The 30% Federal Tax Credit ends Dec 31, 2025. Pre-order your OCEAN Pro today—own the power and the savings.
Own Your Energy. Your Way.
EcoFlow OCEAN Pro Solar Battery System
An All-in-One Ecosystem, Built to Outperform.
Energize Your Home. Your Way.
EcoFlow OCEAN Pro gives you reliable, AI-powered energy storage that works with solar, the grid, and generators.
  • Max Out on Power
  • 24/7 Energy
  • Save & Earn with AI
With 40kW solar input, EcoFlow OCEAN Pro utilizes more rooftop solar to store extra energy, cut bills, and power your home longer. Using a generator cord, it can even charge your system directly with portable generators and EcoFlow power stations, without any installation.
Unlimited Whole-Home Backup
100% Energy Freedom
Zero Compromise
Uninterrupted Backup Power
At the core of EcoFlow OCEAN Pro is its 24kW continuous output and 205A LRA surge power, delivering enough power to run your entire home without compromise. Whether it’s two HVAC systems, a pool pump, EV charger, or heavy-duty appliances all running simultaneously, EcoFlow OCEAN Pro handles it effortlessly.4
Multi-Source Backup Options
Solar + Battery + Portable Generator + Power Station
EcoFlow OCEAN Pro intelligently integrates solar, grid, battery, portable generators, and EcoFlow Power Stations to power your home. Whether it’s a short outage or days off-grid, EcoFlow OCEAN Pro allows you to easily switch to the best available power source, keeping your home powered without hassle.
  • Capture up to 40kW of solar power for uninterrupted home backup and greater energy independence.
  • Start with 10kWh and expand to 80kWh, ensuring reliable backup for any scenario.
  • Connects directly to portable generators and EcoFlow power stations for unlimited backup when solar and grid power aren’t available.
  • Integrates with EcoFlow DELTA Pro Ultra for seamless power expansion.
Explore Multi-Source Backup
24/7 Whole-Home Backup
Power Through Any Outage
EcoFlow OCEAN Pro combines multi-source backup and expandable storage to go beyond standard battery systems.
During Outages
Extend your home backup with 3 plug-and-play options
During Outages
  • All Kinds of Portable Generators
    Compatible with portable generators from leading brands and beyond — plug in and power up instantly.
  • All EcoFlow Portable Power Stations
    Connects EcoFlow portable power stations into a seamless, unified system—delivering reliable power from portable to home use.
  • All V2L EVs
    Upgrade from V2L to V2H and enjoy massive backup capacity for your energy storage system.
Designed to Fit Every Home.5
EcoFlow OCEAN Pro isn’t just powerful—it’s built to complement your home. With a sleek, modern aesthetic and premium material options, it seamlessly blends into any space while delivering unmatched performance.
Form Meets Function
EcoFlow OCEAN Pro is designed to elevate both your home's energy and its aesthetic. With premium finishes, it blends into any space while delivering industry-leading performance. An intuitive on-device LED display gives real-time energy insights at a glance, while a breathing light brings a sense of motion and clarity to your power system.
Aerospace-Grade Aluminum
Precision-engineered for durability and corrosion resistance, ensuring long-lasting strength.
Form Meets Function
Premium Walnut Wood
Premium Walnut Wood
Crafted from high-density hardwood with a refined finish, offering a natural look and a premium feel.
Form Meets Function
Performance-Grade Carbon Fiber
Lightweight yet impact-resistant, designed for strength and durability without compromising on style.
Industry-Leading Integrated On-Device LED Energy Display
Real-Time Power Visualization
The inverter features an intuitive LED display that shows the energy flow, output levels, and current mode—all at a glance.
Mode Confirmation
Error & Status Alerts
Mode Confirmation
When users change system modes—like activating AI Mode—the display updates instantly to reflect the new status, offering reassurance the system is responding as expected.
The system proactively shows warning codes or fault indicators, prompting users to check the app or contact support immediately.
Energy That Breathes
Inspired by the curves and motion of sports cars, the breathing light brings energy to life with fluid, ambient movement.
Built to Shield. Built to Last.
Engineered for Peace of Mind.
EcoFlow OCEAN Pro is designed with a multi-layered safety system that sets a new standard in home energy storage. From temperature extremes to fire and flood scenarios, EcoFlow OCEAN Pro is built to protect.
Engineered to perform in temperatures from -4°F to 140°F, EcoFlow OCEAN Pro's LFP battery pack features an advanced Battery Management System that continuously monitors every cell and connection point for overheating risks. Its 360° Aerogel Insulation helps regulate battery temperature, preventing thermal stress even during peak load or harsh weather.
15-Year Warranty.6
Maximum Peace of Mind.
EcoFlow OCEAN Pro sets a new standard in reliability with an industry-leading 15-year warranty. Designed for long-term energy security, this extended coverage ensures you get the most from your investment.
Smarter Energy, Powered by AI
The EcoFlow App
With the EcoFlow App, EcoFlow OCEAN Pro uses AI to manage your home’s energy with precision. It learns your daily patterns, predicts solar input, and runs your system in the most efficient way.
Smarter Energy. Lower Bills.
Manage appliances, shift usage, and reduce bills — effortlessly and intelligently.
smarter_text1
AI Mode
Switch to AI Saving Mode with one click and let smart energy management cut your bills automatically.
smarter_text2
Smart Energy Scheduling
Let AI optimize your energy use with a smart schedule that adapts to your solar power, tariff, and consumption patterns.
smarter_text3
Device-Level Energy Management
Prioritize your home’s power supply with the EcoFlow App to save on bills while keeping what matters powered.7
AI Brings You Closer to a $0 Bill — Or Even Better Earn While You Save.
