar installations.
Battery Banks
Your battery bank stores electricity for use after sunset or during cloudy weather. Battery capacity determines how long you can remain off-grid before needing additional charging.
Lithium iron phosphate batteries have become the preferred choice for many RV owners because they provide greater usable capacity, faster charging, and longer service life compared to traditional lead-acid batteries.
Understanding proper battery maintenance is equally important, and following a reliable camper battery charging guide helps maximize battery lifespan regardless of the chemistry you choose.
Inverters
Most RV batteries store electricity as DC power, while household outlets and many appliances require AC power. An inverter converts stored battery energy into standard household electricity.
The inverter size should match the appliances you intend to operate.
DELTA 3 Ultra Plus Portable Power Station
The EcoFlow DELTA 3 Ultra Plus delivers 3072Wh of smart, reliable backup power you can scale up to 11kWh. Prioritize essential circuits, power heavy appliances with 3600W output, and recharge fast with 48-minute Dual Charging. With long-lasting LFP cells, 10ms auto-switching, ultra-quiet operation, and OASIS 3.0 app control, it’s a compact, future-ready solution for seamless home backup.
How Do You Size a Solar Setup for Your Camper?
Sizing an RV solar system starts by calculating your average daily energy consumption in watt-hours. Once you know how much electricity you use each day, you can determine the battery capacity and solar panel output needed to replenish that energy.
Battery storage should provide enough reserve capacity for cloudy weather or overnight use. Solar panels should generate enough electricity during daylight hours to fully recharge those batteries under typical conditions.
Portable power stations simplify this process because they're built to pair directly with solar panels, rather than requiring you to size and match separate components.
The EcoFlow DELTA Pro, for example, is designed for compatibility with high-efficiency solar panels, so your battery capacity and solar input can be sized together as one system. For an even more streamlined option, EcoFlow's portable solar generators come with the power station and solar panels already matched, taking the guesswork out of sizing entirely.
Many RV owners also appreciate equipment that can serve multiple purposes beyond the road. The same portable power station that runs your camper's lights, refrigerator, and devices can just as easily power a campsite kitchen setup, keep gear charged during a weekend at the lake, or provide backup power for tailgating and other outdoor events.
An RV setup in an off-grid camping location
How Many Watts of Solar Do You Need for an RV?
The right solar capacity depends on your daily electricity usage. Smaller campers with modest energy needs may require only a few hundred watts of solar, while larger RVs with residential-style appliances often benefit from significantly larger solar arrays.
Can You Run an RV Air Conditioner on Solar Power?
Yes, but it requires a substantial battery bank, a powerful inverter, and enough solar generation to recharge the batteries. Running an air conditioner for extended periods typically demands much more storage capacity than powering lights, refrigerators, or electronics.
Do You Need Lithium Batteries for RV Solar?
Lithium batteries are not required, but they offer significant advantages. They provide more usable energy, recharge faster, last longer, and require less maintenance than traditional lead-acid batteries.
Can You Install RV Solar Panels Yourself?
Many RV owners successfully install basic solar systems themselves, especially portable panel setups and all-in-one power stations. Larger roof-mounted systems with permanent wiring may require more electrical knowledge.
EcoFlow DELTA Pro Series
EcoFlow DELTA Pro is a portable home battery built for plug-and-play backup, delivering 3,600–7,200W AC output to run 99% of appliances. Expand capacity from 3.6kWh up to 25kWh with Smart Extra Batteries, recharge fast with up to 6,500W MultiCharge (as little as 2.7 hours via AC), and even top up at thousands of EV charging stations—powered by a long-lasting LFP battery designed to support up to 10 years of use.
Solar Power Keeps Your RV Self-Sufficient and Comfortable Off the Grid
An RV solar power system gives you the freedom to travel beyond traditional campgrounds while keeping essential appliances running wherever your adventures take you. By choosing the right combination of solar panels, batteries, charge controllers, and inverters, you can build a system that matches your travel style and energy needs.
That freedom is a big part of why RVing keeps growing: 8.1 million American households now own an RV, with off-grid "boondocking" continuing to gain traction among adventure seekers.
Explore EcoFlow’s collection of portable solar generators to find the right system for your next off-grid adventure.
RV and Motorhomes
