PECO Outage Map and Status Guide: How to Stay Informed and Prepared for Power Outages
The PECO outage map gives you real-time power outage data across southeastern Pennsylvania, updated every 10 minutes. But the map has limits most people do not know about. In June 2025, a single storm knocked out power for 327,000 PECO customers, and restoration took days.
Quick Answer
To check a PECO power outage, visit the PECO Outage Center, open the outage map, and search by your zip code for current status. If your outage is not listed, report it online, by calling 1-800-841-4141, or by texting "ADDOUTAGE" to 697326. During major storms, restoration estimates may be suspended entirely, so keep a backup power source ready to protect your food, medical devices, and internet connection while crews assess damage.
What Is PECO and Who Does It Serve?
PECO is the largest electric and natural gas utility in Pennsylvania, and its service territory spans much of the Philadelphia region.
PECO, a subsidiary of Exelon Corporation, delivers electricity to roughly 1.7 million customers and natural gas to over 550,000 customers. The service area covers about 2,100 square miles across Philadelphia, Bucks, Chester, Delaware, and Montgomery counties, along with parts of York County.
Chester County, Delaware County, and Montgomery County are the hardest-hit areas during major storms. Dense tree canopies and extensive overhead power lines make these suburban zones especially vulnerable. If you live in any of these counties, knowing how to read the PECO outage map and having a backup plan is critical.
EcoFlow DELTA 3 Ultra Plus + 500W Portable Solar Panel
What Is the PECO Power Outage Map and How Does It Work?
The PECO power outage map is a free online tool that tracks active outages across the full PECO service area. It serves two core purposes: real-time outage tracking and outage reporting.
Real-Time Outage Tracking by Zip Code
Enter your zip code on the outage map PECO provides, and you can see which areas are affected right now. The map refreshes about every 10 minutes and displays the number of customers without power, the cause of the outage when known, and the estimated time of restoration.
Color-coded icons on the map indicate severity. Larger icons represent outages affecting more customers. A star icon with a number shows how many separate outage events are active in a given area.
How to Report an Outage to PECO
Not every outage appears on the map automatically. If your power is out and the PECO power outage map does not show it, report it through any of these channels:
  • Online through the PECO Outage Center at peco.com, where you can submit a report tied to your account.
  • By phone at 1-800-841-4141, available 24 hours a day, 7 days a week.
  • By text by sending "ADDOUTAGE" to 697326 (MYPECO) to enroll in outage alerts, or "STAT" to 697326 to check current outage status.
Your report helps PECO pinpoint the problem faster and update the map for everyone in your area.
What the PECO Outage Map Won't Tell You
The PECO outage map is a strong tool, but it has blind spots that show up during major events.
Suspended Restoration Estimates During Major Storms
During large storms, PECO suspends estimated restoration times entirely. After the June 2025 storm, the company stated that restoration estimates were suspended while crews assessed damage across the region. All you may see on the map during these periods is "assessing damage," with no timeline at all.
The reason is practical. When thousands of poles, wires, and trees are down at once, repair teams need to evaluate the full scope before committing to any restoration schedule.
Why Your Outage Might Not Show on the Map
The PECO outage map depends partly on customer reports to display affected areas. If too few people in your neighborhood have reported the outage, it may not appear at all. The online reporting process also requires account verification, which creates friction during a stressful moment.
Do not assume your neighbors have already filed a report. Submit your own every time the power goes out.
Whole home powered by the EcoFlow DELTA Pro portable power station system in the garage, keeping lights on during a night power outage
When Your Phone and Internet Go Down Too
A widespread outage can knock out cell towers and your home Wi-Fi router at the same time. That leaves you unable to access the PECO power outage map at the exact moment you need it most.
No amount of bookmarking solves that problem. Keeping your router and phone charged with backup power is the only reliable way to maintain access to outage updates. It also keeps you in contact with your family during a prolonged event.
How Common Are PECO Power Outages in the Philadelphia Area?
PECO power outages happen frequently enough that preparation should be routine for every household. Real data from recent years makes the risk clear.
