High Winds: What Counts as High Wind and How to Prepare
You step outside, and the trees are bending sideways. Your trash can just rolled down the driveway on its own. Is this a normal windy day, or something the weather service actually treats as dangerous? Most of us guess. The National Weather Service doesn't. It draws a hard line at 40 mph sustained or 58 mph gusts, and that line matters more than people realize. Here's where the threshold sits, what high wind does to a house, and how to get ready.
What Actually Counts as a High Wind?
Ask ten neighbors what is considered strong wind, and you'll get ten different answers. Here's how the NWS alert definitions break it down:
  • Wind Advisory: sustained winds of 31 to 39 mph for an hour or more, or gusts of 46 to 57 mph.
  • High Wind Warning: sustained winds of 40 mph or greater for an hour or more, or gusts hitting 58 mph, even briefly.
  • High Wind Watch: those same conditions are possible, usually within 36 hours.
  • Watch versus warning: a watch buys you time. A warning means it's happening now. That gap is your window to bring in the patio furniture and charge what needs charging.
  • No named storm required: a strong cold front can trigger warning conditions on an ordinary afternoon.
  • Reading the alert: wind deserves as much attention as any hazard, and reading weather alerts is a skill worth having.
So what is high wind by the book? Anything at or above 40 mph sustained, or a 58 mph gust. The answer to what is a high wind comes down to those two numbers.
High WindHigh Wind
The Beaufort Scale: Reading Wind Speed Like a Meteorologist
The number on your phone doesn't tell you much. Watching large branches whip back and forth does. The National Weather Service still uses the land-based Beaufort scale to describe real-world effects.
What Each Force Level Looks Like Outside
  • Force 6, 25 to 31 mph: large branches move constantly, and umbrellas turn useless.
  • Force 8, 39 to 46 mph: official warning territory. Twigs break, and walking gets hard.
  • Force 9, 47 to 54 mph: structural damage starts. Chimney caps and shingles go first.
  • Force 10 and up, 55 mph and higher: uprooted trees and the damage that cuts power across whole neighborhoods.
Beaufort Wind Speeds at a Glance
Force
Speed
Description
What You'd See
4
13-18 mph
Moderate breeze
Small branches move, loose items shift
6
25-31 mph
Strong breeze
Large branches in constant motion
8
39-46 mph
Gale
Twigs and small branches break
9
47-54 mph
Strong gale
Chimney caps, roof tiles come loose
10
55-63 mph
Whole gale
Trees uprooted, considerable damage
12
73+ mph
Hurricane force
Severe, widespread structural damage
That jump from broken twigs to uprooted trees explains why wind alone causes so many outages.
Why High Winds Are One of the Biggest Threats to Your Power
Most people picture a hurricane when they imagine losing power for days. The outage data says otherwise.
What the Outage Numbers Show
  • About 83% of reported U.S. power outages from 2000 to 2021 were tied to weather, per Climate Central's outage analysis.
  • Severe weather, including high winds, heavy rain, and thunderstorms, caused 58% of the 1,542 major outages examined.
  • Weather-related outages rose roughly 78% from 2011 to 2021 versus the decade before.
One cold front pushing 50 mph gusts can down enough lines to cut power for days.
Storm-Ready PowerStorm-Ready Power
Figuring Out How Much Backup You Actually Need
Before you shop, answer two questions. What has to stay running? And for how long? A fridge, lights, and a modem are a very different load than a well pump and central air. Checking how long outages last helps you size the capacity. If your must-run list is the whole house, start here. The EcoFlow DELTA Pro Ultra X ties into your panel and carries central air, a well pump, and everything else at once.
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. •Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Auto switchover in under 10ms standalone, under 20ms with Smart Home Panel. • High Savings: Saves up to $6,000 per year with a 3-year ROI. •Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
If your list stops at the essentials, a whole-home system is more than you need. A portable power station covers the fridge, lights, and modem with no installation and a much lower price, and you can carry it to whatever room needs it. The EcoFlow DELTA 3 Max is built for exactly that job.
