Heated Driveway Cost: What Electric and Hydronic Snow Melt Systems Cost to Install and Run
- Electric vs Hydronic: Two Very Different Heated Driveway Systems
- How Much Does a Heated Driveway Cost to Install and to Run?
- Can Backup Power Keep a Heated Driveway Running in a Storm Outage?
- Heated Driveway Installation: Zones, Controls and Who Does the Work
- Is a Heated Driveway Worth the Cost for Your Home?
- Conclusion
- FAQs
Picture a steep driveway coated in ice at 6 a.m. A shovel waits by the door. A heated driveway removes that chore, but the heated driveway cost has two separate parts. One is the install bill, paid once. The other is the running cost, paid every storm. Many cost pages blur the two together.
This article keeps them apart. It splits electric and hydronic systems, uses real numbers from a maker's published price page, and shows a simple formula for kWh per storm. It also looks briefly at whether a home battery can keep an installed system going in an outage. Often, it cannot.
An electric system buries heating cable or mats in the driveway and heats them with electricity. A hydronic system pumps a heated water and glycol mix through tubing. The heat comes from a boiler, usually gas-fired. That difference drives almost everything else, from install cost to what happens in an outage.
Glycol is antifreeze in the loop. It keeps the tubing from freezing when the system is off.
Each heated driveway system also runs on different numbers. The table below sets the two side by side, and every figure is tied to the maker or course that published it.
Question | Electric snow melt | Hydronic snow melt |
Where the heat comes from | Electricity through cable or mats | A boiler or other heat source, with a pump moving a water and glycol mix |
Typical heat density (maker data) | About 39 to 50 W per sq ft (WarmlyYours mats and cable; Raychem WinterGard Mesh 50 W per sq ft) | 120 to 170 Btu/h per sq ft as a general design range (Watts-sponsored course) |
Voltage | Raychem WinterGard Mesh comes in 120V and 240V; WarmlyYours cable in 120V, 208V, 240V and 277V | Pump and controls are often 120V (check the nameplate); the heat itself comes from fuel |
Required electrical protection | Ground-fault equipment protection on each heating cable branch circuit (Raychem) | Per the boiler and pump makers' instructions |
Surfaces | Concrete, asphalt, or screenings under pavers (Raychem) | Per the tubing maker's guide |
Automatic control | Sensors start the system below 38°F when moisture is present (Raychem controllers) | Slab and moisture sensors, sometimes with an anticipating start (Watts course) |
The Btu range is a design figure from one course. It is not a code requirement. Portable snow-melt mats also exist, but they are a separate product category and fall outside this comparison.
Voltage matters more than most owners expect. Most snow-melt circuits run at a different voltage than the outlets in a kitchen, and 240V versus 120V setups shape how those circuits are wired and backed up.
Once the type is clear, the two halves of the cost are easier to estimate on their own.
The install price is a one-time hit. It depends on area, coverage, and whether the driveway is being poured new. The running cost depends on watts per square foot, the size of the heated area, and the hours of operation per storm. Many homeowners wonder how much a heated driveway costs before they ask which half they are pricing.
Installed cost: One maker's published examples (electric)
WarmlyYours publishes installed examples for electric systems. Treat the table as one maker's estimates, not national averages.
Driveway coverage | Area | Installed cost published by WarmlyYours |
Full coverage, 10 ft × 20 ft | 200 sq ft | About $2,500 |
Full coverage, 20 ft × 20 ft | 400 sq ft | About $4,750 |
Full coverage, 30 ft × 20 ft | 600 sq ft | About $7,000 and up |
Tire tracks only | 80 / 160 / 240 sq ft | About $1,850 / $2,360 / $3,500 and up |
Controls (separate) | N/A | $629 to $3,799 |
Maker's published estimates, electric systems. They leave out removal of an old driveway and any new paving. WarmlyYours also lists material cost per square foot, at about $12 to $25 for mats and $10 to $18 for cable.
One maker's page cannot show how much heated driveways cost across the country. Hydronic work is harder to pin down. No installed price from a hydronic maker was verified for this article. Those systems add a heat source, pump, tubing, and glycol, so pricing needs a local quote.
