Furnace vs Boiler: Warm Air or Hot Water, What Each Costs to Keep, and the Power Both Need in a Blackout
- Is a Furnace a Boiler? How Each One Moves Heat Through the House
- Efficiency, Upkeep, and Fuel Cost: Boiler vs Furnace Side by Side
- Both Stop in a Blackout: The Electric Parts Behind Gas and Oil Heat
- Getting Backup Power to the Furnace or Boiler Without Backfeeding
- Boiler or Furnace: Which One Fits Your House?
- Conclusion
- FAQs
If your home has floor vents and a filter to change, you probably have a furnace. If radiators or baseboards warm your rooms, you may have a boiler. You can often identify your heating system just by looking around your house.
Both systems can keep your home comfortable through a cold winter. But they deliver heat differently, have different maintenance needs, and may cost different amounts to operate. There's another detail worth planning for: both gas and oil heating systems typically need electricity to operate. When the power goes out, your heat can stop, too. Here's how furnaces and boilers compare, what affects their running costs, and how to plan for safe backup power.
No, a furnace is not a boiler. Both are central heating systems. Both usually burn heating oil or natural gas. But they move heat through your home in completely different ways.
The Department of Energy (DOE) explains the difference simply. A furnace heats indoor air and pushes it through sheet-metal ducts. A boiler heats water to supply hot water or steam through sealed pipes.
The furnace path: burner, heat exchanger, blower, ducts
A furnace uses forced air to warm your living space. The heating cycle follows a straightforward mechanical path:
The thermostat calls for heat.
The burner ignites and heats a metal heat exchanger.
A blower pushes indoor air across the heat exchanger.
Warm air travels through supply ducts and enters rooms through vents.
Cooler air returns through return ducts, and the cycle repeats.
Because a furnace moves air through ductwork, it depends on an air filter. Equipment maker Carrier recommends changing that filter every 30 to 90 days. A big perk of ductwork is dual use. Your furnace can share those same ducts with a central air conditioning unit during summer.
The boiler path: hot water or steam through pipes
A boiler uses hydronic heat instead of blowing air. It heats water inside a closed vessel and circulates that thermal energy through plumbing lines:
Hot water boilers: The system sends heated water through pipes to baseboard units, cast-iron radiators, or radiant floor tubing. A circulator pump pushes the water through the loop. Hot water can also run through a hydro-air coil inside an air handler.
Steam boilers: The unit boils water into steam. The steam rises under its own pressure through pipes to radiators, then condenses back into water and drains return-side. The DOE notes that steam systems run hotter and are inherently less efficient than hot water setups. Still, modern high-efficiency options exist for both types.
Most boiler systems do not use ducts or blowers. With baseboards, cast-iron radiators, or radiant floor tubing, heat moves through sealed pipes and warms rooms by radiation and convection, so there is no central fan stirring dust around. Carrier notes this as a comfort advantage of hydronic heat.
Hydro-air systems are the exception. In a hydro-air setup, a hot water boiler sends water to a coil inside an air handler, and a blower pushes air across that coil and through ductwork. Manufacturer documentation, such as First Co.'s HBXBX-HW and MBXR-HW literature, describes configurations that pair a hot water boiler with a fan, a coil, and an outdoor condensing unit for DX cooling. In those homes, the boiler heats and the same air handler and ducts can also deliver cooling.
The boiler itself never provides cooling. Homes with radiators, baseboards, or radiant floors usually need a separate cooling solution, such as ductless mini-splits or window units. Homes with a hydro-air air handler may be able to add a cooling coil and condensing unit instead.
Most furnaces and boilers in American basements burn natural gas, oil, or other fossil fuels, so the fuel line matters as much as the equipment.
Once you know which setup sits in your basement, the next step is simple. You need to know what it takes to maintain it and what it costs to run each winter.
Neither heating system is automatically cheaper to run. Your annual fuel bill depends heavily on the fuel source and your equipment's AFUE rating. Maintenance chores depend on whether your system circulates air or water.
