RV Generator Maintenance: The Schedule, Straight From Your Generator's Manual
Here's a fact most RV owners don't expect. Two RV generators from the same maker can have different oil change intervals. So a one-size schedule copied from a forum could be wrong for yours. Good RV generator maintenance starts with your own operator manual. This guide sets the schedules from real manuals side by side. They cover a gas Onan, a diesel Onan, and a Champion RV-ready portable. You'll also get clear steps for monthly runs, diesel care, carbon monoxide checks, and storage.
RV Generator Maintenance Schedule: What Three Operator Manuals Say
Most guides hand you one generic RV generator maintenance schedule. But the numbers that count are in your own manual. Find the model and spec letter on your nameplate. Then download it from Cummins' Onan RV generator manuals or your maker. Here's how three manuals compare, as checked October 14, 2026.
Task
Onan QG 2800i/QG 2500i LP (HGLAA Spec B)
Onan QD 8000 diesel (HDKAK, Operator Manual A046L053, Aug. 2024)
Champion 3500W open frame inverter, RV ready, dual fuel (model 100574, Operator's Manual REV 20200520, pp. 25 to 26)
Daily or pre-use check
General inspection daily or every 8 hours
Inspect before the first start of the day and every 8 hours; oil and coolant level checks are listed in Table 7
Check oil, clean around air intake and muffler, check LPG hose: every 8 hours or before each use
First (break-in) oil change
20 hours
50 hours
First 5 hours
Oil change after break-in
167 hours or 1 year
Every year or every 150 hours, whichever comes first (Cummins RV parts and maintenance page); manual footnote: at least once a year, more often in dust or heat
Every 100 hours or annually; every 50 hours under heavy load or in hot weather
Air filter
Clean at 167 hours; replace at 500 hours
Replace at least once a year; more often in dust
Clean every 50 hours or annually
Spark plug
Replace at 500 hours
Not applicable (diesel)
Clean or adjust every 100 hours or annually
Fuel filter
Every 250 hours on B20 biodiesel (see the diesel section)
Clean fuel valve filter every 100 hours or annually (experienced owners or service center)
Coolant
Not listed in the manual's schedule
Flush and replace pressure cap every 1,000 hours or at least every 2 years, whichever comes first
Not applicable
Exercise
At least 2 hours each month at about half rated power
Not listed as an exercise schedule (see the storage section)
Cummins says it plainly: "Recommended maintenance schedules differ between the generator set models." Its RV parts and maintenance page gives a general rule of oil every year or 150 hours. If your manual differs, follow your manual. Your onboard RV generator options decide which column applies. The table's last row, exercise, is the one owners skip most.
Monthly Exercise Under Load and the Before-Every-Trip Check
A generator that sits for months is more likely to fail. Both Onan manuals give the same rule. "Exercise the generator set at least 2 hours each month if use is infrequent," at about half of rated power. Cummins adds that "a single 2 hour exercise period is better than several shorter periods."
Exercise drives off moisture, oils the engine, and replaces stale fuel, says the Onan QG 4000i DF manual. To add load, run the roof AC or microwave. Check their nameplate watts against the generator's rating. Your RV air conditioner wattage shows how close that gets you to half load.
Onan's manuals also call for checks before the first start each day and every 8 hours. Check the oil, look for exhaust leaks, and test the carbon monoxide (CO) detectors. Cummins also says to warm up 2 minutes before adding load and cool down 2 minutes before stopping.
Still, service can take it offline for days. So what runs your small devices meanwhile?
While the Generator Is Being Serviced: EcoFlow DELTA 3 Classic and EcoFlow DELTA 3 Max for a Few Devices
A portable power station doesn't replace generator maintenance. This guide only covers plugging devices straight into the unit while the generator is in the shop. Wiring one into your RV's shore power inlet or fixed circuits is a separate topic, so check EcoFlow's and your RV maker's guidance. Keep it inside the RV or another dry spot, as no IP rating is listed.