Major Storms That Hit PECO's Service Area
Large storms have caused repeated mass outages in the region:
  • In June 2025, winds exceeding 55 mph knocked out power for 327,000 customers. PECO identified it as among the 20 worst storms in its 144-year history.
  • A 2014 ice storm left roughly 600,000 customers without power across the Delaware Valley.
  • The March 2018 nor'easter knocked out power for hundreds of thousands of customers, and some households waited six days for restoration.
Multi-day restoration periods are common after severe weather, not unusual.
Why Philadelphia's Suburbs Are Hit Hardest
Power outages in PECO's territory follow a consistent geographic pattern. Chester County, Delaware County, and Montgomery County take the worst damage nearly every time, while Philadelphia proper sees far fewer disruptions.
Suburban areas have taller, denser tree cover that falls onto overhead lines during high winds. Restoration crews also need considerably longer to reach spread-out suburban infrastructure compared to dense city grids. Homeowners in these counties face a consistently higher outage risk and should plan accordingly.
How to Prepare for a PECO Power Outage Before It Happens
Preparation covers short outages of a few hours and extended losses lasting multiple days. Both scenarios call for different levels of readiness.
Set Up PECO Alerts and Save Emergency Contacts
Text "ADDOUTAGE" to 697326 (MYPECO) right now to register for PECO outage notifications. Save the outage-reporting number, 1-800-841-4141, in your phone contacts today.
Download the PECO mobile app while your connection is stable. If the power is already out when you try to access the website, a slow or dead connection could block you entirely. Screenshot your account info and store it locally on your device so you can access it offline.
Build an Outage Kit for Short and Extended Outages
  • For short outages of a few hours, keep flashlights, fresh batteries, bottled water, a charged power bank, and non-perishable snacks ready to go.
  • For outages lasting one to two days, add ice packs to protect refrigerated food, keep cash on hand because card readers go down too, and have non-electronic entertainment available for children.
  • For multi-day outages of three days or longer, prepare a plan that includes a safe alternate location, several days of medication, and a backup power source capable of running your refrigerator and medical devices. PECO itself advises customers to identify safe alternate locations during extended power losses.
Residential home staying fully powered at night using the EcoFlow DELTA Pro portable power station system during a grid outage
Protect Food, Medical Equipment, and Home Networks
A closed refrigerator holds safe temperatures for about four hours after the power goes out. A full freezer stays cold for roughly 48 hours if the door remains shut.
Medical devices like CPAP machines and oxygen concentrators require a dedicated backup power plan. The American Red Cross advises households with power-dependent medical equipment to inventory all essential electrical needs and make an evacuation plan before an outage occurs. The American Lung Association also recommends consulting your healthcare provider and equipment supplier about device-specific power requirements and backup options. Without advance preparation, a multi-day outage can become a serious health emergency for vulnerable family members.
Keeping your Wi-Fi router running during an outage also matters. A working router lets your household track the PECO outage map, contact family, and coordinate plans. A typical router uses 10 to 20 watts, a phone charger about 5 watts, and a full-size refrigerator about 150 watts. That combined load sits well within the capacity of a portable power station.
Medical Disclaimer: The information in this article is intended as general preparedness guidance only. If you or a household member depends on electrically powered medical equipment, consult your healthcare provider, equipment supplier, or home health agency to develop a personalized emergency power plan before an outage occurs.
Why a Portable Power Station Is the Best Backup for PECO Outages
The gap between checking the PECO outage map and actually getting through a multi-day outage comes down to backup power. Two main options exist for residential use.
Gas Generators vs. Battery Backup: Which Works Better Indoors?
Feature
Gas Generator
Indoor use
No (carbon monoxide risk)
Yes (zero emissions)
Noise level
65-80 dB (loud)
Under 60 dB (quiet conversation level)
Fuel source
Gasoline (needs refueling and storage)
Rechargeable (wall outlet, solar panels, car)
Ongoing maintenance
Oil changes, spark plugs, fuel stabilizer
Minimal
Fit for row houses and apartments
Not recommended
Well suited
For Philadelphia-area row houses, apartments, and suburban homes with close neighbors, a portable power station is the safer and quieter option.