Here is how both systems stack up across performance, maintenance, and hidden thermal losses:
What you're comparing | Furnace (forced air) | Boiler (hot water or steam) |
Efficiency labels | ENERGY STAR gas models are up to 16% (South) or 18% (North) more efficient than baseline models; oil units gain up to 4%. | ENERGY STAR boilers require 90% AFUE or higher for gas, or 87% for oil (standard updated January 2024). |
What a pro checks (DOE) | Inspects for combustion chamber cracks, tests for carbon monoxide, cleans and oils blowers, checks duct seals. | Hot water: tests pressure-relief valves, high-limit controls, expansion tanks. Steam: flushes sediment, tests low-water cutoffs, analyzes boiler water. |
Homeowner task | Swap or clean air filters every 30 to 90 days (Carrier). | Radiators, baseboards, and radiant floors have no air filter; inspect pipes for leaks and check the pressure gauge regularly (Carrier). Hydro-air systems have an air handler, so they use a filter that needs regular changes. |
Cooling integration | Shares existing ductwork with central AC systems (Carrier). | The boiler itself cannot cool. Radiator, baseboard, and radiant systems typically need a standalone setup such as ductless mini-splits. Hydro-air systems can share the air handler and ducts with a cooling coil and condensing unit (manufacturer documentation, e.g. First Co.). |
Losses AFUE doesn't show | Ducts running through unconditioned attics, basements, or crawl spaces can lose up to 35% of heat (DOE). | Piping runs through cold basements lose heat; the DOE notes AFUE ratings leave out distribution pipe losses. |
Fuel cost: same fuel, different efficiency (example)
Fuel prices drive heating expenses far more than equipment type. Let us look at a real-world calculation using national benchmarks.
The U.S. Energy Information Administration (EIA) listed the Q1 2026 residential natural gas price at $14.77 per thousand cubic feet (Mcf) in the "Residential Sector" row of Table 2 in its October 2026 Short-Term Energy Outlook. The EIA rates one cubic foot of natural gas at roughly 1,036 Btu. That means 1 Mcf contains approximately 1.036 million Btu.
To find the raw fuel cost per million Btu:
$14.77 ÷ 1.036 = $14.26
Now consider how equipment efficiency changes what you pay for actual warmth delivered into your living space:
Delivered by a 95% AFUE gas furnace:
$14.26 ÷ 0.95 = about $15.01
Delivered by a 90% AFUE gas boiler (ENERGY STAR baseline):
$14.26 ÷ 0.90 = about $15.84
This national average example shows that a five-point jump in AFUE changes the fuel cost by about 83 cents per million Btu, or roughly 5.5%. Distribution losses can matter as much or more. The DOE notes that ducts running through unconditioned spaces can lose up to 35% of heat, and that AFUE ratings leave out distribution losses entirely, including pipe losses in boiler systems. Sealing and insulating ducts or pipes is worth considering alongside equipment efficiency.
Fuel price per Btu gives you one angle on heating costs. Comparing gas furnace and solar heating costs shows how much your raw energy source shapes your winter utility bills.
On paper, both heating units run on fossil fuel. But when severe winter weather knocks out the grid, you quickly discover that both depend on electric power to run.
A gas furnace cannot blow warm air without its electric blower motor. A hot water boiler cannot push heat without its electric circulator pump.
Electronic igniters, draft inducer fans, safety sensors, and zone valves all demand grid electricity. When a winter storm knocks out your power lines, your heating stops. That happens even if your gas line has pressure or your oil tank sits full.
What the equipment nameplate tells you
You cannot guess your backup power needs. You have to read the electrical specifications stamped directly onto your unit's data plate:
Equipment (named example) | Voltage | Electrical rating from the maker | What it means for backup |
Carrier 59TP6C gas furnace | 115V single-phase | Max unit amps 7 to 13.2A by size; 080V17-16 lists 10A; max fuse or breaker 15 or 20A | About 1,150W at 115V at the maximum (10A × 115V) |
Navien NHB-H gas boiler | 120V | "Less than 15 amperes" maximum | Treat 15A as a ceiling for dedicated circuit sizing, not regular running load. |
Taco 007-F5 circulator | 115V | 1/25 HP motor, draws 0.71A running current. | Consumes around 82 VA per pump; multizone houses often run several simultaneously. |
Taco 007 with 230/60/1 motor option | 230V | Option listed; amps not given | A 240V pump needs a split-phase source |
Beckett AFG 240V oil burner (on oil-fired boilers or furnaces) | 208 to 240V | Motor draws 5 full-load amps (FLA) and 30 locked-rotor amps (LRA). | Demands a 240V circuit and must handle a momentary 30A starting surge. |
Labeled runtime estimates for backup power
Battery runtime depends on usable capacity, electrical demand, conversion losses, and how often the equipment operates.