Running cost: kWh per storm, worked out
The cost of heating a driveway starts with one formula:
kWh = W per sq ft × sq ft × hours ÷ 1,000
The price used here is 17.83 cents per kWh. That is the U.S. average residential price for the first quarter of 2026, from the EIA Short-Term Energy Outlook (October 2026 release, Table 2, historical quarter). A winter quarter suits snow melt.
Anyone asking how much heated-driveway electricity costs per storm can follow the examples below. Each assumes 6 hours of operation.
Example (6 hours of operation) | Load | Energy | Cost at 17.83¢ per kWh |
Tire tracks, 120 sq ft at 50 W per sq ft (Raychem WM2-0340 mat, 6,000W, 240V) | 6.0 kW | 36 kWh | About $6.42 |
Full coverage, 200 sq ft at 50 W per sq ft | 10.0 kW | 60 kWh | About $10.70 |
Full coverage, 400 sq ft at 50 W per sq ft | 20.0 kW | 120 kWh | About $21.40 |
These are examples only. Real cost shifts with the local rate, any demand charge or tiered pricing, how long the controller runs the system, and how many storms arrive. That is why no annual figure appears here. Storm counts vary too much.
Hydronic running cost is mostly boiler fuel. It depends on local fuel prices, so it stays qualitative here.
A utility bill shows kWh, not watts. It helps to start with calculating kWh usage before trusting any running cost estimate.
Those per-storm numbers also answer a question many owners ask after their first outage. Can a battery keep the driveway clear when the grid is down?
Only in narrow cases, and only for a system that is already installed. Electric snow melt draws many kilowatts for hours. That outruns most home batteries fast. A hydronic system is different, because the battery only has to run the pump and controls while gas supplies the heat.
Electric systems hit the output limit quickly
Start with the load. A 10 ft × 20 ft full-coverage zone at 50 W per sq ft draws 10,000W. That already exceeds the 7,200W rated output of the EcoFlow TITAN 5000.
A single 120 sq ft zone at 6,000W and 240V fits under 7,200W. The energy runs out fast, though. Here is the labeled estimate:
One 5kWh battery: 5,000Wh × 0.85 ÷ 6,000W gives about 0.7 hours.
Maximum 30kWh capacity: 30,000 × 0.85 ÷ 6,000 gives about 4.3 hours. That is less than one 6-hour melt cycle.
For most electric driveways, backup power is not a practical plan. The product cards below apply only to the narrow cases described next.
Hydronic systems need far less electricity
The pump is the main electrical load. One example is the Taco 007e circulator. It runs at 120V, draws 44W at maximum, and is rated for up to a 50% water and glycol mix. A labeled estimate for that pump alone on one battery gives 5,000 × 0.85 ÷ 44, or about 97 hours.
That number covers the pump only. The boiler's own electrical draw and the snow-melt controller must be added from their nameplates. Snow-melt loops may also use larger pumps than this example.
The battery does not supply heat. The boiler still needs its gas supply, and a battery does not make up for a lack of fuel.
If one of those narrow cases fits a system, these two EcoFlow TITAN models line up with them by voltage and load.
The second model suits a different situation. A small electric zone on a 240V circuit needs a battery built for split-phase output.
How the two products divide the job
The EcoFlow TITAN 5000 Classic matches a hydronic snow-melt system that has its own gas heat source. The 120V circulator pump and controller fit within its output. The battery does not provide the system's heat.
The EcoFlow TITAN 5000 matches only a small 240V electric zone whose total wattage and energy use have been worked out and fit. Its 7,200W is not a promise for any driveway size. Large electric areas and long melt times rule it out.
A professional should check zoning, pump starting load, melt duration, and the glycol plan. Fixed circuits use the voltage-matched Smart Home Panel 10 and a licensed electrician. The battery never goes outdoors where snow or water can reach it.
Stored energy runs out far faster under a melt load than under the loads people usually plan for in whole-home battery storage. That is why the hours matter as much as the watts.
Whether or not backup is part of the plan, a few install decisions shape how well the driveway works and how much it costs to run.