How the EcoFlow DELTA Pro Keeps Your Home Running During Multi-Day Outages
The EcoFlow DELTA Pro Portable Power Station handles the kind of multi-day outages that PECO customers face regularly. It stores 3.6 kWh of energy and expands up to 25 kWh with Extra Batteries, giving you enough capacity to keep your refrigerator, Wi-Fi router, lights, phone chargers, and medical devices running for days instead of hours.
With 3,600W of output, it covers 99.99% of household appliances, so you do not have to choose between keeping food cold and keeping your phone charged. You can recharge it from a wall outlet in about 2.7 hours, from solar panels during a prolonged grid failure, or at thousands of EV stations worldwide. The LFP (lithium iron phosphate) battery supports up to 10 years of daily use. And because it runs quietly with zero emissions, you can place it anywhere inside your home, no ventilation or outdoor setup required.
Check the PECO Outage Map and Prepare Your Home Today
The PECO outage map shows you where the power is out. It does not keep your food cold, your medical devices running, or your family connected. Storms will keep hitting southeastern Pennsylvania, and multi-day outages will keep happening. Bookmark the map, set up text alerts, build your outage kit, and secure backup power with the EcoFlow DELTA Pro. The time to prepare is before the next storm, not during it.
The first portable home backup battery: expandable 3.6–25kWh, 7200W AC, 6500W MultiCharge, Plug & Play, EV station recharging & 10-year LFP life.
FAQs About the PECO Outage Map
Q1: Does PECO Offer Compensation for Food Lost During an Outage?
Not typically. PECO is not required to reimburse customers for food spoilage caused by power outages. You can submit a damage claim through PECO's website, but approval is not guaranteed. Homeowner's or renter's insurance may cover some losses depending on your policy, with standard coverage ranging from $500 to $1,000. The most reliable way to prevent food waste during an extended outage is keeping your refrigerator powered with a backup battery source.
Q2: What Should I Do if I See a Downed Power Line After a PECO Outage?
Treat every downed power line as live, even if it appears inactive. The Electrical Safety Foundation International (ESFI) notes that the ground around a downed line can be energized up to 35 feet away; stay beyond that distance and do not run. Call 911 first, then report it to PECO at 1-800-841-4141. Do not touch the line, any object in contact with it, or stand near water. Keep children and pets clear of the entire area until utility crews arrive and confirm the line is safe.
Q3: How Does PECO Decide Which Areas Get Power Restored First?
PECO follows a priority-based restoration process. Crews first address downed live wires and life-threatening hazards. Next, they repair transmission lines and substation equipment (the large facilities that distribute power to neighborhoods) that serve the largest number of customers at once. After those high-impact fixes, crews move to local power lines that feed individual neighborhoods and streets. Public safety facilities like hospitals, 911 centers, and water pumping stations also receive priority attention. This approach means your block may stay dark while a nearby area gets restored first, even if your outage started earlier.
Q4: Why Does My PECO Restoration Estimate Keep Changing?
Restoration timelines shift because storm damage is rarely fully visible from an initial assessment. Crews often discover additional broken poles, tangled wires, or underground faults only after arriving on site. Fallen trees weakened by a storm can also come down hours or days later, triggering brand-new outages in areas that were already restored. Each new fault resets the repair queue for that location. High winds or follow-up storms can compound the delays further. Checking the PECO outage map frequently gives you the most current status as conditions develop.
Q5: Does PECO Trim Trees Near Power Lines on Private Property?
Not always. PECO maintains trees along its rights-of-way and public utility corridors to keep lines clear. Trees rooted on private property typically fall under the homeowner's care, including trimming and removal. If a tree on your land falls onto a PECO line, the company will repair its own equipment, but you cover the tree removal and any resulting property damage. Proactive trimming before storm season can reduce your risk of a prolonged outage caused by falling branches.
Power Outages