A simple estimate is:
Runtime in hours = Battery capacity in Wh × usable efficiency ÷ electrical load in W
Let us test a Carrier 59TP6C (model 080V17-16) pulling its maximum 1,150W electrical draw on a 5,000Wh (5kWh) battery:
5,000 × 0.85 ÷ 1,150 = approximately 3.7 hours.
Furnaces cycle on and off rather than running non-stop. Because of this, real-world runtime between recharges will be significantly longer. Adding a second 5kWh battery module roughly doubles that operating window.
For a hot water boiler, check your rating plates. Add the boiler's control wattage to the combined wattage of every circulator pump running at once. Apply the same formula to get your runtime.
Remember, a battery station only powers the electrical pumps, fans, and circuit boards. The actual heat energy comes from burning gas or heating oil. Your fuel line must be open, and your heating unit must be in good working order.
Winter power outages can drag on for days during freezing Nor'easters or blizzards. When temperatures plunge below freezing, protecting your plumbing and keeping your heating controls running becomes urgent. Modern home storage systems let you back up these critical heating circuits cleanly indoors without engine noise or exhaust fumes.
Which backup setup fits your home depends on your equipment's rating plate: whether your heating circuits run on 120V or 240V.
The EcoFlow TITAN 5000 Classic delivers reliable 120V power for essential circuits. It keeps your furnace blower, boiler circulator pump, and electronic controls running smoothly through sudden, freezing winter blackouts.
The EcoFlow TITAN 5000 delivers dual-voltage 120V/240V power for heavy-duty setups. It easily handles high-draw auxiliary circuits, split-phase burners, well pumps, and full-home loads without skipping a beat during severe storms.
The EcoFlow TITAN 5000 Classic matches standard 120V equipment. It handles gas furnace blowers, standard boiler circulator pumps, and zone controllers, provided the running and inrush loads fit within its 4,000W rating.
The EcoFlow TITAN 5000 serves homes with 240V heating auxiliaries. This includes homes with 230V commercial-grade circulator pumps, 240V oil burners, or central air handlers tied to heat pumps.
Keep these practical limits in mind:
Neither battery unit generates raw heating BTUs. That heat comes from your gas or heating oil supply.
High-capacity whole-house electric resistance furnaces and electric boilers often exceed the output or runtime of a home battery. Smaller electric boilers may fall within the rated output of the EcoFlow TITAN 5000 (7.2kW, 240V), but only after checking the nameplate rating, the building's heat load, everything that runs at the same time (pumps and controls included), and the battery runtime. The 120V EcoFlow TITAN 5000 Classic is not suited to 240V electric boilers.
Have a licensed electrician verify starting currents, equipment voltages, and simultaneous electrical loads.
Hardwired appliances must connect through the matching Smart Home Panel 10 installed by a licensed electrician. Never use dangerous backfeed cords.
A Carrier 59TP6C furnace requires a 15-amp or 20-amp breaker depending on its cabinet size. Learning how 15-amp and 20-amp circuits differ will help you read your main electrical panel accurately.
Once you know your electrical loads, you must focus on connecting everything safely. Improper connections during a storm can create severe life-safety hazards.
Some homeowners attempt an illegal shortcut during a blackout. They build a double-male extension cord and plug a portable generator straight into a standard wall outlet.
Mississippi State University Extension warns that this practice, known as backfeeding, sends high-voltage electricity backward through your home panel and out into neighborhood utility lines. It can electrocute utility line crews working down the street. It can also fatally injure neighbors connected to the same shared utility transformer.
Follow these strict safety rules to keep your household and utility workers safe:
Install a transfer switch: MSU Extension states you must never plug a generator directly into a wall receptacle. If you connect backup power into home wiring, have a licensed electrician install a code-compliant transfer switch.
Keep engine exhaust outside: The Centers for Disease Control and Prevention (CDC) warns that fuel-burning generators must run strictly outdoors. Keep them more than 20 feet away from all windows, doors, and fresh-air vents.
Maintain working carbon monoxide alarms: The CDC recommends installing battery-operated or battery-backed CO detectors near every sleeping area. Test them monthly and schedule professional maintenance for your heating equipment every fall.
