Is a Heat Pump Electric or Gas? Electric, Dual-Fuel, and What Runs in an Outage
Is a heat pump electric or gas? A standard residential heat pump runs on electricity. It uses a compressor and refrigerant to move heat. The U.S. Department of Energy (DOE) explains that this can use less electricity for heating than electric resistance equipment. Some homes pair a heat pump with a gas furnace in a dual-fuel setup. That combination can make the system seem like it runs on both fuels. Here's how the different setups work and what they need to keep running during a power outage.
Is a Heat Pump Electric or Gas?Is a Heat Pump Electric or Gas?
A standard heat pump is electric. It moves heat between the indoors and outdoors using a compressor, refrigerant, and fans. A gas furnace isn't part of the system unless the home has a dual-fuel setup. The DOE explains that heat pumps use electricity to transfer heat from a cool space to a warm space. Because they move heat rather than generate it through electric resistance, they can use considerably less electricity for heating. The DOE estimates that a modern heat pump can reduce electricity use for space heating by about 65% compared with electric resistance equipment, such as electric furnaces and baseboard heaters. Actual savings vary with the home, climate, and equipment. Here’s how three common setups compare.
Setup
Main heat
Backup heat
Fuel
All-electric heat pump
Heat pump
Electric resistance strips, if installed
Electricity
Dual-fuel (hybrid)
Heat pump
Gas furnace
Electricity + gas
Gas furnace + AC
Gas furnace
None
Gas (plus electricity for blower)
A gas furnace paired with central air conditioning isn't a dual-fuel heat pump. The furnace heats the home by burning gas, while the AC cools it during warmer months. If you're comparing installation and operating costs, look at heat pump and furnace costs alongside your local electricity and natural gas rates. Either way, the heating equipment needs electricity to operate. That matters when the power goes out.
What Needs Power During an Outage?
A heat pump can't run without electricity. Its compressor, outdoor fan, indoor blower, and control board all need power. A gas furnace also relies on electrical components, even though natural gas supplies the heat. The electrical load depends on the equipment installed in your home. An all-electric heat pump may draw power for the outdoor unit, air handler, and auxiliary heat strips. A dual-fuel system may need electricity only for the gas furnace's controls, igniter, inducer motor, and blower when it switches to gas heat.
Check the electrical load before choosing backup power
Start with the equipment nameplates and installation manuals. Look at the voltage, running wattage, and startup requirements for each component. A compressor can draw more power briefly when it starts, so its startup load needs to be included in the calculation.
Pay particular attention to electric auxiliary heat. These resistance heating strips can draw a substantial amount of power, and their load may be too high for the backup system you're considering. An electrician should determine whether they can be supported and which circuits make sense to back up. Use this checklist when reviewing your system:
  • Outdoor heat pump unit: Check its voltage, running load, and compressor startup requirements.
  • Indoor air handler: Include the blower motor and controls.
  • Auxiliary heat strips: Check their rated load separately. Don't assume a backup battery can support them.
  • Gas furnace: Account for the igniter, inducer motor, controls, and blower.
  • Other backed-up circuits: Include any appliances or household loads that may run at the same time.
A gas furnace still needs power to operate its electrical components. Read more about running a gas furnace without electricity if you're considering relying on gas heat during an outage.
Using EcoFlow TITAN 5000 for selected heating circuits
EcoFlow TITAN 5000 offers 5kWh of base capacity and 7,200W of 120V/240V split-phase output. The Basic option linked below includes one TITAN 5000. To back up wired heating circuits, pair it with the compatible Smart Home Panel 10 (240V), sold separately or in a bundle, and have a licensed electrician install it. The electrician must check the compressor, blower, controls, and backup heat separately to confirm which loads the system can support.
EcoFlow TITAN 5000
Estimate runtime using the actual equipment loads
You can estimate backup runtime once an electrician confirms which circuits the system can support. Use the table to record the electrical input for components that are installed and will run on backup. Check the equipment nameplate or manufacturer’s manual for input power at the operating mode you intend to use. If it only lists current or breaker sizing, ask the electrician to establish the running watts and startup demand. Count any shared blower once.
Installed load
Running input to record (W)
Notes
Heat pump outdoor unit
Outdoor unit input for the heating mode, including compressor and outdoor fan
Record voltage and have the electrician check startup demand separately
Air handler blower
Input for the indoor blower and controls, if listed separately
Count a shared blower once if the furnace input already includes it
Electric aux strips
Rated input for the installed stages that would operate on backup
May exceed backup; electrician decides
Gas furnace electrical parts (dual-fuel)
Total electrical input in gas-heat mode
Include igniter, inducer, controls, and blower. Count the blower once.
