Air Source Heat Pump Basics: How It Heats and Cools, Which Type Fits, and What the Ratings Mean
- How an Air Source Heat Pump Moves Heat Instead of Making It
- Ducted, Ductless, or Packaged: Matching the Air Source Heat Pump System to Your House
- An Optional Backup Plan: Outage Heating and Solar Recharge for Homes That Need It
- Reading SEER2, HSPF2, and COP on an Air Source Heat Pump Label
- Is an Air Source Heat Pump a Good Fit for Your Climate and Budget?
- Conclusion
- FAQs
A homeowner is staring at an aging furnace and an aging AC unit. Both need replacing, and a contractor suggests one air source heat pump could handle both jobs. The system moves heat instead of burning fuel, so it can warm a house in winter and cool it in summer. This article covers how the system works, the three common types, how to read SEER2 and HSPF2 without a spreadsheet, and where it fits by climate. It also offers an optional backup plan for homes that need heat during outages or want solar recharging.
A furnace burns fuel or heats a coil to make warmth. An air source heat pump works differently. It pulls heat out of outdoor air in winter and pushes indoor heat outside in summer.
The process starts with refrigerant, a fluid that boils at low temperatures. In heating mode, the outdoor coil uses it to collect warmth from outside. The DOE explains that the refrigerant "removes heat from the air and evaporates into a gas." Even cold air is a usable air heat source, because it still holds some heat. The gas then travels indoors and releases that heat as it condenses back into a liquid.
A reversing valve flips the flow for cooling. It also flips it briefly to defrost the outdoor coil in winter. Because the system moves heat rather than making it, the DOE says a properly installed unit can deliver up to three times more heat energy than the electricity it consumes. ENERGY STAR adds that without combustion, the unit itself has no direct emissions such as NOx, carbon dioxide, or carbon monoxide. That is why one setup can offer air source heating and cooling from a single outdoor unit.
Parts you'll see on an air source heat pump HVAC system
A typical setup includes four pieces:
Outdoor unit: It holds the compressor and the outdoor coil that trade heat with the air.
Indoor coil or head: This may be an air handler, a wall unit, or a ceiling cassette, depending on the layout.
Refrigerant lines. In split systems, these link the indoor and outdoor parts. Packaged systems skip them by keeping everything in one outdoor cabinet.
Thermostat and backup heat: The thermostat sets the temperature. Many ducted homes also have electric backup heat in the air handler.
Capacity is sold in tons and Btu per hour. One ton equals 12,000 Btu per hour, so a 2-ton unit is rated near 24,000.
The same heat-moving idea comes in a few shapes, and the shape matters as much as the brand.
The right type depends on whether a home already has ducts. It also depends on how many rooms need separate control. The DOE groups residential air-source heat pumps into a few main layouts.
Type | How it delivers heating and cooling | Often a fit for | Source |
Ducted split | Uses existing or new ductwork with one indoor coil and one outdoor coil | Homes with working ducts, or new construction | DOE Energy Saver; ENERGY STAR |
Ductless mini-split (single or multi-zone) | Indoor heads connect to an outdoor unit through "a three-inch hole through the wall"; multi-zone links "two or more indoor coils" to one outdoor unit | Additions, homes without ducts, room-by-room control | DOE Energy Saver |
Short-run ducted | Short duct runs in one part of the house, often paired with ductless heads elsewhere | Partial-house projects | DOE Energy Saver |
Packaged | Both coils and the fan sit outdoors; air reaches the house through a wall or roof | Homes with limited indoor space | DOE Energy Saver |
A few DOE points help when comparing quotes:
Most are split systems: The DOE notes that "Most heat pumps are split-systems," so the indoor and outdoor parts sit apart.
Airflow matters: Ducted units need about 400 to 500 cubic feet per minute (cfm) per ton of cooling. Weak airflow cuts performance.
Refrigerant charge must be right: It is often set in the field, so a careful technician is part of the equipment's performance.
