Air to Water Heat Pump: How It Heats and Cools With Water, and Which Homes It Suits
- What Is an Air to Water Heat Pump? The Same Refrigerant Cycle, a Different Delivery
- Which Homes and Emitters Match an Air to Water Heat Pump's Water Temperatures
- Planning Power for an Outage: The Circulation Loop and the Compressor Are Two Separate Loads
- Air to Water Heat Pump for Cooling: Fan Coils, Radiant Floors, and Dew Point
- Freeze Protection, Cold-Weather Output, and Backup Heat
- Conclusion
- FAQs
If you already have radiant flooring or a hydronic boiler in your house, you might not need to replace all of your existing pipes to convert to electric heating. An air to water heat pump extracts heat from the outside air and transfers it to water that flows through your home. It can also provide cooling depending on the setup. Knowing which heating emitters perform best, how cooling impacts moisture and what happens during a power outage is helpful before deciding on one. Here is what homeowners should know before investing in an air to water heat pump system.
An air to water heat pump works on the same basic principle as the heat pump found outside many American homes. The main difference is how it delivers heat. Instead of warming air that travels through ducts, it heats water that flows through pipes to radiant floors, radiators, or fan coils.
What NREL says the outdoor unit does
The outdoor unit absorbs available heat from the surrounding air. Refrigerant carries that energy through the system, while the compressor raises its temperature so a heat exchanger can transfer the energy into water. The system can also reverse its operation to produce chilled water for compatible cooling equipment. According to the National Renewable Energy Laboratory (NREL), air-to-water heat pumps can produce hot or chilled water, with reported water temperatures typically ranging from 40°F to 130°F. Actual limits depend on the equipment.
The parts of an air to water heat pump system
An air-to-water heat pump system uses outdoor air to heat water that circulates through your home’s heating system. Several components work together to transfer heat efficiently, distribute it indoors, and, in some setups, provide domestic hot water.
Outdoor unit: Contains the compressor, refrigerant circuit, and heat exchangers that extract heat from outdoor air.
Buffer tank: Helps stabilize water flow and system operation when required by the system design.
Circulator pumps: Move water between the heat pump, storage tank, and heating or cooling zones.
Heat emitters: Radiant floors, compatible radiators, or fan coils distribute heat or cooling throughout the home.
Optional domestic hot water equipment: Some systems can also heat household water, depending on the equipment and system configuration.
Air-to-water heat pumps are not the only option for homes with hydronic heating. Geothermal heat pumps use heat from the ground instead of outdoor air, but installation requirements and costs differ. Exploring whether geothermal energy is a suitable investment can help you compare renewable heating options alongside your home's electricity needs.
Air to water heat pumps generally perform better when they can deliver the required comfort without producing unnecessarily hot water. Lower heating supply temperatures and higher cooling supply temperatures can improve efficiency. That makes your existing radiators, floor loops, and insulation just as important as the heat pump itself.
Heat emitter | Suitability | What to check |
Radiant floors | Often an excellent match | Floor construction, insulation, and water temperature |
Fan coils | Suitable for heating and cooling | Output, airflow, and dehumidification |
Existing radiators | Depending on the installation | Heat output at the proposed supply temperature |
Good candidates and harder cases
Homes with radiant floors, good insulation, and low heating demand are often well suited to air-to-water heat pumps, while older homes with radiators designed for hotter boiler water may need upgrades. Before choosing a system, ask an installer to calculate heat loss and check radiator output at the planned water temperature. Manufacturer limits vary by model, so compare specifications carefully. Understanding how to convert watts to BTU/hr can also help you distinguish electrical consumption from delivered heating capacity when evaluating system performance.
A common mistake is assuming that keeping the circulator pumps running will keep the home warm during a blackout. Pumps move existing warm water, but they cannot create new heat without a functioning heat source. The outdoor compressor, fan, controls, and defrost operation all need suitable power for the heat pump to continue heating.
Component | Typical supply | What it does during an outage |
Circulator pump | Often 120V | Moves existing warm water |
Controls and thermostats | Depending on the installation | Operates controls and heating zones |
Outdoor heat pump | Often 208–240V | Produces new heat when adequately powered |
Backup electric heater | Often 240V | Provides additional heat but can draw substantial power |
Estimates
Assuming 85% of battery capacity is usable, a 5kWh battery could run two 88W circulation pumps for about 24 hours, while a 10kWh battery could power a 2,744W compressor-and-pump setup for roughly 3.1 hours. Actual runtime varies with compressor cycling, outdoor temperatures, and defrost operation. Before choosing a battery, check its output and startup capacity, as the difference between starting and running watts helps determine whether it can handle the equipment's demands.
Choosing backup power for your system
If you need backup power for an air-to-water heat pump, first decide whether you want to maintain circulation or continue producing heat. This choice determines the required power output, battery capacity, and electrical compatibility. Check your system's voltage and load requirements before selecting a backup solution.
