AGM vs Gel Batteries: How They Differ in Charging, Lifespan, and the Jobs They Do Best
- AGM vs Gel: Both Sealed Lead-Acid, Built Differently
- Charging AGM vs Gel: Voltages, Settings, and Common Mistakes
- When You Need a Complete Power System, Not Another Battery: EcoFlow DELTA Pro
- Cycle Life, Heat, and Cold: Which Lasts Longer, Gel or AGM?
- Which to Choose: Gel or AGM for a Car, RV, Boat, or Solar Setup
- Conclusion
- FAQs
A lot of RV and boat owners lose a good battery to one simple mistake. They swap a worn gel battery for an AGM, or the other way around, and leave the charger on its old setting. Both types are sealed, maintenance-free lead-acid batteries, so the swap looks easy. But gel is built differently, and it needs a lower, tighter charging voltage. This guide puts AGM vs gel side by side. It covers how each is made, the charger settings their makers publish, and one brand's cycle life data.
You'll also see how heat and cold affect each type and which fits a car, RV, boat, or solar setup. Last, we'll look at when a complete power system makes more sense than another battery.
Both gel and AGM are valve-regulated lead-acid (VRLA) batteries, so neither one needs watering. The real difference is how each one holds its acid. That one design choice drives the rest of this gel vs AGM comparison.
How Each Battery Holds Its Acid
Discover Battery calls both "valve-regulated lead-acid (VRLA) recombinant technology batteries." In an AGM battery, Victron explains, the electrolyte soaks into a glass-fiber mat between the plates. In a gel battery, it's held as a gel, which East Penn describes as sulfuric acid mixed with silica.
AGM vs Gel at a Glance
AGM | Gel | |
Electrolyte | Absorbed in glass-fiber mat | Gelled with silica |
Charge voltage | Close to flooded (Discover: 14.4 to 14.7V) | Lower and "precisely controlled" (Discover) |
Strengths (manufacturer statements) | High current and cold (Discover); "very low internal resistance" (Victron) | Deep cycle durability and "overall longer life" (Victron); tends to live longer in hot climates (Discover) |
Same-brand cycle life at 50% DoD (Victron) | 600 cycles | 750 cycles |
Float design life at 68°F (Victron) | 7 to 10 years | 12 years |
Maintenance | Sealed, no watering | Sealed, no watering |
One rule applies to every lead-acid battery, AGM or gel. A DOE energy storage assessment says lead-acid "cycle life depends highly on DOD." DOD means depth of discharge. These batteries are typically cycled between 50% and 80%, and the deeper you drain one, the fewer cycles you get.
Lead-acid is only one branch of the battery family. Our guide with the main solar battery chemistries compared shows where it fits next to lithium.
The construction difference shows up most when it's time to charge. That's also where most people damage a battery without knowing it.
Have you ever hooked a new battery to an old charger without checking the settings? Gel needs lower charge voltages and doesn't forgive overcharging, while AGM handles a wider range. So the first rule of any AGM vs gel battery choice is to match the charger profile to the battery type.
Charge Voltage Settings by Battery Type
Makers often list charge voltage per cell. A 12V battery has six cells, so multiply by six. The 12V figures below are approximate, so check your battery's label.
Battery | Absorption | Float | Source |
AGM (Discover limits) | No more than 2.45V/cell (about 14.7V) | No more than 2.27V/cell (about 13.6V) | Discover charging guide, 77°F |
Gel (Discover limits) | No more than 2.35V/cell (about 14.1V) | No more than 2.25V/cell (about 13.5V) | Same |
Victron AGM | 14.2 to 14.6V | 13.5 to 13.8V | Victron datasheet |
Victron Gel | 14.1 to 14.4V | 13.5 to 13.8V | Same |
Deka 8G31 Gel | 2.30 to 2.35V/cell (13.8 to 14.1V) | 2.25 to 2.30V/cell | Deka datasheet, 68°F |
What Happens When You Use the Wrong Setting
On Discover's limits, AGM can go to about 14.7V while gel stops near 14.1V. That half-volt gap matters more than it looks. Lifeline, an AGM maker, cites a gel maker in its manual. A charge just 0.7V too high cuts gel cycle life by 60%. Lifeline puts the loss for an AGM charged 1.0V too high at 23%.