EcoFlow OCEAN Pro learns your energy habits, predicts solar availability, and automatically optimizes your usage. You save more — and it can even pay back 100% or more of your energy bill.8 With Virtual Power Plant integration, you can sell stored energy back to the grid.9 AI-powered forecasting helps you maximize savings and turn extra power into earnings, while keeping your home fully powered.
Bill Before Optimization
You pay the full bill
100%
Cutting Costs with Solar & Storage
Start saving on energy, up to
101%
With AI-TOU Mode Earn While You Save
Save even more, up to
118%
EcoFlow OCEAN ProEcoFlow DELTA Pro Ultra X
What is it?An on-grid residential battery system that works with solar, V2L EVs, and generators to deliver unlimited whole-home backup. It lets homeowners maximize solar self-consumption, save under TOU by charging off-peak and using at peak hours, and earn extra by selling power back to the grid or joining VPPs.An off-grid, plug-and-play whole-home backup system that keeps your home powered 24/7. Modular and portable, it can expand as needs grow, stores surplus solar and TOU to cut costs, and ensures backup during outages — compatible with generators and solar panels for seamless power.
Grid Connection
On-grid
Off-grid
Who is it for?Homeowners who:
Want a comprehensive home energy solution.
Live in areas with extended power outages and want reliable backup power.
Want to earn by selling power to the grid or VPP and maximize renewable incentives.
Homeowners who:
Want a simple and affordable whole-home backup system.
Value portability and easy expansion — easy to move when relocating and simple to add capacity.
Enjoy hands-on setup and DIY energy control.
Use CaseLong-term energy independence, bill savings, full-home solar integration.Fast backup for outages, critical loads, and flexible expansion in the future.
InstallationRequires certified installer with local utility & authority having jurisdiction approval.Plug-and-play system with quick setup by you or your electrician — typically installed within 7 days of delivery.
How to Choose
Want to save on utility bills through solar generation?
Ready to work with an installer for permits and solar setup?
Want a turnkey, utility-connected system?
Currently Viewing
Need a DIY backup system that’s simple to set up?
Want to start small and easily expand as your power needs grow?
Want a portable system you can move and adapt to your home?
Try a demo with the EcoFlow app.
Get a hands-on preview of the EcoFlow app and explore how you can monitor, manage, and optimize your Ocean Pro system.
Simulate real-time energy tracking.
View battery status, solar input, and grid usage.
Test smart energy management.
Adjust settings and see how Ocean Pro optimizes power.
Experience remote control features.
Toggle between power sources and monitor system health.
Datasheet
Download now
Datasheet
Free consultation
Schedule a call
Free consultation
Join our community
Join our community
Join our community
Datasheet
Download now
Datasheet
Free consultation
Schedule a call
Free consultation
Join our community
Join our community
Join our community
* All specifications and descriptions shown may differ from the actual product. EcoFlow reserves the right to make changes and amendments to the product shown or described here at any time without prior notice. All functionality, features, specifications, design, and other product information displayed on this webpage—including, but not limited to, components, performance, availability, and capabilities—are subject to change without notice. The contents and simulated images on the screen are for demonstration purposes only. * Performance data is based on tests conducted in controlled environments using pre-configured settings. Actual results may vary depending on the environment, system updates, and individual usage patterns. * EcoFlow OCEAN Pro supports unlimited backup duration by integrating with all kinds of generators for continuous energy replenishment. The system charges the battery first, then powers the home. Backup duration depends on generator output and fuel supply. * EcoFlow OCEAN Smart Electrical Panel 40, EcoFlow portable power stations and generator cords are sold separately. * Connecting portable generators, EcoFlow portable power stations, or EVs to the inverter may require device-specific connection cables or accessories, which are sold separately. Users should ensure that all connections comply with the device manufacturer’s specifications and safety guidelines. * The ability to sell excess energy back to the grid depends on your region, utility company, and availability. * Walnut Wood and Carbon Fiber chassis options coming soon. 1. Depends on the battery state of charge, total load size, and individual appliance startup requirements. 2. Full access to smart optimization features (such as AI mode) may depend on certain user actions or configurations. For details and assistance, please contact our customer support team. 3. Activation of AI mode is required to utilize this feature. 4. Actual backup capability depends on battery state of charge, total load size, and individual appliance startup requirements. 5. Refers to offering users a choice of three different chassis styles. 6. Warranty terms are subject to https://homebattery.ecoflow.com/us/support/warrantly-and-policy. 7. Requires EcoFlow OCEAN Smart Electrical Panel 40 for functionality. 8. The savings figure is calculated based on a typical scenario and is for illustrative purposes only. Actual results will vary depending on factors such as household electricity usage, local rates, solar generation, and consumption habits. Please consult your installer or use the web calculator on our official website for an estimate based on your household’s specific conditions. Example assumptions: California household with 11 kW solar (approx. 50% of CA homes), 26 kWh daily consumption (approx. 50% of CA homes), 20 kWh battery storage (two E7 units), and PG&E 2025 NEM export rate with EV TOU plan. Under these conditions, the annual electricity bill without solar and storage is $3,761.71; with Self-Consumption Mode, annual net profit is $44.08; with AI Mode, annual net profit is $680.48, representing an approximate 118% savings compared to the original bill. 9. The ability to join a Virtual Power Plant (VPP) varies by region, utility company, and availability.