Defrost controls: Demand-defrost controls start defrost when the coil needs it rather than on a fixed timer.
Wind protection: Strong winds can disturb airflow across the outdoor unit, so a sheltered spot or windbreak helps.
Ductless setups are priced per zone, and mini-split system cost rises with each indoor head added.
Some households also need the heat pump to keep running when the grid does not. That calls for a separate, optional plan.
Most homeowners will not need this section. It is for homes where losing heat in an outage is a real problem, or where solar recharging during a long outage matters. For an air heat pump system, backup power is a separate question from efficiency, since a battery does not change COP, SEER2, or HSPF2. Depending on the configuration, it can provide backup power during outages or daily energy storage, such as solar self-consumption and managing peak and off-peak electricity prices.
Start with the heat pump's nameplate
The Mitsubishi Electric MSZ-GS12NA / MUZ-GS12NA ductless system (maker submittal, form 202406) makes a useful worked example.
Rating point | Capacity | Power input | What it tells |
Cooling at 95°F (rated) | 12,000 Btu/h | 920W | Summer running load |
Heating at 47°F (rated) | 14,400 Btu/h | 1,100W | Mild-weather heating load |
Heating at 5°F (maximum) | 9,540 Btu/h | 1,540W | Cold-day load, before defrost |
Electrical | 208/230V, 1 phase | MCA 10.0A; MOCP 15A | A 240V circuit; the indoor unit is powered from the outdoor unit |
Here are labeled estimates for one 5kWh battery, counting 85% of stored energy as usable:
Heating at 47°F: 5,000 × 0.85 ÷ 1,100 gives about 3.9 hours of compressor running time.
Heating at 5°F maximum: 5,000 × 0.85 ÷ 1,540 gives about 2.8 hours.
Cooling at 95°F: 5,000 × 0.85 ÷ 920 gives about 4.6 hours.
Two batteries at the 5°F figure: 10,000 × 0.85 ÷ 1,540 gives about 5.5 hours.
These are estimates. The unit cycles on and off, so clock time varies, and defrost adds load.
Larger ducted systems with electric heat strips can draw several times more. An electrician must check starting current, any auxiliary heat, and other loads on the backed-up circuits against the 7,200W output. No TITAN surge rating is published. Some smaller mini-splits are built for 120V, and the same nameplate check applies.
What solar can and can't do in winter
Grid-tied panels shut down in outages: Rooftop solar that feeds the grid stops during an outage. Outage recharging needs panels wired to the TITAN's own solar input.
Winter production can fall: Short days, low sun angle, and snow cover can cut output sharply. No battery can promise that solar will cover a full winter day of heating. NREL's PVWatts calculator gives a site-specific estimate.
Both batteries below share the same 7,200W battery output, so the real difference is how much solar each can take in. The first suits homes with a single array.
Homes with larger arrays face a different question: how much solar can flow in at once. That is where a second solar input comes in.
The EcoFlow TITAN 5000 fits homes with a 120V or 240V heat pump whose power draw it can handle, and up to 4kW of direct solar input. The EcoFlow TITAN 5000 Plus fits homes with the same kind of heating load that truly need two solar inputs, for more than 4kW and up to 8kW of direct solar.
Each battery has the same 7,200W rated output on its own. Choosing the Plus does not by itself mean it can run a larger heat pump. Starting current, auxiliary heat, and port limits need a check first. Home circuits need the Smart Home Panel 10 (240V version) and a licensed electrician. The battery does not change the heat pump's COP or SEER2, and on cloudy or snowy days solar may not refill what the house used that day.
Winter output drops when snow covers solar panels, which is one reason to plan battery capacity without counting on a full recharge.
Back to choosing the heat pump itself: spec sheets and yellow labels are full of ratings that look alike.
Every spec sheet for a heat pump air source model throws three or four efficiency numbers at readers. They measure different things. Knowing which one matters locally saves a lot of second-guessing.