Watch for gas leaks: The DOE advises that if you smell rotten eggs or suspect a natural gas leak, leave immediately. Contact your utility provider or emergency heating contractor from a safe distance. If you see downed power lines or face immediate danger, call 911 right away.
Use dedicated panel integration: For an EcoFlow TITAN setup, a licensed electrician connects your critical heating circuits directly into a Smart Home Panel 10. Do not plan on plugging your furnace into a portable battery outlet with an extension cord. Most modern boilers and furnaces are hardwired into dedicated home junction boxes.
Maintain vent clearances: Battery storage systems do not emit carbon monoxide or toxic exhaust fumes. However, your gas furnace or oil boiler still burns fuel during an outage. Ensure outdoor flue pipes and intake vents remain clear of heavy snow drifts and ice buildup.
If an engine-driven generator is part of your storm plan, you need to prepare early. Learn why your home needs a transfer switch before winter storm season knocks out your neighborhood grid.
Once you have a plan for safe winter operation, you can evaluate which heating system fits your house best.
For most homeowners replacing an existing heating system, the infrastructure already in place is a major factor. Switching from a furnace to a boiler may require new piping and heat emitters. Moving from a boiler to a furnace may require extensive ductwork.
Use this decision matrix to evaluate your home's setup:
If your house has or needs... | Usually points to | Why |
Existing ducts and central AC | Furnace | Uses existing ductwork and pairs directly with central air conditioning systems (Carrier). |
Radiators or baseboards in place | Boiler | Connects to existing hydronic piping without the high cost of cutting ducts into walls (Carrier). |
In-floor radiant warmth | Boiler | Boilers easily deliver steady hot water through subfloor PEX tubing networks (DOE). |
Less air movement and dust | Boiler | Radiator, baseboard, and radiant-floor systems deliver heat without a central blower stirring up dust or pet dander (Carrier). Hydro-air systems use a blower and ducts. |
Quick warm-up after a setback | Furnace | Furnaces blow hot air immediately; boilers take longer to heat metal pipes and water volume (Carrier). |
Heat pumps offer another option. An electric heat pump can pair with forced-air ductwork or supply hydronic heating coils.
Homes with radiator, baseboard, or radiant floor heating often lack ductwork for summer cooling. A ductless mini-split, or a portable air conditioner that heats and cools, can condition individual rooms without installing ducts. If your boiler feeds a hydro-air air handler, ask an HVAC contractor whether a cooling coil and condensing unit can use the existing ducts.
A furnace heats air and distributes it through ducts, while a boiler heats water or steam for radiators, baseboards, or floors. Fuel prices and AFUE ratings influence running costs more than the system type alone. Before an outage, check your equipment's voltage and amperage, identify every pump or blower that may run simultaneously, and consult a licensed electrician about safe backup connections. For compatible 120V heating equipment, compare the EcoFlow TITAN 5000 Classic. For verified 240V heating circuits, consider the EcoFlow TITAN 5000, subject to load and compatibility checks.
Is a furnace a boiler?
No. A furnace heats air and distributes it through ducts. A boiler heats water or produces steam and sends it through pipes to radiators, baseboards, or radiant heating systems.
Which is more efficient, a boiler or a furnace?
Neither system is automatically more efficient. Both are sold in high-efficiency configurations. Modern ENERGY STAR gas boilers start at 90% AFUE, while high-efficiency gas furnaces reach between 90% and 98.5% AFUE (DOE).
Does a gas boiler work without electricity?
Most do not. Modern gas boilers rely on electronic igniters, safety limit switches, zone valves, and electric circulator pumps to push hot water through the house. When the electric grid shuts down, the boiler turns off.
Is a boiler better for allergies?
Boiler systems with radiators, baseboards, or radiant floors do not use a central blower to circulate heated air through ductwork, so they may reduce the amount of dust moved by the heating system. Hydro-air systems use a blower and ducts, so that distinction does not apply to them. Indoor allergens can still enter from other sources. Furnace filtration and overall indoor air quality also matter.
Can a home battery run an electric boiler?
It depends. Large whole-house electric boilers often exceed a home battery’s output or runtime, but smaller 240V units rated 3kW or 6kW may fit the EcoFlow TITAN 5000's 7.2kW output. Check nameplate, heat load, simultaneous loads, and runtime; a licensed electrician should verify the wiring.