If the generator is only out for a quick oil change, a smaller unit is often enough. EcoFlow DELTA 3 Classic suits a short visit with a few light loads, like a Wi-Fi router, phone and laptop charging, and a 120V cooler. Plug it into a campground outlet and the router into it. If that outlet drops, its 10ms auto-switch keeps the router online.
Portable Power During MaintenancePortable Power During Maintenance
Keep it inside the RV or another dry spot, since neither EcoFlow US product page lists an IP rating. Match capacity to your devices with these two options.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
A longer wait is a different story. If parts are back-ordered or you need more devices running, you'll want more stored energy. EcoFlow DELTA 3 Max holds twice the capacity, so it can run a cooler, router, and chargers for longer.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
EcoFlow DELTA 3 Classic covers a short visit with a Wi-Fi router, phone and laptop charging, and a 120V cooler. Plug it into a campground outlet and the router into it. If the outlet drops, its 10ms auto-switch keeps the router online. EcoFlow DELTA 3 Max, with twice the stored energy, covers a longer wait or more devices.
These estimates use each device's listed watts and count 85% of capacity for losses. That's a planning guess, not an EcoFlow figure.
  • 120V cooler (Dometic CFX3 35, 50W): About 17.4 hours on EcoFlow DELTA 3 Classic and 34.8 hours on EcoFlow DELTA 3 Max.
  • CPAP (ResMed AirSense 11, 65W): About 26.8 hours on DELTA 3 Max.
  • Cooler and CPAP (115W): About 15.1 hours on DELTA 3 Max.
A cycling compressor cooler usually runs longer. CPAP draw varies with settings, so confirm your machine's needs with your supplier. Don't treat either unit as a medical backup plan.
These portable power stations for RVs fit what RVers plug in most. Diesels, though, add jobs of their own.
RV Diesel Generator Maintenance: Coolant, Fuel Filters, and Fuel Quality
A diesel adds a liquid cooling system and stricter fuel rules to the gas checklist. So RV diesel powered generator maintenance takes more planning. These come from the Onan QD 8000 Operator Manual (A046L053, Issue 6, August 2024).
Task
What the QD 8000 manual says
Oil and coolant levels
Check as part of the daily check
Oil and filter
Change after the first 50 hours, then on the schedule above, at least once a year
Engine air filter
Replace at least once a year, more often in dust
Fuel filter
Replace on schedule; every 250 hours on B20 biodiesel
Coolant system
Check antifreeze protection; flush and replace the pressure cap at least every two years
V-belt, crankcase breather, coolant hoses, thermostat
At least once every five years
Some jobs need a pro. The manual says breather, hose, and thermostat work "must be performed by a qualified mechanic (authorized Cummins Service Representative)."
For fuel, use clean No. 2 diesel (ASTM 2-D) above freezing and No. 1 (ASTM 1-D) below, with a cetane number of at least 45. B5 biodiesel is fine, but blends up to B20 need the engine, fuel lines, and water separator verified. Before storage over 90 days, run pure diesel for at least 30 minutes to purge biodiesel.
After a filter change or running dry, hold the switch at STOP/PRIME for 30 seconds to prime. A generator sharing the vehicle's tank runs out first by design. Diesel is one of several common RV generator types. And all these manuals put carbon monoxide warnings first.
Carbon Monoxide Checks Belong on Every RV Generator Schedule
An exhaust leak can push carbon monoxide into the coach, and you can't see or smell CO. Onan's manuals say to check for exhaust leaks before every start and every 8 hours. They also say to "test and confirm that all carbon monoxide detectors are working." Never stay inside while it runs without a working detector, and never run it in a garage or with a leak. Disable auto-start before parking in a confined space.
These CPSC carbon monoxide safety tips say to "Install battery-operated CO alarms or CO alarms with battery backup." Test them monthly. If one sounds, "Get outside immediately. Then call 911." CPSC says portable generators belong outside, at least 20 feet from the house. Aim the exhaust away. At camp, apply that to nearby RV doors and windows.