SEER2: This is seasonal cooling efficiency. EER2 is peak cooling efficiency at 95°F. HSPF2 is seasonal heating efficiency. NY Clean Heat uses these definitions in its explainer on DOE Appendix M1.
Why the "2" numbers look lower: Units made on or after January 1, 2023 are rated under DOE Appendix M1. NY Clean Heat notes that the M1 ratings are typically lower because of the testing procedure itself. The machines are not less efficient.
COP: This is heat delivered divided by electricity used at one set of conditions. The DOE's "up to three times more heat energy" line is the plain-English version of a COP near 3.
Which number to weigh: The DOE says SEER matters more in warmer climates. In colder climates, it advises focusing on the highest HSPF feasible.
The worked example: The MSZ-GS12NA / MUZ-GS12NA lists SEER2 25.6 and HSPF2 10.7.
For current federal criteria, ENERGY STAR keeps the up-to-date list. Ratings feel more concrete next to real usage, and household kWh per day vary with climate, home size, and heating fuel.
With the ratings sorted, the last question is whether an air source heating system makes sense for the climate and the budget.
Air source heat pumps are not just for mild climates anymore. Fit still depends on how cold winters get, how tight the house is, and what the system replaces. Costs vary too much by region to print one number.
Climate
Long track record: The DOE says air-source units have long served most of the US, except where temperatures stay below freezing for long stretches. Newer technology makes them a real option for space heating in colder regions.
Know the unit's limit: The MUZ-GS12NA heating range goes down to -4°F outdoor dry bulb. Colder places should look at cold-climate models.
Cold-climate certification: ENERGY STAR tests certified units down to 5°F.
Budget and incentives
Federal credit: The IRS says the Energy Efficient Home Improvement Credit (25C), which covered up to $2,000 a year for qualified heat pumps, applies to improvements made through December 31, 2025. It does not apply to heat pumps placed in service in 2026.
State and utility rebates: Homeowners should check their state energy office and their electric utility's current program pages. Amounts change often.
Running cost: ENERGY STAR says switching from electric resistance, propane, or oil can lower energy bills. Results depend on local rates and climate.
A heat pump works best in a house that holds its heat. An air heating pump sized for a leaky house runs longer and costs more to operate. Air sealing and insulation reduce the size of unit needed.
An air source heat pump moves heat rather than making it, so one system handles heating and cooling. Ducted, ductless, and packaged types fit different homes. SEER2 and HSPF2 matter in different climates.
The practical steps are short. Match the type to the ducts, weigh HSPF2 more if winters are cold, and confirm current incentives before signing.
If outage heating or solar recharge matters, an electrician can say whether the EcoFlow TITAN 5000 or the EcoFlow TITAN 5000 Plus suits the heat pump circuit.
How does an air source heat pump work?
It uses refrigerant to pull heat from outdoor air and release it indoors, then reverses the flow to cool the home in summer. The U.S. Department of Energy says it can deliver up to three times more heat energy than the electricity it consumes.
Is an air source heat pump the same as a mini-split?
A mini-split is one type of air source heat pump. It skips the ductwork and uses wall, floor, or ceiling indoor heads linked to an outdoor unit by refrigerant lines. Some systems connect several heads to one outdoor unit.
Do air source heat pumps work in cold weather?
Many do, and DOE says newer technology makes them a real option in colder regions. Check the model's lowest operating temperature and its heating capacity at 5°F before buying, since output drops as the outdoor air gets colder.
Can I still get the federal tax credit for a heat pump?
Not for new installs in 2026. The IRS says the 25C credit covers improvements made through December 31, 2025. Homeowners should still check state energy offices and utility programs for rebates that may apply. Amounts vary by location.
Will a home battery make my heat pump more efficient?
No. A battery supplies power during an outage or stores solar energy, but the heat pump's COP, SEER2, and HSPF2 stay the same. Efficiency depends on the heat pump itself, its sizing, its installation, and the local climate.