For a rough runtime estimate, divide the battery's usable energy by the average load in watts. EcoFlow lists 5,017.6Wh of rated capacity per TITAN 5000. For illustration, if 85% of that energy were available to your loads after losses and any reserve, that would be about 4,265Wh. At a combined average load of 1,500W, the estimate is 4,265Wh ÷ 1,500W, or about 2.8 hours. The 85% is a planning assumption. Actual usable energy and runtime vary with reserve settings, conversion losses, temperature, which heating components run, how often they cycle, and other loads. The electrician should also confirm that the system can handle startup loads and the selected circuits together. Don't assume the battery can run every part of a heating system just because its total running wattage appears to fit.
How Dual-Fuel Heat Pumps Work
A dual-fuel heat pump combines an electric heat pump with a gas furnace. The heat pump usually handles heating in milder weather. When outdoor temperatures fall below a set point, the system switches to the gas furnace. The installer configures that changeover point based on the equipment and home.
When does the system switch to gas?
The thermostat and system controls manage the switch between heating sources. The changeover temperature varies by installation, so there isn't one setting that applies to every home. A dual-fuel system can use the heat pump when outdoor conditions allow it to heat the home efficiently, then rely on the gas furnace when the system reaches its configured switchover point. This lets homeowners use both heating sources through the same ductwork.
The setup also affects backup power planning. During a power outage, the gas furnace still needs electricity for its controls, ignition, inducer motor, and blower. If the heat pump is running, its compressor and fans need power as well. Check which mode the system is likely to use and have an electrician evaluate those loads before choosing a backup setup. Homes without existing ductwork may use a different arrangement. Review mini-split and heat pump options if you're comparing options for a room addition or a home without ducts.
Heat Pumps in Cold Weather
Heat pumps can keep heating a home in cold weather, but their performance depends on the model and outdoor temperature. In cold, damp conditions, frost can collect on the outdoor coil and restrict airflow. The system periodically runs a defrost cycle to clear it.
Heat Pumps in Cold WeatherHeat Pumps in Cold Weather
Why a heat pump may switch modes during defrost
During defrost, the heat pump temporarily changes how it operates to warm the outdoor coil. Some systems use auxiliary heat to help maintain indoor comfort during this cycle. That can increase electricity use for a short period. The DOE recommends choosing a heat pump with demand-defrost controls. These controls activate defrost when needed rather than running it on a fixed schedule, helping reduce unnecessary supplementary heating and heat pump energy use.
Cold-climate heat pumps are designed to operate at lower outdoor temperatures, but their performance varies by model. Check the manufacturer's specifications for the unit's rated operating range and heating capacity. If you see persistent ice buildup or the outdoor unit remains covered in ice, it may need service. Learn how to identify heat pump ice buildup and when to call an HVAC technician.
A standard heat pump runs on electricity, while a dual-fuel system adds a gas furnace for colder conditions. Both setups need electricity to operate, so a gas furnace won't keep running through an outage unless its electrical components have power. Before choosing backup power, identify your heating system and check the nameplate ratings for each component. Include compressor startup, blower loads, controls, and auxiliary heat in the calculation. An electrician can then determine which circuits are compatible with a backup setup. EcoFlow TITAN 5000 offers 5kWh of base storage and 7,200W of split-phase output for selected circuits connected through a professionally installed Smart Home Panel 10 (240V). The right configuration depends on your equipment and its actual electrical demand.
A standard heat pump runs on electricity. It uses a compressor and refrigerant to move heat rather than burning fuel. A dual-fuel system pairs the electric heat pump with a gas furnace.
Do heat pumps use gas?
In a typical dual-fuel setup, the heat pump runs on electricity and the separate furnace burns gas when it takes over. An absorption heat pump is a less common design that can use natural gas as a heat source.
What is a dual-fuel heat pump?
A dual-fuel heat pump combines an electric heat pump with a gas furnace. The heat pump usually heats the home in milder weather, and the furnace takes over when outdoor temperatures reach the system's configured changeover point.
Does a heat pump work in a power outage?
A typical electric heat pump can run during an outage only if compatible backup supplies its circuits and can handle the running and startup loads. Its compressor, fans, and controls all need electricity. A gas furnace also needs electricity for its igniter, inducer motor, controls, and blower, even when it burns natural gas for heat.
Is a heat pump cheaper than gas?
It depends on your local electricity and natural gas rates, climate, and equipment efficiency. Compare the cost of running each system using your utility rates and the manufacturer's efficiency ratings. A dual-fuel system may also switch between the heat pump and furnace based on its thermostat settings.
Home Backup