Its portable generator safety alert calls for alarms certified to UL 2034, IAS 6-96, or CSA 6.19.01. CDC's carbon monoxide basics list headache, dizziness, weakness, upset stomach, vomiting, chest pain, and confusion. They're often called "flu-like." Sleeping people can die before symptoms. CDC says to replace detectors per the maker's instructions or every 5 years. For RVs, NFPA 1192 is the National Fire Protection Association's standard. In a closed-up coach, carbon monoxide monitoring basics still apply.
CO checks happen at every start. Storage tasks come once a year.
Annual Maintenance and Off-Season Storage for RV Generators
Annual maintenance for RV generator owners usually lines up with winter storage. Onan's rule: if the generator won't be exercised or used for over 120 days, prepare it for storage.
Protect Your RV GeneratorProtect Your RV Generator
Onan Gas Generators (QG 4000 manual, Section 5.12)
  1. Add preservative to fresh fuel and run about 30 minutes, plus 2 minutes per foot of fuel line, at half load.
  2. Change the oil and tag the generator with the grade.
  3. Remove the air filter, restart, and spray fogger into the carburetor while it runs.
  4. Disconnect appliances and the battery (negative first). Cap the tailpipe, close the fuel valve if equipped, and set the breaker to OFF.
  5. Drain the float bowl once the engine cools.
In spring, check the oil tag, reconnect the battery (negative last), check the air filter, prime, and start. Brief smoke is normal as fogger oil burns off.
Onan Diesel Generators (QD 8000 manual, Section 5.15)
Disable automatic starting, then change the oil and tag the grade. Disconnect the starting battery (negative first) and set the line breaker to OFF. Purge any biodiesel blend with pure diesel first.
Champion RV-Ready Portable Inverter (model 100574 manual)
Champion warns gasoline "may gum up and clog the carburetor" within 4 weeks. Store it cool, dry, and out of direct sun.
Storage time
What the manual says
Up to 30 days
Run the engine until it stops from fuel starvation
30 days to 1 year
Add fuel stabilizer, run 10 minutes, then drain or run the carburetor dry
Over 1 year
Drain the tank and carburetor completely
Every 3 years
Replace the fuel line and LPG hose
What Owners Can Do and What Needs a Dealer
Owners handle oil, filters, plugs, and storage. Valve lash goes to an authorized Cummins service rep. So do the QD 8000's breather, hoses, and thermostat. Champion leaves fuel valve filter, valve clearance, combustion chamber, and fuel line work to skilled owners or a certified shop.
Cummins recommends a maintenance log, which supports warranty claims. The Champion runs on gas or propane. A dual fuel generator maintenance checklist pairs well with its LPG hose checks.
RV generator maintenance follows your own manual, and the manuals differ. Oil comes every 167 hours or yearly on the Onan QG 2800i, every 150 hours or yearly on the QD 8000 diesel, and every 100 hours or yearly on the Champion 100574. For the Onan sets covered here, run them 2 hours a month at about half load, test CO detectors before every start, and prep them for storage past 120 days idle. The Champion manual lists no monthly run and sets storage steps by time instead. While your generator is in the shop, EcoFlow DELTA 3 Classic or EcoFlow DELTA 3 Max can run a few plug-in devices.
What's a normal service interval for an RV generator?
Most manuals call for an oil change at least once a year, or sooner by hours. The Onan QG 2800i sets 167 hours, and the Champion 100574 sets 100.
Do I need to run my RV generator if I'm not using it?
Yes. Run it 2 hours once a month at about half load to drive off moisture and keep fuel fresh. One long run beats several short ones.
What extra upkeep does a diesel RV generator need?
A diesel adds coolant and stricter fuel rules. Plan for coolant checks, a flush at least every two years, fuel filter changes, and priming after it runs dry.
Is it safe to sleep in an RV with the generator on?
Only with a working CO detector, tested before you start. If the alarm sounds, get out and call 911.
Can a portable power station stand in for an RV generator?
Not fully. It isn't wired into your RV, but it can run a router, phones, or a small cooler while the generator is in the shop.
RV and Motorhomes
