How to Winterize a Camper: A Beginner's Guide
If you leave a camper full of water through a freezing winter, you can come back to cracked pipes, damaged fittings, and an expensive repair bill. Learning how to winterize a camper means draining the plumbing, protecting the lines, sealing up the exterior, and preparing the inside for months of cold weather. The process takes some time, but most of the work is straightforward once you know what to check.
Drain and Flush the Water System
Water left in your camper's plumbing can freeze and expand when temperatures drop below 32°F. Before storing the camper for winter, drain as much water as possible from the tanks, water heater, faucets, and plumbing lines.
Drain and Flush the Water SystemDrain and Flush the Water System
Empty the tanks
Start with the fresh water tank, gray water tank, and black water tank. Drain each one completely at an appropriate dump station or sewer connection, following your camper manufacturer's instructions. Next, drain the water heater. Make sure the system is cool and follow the manufacturer's instructions before removing the drain plug or opening the drain valve. Leaving water sitting in the tank all winter can lead to freezing and other problems.
Open every faucet
Open the hot and cold faucets inside the camper after draining the tanks. Don't forget the shower, outside shower, or outdoor kitchen faucet if your camper has one. Open the faucets while the system drains so air can move through the lines. Flush the toilet several times as well. This helps remove water that could otherwise remain in the toilet supply line.
Check for leftover water
Draining the tanks won't remove every drop of water. Check the plumbing for any remaining water, then use compressed air at the pressure recommended by your camper's manual or follow up with RV-specific antifreeze. If your camper uses a separate water system, this guide to well pump battery sizing can help with backup planning. With the plumbing drained, you can now protect the remaining water from freezing.
Bypass the Water Heater and Add Antifreeze
Use only non-toxic RV antifreeze made for potable water systems. Automotive antifreeze is toxic and isn't designed for the plumbing in a camper.
Bypass the water heater
Use the water heater's bypass valve before adding antifreeze to the plumbing. If your camper doesn't have a built-in bypass, you may need a bypass kit. This keeps several gallons of antifreeze out of the water heater. You can protect the plumbing without filling the entire tank with antifreeze.
Pump antifreeze through the lines
Connect the RV antifreeze to the water system according to your camper's instructions, then use the water pump to move it through the lines. Open each faucet until you see antifreeze coming through. Work through the hot and cold sides separately. Don't forget the shower, outside fixtures, and toilet supply line. The goal is to get antifreeze through every part of the plumbing that could hold water.
Protect the drains
Pour the recommended amount of RV antifreeze down each sink and shower drain to protect the P-traps from freezing. Never use automotive antifreeze in the camper's water system, and check your owner's manual if you're unsure about the right amount. If the camper is stored away from an outlet, a portable power station can also run tools like an air compressor or shop-vac without a long extension cord.
Powering Tools for a DIY Winterizing Job
Winterizing often means working with tools that need electricity. You may use an air compressor to blow out plumbing lines, a shop-vac to clean the interior, or other equipment while the camper sits in storage without a nearby outlet. A charged portable power station can give you an outlet right where you're working.
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
If you're storing the camper somewhere without easy access to an outlet, the EcoFlow DELTA 3 Max gives you more power for larger winterizing tools and equipment. Its 2,048Wh capacity and 2,400W AC output make it a practical step up when you need longer runtime or want to run more than one device.
EcoFlow DELTA 3 Max (2,048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Once the plumbing is protected, turn your attention to the camper itself. The roof, seals, appliances, and storage areas all need a quick check before the camper sits through the winter.
Protecting the exterior and interior
Winter storms can bring freezing temperatures, snow, rain, and strong winds. A few simple checks before storage can help keep moisture and cold air from causing problems while the camper is sitting unused.
Clean and inspect the exterior
Wash the camper before storing it so dirt and moisture don't sit on the surface for months. Check the roof, seams, windows, and other seals for cracks or gaps, and repair any areas that could let water in during winter storms.
Prepare the interior
Remove perishable food and clean the refrigerator before closing up the camper. Leave the refrigerator doors slightly open so air can circulate and help prevent mold and odors. It's also a good time to remove anything that could be damaged by freezing temperatures.
Store propane safely
If you're removing propane tanks for storage, follow the manufacturer's instructions and local requirements, and keep them in a proper, well-ventilated area away from ignition sources. If you'll stay in the camper through winter, see this guide to living in an RV in winter for tips on keeping the space and plumbing protected while you still have access to water and power.
Winterizing a Camper You Still Live In
Winterizing a camper you plan to occupy through the season takes a different approach. You can't fully drain the plumbing if you need running water every day, so the focus shifts to keeping the pipes, tanks, and living space warm enough to prevent freezing.
Winterizing a Camper You Still Live InWinterizing a Camper You Still Live In
Keep exposed plumbing warm
Heat tape can help protect exposed pipes and hoses from freezing temperatures. Use products designed for the specific application and follow the installation instructions carefully. Skirting can also help. Covering the lower perimeter of the camper reduces exposure to cold wind around the plumbing and holding tanks underneath.
Keep the interior heated
If you're living in the camper, maintaining a safe indoor temperature becomes part of winter preparation. Cold weather can affect more than the plumbing, especially during a prolonged freeze. Plan for nights when temperatures drop sharply. A backup power source can be useful if your heating equipment or water pump depends on electricity.
Have a backup power plan
A power outage is more disruptive when you're living in the camper. You may need electricity for heat, lighting, a water pump, communication devices, or other essentials. Keep your backup power source charged and know which devices you need to run first. A portable power station can also help during an outage when you can't rely on a nearby outlet. If your camper is connected to a home water system, this guide to well pump battery sizing can also help you think through backup power for your water supply.
Learning how to winterize a camper comes down to protecting the plumbing, sealing the exterior, and preparing the interior before freezing weather arrives. Drain the tanks and water heater, open the faucets, bypass the heater, and use only RV-specific antifreeze where needed. Check the roof and seals for gaps, clean out food, and prepare the refrigerator for storage. If you'll keep living in the camper, use skirting and heat tape instead of fully draining the water system. EcoFlow DELTA 3 Plus and EcoFlow DELTA 3 Max can also provide portable power for tools and essential equipment during winter prep.
What kind of antifreeze should I use to winterize a camper?
Use non-toxic RV antifreeze made for recreational vehicle plumbing. Don't use automotive antifreeze, since it's toxic and isn't designed for a camper's water system. Check your owner's manual for any specific product or winterizing instructions.
Can I winterize a camper without an air compressor?
Yes. An air compressor can help clear water from the plumbing, but you can also drain the tanks and lines and use RV antifreeze to protect the remaining water. If you use compressed air, follow the pressure limit in your camper's manual.
How much antifreeze does it take to winterize an RV?
The amount depends on the size and layout of your RV's plumbing. A smaller camper with fewer fixtures may need less than a larger RV with longer water lines. Follow the manufacturer's instructions and use enough antifreeze to reach each faucet, fixture, and drain that needs protection.
Do I need to winterize a camper if I'm still living in it?
Not in the same way as a camper going into storage. If you're living in it, you'll need to keep the water system operating while protecting exposed pipes from freezing. Skirting, heat tape, and a reliable heat source can help, and backup power can keep essential equipment running during an outage.
What happens if I forget to winterize my camper?
Water left in the plumbing can freeze and expand, which may crack pipes, fittings, valves, or other components. You might not notice the damage until you turn the water back on in spring. Winterizing before freezing weather arrives helps avoid those repairs.
RV and Motorhomes