The mix-up hurts the other way too. OPTIMA, another AGM maker, says gel or combined "gel/AGM" charger settings "may not fully-charge non-gel batteries." A battery left short of full over and over won't give you its rated life.
Other Charging Mistakes to Avoid
Voltage isn't the only thing that matters. Three other habits can shorten battery life too.
Charging gel too fast. East Penn limits gel charge current to 30% of the 20-hour (C20) amp-hour rating, or 30 amps for a 100Ah battery.
Using an equalize mode. Discover warns, in capital letters, never to equalize gel or AGM batteries. That high-voltage charge is meant for flooded batteries.
Ignoring temperature. Charge voltage should drop as the battery warms and rise as it cools. East Penn's gel manual uses 3mV per °C per cell and Victron uses 4mV, roughly 0.2V on a 12V battery for every 18°F swing.
Overcharging can also make a sealed battery vent gas. OSHA's battery charging safety guidance calls for good airflow. That keeps hydrogen from building up.
RV owners often change chargers when they change battery types. Our walkthrough on how to charge RV batteries explains converter and shore-power charging.
Before choosing between two lead-acid batteries, step back. Is the battery really the part that needs replacing?
Does your gel or AGM battery run an inverter for AC loads in an RV or for home backup? Then you're maintaining a whole system. That means batteries, a charger tuned to them, an inverter, and wiring. An all-in-one LFP (lithium iron phosphate) power station replaces that chain for plug-in AC loads. It doesn't drop into a gel or AGM battery slot, though.
Gel or AGM + charger + inverter | EcoFlow DELTA Pro | |
Parts | Batteries, charger with the right profile, inverter, cabling, fusing | One unit with inverter and charger built in |
Charging | Must match gel or AGM voltages | Charges from AC (1,800W at 120V) or solar (up to 1,600W); no lead-acid profile to set |
AC output | Set by your inverter | 3,600W (7,200W surge) |
Energy | Lead-acid makers advise shallow cycling (around 50% DoD) for long life | 3,600Wh LFP |
Rated cycles | Victron gel: 750 at 50% DoD; AGM: 600 | EcoFlow: "6,500 cycles to 50% capacity, 3,500 cycles to 80% capacity" (different test basis) |
Estimating Runtime for a Refrigerator
What does that mean day to day? Take a fridge that uses about 1.7 kWh a day. That figure comes from a DOE sample refrigerator EnergyGuide label. As a rough estimate, assume about 15% is lost converting stored power to AC. That leaves about 3,060Wh from 3,600Wh, or roughly 1.8 days for that fridge alone, and other loads shorten it.
Compared with a new gel or AGM bank plus an inverter, the card below shows what one unit replaces. Check it against the appliances you run.
EcoFlow DELTA Pro fits RV and backup users whose batteries mainly feed AC appliances. It is not an in-place replacement for a gel or AGM battery. It doesn't use lead-acid charge profiles, the old wiring, or a battery tray, and it won't work as a 12V starting battery. Still comparing chemistries? Read what a LiFePO4 battery is to see how its cycle ratings stack up.
For readers sticking with lead-acid, the next question is which type lasts longer. That depends a lot on where the battery lives.
Will your battery cycle every weekend or sit on float most of the year? In one brand's side-by-side data, gel outlasts AGM either way. Temperature changes the picture, since cold favors AGM and heat shortens both.
Cycle Life by Depth of Discharge
Depth of discharge | Victron AGM Deep Cycle | Victron Gel Deep Cycle |
80% | 400 cycles | 500 cycles |
50% | 600 cycles | 750 cycles |
30% | 1,500 cycles | 1,800 cycles |
Float design life (68°F) | 7 to 10 years | 12 years |
For the gel battery vs AGM lifespan question, depth matters as much as type. Drain either one to 80% and you get a few hundred cycles. At 30% DoD, Victron rates AGM for 1,500 cycles and gel for 1,800. An AGM kept shallow therefore outlasts a gel run to 50% in Victron's figures.