EcoFlow DELTA 3 Max (2,048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. •OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Where a Battery Differs From a Fuel Generator
So how does it handle strong winds? It doesn't have to. A fuel generator runs outside, away from windows and vents, in the worst of the weather. A battery stays charged indoors until the power drops. That saves a trip into the yard at the worst moment.
What Actually Happens to a Home in High Wind
Damage rarely starts with the whole roof. It starts at one weak point and spreads.
Garage Doors and Roofs Fail First
  • Garage doors are a common failure point. Once one gives way, pressure builds inside and pushes the roof from underneath.
  • Shingles and tiles fail next, matching Force 9 on the Beaufort scale. That's a wind heavy enough to peel roofing well before hurricane strength.
  • Reinforcing the door before storm season is one of the best projects a homeowner can take on.
Trees and Everything Loose in the Yard
  • Trees with shallow or weakened roots come down disproportionately, and they're the leading cause of downed lines.
  • Patio furniture, trash cans, and grills turn into projectiles well before winds get severe.
Knowing what breaks first is useful. Getting ahead of it is better.
Preparing Your Home and Family Before High Winds Hit
The work that protects a house happens on a calm weekend, not during a warning.
  • Pick a shelter spot now: the American Red Cross recommends a basement or a small interior room without windows.
  • Skip the mobile home or RV: neither is safe shelter in high wind. Find a sturdier location in advance.
  • Tell everyone the plan: the whole house should know the spot, kids included.
  • Clear the yard: bring in or tie down furniture, trash cans, grills, and decorations.
  • Trim the trees: cut weak or overhanging branches before storm season.
  • Secure loose siding and gutters, since flapping material fails fast.
  • Charge everything: back up power and phones as soon as a watch is issued.
  • Build the wider plan: a severe weather power plan is worth having before any warning.
Preparing for high windsPreparing for high winds
Staying Safe During and After High Winds
Once the wind picks up, your decisions get simpler.
While the Wind Is Blowing
Stay inside, keep away from windows, and move to that interior room if a warning is issued. Skip errands too. Trucks and vans really do get pushed around on open roads, and NWS wind safety notes damage starts near 40 to 50 mph sustained.
Once the Wind Dies Down
Head straight out to clean up, and you can walk into the day's worst hazard. Treat every downed line as live, since CDC outage safety says to avoid contact and keep kids and pets away. A generator running while the grid is down belongs outside, far from windows and vents. Generator safety rules cover the mistakes that turn dangerous fast.
High wind has a real definition: 40 mph sustained or 58 mph gusts. It causes a large share of U.S. outages every year with no hurricane attached. Learn which alerts your area issues. Secure loose items and reinforce the garage door before storm season. Pick a shelter spot while a watch is still just a watch. Since wind knocks out power more often than people expect, decide in advance how you'd keep the essentials running, and both the EcoFlow DELTA Pro Ultra X and DELTA 3 Max do that without sitting outside in the weather.
What wind speed is officially considered a high wind?
Sustained winds of 40 mph or greater for an hour or more, or gusts of 58 mph or higher. That's the NWS threshold for a High Wind Warning. In short, what high winds are by official standards comes down to those two numbers.
What's the difference between a Wind Advisory and a High Wind Warning?
An advisory covers 31 to 39 mph sustained, or gusts of 46 to 57 mph. A warning is the tier above, at 40 mph sustained or 58 mph gusts. An advisory means inconvenient. A warning means expect damage and outages.
What does high wind actually do to a house?
Garage doors and roof shingles usually fail first. Once a door gives way, pressure builds inside and pushes the roof from underneath. Loose yard items become projectiles, and weakened trees fall onto lines and roofs.
How does battery backup handle strong winds compared to a gas generator?
A gas generator runs outside, away from windows and vents, while the weather is still bad. A battery power station stays indoors, charged and ready, and switches on when the grid drops. No fuel, no fumes, no trip outside mid-storm.
How can I prepare my home before a high wind warning is issued?
Trim weak branches, reinforce the garage door, and decide where everyone shelters. Then list what needs to stay powered and keep your backup charged. Most of it takes one weekend.
Power Outages