EcoFlow TITAN 5000 Classic
The EcoFlow TITAN 5000 Classic is worth evaluating if your priority is keeping compatible 120V circulation pumps and controls running during an outage. This approach can help maintain water circulation without powering the outdoor compressor. Confirm your equipment's electrical requirements and backup runtime before choosing a setup.
EcoFlow TITAN 5000 Plus
If you want to keep a compatible 240V outdoor heat pump running during an outage, consider evaluating the EcoFlow TITAN 5000 Plus. The system must meet the heat pump's power and startup requirements. Consult a qualified electrician to confirm compatibility and determine the appropriate backup configuration.
Neither model should be assumed to start a specific compressor without checking its electrical requirements. A licensed electrician should assess starting current, continuous demand, defrost operation, backup heating elements, and other household loads, as well as arrange professional installation of the Smart Home Panel 10. When planning your setup, consider how long a home backup battery can last, since runtime depends on battery capacity, power output, and the appliances connected.
An air to water heat pump can also cool a home by reversing its operation and circulating chilled water. That water can supply fan coils or, in suitable installations, radiant floor systems. However, cooling introduces a moisture problem that homeowners must take seriously.
Why the dew point matters
When a cooled surface falls below the surrounding air's dew point, moisture can condense on floors, inside walls, or around pipework. Radiant cooling therefore requires dew point monitoring and careful temperature control. NREL recommends a minimum floor-surface temperature of about 65°F and notes that radiant cooling is best suited to exposed concrete slabs rather than carpeted or wooden floors. In humid climates, radiant cooling alone may not remove enough moisture, so additional dehumidification may be needed.
A quick way to pick a cooling setup
The best cooling arrangement for an air-to-water heat pump depends on your climate, floor construction, and humidity levels. Radiant cooling may suit dry conditions, while fan coils are often more practical in humid environments.
Dry climates: Radiant cooling may work well with exposed slabs and suitable dew point controls.
Humid climates: Fan coils are often more practical because they can cool the air and remove moisture.
Mixed systems: A fan coil may help control humidity before chilled water reaches a radiant surface.
Chilled-water pipes need suitable insulation and vapor-tight sealing to prevent condensation. When comparing cooling options, understanding how many watts an air conditioner uses can help you estimate electrical demand, but an air-to-water heat pump's actual consumption also depends on its compressor, circulation pumps, controls, and cooling load.
Air-to-water heat pumps move water through outdoor equipment or connected pipework, depending on the design. When temperatures fall below freezing, that water can become a liability unless the system has a suitable protection strategy. Some systems use a water-glycol mixture, while others rely on manufacturer-approved controls or different plumbing arrangements. The correct approach depends on the specific equipment and installation.
Protect the outdoor water circuit
Some systems use a water-glycol mixture, while other designs may rely on manufacturer-approved controls or different freeze-protection arrangements. The correct approach depends on the model and installation. For example, the Chiltrix CX35 manual specifies a minimum glycol concentration of 10% and calls for an appropriate concentration based on potential freezing temperatures. This is a model-specific requirement, not a rule for every air to water heat pump.
Questions to ask the installer
Does the system use glycol or another freeze-protection method?
What happens if electricity is unavailable for several hours?
Does freeze protection depend on powered pumps or controls?
Is backup heat installed, and does it use a separate circuit?
What water temperature will the system need on the coldest design day?
When planning battery backup, distinguish the power needed to run equipment from the energy stored for later use. Understanding the difference between kW and kWh helps you compare the heat pump's electrical demand with the battery capacity needed to support it during an outage.
An air to water heat pump can efficiently heat homes with radiant floors, suitable radiators, or fan coils. Before buying, check your home's heating requirements, confirm emitter output at the planned water temperature, and ensure proper cooling and freeze protection. For backup power, calculate the circulator and compressor loads separately. The EcoFlow TITAN 5000 Classic may suit compatible 120V pumps and controls, while the EcoFlow TITAN 5000 Plus may support a matched 240V heat pump after an electrician confirms compatibility.
What is an air to water heat pump?
It transfers heat from outdoor air into water, which then supplies radiant floors, radiators, or fan coils. It uses the same basic heat-transfer principle as an air-to-air heat pump but distributes energy through water.
Can an air to water heat pump cool a house?
Yes. It can supply chilled water to compatible fan coils or radiant systems. Radiant cooling requires dew point controls, and humid homes generally need a separate strategy for removing moisture.
Does an air to water heat pump work with old radiators?
Sometimes. The radiators must provide enough heat at the lower water temperatures the heat pump can efficiently supply. Have an installer assess their output before deciding whether replacements are necessary.
Do air to water heat pumps need antifreeze?
Some systems require glycol or another approved freeze-protection method. Requirements vary by manufacturer, model, and climate, so follow the installation manual rather than assuming one approach fits every system.
Will a battery keep my air to water heat pump heating during an outage?
Only if the backup system can safely power the outdoor compressor and its associated loads. Powering the circulator pumps alone moves stored warm water but does not create new heat.