How Cold and Heat Change the Picture
Cold weather is where AGM pulls ahead. Discover says "GEL battery power declines faster than an AGM battery's as the temperature drops below 32°F (0°C)." It also says AGM excels "in extremely cold environments." Think of a pickup in Minnesota or an RV parked through a Colorado winter.
Heat is harder to call. East Penn says running gel above 77°F will reduce its life. Lifeline says AGM life drops by half for every 18°F rise. Discover says gel tends to live longer in hot climates, while OPTIMA describes gel as less tolerant of high heat. With makers split, AGM v gel batteries debates about heat rarely settle. Keep either type shaded and ventilated.
Storing Gel and AGM Batteries
Storage is easier on both. Victron lists self-discharge under 2% per month at 68°F for each. East Penn says to recharge stored gel every 6 months at 0°F to 77°F, and every 3 months at 78°F to 90°F. Lithium packs follow different storage rules, and these tips to extend battery lifespan cover those habits.
Put all of this together and the choice usually comes down to the job. Here's how that plays out for common setups.
AGM is the usual pick for engine starting, high current, and replacing a flooded battery. Gel suits slow, deep, steady cycling where you can set the charger precisely. Either way, read the battery's own manual for mounting and charging.
Best Uses for Each Battery Type
Cars and start-stop vehicles. The gel cell vs AGM question is easiest here. Clarios advises that a vehicle that came with an AGM battery should always get AGM again. OPTIMA suggests a true gel battery in a car would be a rare find.
Replacing flooded batteries. Discover says AGM is the better swap for a flooded battery. Its charge voltages sit close to flooded ones.
Solar and steady deep cycling. East Penn lists solar, water pumping, homes, and remote monitoring among its gel uses. The same logic fits a boat or RV house bank. Pick gel for slow cycling and AGM for cold or heavy loads.
Mounting. Rules vary. Deka AGM goes in almost any position but not upside down, and ODYSSEY allows any position except inverted. Lifeline calls for upright, and East Penn's gel solar monobloc must sit vertically.
Cost and Disposal
Prices vary by brand and region, so compare local quotes. Disposal matters too. Per the EPA's household battery recycling guidance, "do not put lead-acid batteries in the trash or municipal recycling bins." Take old ones to a battery store or a local hazardous waste program.
Weighing a power station instead of a battery bank for boondocking? Our roundup of the best RV batteries for dry camping compares three EcoFlow options.
AGM and gel are both sealed lead-acid batteries, but they don't charge or age the same way. Gel needs lower, tighter charge voltages, and it lasted longer in Victron's cycle and float data. AGM handles high current, engine starting, and cold weather better. Whichever you pick, match the charger profile to the battery and size the bank so it cycles shallow. Check the manual before you swap one type for the other. If your batteries mostly run AC appliances through an inverter, compare a new bank with an all-in-one LFP setup like EcoFlow DELTA Pro.
Which lasts longer, AGM or gel?
Gel comes out ahead in Victron's figures. It's rated for 750 cycles at 50% depth of discharge, versus 600 for AGM. On float at 68°F, gel's design life is 12 years against 7 to 10 for AGM.
Can I charge a gel battery with an AGM charger setting?
It's best not to. AGM settings run higher than gel limits, and gel loses cycle life fast when overcharged. Use the gel profile, or set voltages from your battery's manual.
Can I replace a gel battery with an AGM?
Often, yes, if the size, terminals, and mounting fit. The step people skip is the charger, so move it and any solar charge controller to the AGM profile.
Is gel or AGM better in cold weather?
AGM wins when temperatures drop. Discover reports that gel power falls off faster below 32°F. That gives AGM the edge in any AGM battery vs gel battery choice for cold winters.
Are gel and AGM batteries maintenance-free?
Yes, you never add water to either. Both are sealed VRLA batteries, which is why buyers often weigh AGM versus gel against flooded types. They still need correct charging and should never be opened.