Install choices lock in both the price and the running cost for the life of the driveway. Coverage area matters most, followed by controls. The electrical side is not a DIY job, and it shapes the final heated driveway cost as much as the materials do.
Decisions that set cost and load
Coverage: Tire tracks heat far less area than full coverage. Compare the 80 sq ft and 200 sq ft rows in the cost table above.
Zoning: WarmlyYours says a multi-zone controller can heat a driveway one zone at a time. That keeps the peak load lower.
Controls: Moisture and temperature sensors start the system before snow builds up (WarmlyYours). Raychem's controllers activate below 38°F when moisture is present.
Ground-fault protection: Raychem requires ground-fault equipment protection on each heating cable branch circuit. One controller version needs a separate 30 mA GFCI, and another has it built in.
Electrical capacity: A 10 kW or 20 kW zone may need a panel and service check by a licensed electrician before anything is poured.
Hydronic extras: Boiler sizing, pump selection, and the glycol mix should come from the designer. The Watts course describes systems that use an existing boiler or a dedicated one.
Decision | Lower cost and load | Higher cost and load |
Coverage | Tire tracks, walkway strip | Full width, full length |
Controls | Automatic moisture and temperature sensor | Manual switch left on too long |
Timing | Built into a new pour | Retrofit that requires removal |
Removal and repaving prices are not quoted here. None were verified from a maker or a primary source.
A large melt zone can strain an older service, and smart electrical panels are one way homeowners manage big loads.
With the costs and install trade-offs on the table, the last step is deciding whether a heated driveway makes sense for a given house at all.
It depends on how often it snows, how steep the driveway is, and who uses it. For some homes, it is a safety upgrade. For others, a snow blower or a plowing service is cheaper. Owners still asking how heated-driveway costs compare with those options should weigh the factors below.
If this describes you | A heated driveway makes more sense when... |
Steep driveway or frequent ice | Falls and stuck cars are a real risk |
Older adults or mobility needs at home | Shoveling isn't safe or possible |
Already pouring a new driveway | Install cost is lower than a retrofit |
Existing gas boiler with spare capacity | A hydronic system can use it (designer's call) |
Mild winters with a few light snows | Usually not; running and install costs are hard to justify |
No resale value or payback claims are made here. None were verified.
Before spending thousands on snow melt, it is worth comparing it with other projects that offer the best return on investment dollars.
Heated driveway cost has two parts. One is a one-time install price that grows with coverage. The other is a per-storm running cost, estimated from watts per square foot, area, and hours. Electric systems are simpler but draw many kilowatts. Hydronic systems rely on a boiler.
The practical step is to price tire tracks and full coverage side by side. Then run the kWh formula for a 6-hour storm before signing anything.
If outage backup matters, ask the installer whether a hydronic pump fits an EcoFlow TITAN 5000 Classic or whether a small 240V zone fits an EcoFlow TITAN 5000.
How much does a heated driveway cost?
It varies with size and coverage. WarmlyYours publishes installed electric examples of about $2,500 for a 200 sq ft full-coverage driveway and about $4,750 for 400 sq ft, plus controls. Hydronic systems need a local quote.
How much does it cost to heat a driveway per storm?
At 50 W per sq ft and EIA's Q1 2026 average of 17.83 cents per kWh, a 200 sq ft area running 6 hours uses 60 kWh, about $10.70. Local rates, demand charges, and run time change the result, so treat it as a rough example only.
Is hydronic or electric cheaper to run?
It depends on local fuel and electricity prices. Hydronic systems burn fuel for heat and use electricity mainly for pumps and controls, while electric systems use electricity for all of the heat. Local prices for each decide which costs less.
Can a heated driveway be installed in an existing driveway?
Usually not without removing and replacing the surface. Electric cable and mats are embedded in concrete, asphalt, or the bedding under pavers, so a retrofit often means tearing out the old driveway and paving it again later.
Can a home battery run a heated driveway?
Rarely for electric systems. A 200 sq ft electric zone at 50 W per sq ft draws 10,000W, more than the EcoFlow TITAN 5000's 7,200W rated output. A hydronic pump and controller are a better fit for battery backup during an outage.
